跳转到主内容
iPhone 6s Battery Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. iPhone 6s Battery Replacement, Battery Connection: 步骤 1 中的图像 1,1
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws surrounding the Lightning connector.
  2. iPhone 6s Battery Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    iSclack
    $24.99
    购买
    • If you don't have an iSclack, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
  3. iPhone 6s Battery Replacement: 步骤 3 中的图像 1,3 iPhone 6s Battery Replacement: 步骤 3 中的图像 2,3 iPhone 6s Battery Replacement: 步骤 3 中的图像 3,3
    • There is a notch on the underside of the display just above the headphone jack that is the safest place to begin prying the phone open.
    • Pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Once a small gap has been opened, insert the flat end of a spudger above the headphone jack.
  4. iPhone 6s Battery Replacement: 步骤 4 中的图像 1,2 iPhone 6s Battery Replacement: 步骤 4 中的图像 2,2
    • Twist the spudger to open the gap more and break it free from the adhesive.
    • Keep pulling up on the suction cup while twisting the spudger.
  5. iPhone 6s Battery Replacement: 步骤 5 中的图像 1,2 iPhone 6s Battery Replacement: 步骤 5 中的图像 2,2
    • Use the edge of a spudger to slice through the adhesive on either side of the phone.
  6. iPhone 6s Battery Replacement: 步骤 6 中的图像 1,2 iPhone 6s Battery Replacement: 步骤 6 中的图像 2,2
  7. iPhone 6s Battery Replacement: 步骤 7 中的图像 1,3 iPhone 6s Battery Replacement: 步骤 7 中的图像 2,3 iPhone 6s Battery Replacement: 步骤 7 中的图像 3,3
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90 degrees, as it is still connected at the top by three cables that may break if stretched.
  8. iPhone 6s Battery Replacement: 步骤 8 中的图像 1,1
    • Lean the display against something to keep it propped up while you're working on the phone.
    THESE INSTRUCTION / GUIDE IS NOT COMPLETE. I broke my phone and ended up with $250 in repairs at the local cell phone store at this step. You need to detach the display completely instead of prop it up against a box. It is very likely your cables will tear at this step if you don’t completely detach the display
    Christopher Kuhar - 回复
  9. iPhone 6s Battery Replacement: 步骤 9 中的图像 1,1
    • Remove the following screws from the battery connector bracket:
    • One 3.0 mm Phillips #00 screw
    • One 2.3 mm Phillips #00 screw
  10. iPhone 6s Battery Replacement: 步骤 10 中的图像 1,1
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6s Battery Replacement: 步骤 11 中的图像 1,3 iPhone 6s Battery Replacement: 步骤 11 中的图像 2,3 iPhone 6s Battery Replacement: 步骤 11 中的图像 3,3
    • Use the flat end of a spudger to disconnect the battery connector from the logic board.
    • Push the connector to the side to ensure it doesn't accidentally make contact and power on the phone while you're working on it.
  12. iPhone 6s Battery Replacement, Battery: 步骤 12 中的图像 1,3 iPhone 6s Battery Replacement, Battery: 步骤 12 中的图像 2,3 iPhone 6s Battery Replacement, Battery: 步骤 12 中的图像 3,3
    • Use tweezers to peel up the edges of the two adhesive strips at the bottom of the battery.
  13. iPhone 6s Battery Replacement: 步骤 13 中的图像 1,1
    • Grab the ends of the two adhesive strips and hold them together. Try to keep the strips flat and wide.
  14. iPhone 6s Battery Replacement: 步骤 14 中的图像 1,3 iPhone 6s Battery Replacement: 步骤 14 中的图像 2,3 iPhone 6s Battery Replacement: 步骤 14 中的图像 3,3
    • Slowly and gently pull the two strips up and away from the phone.
    • The strips will stretch to many times the length of the battery—keep pulling until they come out from between the battery and the rear case.
  15. iPhone 6s Battery Replacement: 步骤 15 中的图像 1,1
    • Remove the battery from the rear case.
    • When installing the battery, refer to this guide to replace your battery's adhesive strips.
    when I remove battery can I again uset
    Mohammed Alhussain - 回复
结论
75等其他人完成本指南。
Sam Goldheart
于10/18/12注册
465,602 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,718篇指南
11条评论
Quickkkkkkkkkkk Question. How do I go about replacing that adhesive you had me slice?
Doc Brown - 回复
I need to buy the 6s replacement battery itself as well as the tools. Do you sell that as well as the display?
2ndwindranch - 回复
i remember i get my battery repair kit and adhesive for less than 25$ from this seller on amazon https://www.amazon.com/dp/B01LKN9AUG
exdany9 -
Please do a video. Lets see how fast you guys can change the 6s battery.
klactwiggy - 回复
nice very repair mizan.....
mohsen m - 回复
Phone fell in water
matouq - 回复
Do the 6 and 6 s have the same battery???
Cashmand - 回复
If your phone is under the 'necessary recall] battery replacement be aware that Apple will give you quite a run around requiring at least two perhaps three trips to the apple store to effect repair.
WhyMeLord - 回复
What if I didn't get all the adhesive out from under the battery?!
Margo Christianson - 回复
Very nice and helped me a lot. Thank you.
krakkoandras - 回复
Success. I got one adhesive strip to come out in one piece. The 2nd one snapped in half. I had to do the pry-of-shame, but once I could see the adhesive underneath the battery, I was able to grab it with the angled tweezers, and pull the rest of it out. Wow it’s a lot easier to remove the battery if you get both adhesive strips out in one piece each! I left the screen attached during the battery replacement, so I only removed the batter connector cover. Helps to have a 2nd person hold the screen so you don’t damage the connectors.
ericrose62 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 68,698
