简介
使用本指南如果屏幕出现以下状况:
iPhone 6s Plus 前面板更换|前置摄像头和感应器
iPhone 6s Plus 前面板更换|显示EMI屏蔽罩
你需要做的是从旧屏幕上取下 Home 键并将Home键安装在新屏幕上。
如果你更换的屏幕不包含这些部件请使用以下指南:
iPhone 6s Plus 前面板更换|here
不管什么情况,把原装的Home键取下并安装在新屏幕上才可以使用Touch ID(指纹识别)。
你也可以使用该指南:显示屏电线支架
你所需要的
视频概述
如果您的手机显示屏已经碎裂,请避免屏幕进一步的破碎,并且当您用胶带粘贴屏幕玻璃以维修手机时,请避免身体部位受伤。
使用透明胶带交替重叠粘贴,完整地覆盖住手机的屏幕。
如果屏幕玻璃的碎裂导致接下来的步骤中的吸盘难以吸在屏幕上,请尝试使用黏度较高的胶带(如粘水管用的胶带)折叠成一个把手,来提起屏幕。
请倒序重组你的设备。
请倒序重组你的设备。
582等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
73条评论
What do you do about the 3D touch?
The 3D Touch sensor should be integrated into the replacement part that you buy. If you check out our display teardown you can see that it's embedded two layers deep in the display assembly, so there are no discrete parts you need to worry about.
And if you replace the home button with a new one the finger sensor usually don't work again
This is because the home button that originally comes with the phone is "married" is married to the phone. This connection can never be returned if home button is broken or replaced. That in turn makes touch id not work because its not coded to the phone. Apple can not remarry phones in case anybody was wondering. Take good care of your home button
