跳转到主内容
iPhone 6s Camera Ring Replacement
你所需要的
  1. iPhone 6s Camera Ring Replacement, Pentalobe Screws: 步骤 1 中的图像 1,1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, on either side of the Lightning connector.
  2. iPhone 6s Camera Ring Replacement, Opening Procedure: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    Anti-Clamp
    $24.95
    购买
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  3. iPhone 6s Camera Ring Replacement: 步骤 3 中的图像 1,1
    • Opening the display on the 6s separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • Take care not to place the suction cup over the home button.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. iPhone 6s Camera Ring Replacement: 步骤 4 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 4 中的图像 2,2
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
    • If you have any trouble, heat the front of the iPhone using an iOpener, hair dryer, or heat gun until it's slightly too hot to touch. This will help soften the adhesive securing the edges of the display.
  5. iPhone 6s Camera Ring Replacement: 步骤 5 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 5 中的图像 2,2
    • There is a notch on the underside of the display, just above the headphone jack. This is the safest place to begin prying the phone open.
    • Place the flat edge of a spudger into the gap between the screen and rear case, directly above the headphone jack.
  6. iPhone 6s Camera Ring Replacement: 步骤 6 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 6 中的图像 2,2
    • Twist the spudger to widen the gap between the front panel assembly and the rest of the phone.
  7. iPhone 6s Camera Ring Replacement: 步骤 7 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 7 中的图像 2,2
    • Insert the flat end of the spudger on the left side of the phone, between the display assembly and rear case.
    • Slide the spudger up the side of the phone to separate the adhesive and pop the clips free.
  8. iPhone 6s Camera Ring Replacement: 步骤 8 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 8 中的图像 2,2
    • Remove the spudger and reinsert it on the bottom edge, where you pried the phone open.
    • Slide the spudger to the right, along the bottom edge of the phone.
  9. iPhone 6s Camera Ring Replacement: 步骤 9 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 9 中的图像 2,2
    • Slide the spudger up the right side to continue separating the adhesive and popping the display clips free from the iPhone.
  10. iPhone 6s Camera Ring Replacement: 步骤 10 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 10 中的图像 2,2
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90º, as it is still connected at the top by three cables that may break if stretched.
  11. iPhone 6s Camera Ring Replacement: 步骤 11 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 11 中的图像 2,2
    • Pull up on the nub on the top side of the suction cup to remove it from the front panel.
  12. iPhone 6s Camera Ring Replacement: 步骤 12 中的图像 1,3 iPhone 6s Camera Ring Replacement: 步骤 12 中的图像 2,3 iPhone 6s Camera Ring Replacement: 步骤 12 中的图像 3,3
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  13. iPhone 6s Camera Ring Replacement, Battery Connector: 步骤 13 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Remove two Phillips screws securing the battery connector bracket, of the following lengths:
    • One 2.9 mm screw
    • One 2.2 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  14. iPhone 6s Camera Ring Replacement: 步骤 14 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 14 中的图像 2,2
    • Remove the battery connector bracket from the iPhone.
  15. iPhone 6s Camera Ring Replacement: 步骤 15 中的图像 1,3 iPhone 6s Camera Ring Replacement: 步骤 15 中的图像 2,3 iPhone 6s Camera Ring Replacement: 步骤 15 中的图像 3,3
    • Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
  16. iPhone 6s Camera Ring Replacement: 步骤 16 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 16 中的图像 2,2
    • Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
  17. iPhone 6s Camera Ring Replacement, Unfasten the display cable bracket: 步骤 17 中的图像 1,1
    • Remove the following four Phillips screws securing the display cable bracket:
    • Three 1.2 mm screws
    • One 2.8 mm screw
  18. iPhone 6s Camera Ring Replacement: 步骤 18 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 18 中的图像 2,2
    • Remove the display cable bracket.
  19. iPhone 6s Camera Ring Replacement: 步骤 19 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 19 中的图像 2,2
    • Use a spudger or a clean fingernail to disconnect the front camera flex cable by prying it straight up from its socket on the logic board.
  20. iPhone 6s Camera Ring Replacement: 步骤 20 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 20 中的图像 2,2
    • Disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  21. iPhone 6s Camera Ring Replacement: 步骤 21 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 21 中的图像 2,2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the display cable by prying it straight up from its socket on the logic board.
  22. iPhone 6s Camera Ring Replacement: 步骤 22 中的图像 1,1
  23. iPhone 6s Camera Ring Replacement, Rear Camera: 步骤 23 中的图像 1,2 iPhone 6s Camera Ring Replacement, Rear Camera: 步骤 23 中的图像 2,2
    • Use the flat end of a spudger to disconnect the rear camera from its socket on the logic board.
  24. iPhone 6s Camera Ring Replacement: 步骤 24 中的图像 1,1
    • Remove the following two Phillips screws over the rear camera bracket:
    • One 1.6 mm screw
    • One 2.0 mm screw
  25. iPhone 6s Camera Ring Replacement: 步骤 25 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 25 中的图像 2,2
    • Remove the camera bracket.
  26. iPhone 6s Camera Ring Replacement: 步骤 26 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 26 中的图像 2,2
    • Insert a spudger to the side of the camera, between the rear case and the camera module.
    • Gently pry up on the camera to nudge it out from its housing.
  27. iPhone 6s Camera Ring Replacement: 步骤 27 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 27 中的图像 2,2
    • Remove the camera.
  28. iPhone 6s Camera Ring Replacement, Removing the glass: 步骤 28 中的图像 1,2 iPhone 6s Camera Ring Replacement, Removing the glass: 步骤 28 中的图像 2,2
    • Remove the glass by pushing out from the inside of the frame
  29. iPhone 6s Camera Ring Replacement, Removing the ring: 步骤 29 中的图像 1,1
    • Butt the lens rim up against a raised surface with the rest of the phone on the surface and the ring over air.
  30. iPhone 6s Camera Ring Replacement: 步骤 30 中的图像 1,2 iPhone 6s Camera Ring Replacement: 步骤 30 中的图像 2,2
    • Use a driver without a bit to fit on the ring from the inside. It shouldn't rest on the frame around the ring at all. Gently tap down on the ring until it pops out while firmly holding the frame down.
  31. iPhone 6s Camera Ring Replacement: 步骤 31 中的图像 1,1
    • Once ring is out of the frame, there should be no bending at all on the frame.
  32. iPhone 6s Camera Ring Replacement: 步骤 32 中的图像 1,1
    • Insert new ring with tiny dots of super glue. Don't use too much glue and get it on the frame.
结论
43等其他人完成本指南。
jeremyfitz
于02/12/14注册
1,862 声望
撰写一个指南
5条评论
sometimes it becomes a pain to remove old ring, some devices has rolled ring so it much harder to remove carefully
Max Nikiforov - 回复
I bent the frame and distorted the back panel where it started to come out trying to “pop-out” the lens ring. The lens ring was attached to an inner piece that holds the camera by a metal piece, this wasn’t described in these instructions.
Be careful of this!
John J - 回复
You’re right! I used a previous guide that shows up until the camera is removed, then my own starts after I’ve already removed this flexible metal bracket. This bracket is used as a alignment guide and stabilizer for the camera so hard hits don’t rattle the sensitive internal magnets that stabilize the camera lenses. With a fine screwdriver, pop the 4 points that this is welded to the lens up then remove the bracket. It may get mangled a bit but it can usually be straightened back out to re-use upon camera reinstall.
jeremyfitz -
The only way to get the ring out for me without damage or strain other components ,board or case was to take a 7.5mm drill and drill out the ring from the back and when the inner bracket came lose you know you are deep enough .
A little dot of CA applied with a toothpick to glue the lens inplace and a little glue on the inside to fix that bracket.
Tip: if just the lens glass piece is broken and there is no damage to the ring try to source and buy the glass lens without the ring alot easier to
repair ,you don’t have to take the screen and camera if no glass made it to the camera.
Just make sure that the ring and the rim where the glass is seated is clean and free of glass splinters and glue .
Again add a little CA with a toothpick pop in the lens and done.
Few minutes of work and no risk of breaking somthing in the proces.
Jacksat - 回复
first iPhone repair for me… I was trembling when I switched it back on. I was worried I didn’t put the screen and front camera connectors in place properly (it’s hard). But it went all well! Thanks for the guide, but I think it’d be really good to add the steps about the square metal thingy between the camera and the ring.
Nicolas Riffard - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 61
过去 30 天: 180
总计 28,493
