跳转到主内容
iPhone 6s 显示屏总成更换
你所需要的
  1. iPhone 6s 显示屏总成更换, 五角螺丝: 步骤 1 中的图像 1,1
    • 在拆卸iPhone之前,请将电池放电至25%以下。 充电的锂离子电池如果意外被刺破可能会着火和/或爆炸。
    • 在开始拆卸之前请将你手机关机。
    • 将位于Lightning数据口两侧(处于iPhone底部边缘)的2颗3.4 mm的五角螺丝拧下。
    Hi, just got the repair kit that came with IPhone 6S battery. I felt that there’s no explanation on which tool to use to remove the two 3.4mm P2 Pentalobe screws. It’s not helpful just to say “Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, next to the Lightning connector. “. It’s more important to explain how and what tool to use. The repair tool kit tools were not marked at all and it’s not right to assume that people know which tool or part to use. Please kindly address this issue. Thanks. Janet
    Janet Monaghen - 回复
    @beingchen For the P2 pentalobe screws you should use the driver bit marked P2. Might be a little hard to see but it’s there, etched into the side of the bit.
    Jeff Suovanen -
    It’s very clear which tool you need. As it says these are “3.4 mm P2 Pentalobe screws” - so you need a 3.4 mm P2 Pentalobe screwdriver…
    alexanderbrix1987 - 回复
    Just a P2 driver—3.4 mm is the length of the screw.
    Jeff Suovanen -
    If you can’t identify which screwdriver in the kit to use, you probably shouldn’t be working on your phone. Just sayin’
    Keith Hockenbeck - 回复
    Is it ok to replace the battery if the phone screen is broken?
    Reem - 回复
    Of course! As long as the screen and battery are disconnected from the motherboard, you can replace anything!
    Charles Bejarano -
    is it possible to change my battery on my iphone 6s and use a battery that has been already used in another 6s
    morgan durnford - 回复
    Yeah it would work, but if the battery heath on the 2nd battery is bad, just get a new one.
    Charles Bejarano -
    @moe6802 Removing the battery can damage it, and it shouldn’t be used afterward. It may seem fine, but even minor battery damage can lead to a fire hazard. Not worth it for such a cheap part. If you need a battery, just get a new one.
    Jeff Suovanen -
    How do you discharge a battery? Do you just let the battery drain or is there something less time consuming that you can do?
    Matthew Petts - 回复
    There is no easy way to discharge the battery in “less time”. Perhaps the fastest way is to play a visually-complex modern game or otherwise make your phone do a lot of work.
    Lance J -
    So my phone screen is completely black causing me to see nothing that is on my screen. And the battery is above 25%, near 100%. What do I do??
    Jessica I - 回复
    you should post a question on the answers forum
    Seizure Salad -
    Seizure Salad - 回复
    I can’t the screws with the P2, seems that the screws are stuck, what can i do?
    Alberto Jabiles - 回复
    My kit came with 3 screws. Are those to replace these 2 P2 screws? And what’s the third one for?
    Daniel Morse - 回复
    If it came with 3 screws, then it’s an extra one just in case if a replacement screw gets lost.
    Charles Bejarano -
    My display is cracked/broken and not functioning. The slide bar doesn’t work. How do I shut down my phone?
    Timothy Huss - 回复
    i have replaced several ipod batteries and laptop work, but these screws seem to loose but do not come out. how am i to remove them.shake the iphone?it seems the ioen is not in my kit, is that how to remove them?
    this seems idiotic but i remember some other system magnets that firt make your screws easier to keep, but this might be changed….any video? this seems 1st step blues!!!!
    makinfilms - 回复
    never ind ishook it… is that in the guide?….iopener is not in the kit……never was before is this an upsell? do i skip it? i dont have it
    makinfilms - 回复
    My screws aren’t coming out either. I’ve loosened them, but they aren’t coming out. I’ve shaken the phone, given it some slight bangs…nothing.
    Jesse Fisher -
    The following info is not given until step 21 in the instructions, and probably too late at that.
    DO NOT disconnect or reconnect any of the cables in this device until the battery itself has been disconnected!
    Don’t skip that step, intending to do it at the end, as you may damage the phone.
    ffissk - 回复
    2 thoughts:
    1) Really? Steps 14-17 are about disconnecting the battery first, and step 17 notes “so it doesn’t get reconnected while you work.” How’d you get to step 21 and miss 14-17?
    2) These pages are user-editable. (Probably (hopefully) “curated” by iFixit staff.) You should add a warning to step 17 (or step 24).
    Bass Clef -
    NOW THAT YOU’VE REMOVED 2 SCREWS, and
    BEFORE YOU SNEEZE them into oblivion, or under the refrigerator (which is the same in many houses)
    MAY I suggest:
    1) Obtain:
    — a piece of paper, such as normal printer paper (not too much writing on one side)
    — a piece of tape, not too sticky, like masking tape (duct tape would be bad)
    ——— 1-1.5 inches (2.5-4 cm) wide
    ——— 6-8 inches (15-20 cm) long
    — a pencil (or pen)
    2) Put the paper on the side of your work area
    3) Lay the tape, sticky side up, on the paper
    4) Fold each end of the tape (~1 inch/2.5cm) back under itself, so the folded part faces the paper. Press the folded-back tape onto the paper
    You now have Sneeze & Wind Insurance for your tiny bits!
    5) Put the 2 pentalobes end down on the top end of the tape, next to each other. Push them a little onto the tape so they stick
    6) Use your pencil to note on the paper next to the screws: “1. Pentalobes”
    Now you may proceed with dissassembly, without worrying about telling the 1.5mm from the 1.6mm screws.
    or about sneezing!
    Bass Clef - 回复
    My phone has a bad battery and a bad connector and I wasn’t able to get all of my photos before it died. Is there any chance I won’t lose them when I replace the battery? Or, is there any way to charge a 6s battery with a bad connector?
    Liz R - 回复
    There is a great chance that photos, which are stored to flash memory, which is solid state memory, which is not affected when power is lost, will be there, right where you left them, once you restore power to your device. You could install a partially charged battery into your phone and then retrieve the important things, like your photos, if you don’t intend to continue using the phone. Else look at replacing the lightning connector assembly. Here: iPhone 6s Lightning 接口更换
    TimD -
    The P2 is not getting the screws loose at all. I have tried this several times and no budge on my iPhone 6s.
    Cassandra Vigil - 回复
    To avoid to be screwed by lost or mixed screws:
    - Use magnetic pad, wipeable
    - Write the ifixit- steps next to the screws (maybe even with their sizes) and other bits removed
    with a non-permanent marker
    - When finished, simply wipe the pad, and it’s ready for the next repair
    Hope that helps.
    Ulrich Janßen - 回复
    I found a pentalobe 1 driver to work much better.
    joelkevinjones - 回复
    The suction cup didn’t hold at all. I tried Windex and then hospital grade alcohol, but nothing worked. Finally had to use two exacto knife blades to begin lifting the screen. As soon as I got a little gap, used the spudger tool the rest of the way, The small philips driver didn’t fit the screws exactly, but with a little effort they came out. My battery adhesive strips snapped immediately and I had to remove the original battery the “hard way”. The kit came with replacement display adhesive but no explanation how to use it. I got some on - so better than nothing. Overall I’m happy with the results, and the new battery is charging now.
    Daniel Wolf - 回复
    First step problem? Couldn’t get the screws out. I checked my other iPhone and realized the screws were missing!Just started prying it apart.
    Hoyt Smith - 回复
    I went through the whole procedure, replaced the battery and got the screen back on. Then the 2 pentalope screws would not go into their sockets. They sink in all the way and spin, but it appears there are no threads to grab. The screen seems to be in position since I can insert a plug into the headphone jack without trouble. Did anyone else have this problem. Using the phone now with no screws. Yikes.
    Walter Plante - 回复
    Hi Walter, in case you’re still dealing with this or anyone else has the same problem, check that the screw bosses on the bottom of the screen are straight and line up with the screw holes on the case. They should be at a 90° angle to the screen, but they’re easy to accidentally bend and could’ve gotten flattened against the screen.
    Adam O'Camb -
    I recommend a loop of tape attached to the table, and placing the screws on the tape in the order they were taken out. identifying the screws to put back is a simple matter of going the other way back up the tape.
    David Taylor - 回复
    Did the repair for the second time, each time faster and easier. This steps by step is amazing and crystal clear no mistake possible.
    Jean-Gabriel Duquesnoy - 回复
  2. iPhone 6s 显示屏总成更换, 给屏幕粘胶带: 步骤 2 中的图像 1,3 iPhone 6s 显示屏总成更换, 给屏幕粘胶带: 步骤 2 中的图像 2,3 iPhone 6s 显示屏总成更换, 给屏幕粘胶带: 步骤 2 中的图像 3,3
    • 如果你的屏幕玻璃碎了,可以使用胶带粘住整个屏幕,防止玻璃碎屑伤到你。
    • 使用胶带粘满整个iPhone屏幕,直到覆盖整个显示屏。
    • 这可以固定住玻璃碎片,保持结构完整,给接下来的维修提供方便。
    • 戴上护目镜,以保护你的眼睛免受任何在修理过程飞溅的玻璃碎片。
    • 如果破碎的玻璃在接下来的几个步骤中使吸盘很难粘住,请尝试使用强力胶带(例如布基胶带,然后用其提起显示屏。
    In case of broken glass you can make the suction cup much more effective by covering the glass with a broad piece of translucent tape which eliminate air leakage through cracks in the glass.
    lionno1 - 回复
    Il n’est pas nécessaire de mettre beaucoup de scotch.
    Au contraire plus vous mettez de scotch, plus il y aura de défauts et la ventouse ne collera pas.
    Une bande bien positionnée suffit.
    Chloé Bossuette - 回复
    I’ve used hot glue on low setting to remove all types of crystals. The hot glue will release with a little iso alcohol. No damage to glass or plastic faced crystals or screens. Use a narrow piece of wood as a prying handle.
    Emilio Gonzalez - 回复
    I recently had issues with removing the glass with the suction cup. I have done this many times with older generation iPhones but this time the glass seemed sealed on quite solidly. I told myself that the last option would be to use the screwdriver tip. After all my attempts, I transitioned to the option of using the screwdriver tip. Surprisingly, it was the easiest thing ever. I placed the 1mm flathead screwdriver at the interface between the glass and the cover (normal start location) and pried up very gently. Voila, the glass came up and I can’t even notice any dents or scratches. It felt much easier than the suction cup technique. If the suction cup is giving you a hard time consider using that 1mm flathead.
    forhereyesonly - 回复
    This is definetly the best option to open this thing up. I’ve spend 30min with trying to heat it up and remove it using the suction cup. I needed 3sec with the 1mm flat screwdriver and i t was’nt scary at all. No dents nor scratches here too. Thanks for your comment.
    Berggorilla -
    thank you!!!!!
    Adrian Phan -
    Great suggestion to use the screwdriver!! Thanks, it really helped
    obo12759 - 回复
    Duck Tape worked great for me. Thanks for the great instruction!
    Michael - 回复
    Tried several types of tape but finally used this screw driver solution. At first I wasn't pushing hard enough for fear of damaging things but with just a bit of extra force I was able to open it right up. Everything is fine with only a slight scratch on the frame.
    Wesley Shank - 回复
  3. iPhone 6s 显示屏总成更换, 拆卸步骤大全: 步骤 3 中的图像 1,1
    • 如果你没有反向钳,请遵循以下三步使用吸盘。
    • 可选择使用 iOpener 或吹风机,对 iPhone 下边缘稍加热约一分钟。
    • 加热软化固定屏幕的胶水,可以更容易打开 iPhone。
    What about specifying the hot air temperature?
    Nicola Centrone - 回复
    The glue softens pretty easily, so the exact temperature isn’t critical. Get it slightly too hot to touch. If you have trouble, heat it a little more and try again.
    Jeff Suovanen -
    What temperature on the screen separator lcd machine and for how long?
    Manraj Gulati - 回复
    This is the first time I opened my 6s since it was purchased new four years ago. Even without heat, constant and firm works enough to be able to squeeze the flat edge of the spudger. From that point and without any additional pulling from the suction, twist the spudger gently to “walk” it open on both sides.
    Family Juinio - 回复
    I used a hand towel folded in half and a clothes iron on the cotton setting (med-high heat, no steam). Placing the doubled towel between the phone and the iron, I would set the iron down for about 20 seconds (my iron has a timer that beeps when left horizontal for too long). Lift the iron, check the temperature (aiming for just too hot to touch), reposition as needed, repeat. It took me a while, but that’s because I took my time not knowing how fast this would heat. All-in-all, about 2 minutes to reach the right temperature to loosen the adhesive (it IS tenacious).
    Sarah Wruck - 回复
    Holy. Redii eirhejbrd
    Andy Carson - 回复
    just been given a 6s to repair, for this stage would a hot water bottle work ??
    Steven James - 回复
    I used a hot-water bottle to keep the iPhone warm while prying patiently, though the moving surface added to the challenge.
    Before that, I put the iPhone - screen facing down - to warm on the coffee cup heater (45°C) of an espresso coffee machine. Half an hour seemed more than enough.
    A hot-water bottle filled with water at 60°C would do the job I think.
    Later repeated the same heating before removing the adhesive strips under the battery (allowed me to extract each strip successfully, rolling it on the body of the spudger).
    And also before putting the new display assembly adhesive under heavy book weight.
    Aubin -
    I heated a stone pestle in the air fryer, wrapped in a cloth.
    Ark - 回复
    I didn’t have any of the heating tools listed here so I improvised:
    To soften the glue I heated water in a pan (not boiling but quite hot).
    I put the phone in a thick plastic bag in the water for about 20 - 30 seconds. (I checked the bag was properly watertight first by dipping it in water – minus the phone). Maybe I was lucky but the screen came away easily doing it this way.
    Henrik Dahle - 回复
    Clean the glass screen first with eye glass cleaner wipes (alcohol). Hair dryer on hot with low air speed works excellent. Aim the heat at 45 degrees (phone face up) and move around the perimeter for about 1 minute. The edges should be hot enough to barely touch without burning your figures. This seems to get the glue hot enough at the edges for easy removal. Warm the glass face a bit and also warm the suction cup, this makes the suction a lot better and the suction cup won’t come off like it will if the face and suction cup are cold. Later when removing the battery, heat the bottom with the hair dryer for about 30 seconds and the top of the bottom of the battery where the 2 tabs are for the tape behind the battery. This makes for simple removal of the battery tape under it.
    Keith Paget - 回复
    Here’s what I did to open my iPhone (I had it open in under 1 minute): 1) I has one of those rice/barley filled eye masks that you heat up in a microwave. I heated it for 1 min and then placed my phone face down onto it for 1-2 min. 2) I placed the suction cup onto the left lower corner and the “tweezers” into the headphone jack. Pull upwards with the suction cup and hold the phone’s body down in place with the tweezers. 3) a gap will open. Slide the edge of a razor blade into the gap (not too deep) 4) insert the plastic triangular guitar pick tool into the gap next to the razor blade. Slide sideways with the triangular tool to make the gap large enough to insert the spudger. 5) insert the edge of the spudger tool (curve down) into the, now widened, gap. 6) slide the spudger tool along the edges of the iPhone. Opened!
    jennismith2 - 回复
  4. iPhone 6s 显示屏总成更换: 步骤 4 中的图像 1,1
    • 6s 屏幕四个边缘周围有黏胶固定, 若你选择要更换黏胶的话, 在你拆解之前, 最好是先准备好新的黏胶。若你本身不想更换新黏胶也行, 因为在功能上, 跟使用原有的黏胶没有太大差别 。
    • 将吸盘置于屏幕左下角, 进行拆解。
    • 注意, 吸盘放置地方不能与Home键重叠。
    Hello, I was wondering if there was a guide of how to replace the adhesive strips, thank you
    Pablo Reyes - 回复
    The suction cup will not work if you have a shattered screen. I put a tip of an exacto knife between the glass and side frame above the power connector, carefully pried up then used the spluger to pry the rest of the way up.
    johnmurphyjr - 回复
    Tape will work as well in order to create a smooth surface
    Nick Stine -
    Even tape didn’t work on my first shattered screen 6S disassembly. Had to reset to the exacto/thin blade technique.
    Peter Bovey - 回复
    For me, it seemed like I only had one shot at the suction cup. It stuck on firmly the first time, but I noticed in the instructions that it was placed more on the side. I detached my suction cup and repositioned it and now it doesn’t stay (sucked) on. Hmmm.
    Frank Terence - 回复
    Can you use the iSclack opener to open the iPhone 6s?
    Joe Koffee - 回复
    The iSclack is helpful, although you have to use it a bit differently than you would on, say, a 5s or 6. The iSclack alone isn’t strong enough to pop the display open, because of all the adhesive around the perimeter of the 6s display. But you can use it to lift the display just enough to get a tool in there and start cutting the adhesive. Basically, the iSclack does the same job as the suction cup shown here, with maybe a bit less fuss.
    Jeff Suovanen -
    My screen was SUPER shattered… the hair dryer did the trick. Patience it definitely the key… I tried putting tape over the glass but the suction cup wouldn’t stick to it at all but it stuck to the broken glass for a few seconds. I taped it up when I was finally able to move onto the next steps to keep the glass from getting everywhere then peeled it off for Step 10.
    Mandy Ng - 回复
    Hi, it looks like, from reading the comments, that separating the display assembly from the phone is a tricky step.
    Would the piece of equipment, in the link below, be any use at this stage? Seems it could be used for all makes and models.
    Any info would be appreciated.
    https://youtu.be/8it4o9tx8tQ
    Michael - 回复
    I have a screen protector on my phone. I was wondering if it was going to be problem for the suction cup.
    jeffreyleung2002 - 回复
    I can only suggest to use a hair dryer to loosen up the adhesive underneath the display. Mine was stuck so hard it wouldn't barely move. After warming ist up I could softly pull ist up with way less power
    olonetzky - 回复
    A question, has anyone had success removing a cracked (not shattered) screen? My phone has a single diagonal crack from the top right corner down to the left side. Will the suction cup still work?
    goblazers - 回复
    The suction cup material was very stiff and wouldn’t adhere well even after thoroughly cleaning the screen. Applying heat from a hair dryer helped with that, too.
    Karleen Smith - 回复
    A packing tape handle worked well for me instead of the suction cup. I folded a piece of packing tape in half leaving two ends to stick to the part of the screen indicated for the suction cup placement and used the center fold as a handle.
    Diana Riddle - 回复
    I found that a 3rd hand helped here. Lots of heat and as others say, a strong, steady pull, but you are only creating a gap to get the spludger in, not ripping the screen away from the body. Once I created the teeny gap I had someone else get the spludger in to hold it open while I shifted my grip.
    Steve - 回复
    I’ll throw in here for other noobs as someone who just read ALL the comments and had things go pretty well without a hitch.
    Adhesive here goes ALL the way around edge. I think think many people’s frustration comes from in adequate heating and/or only heating the inferior edge area. I went with 5 min of a rice/shoulder thingy, (uniform rectangle folded in half on a plate, 3 min in the microwave) Plate side was hot potato hot and stayed so.
    Other inference and comment curating:
    a. Use pointy spudger end inserted slightly into headphone jack to hold down phone while pulling up;
    b. 2mm lift MAX the insert something to hold while you bring the flat end of the spudger around (I just used the flesh of my finger;
    c. Twist spudger ONLY zero -20 degrees when inserted;
    d. Avoid spudgering above or between the pentab screw holes.
    e. Avoid sticking the spudger in more than 2 mm as you slide up the left and right edges. If you catch, back it out a bit until you can keep sliding.
    Aaron - 回复
    Also all props to Ifixit for addressing many issues with earlier versions of this and their replacement kit! A lot of complaints are clearly obsolete now.
    And if this your first time block out an afternoon and be glad if it only takes 20-30 minutes. Rushing causes breakage more often than not.
    Aaron - 回复
    I’m in a third world country without access to a hairdryer. Is there anyway else to loosen the adhesive?
    Dylan - 回复
  5. iPhone 6s 显示屏总成更换: 步骤 5 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 5 中的图像 2,2
    • 使用巧劲拉动吸盘, 直到屏幕与后盖中间出现缝隙为止
    • 在拆解过程需花点时间及控制力道。屏幕因为有黏胶的关系, 会比一般产品来得更紧。
    • 注意, 若拉太大力会造成屏幕损坏。只要打开到让显示屏与后盖有个小缝隙即可。
    • 如果有任何问题,请使用iOpener,吹风机或热风枪加热iPhone正面,直至其变得有点烫手。 这将有助于软化固定显示器边缘的粘合剂。
    No, really. Do this on a table and use less strength than you think. If you open the display the whole way at this step you can easily rip the home button connections and one of several display connections at the top. <— too much experience... :(
    chuymatt - 回复
    Wow, that was tough. Patience, patience, patience. Did not use the iOpener, just firm and consistent pulling with the phone on a flat surface. When the suction cup comes off... clean the display surface and go back at it. I did use the pointed end of a spudger inserted into the headphone jack to hold down the bottom case whilst I pulled on the suction cup. Once there was sufficient room (see next step) you can just get the spudger (flat end) to slide in slightly.
    plisi - 回复
    If you're lifting up on the glass, how are you supposed to hold the rest of the phone down? Is it by holding the camera end down with the side of your hand and rotating your hand, or using your other hand (not pictured) on the edges (seems very difficult), or using a spudger in a jack?
    Bryan - 回复
    I got a fingernail on the metal edge and that did the trick.
    David Heinbach -
    On the 6s, which has an annoying black adhesive strip holding the display assembly on, I use the iSclack to loosen a very small area near the home button then insert a thin spudger and gently twist it a bit to release the adhesive. Do this around the bottom and both sides of the phone to release the screen. I usually have to break some of the adhesive strands when the opening is big enough.
    scentaur - 回复
    My spudgers just too thick for initial insertion. In the end, fingernail on my thumb got me started, and I was able to get plastic picks in there to work it. The microwavable iOpener gel strip really helped.
    Heidi Moser - 回复
    Thanks plisi, your comments are helpful. I had to apply pressure several different times. Didnt realize until about the seventh time applying pressure that what I was doing was slowly loosening the adhesive. Patience is truly the key with this step. You may not think you're progressing but it's slowly prying away.
    amylofton - 回复
    What happens if the cup won't even stick to the display because it is cracked and it will not hold air near the bottom of the phone?
    Jaredrett - 回复
    hey everyone, i just did my first iphone 6S display...after many 5, 5c, and 5s iphones...just keep trying and carefully insert the spunger where they said...right around the headphone jack. The black adhesive makes it very tough to get it off unless you work at one corner. Be careful...but you can do it! ;-)
    David Althaus - 回复
    Use a razor, and go along the outside of the phone carevilly using the razor as a spudger. it will efficiently cut and weaken the adhesive while spudging the screen away from the frame. only takes 15 mins.... Use a workbench razor, not a flimsy one. If possible, use one where one side of the razor has a gaurd on it for better grip. Take it slow and try not to scratch the frame. Lots of pressure and patience is key!!!
    Goodluck!!
    -J
    Jaredrett - 回复
    The first time you pull it apart there's black glue tape that you'll have to compete with to get it open. Be careful
    Jeff - 回复
    Use a hairdryer about 2-3 inches from the phone on high heat for about a minute, moving the dryer the entire time. The phone opened for me in less than a minute after trying for several minutes without heating up the phone.
    Todd Leach - 回复
    Careful ..delicate work. I also used a hot hair dryer around the perimeter for just a couple minutes to help loosen the adhesive bond. I then used my sadly short finger nail to help loosen the edge. I placed dental floss under the corner & carefully lifted the display very very slowly. This worked within about 3 minutes. As mentioned earlier the adhesive used in the iPhone 6s is very strong but this routine worked like a charm & was quick!
    Mary Blocher - 回复
    Much easier to do using the Spudger that is provided in the Pro Tool Kit. It has a thinner fin type head. The Spudger provided in this repair kit is definitely too thick and makes it far more difficult.
    Tyler Brady - 回复
    The spudger is too thick and the glue is too strong. Pulling up broke the glass below the power button. Now I am out $200 for a repair, plus a battery. Bummer. I am VERY good at repairing things. The adhesive on this is very very strong. The pentalobe tip that they send with the kits not milled well and I had to take a file and flatten the tip to get it to work - it is not finished well at all. I used the kit for the iPhone 6 for my Mom and had no problem. I am 51 and have been fixing things since I was very young.
    greghabiby - 回复
    Well, I shattered my screen trying to do this. So now I need a battery and screen repair. Not happy.
    Carolann Parran - 回复
    Me too! Be gentle!
    Matthew Simoenau -
    Me as well, I went very slowly, was working the spudger around the edge and then it shattered. Just going to buy a replacement phone and I was replacing the battery to gift this to my sister as a hand-me-down and now it’s not worth it. Perhaps I can sell the kit second hand…
    kpederso -
    Removing the display was the hardest part of the whole job. The adhesive is very strong, but just be patient. What I ended up doing was to use the suction cup, the flat end of the spudger, and an iFixit opening tool. I used the suction cup on the screen as directed. Then I placed the flat end of the spudger just a bit into the charging port and held down the phone body by the spudger on my work mat. I pulled up on the suction cup, pushed down on the spudger, and inserted the thin iFixit opening tool in the small seperation. I took my time and worked my way around all of the edges. After that it was really easy. I was able to reuse the adhesive, and my new battery install went just as planned.
    Eric Olson - 回复
    Use a hair dryer as per the suggestions and this will definitely make the job easier and reducing the risk of breaking the display . Keep a steady pull of the display, don’t rush and it will start to show the small separation gap. An issue is that it will go back in place if you stop pulling before you can use the spudger tool. The suction tool that came with my repair kit did not have a ring on it as per the guide picture. It has a blue handle that is open on the side. I sat at my kitchen desk and opened a drawer. I hooked the open edge of the suction handle around the drawer side edge which me a third hand. I held the phone with one hand and pulled it away from the desk drawer. Once the separation started I could use my other hand with the flat edge of the spudger to complete the separation. Hope this helps.
    emaneht - 回复
    Hair dryer - 1 minute until it’s hot like a fresh mug of coffee. Then as soon as you see the smallest gap, insert a razor blade above the phones jack, I needed to slide it towards the charge port and back. Once it slips in keep it there and use your spudger to enlarge the gap and slide it along the corners.
    Steve Esson - 回复
    Yes, I used the tip of a sharp knife as a pry tool to get me started. Since the screen was cracked anyway I figured I had nothing to lose. It went fine.
    David Heinbach -
    Also tried it with the hair dryer - worked like a charm. 5 Minutes and the phone was open. The whole repair procedure took me about 45 minutes, and was ok. Re-assembling the three display-connectors has been a bit tricky, but with careful movements and taking the time it needs it was not a big problem. New display is very good, phone looks like new :-)
    Christian Woelk - 回复
    My glass was broken and the suction cup wouldn’t hold on the tape. I used a very thin knife an slowly worked between the glass and the phone frame. Please keep in mind that my phone had been run over by a Ford F150, so I really had nothing to lose.
    Michael Cleveland - 回复
    What is unfortunately unclear is just how to 1. apply sufficient force and keeping the phone secure with only one hand, 2. whether this is best done on a table to use its opposing surface to secure the phone.
    The suction cup is a worthless tool because flexes too much to provide a good hold. Mine slipped and popped away three times. -The last time causing a crack in the screen.
    ffissk - 回复
    Glad I read these comments about the screen cracking because I was really trying to force this thing open (with some heat applied already), but it wasn’t budging. Kept applying heat and light force and eventually it started coming apart. The suggestion for placing the pointed end of the spudger in the headphone jack while prying up worked for me and an extra set of hands would have been ideal.
    In the end, with the spudger in the headphone jack, placed a guitar pick in between the screen and the backing and slid it along the bottom left. Left the tip of the guitar pick in to hold the gap and then was able to use the spudger to complete the process as shown.
    Nicholas Anchor - 回复
    Beware! I cracked the screen. Used iOpener, iFixit spudger etc. I managed to get the spudger into the gap by the headset socket and worked my way up the left, when I came to do the right the screen was cracked. I was taking it slow and steady but clearly that wasn’t enough. Be VERY careful.
    James - 回复
    Heat is essential, and take it very slowly. Also take seriously the instruction to open just enough to get the spudger in there—then do the real work with that. The suction is just to get started. I had my son insert the spudger as soon as there was any gap at all, then worked it according to the guide.
    I did this on a card table with a vinyl surface so I could lay the phone down. Then I held the metal frame on both sides while pulling the suction cup—my son having the spudger at the ready. Definitely be patient! I had to restart several times when the suction cup popped off and I accidentally reengaged the clips pressing it back on.
    Matt Burleson - 回复
    Henrik Dahle - 回复
    I did the hair dryer three or four times and applied all of the pressure i could on the suction cup and it just wouldn’t budge. My phone is old and i had a waterproof case on it for a long time that really pressed down on the glass so it would seal. I think having that on for three or more years really sealed the glass!!!! Didn’t want to break it so will live with my battery as is…..it last most of the day and i am usually around a car charger or home. Just thought i would add a comment that said man i gave it my best shot and opted not to do it. I really liked the kit though and the tool will come in pretty handy to repair other small things.
    David Petr - 回复
    This was waaaaay the hardest bit for me. Took ages Almost gave up. Allow AT LEAST twenty minutes. Endless patience pulling, then resting for a bit then pulling again. S.T.E.A.D.Y Keep at it long after your inner voice is saying ‘why did you think you could do this. You have never mended anything in your life.’ Then you see the gap and like a steady bomb disposal expert you quietly winkle it apart.
    Cindy Clarke - 回复
    Used heat from a hairdryer, gentle pulling to lift the glass at the position above the headphone jack one to 2 millimetres with the suction cup, then put my thumbnail in the gap and pulled up gently a bit more to fit the spudger, and mainly slid the spudger as indicated around the glass, bottom first, and then sides to within about a centimetre of the top at most, to release the display. I found very little prying is needed. Once a gap of about a millimetre or 2 is created, that is enough to release the display from the adhesive.
    Nando - 回复
    Run a little isopropanol along the seam at the bottom end (I had no syringe, so I dipped the handle end of a spoon in and ran that along). Leave a couple of minutes, then warm with a hair drier. It will pop right off with the suction cup.
    robthebrew - 回复
    It was so much easier after I removed the two screws from step one… LOL! With heat, the screen should come up quite easily. You definitely don’t want to pull too hard. I introduced a small illumination artifact into the screen where the suction cup was attached. I’m not sure whether this was due to the suction cup or excessive heat. I was using a heat gun and trying to warm the screen evenly so it wouldn’t crack. But the temp might have been too high. Next time I’ll just heat the metal around the edges.
    len - 回复
    don’t forget the screws like my stupid self did!!!
    trevorsklar - 回复
    After 45 minutes of using a hair dryer the entire time while suction cupping it some 50 times (kept popping off), I finally was able to create the gap needed to remove the display. I found steady pulling of the suction cup was useless. I had to quickly pull,release,pull,release,repeat and this nudged the tape apart, which had the constancy of dried superglue. Not easy, but this phone was 7 years old,....
    skypilota72 - 回复
    Got this done in about 2 minutes!! I used a space with that had a fan function. Held up my phone to it for a few minutes, also heated up the suction cup. I didn't have extra help, so the whole "pull suction cup with left hand, hold down phone by headphone jack with right hand, and insert pick with ??? hand" wasn't going to work. I was able to hold the phone down while also pulling up on the suction cup all with my left hand (almost like i was peeling the screen up). Stuck a plastic Opening Pick in the small opening, then slid in the flat end of a spudger. I could not rotate the spudger like in the photo (photo 2 of step 6), the screen was stuck on too tight, so I just started sliding the thin end of the spudger around. I held the phone up in front of the heater during this. I also used the pick to cut adhesive along the way.
    Kelly Archer - 回复
  6. iPhone 6s 显示屏总成更换: 步骤 6 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 6 中的图像 2,2
    • 在屏幕下有个槽口, 位置正好在耳机插槽上方。这里是撬开的最佳位置。
    • 将撬棒平面那头插进屏幕与后盖的缝隙, 也就是耳机插槽上方位置。
    WARNING: easy to stretch/ruin the adhesive
    As you proceed, know that you must keep ALL of the adhesive stuck to the phone. If any stays stuck to display, it can become permanently stretched as you are prying and lifting. Then you’ll need to buy the replacement adhesive, once it’s back in stock!
    Jason - 回复
    If you’re opening the phone at all, you’re compromising the adhesive. There is absolutely no way to somehow open it perfectly so you can re-use it. Fortunately, it’s cheap and fairly easy to replace—and not even that critical on the 6s series anyway, since it’s not doing any real waterproofing.
    Jeff Suovanen -
    I had a badly cracked screen. Packing tape helped the suction cup stick. Heating the phone helped soften the adhesive, and in the end I pried the screen up at the headphone jack with a sharp pointy knife. That helped me get the spudger underneath. Not recommended if the screen is ok, like for a battery replacement, but mine was cracked so I figured I had nothing to lose. Great guide.
    David Heinbach - 回复
    There are two relatively delicate brackets that the two P2 Pentalobe screws screw into. They can be easily bent during this prying open process. I ruined one on my phone and I’m hoping the phone will function with just one bracket.
    dougdalglish - 回复
    +1 on the pointy knife to get the screen pried up. I couldn’t get the suction cup or tape to adhere well enough due to the glass being so shattered. I heated it for quite a while with the hair dryer on high, got a very sharp knife tip under the glass where the “notch” is, and used that to pry upward while another person slid the end of the spudger into the gap I was holding open with the knife. This one step was basically a three-handed job.
    johnjustinirvine - 回复
    Do not insert the spudger at any time directly beneath the home button because it will crack the screen at the point.
    daniel vellone - 回复
    +1 to never trying to lift the screen from directly beneath the home button.
    Romke -
  7. iPhone 6s 显示屏总成更换: 步骤 7 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 7 中的图像 2,2
    • 用撬棒将缝隙左右边撑开, 使屏幕从机身上分离。
    No need to turn the spudger full 90°. Just turn it a little.
    Martin Born - 回复
    should have a warning to be very gentle when doing this as the screen is glass - i shattered my screen following this guide
    Martin McAnespie - 回复
    Do not twist spudger! Broke my screen. Thanks, iBrokeIt.
    Trevor Snow - 回复
    As others have said, do not twist the spudger. To release the display, you only need to create a gap of a few millimetres. Better to slide the spudger as directed to release the adhesive, bottom left and right.
    Nando - 回复
  8. iPhone 6s 显示屏总成更换: 步骤 8 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 8 中的图像 2,2
    • 将撬棒平的那头插进手机左侧, 屏幕与背盖间的缝隙。
    • 将撬棒缓慢地往上移动, 使黏胶与机身分离。
    I’ve found it very easy to open the phone with one of the blue opening picks.
    Just slide it along the left and right side of the display.
    Martin Born - 回复
    Excellent idea. No matter which tool you use take your time so not to damage the display assembly further. Even a cracked screen is a great test tool or spare to use while doing other repairs when it still comes on.
    Bryan Solo -
    Do not go into the top left corner too far your screen will crack i learned the hard way
    Kevin - 回复
    ok but where js the oart about puttung ut back together? mine diesnt snapinto place,……
    makinfilms - 回复
    Use two spudgers.
    One placed in the original breech position to be used as a wedge.
    The other to get worked around the unit.
    These spudgers are going to get destroyed in the process and will not likely be great for another repair.
    ffissk - 回复
  9. iPhone 6s 显示屏总成更换: 步骤 9 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 9 中的图像 2,2
    • 移开撬棒后, 再将撬棒重新插入你一开始从手机底部撬开的地方。
    • 将撬棒缓慢地沿着底部边缘移到右边。
  10. iPhone 6s 显示屏总成更换: 步骤 10 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 10 中的图像 2,2
    This is some important step here I reckon. I didn’t release the clips individually and gradually, so when I pulled, the two halves of the phone separated quite suddenly and the cables ripped in half. Had to order a screen.
    Neil Bass - 回复
    How do I release the clips individually? Is there a good explanation?
    Dan Schwartz - 回复
    i personally use a utility knife and it helps separate the metal bracket that's on the screen from the phone housing
    Andre G. Bashore -
  11. iPhone 6s 显示屏总成更换: 步骤 11 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 11 中的图像 2,2
    • 用吸盘将屏幕小心地掀开, 并将剩余黏胶折断。
    • 請勿將屏幕掀开超过90º, 因为屏幕上还有3条排线连接, 如果掀开角度过大, 可能造成排线损坏。
    Prop it up on something
    Nick Stine - 回复
    an old iPhone box and a rubber band lightly around the display works great to hold it at 90
    Christa - 回复
    You could use a clock weight with 2 socks wrapped around it and an elastic band to keep the screen at a 90 degree angle.
    AudiRo808 - 回复
  12. iPhone 6s 显示屏总成更换: 步骤 12 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 12 中的图像 2,2
    • 使用巧劲将吸盘往上拉, 将屏幕与机身分离。
    Pulling up on the “nub” is a futile waste of time.
    ffissk - 回复
  13. iPhone 6s 显示屏总成更换: 步骤 13 中的图像 1,3 iPhone 6s 显示屏总成更换: 步骤 13 中的图像 2,3 iPhone 6s 显示屏总成更换: 步骤 13 中的图像 3,3
    • 以屏幕顶端为支点,将屏幕缓缓地向上掀起。
    • 将屏幕掀至约90º竖起, 并且在你操作的时候找个东西支撑着它。
    • 用橡皮筋将前面板与支撑物固定住。这可以避免拉扯到显示排线。
    • 若在紧要关头时, 你也可以用未开过的罐装饮料撑着屏幕, 这也是可行方法。
    Smart idea :)
    x226 - 回复
    on the third picture, the screen is opened more than 90 degrees.
    Mirza Zohaib - 回复
    It said about 90 degrees
    Nick Stine -
    Actually it literally says, “Don't open the display more than 90º, as it is still connected at the top by three cables that may break if stretched.”
    David -
    In the second picture I was originally wondering what that diagonal piece of material was. Now that I've done a repair I can say that it's the sticky adhesive around the edge of the phone lifting up with the screen.
    jonl - 回复
    Be careful when separating the halves not to pull off the black tape on the back of the screen half. Mine was stuck to the two halves and I thought it was double sided tape to holding the halves together. It was shredded in separating the 2 halves. It turns out it covers up some kindof of silver paste (purpose unknown) on the back of the screen so I cut a put a piece of plastic film to match it and taped it in place. We’ll see what happens…
    Jamey Gerlaugh - 回复
    can of soup and rubber band did the trick.
    Big Al - 回复
    this is bs as they do not tell you reverse how to snap the fuker back on…..putting it in back on!,!!! the guy asks for points for writing thus? why not make a video you dirk….and how to put it back on….what about the other adhesive?..? you moron it says mothing…anyone else have a link? oi could barely put the screws back in..
    takimg the fuker apart is easy….putting the $@$* together again? humpty dumpty!”!!!
    makinfilms - 回复
    When replacing the screen, make sure to get the top (camera side) lip in first, then work downward along the sides, getting the edge with the home button in last.
    i normally use the long pick as a prop like that on a vehicle
    Andre G. Bashore - 回复
    It should be noted that to camera end of the screen body needs to hook under the edge of the body…..the hooks of the screen frame need to be under the rim of the main body and snugged toward the camera end to easily close the cover and have it properly clip. These hooks are not really a proper hinge but clasps that need to be under the rim of the main phone frame/edge!! This way the screen easily will return to its closed state nicely gently snapping into place!!
    BRIAN Lee - 回复
    EVERYONE read this comment. It is KEY.
    Also reverse order for getting screen clipped back in means pressing along the right side top to bottom corner. Then the left. Between that and this comment sandwiches back in like a cinch.
    Aaron -
    I used a full beer can and 2 elastic bands to hold the face at 90 degrees. One elastic at the top and one at the bottom keeps the face still at 90 degrees. This allows you to work on the phone easily. I did not remove the face totally to redo the perimeter glue as I have never dropped my phone in the water over the “long” time I have had it.
    Keith Paget - 回复
    On reassembly, notice that the top does not snap in. There are hooks that must be engaged before levering the halves back together
    Brian Bygland - 回复
  14. iPhone 6s 显示屏总成更换, 电池接口: 步骤 14 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    In order to put the correct screw back where you took it out mark the head surface and a small dot beside the hole with a pen. Use coloured pens if you want the exact location for each screw/hole. This goes for steps 17, (23) and 29 too.
    lionno1 - 回复
    Please! Please! Please! Invest in a Magnetic Project Mat or its equivalent from fixit. It will assist you with completing your repair.
    Ian Baldwin - 回复
    I just taped down a 8.5 x 11 white piece of paper on my desk and drew a rough image of it, then ‘taped’ the screw I removed to the “image” on paper. It worked just fine. (My first time ever opening an iphone, so give it a shot!)
    italianchick99 - 回复
    If you missed it from the beginning (like I did) it’s the #000 Philips for all screws except the Pentalobes.
    Max Cox - 回复
    if you get a plastic ice cube tray, and a fine marker pen, text the sizes on each cube compartment as you follow the guide, also stops the screws getting lost
    Brendan Cranny - 回复
    used sheet of A4 paper and bluetak - stick screw in bluetak, write location & size on paper
    Kev Salmon - 回复
    mine is missing a screw!!! this is bs! this was mynmithers ohone nonone ooened it….one screw only…im liesed offf
    makinfilms - 回复
    For some odd reason the screw “One 2.2 mm screw “ orange circled seems to be stuck and can not be unscrewed.
    Ahitagni Mandal - 回复
    that could be because of the threaded part might have been broken (i've run into that a few times) never fun but pretty easy to work around it if needed
    Andre G. Bashore -
    Take a picture of the opened phone. Print it out. Put double sided clear tape over the picture of each screw. Stick the screws to the tape on the picture where they belong.
    Jeffrey Smith - 回复
    Rounded corner, both here and Display cover, takes the Longest screw.
    David.
    David - 回复
    For removing screws, I used a piece of paper and sketched the screw locations and screw sizes in the appropriate pattern for each step I was working on removing screws. I folded clear packing tape in a loop so some sticky area was on top for each screw so they did not fly away when the hair dryer was on or in case I knocked the paper while working beside it. This kept all the screws in an easy pattern with descriptions for later install. Worked slick.
    Keith Paget - 回复
    Ordered a replacement kit, opened my Iphone 6S, got to this step... surprise, my OEM battery connector is at the TOP ! I am stuck, what now?
    Michel Lavallee - 回复
  15. iPhone 6s 显示屏总成更换: 步骤 15 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 15 中的图像 2,2
    • 取下iPhone的金属的电池接口铁片支架。
    Little bit of adhesive holds this down- you do have to use the tiniest bit of force.
    Edward Coe - 回复
    Pay careful attention to the orientation of this plate so that when it comes to re-installation you put it back the correct way. Sounds obvious but I’ve found it inverted in one customer’s phone, which led symptoms of charging failures and repeated spontaneous restarts.
    Jonathan Bradley - 回复
    that's something i've never heard happening before wow
    Andre G. Bashore -
    The replacement battery’s connector is just slightly thicker vs the original. When I put the screen back on (also a replacement part from Ifixit) I get a blue shadow because the battery connector is putting pressure on the screen.
    steven pruchniewski - 回复
  16. iPhone 6s 显示屏总成更换: 步骤 16 中的图像 1,3 iPhone 6s 显示屏总成更换: 步骤 16 中的图像 2,3 iPhone 6s 显示屏总成更换: 步骤 16 中的图像 3,3
    • 使用撬棒尖头那端将电池接口铁片往上撬开, 与主板分离。
    Be sure not to skip this step. It is crucial. I have had many repairs where the screen will not light up after the repair if the battery had not been disconnected and reconnected.
    Andrew spoelstra - 回复
    Thanks for the tip, Andrew.
    William Turner -
    It should also be mentioned, DO NOT USE A METAL SPUDGER. You could short the battery to other nearby metal parts. I've done that, the battery clip arced to the metal cover on some of the logic board chips, and my phone wouldn't power back on for 3 days. They should put a caution caption on this step. I've had this happen on a 5S as well.
    Frank - 回复
    Thanks for the tip, Frank.
    William Turner -
    SERIOUS WARNING!: During *reassembly*, you should NOT reconnect the battery connector until the VERY LAST step (upon reassembly!), as many people, including myself, apparently have smoked (burned, destroyed) the main Logic board. This happens when you reconnect the LCD/digitizer assembly FPC cable. ifixit should modify this instruction to be very explicit about this!
    enoughstatic - 回复
    It sounds like several people, including myself, had trouble charging the new replacement battery past about 10%. This ended up being due to the new battery not having a non-conductive insulator. The way to solve this is by adding a small piece of electrical tape to cover the battery connector before screwing in the battery connector bracket over it. You may want to do this on the first go-around.
    If you do experience that problem, I found the answer here and it worked perfectly: iPhone battery not charging after DIY battery replacement. Why?
    Heather Pastushok - 回复
    Thanks to Heather Pastushok (and Behrang Mohajer at “iPhone battery not charging . . .) for this important detail. My iFixit battery came with a thin layer of black foam insulation on the top surface of the battery connector, but even gentle pressure from a blunt plastic tool (pushing the connector in place) scraped an exposed spot. A carefully trimmed piece of black electrician's tape provided peace of mind. The iPhone 6s is good as new with the battery now at 100%!
    Robert Dering - 回复
    Robert Dering - 回复
    To reduce risk of battery arcing , as soon as the old battery connector was detached, I wrapped it with insulation from connection all the way to the battery body. Did the same with the new battery to eliminate concerns about shorts while checking fit position to assure the connector would match up with the receiver. Only removed the insulation after all other connections had been restored, so plugging in the battery was the last step before closing the case.
    Robert Dering - 回复
    so we are supposed to attach the battery connector back on before peeling the plastic off the adhesive on back of new battery and while still attached, remove the plastic to expose the adhesive? And then once adhered, disconnect the battery connector again until last step? Just want to make sure I have this correct. So wish they had did step by step with pics for reassembly vs just "repeat steps in reverse order" with some notations.
    Laura Mae - 回复
  17. iPhone 6s 显示屏总成更换: 步骤 17 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 17 中的图像 2,2
    • 使用撬棒将电池接口铁片与主板从插槽分离,避免操作中不小心接触到电池。
    If you remove the grey bar with the word “TAPTIC” next, removal of the battery adhesive is much easier. It can be pulled straighter back with less chance of tearing. Here’s an image with the securing screws identified.
    If you securely anchor the screen to a can of soup, it is not necessary complete step 16 Front Panel Assembly. I was able to remove the two bottom (1.2 mm) screws and the 2.8 mm screw, but could not get the upper (1.2 mm) screw. I was able to remove the old battery with the Front Panel Assembly left in place.
    Edward Dziuk - 回复
    Amazing tip Edward, I followed your tip exactly and agree to definitely remove the “TAPTIC”
    italianchick99 -
    Hi what it is called black cover between battery connector and sim card tray? Thanks
    Rajendra - 回复
    How in the world does one reapply the edge adhesive without making a mess?
    gary - 回复
    I misread the directions and pulled off the whole large sheet first. I was able to align the bottom of the smaller sheet into the edge of the phone and get the adhesive into the right area. It was a little tricky but once it dropped down it was in the right place. I would have liked an indication of which was top and which was the bottom of the adhesive. The corners seemed slightly different and I aligned the bottom ones carefully.
    Diana Riddle -
    the new battery from ifixit came with a dented connector and wont connect to the logic board. What do I do?
    Adam Frederick - 回复
    are you suuuuuure you didn’t dent the connector? i know if i had received a battery with a dented connector, i’d immediately contact the seller so you probably dented it yourself and now you’re trying to trick all us but we’re on to you.
    unibody deluxe -
  18. iPhone 6s 显示屏总成更换, 前面板组装: 步骤 18 中的图像 1,1
    • 卸下前面板排线固定板上的4颗Phillips螺丝。
    • 3颗1.2 mm螺丝
    • 1颗2.8 mm螺丝
    Thank you for this great guide!
    I was able to skip removing the display assembly and logic board steps and lay the speaker upside down on the bottom edge of the logic board without putting undue pressure on the antenna cable making this a much easier and quicker repair for me. If you choose to leave the display assembly connected, I recommend using a rubber band to hold it to a box of similar size at a 90 degree angle to prevent damage and stress to the attached cables.
    So, the steps I skipped were Steps 16 through 34 and Steps 37 through 45.
    scentaur - 回复
    You need to remove the screen completely if you want to replace the adhesive gasket around the outer phone edge.
    Glen Paetz -
    The 1.2mm screw in the top left corner is refusing to come out, any help?
    Harry Allinson - 回复
    I’m also having this issue now, what did you do to get the screw out?
    Belmin Husanovic -
    Sounds common but no solution? I keep working at it but no luck. Anyone find a way in the last few years?
    Kurt Mickelson -
    There’s no trick… Make sure you’ve got the right driver, press down HARD, and crank it. If it’s stripping, check your driver and consider moving up one size. Resources: Screwdriver Best Practices & How to Remove a Stripped Screw - Good luck!
    Jeff Suovanen -
    Bullshit theres no trick, use a small magnet, or whatever size u have,
    mxcombust -
    why does the battery fix kit not include the #00 bit needed to unscrew all 3 1.2mm screws?!?! !#^&@@ off.
    robertdjclark - 回复
    Either a #00 or a #000 bit should work fine here. Some #0 bits will also work if the point is fine enough. Same goes for a lot of JIS bits. As long as it doesn't strip or slip, you're good.
    Jeff Suovanen -
    My kit's screwdriver failed about the time I got to the last few steps in this tutorial. I had a cheap precision set with a #000 bit but that refused to seat in the screws. I went to Home Depot, bought a lifetime guarantee Husky precision set with #0000 through #0 bits and that worked beautifully on every screw.
    David Shaddock - 回复
    The screwdriver in my kit doesn't remove the bottom two screws! any reason why?
    anujfolsom - 回复
    I actually followed all the guide but isn’t the front panel disassembly skippable? And if so what are the benefits of removing it? Cause i had quite a hard time putting back in the connectors of the 3 flex cables.
    GiovanniB - 回复
    You need to remove the screen completely if you want to replace the adhesive gasket around the phone’s outer edge.
    Glen Paetz -
    I have the 6s from Dubai. the top left screw is different with the rest. I am stuck on this screw. i am clue less why this top left + screw.
    Anyone have the same issue?
    Evander Lorenz - 回复
    A precision screwdriver set is a wise investment for doing any of this work. I got a set from iFixit that is very well machined. Don’t expect the cheap drivers with kits to last more than one disassembly-assembly, if that! Also don’t keep mangled bits or drivers…throw them out!!!
    Peter Bovey - 回复
    what crews  should I use in this step PH000. OR Y000 OR P2 Plz help me
    mshary alzhrany - 回复
    The kit provided with the replacement Battery of iPhone 6s does not include the right bits to remove the three 1,2mm screws! I had to remove it without removing the display.
    Matthias Wagner - 回复
    I too experienced a problem with the size of the screwdriver here (supplied in the iFixit kit.) My phone also had a 5th screw right in the center of the plate - another 1.2mm. I removed and replace it without problems.
    Scott Young - 回复
    @scottvyoung Sounds like you’re working on an iPhone 6. These instructions are for the 6s.
    Jeff Suovanen -
    Screws are very small and very difficult to put back in!! Lost 2-3 screws
    Put phone back together and of course doesnt work Waste of Money!
    Thomas Kintigh - 回复
    I purchased a “screw set” for an i-Phone 5 and have slowly been cannibalizing it whenever I lose a screw. It has been invaluable and the set includes enough screws that I have been able to cover all that have been dropped and lost for 3 i-Phones now. Using a magnetic mat has also limited my screw loss considerably! All of these items were purchased through IFIXIT at very reasonable cost. Thank you IFIXIT!
    Peter Bovey -
    The ifixit kit supplied screwdriver for the display cable bracket did NOT fit. (disappointing) So, I used scentar’s (comment above) method of a large rubber band wrapped around a book weighted kit box to hold it at 90 degrees. Leaving the screen attached and then removing and replacing the battery.
    laffinbuz - 回复
    I had a problem reassembling the iPhone, my touchId wasn’t working any more even if the home button was working correctly. I don’t know why but loosening these 4 screw a bit made it work again. If I tight them again it doesn’t work. Maybe this can help someone.
    Alex Mufatti - 回复
    @alexmufatti I had the same exact issue and luckily came across the same solution by trial and error. However a few weeks later Touch ID suddenly stopped working again and I think it’s the same issue. I was hoping somebody came across a more permanent solution.
    Michel Chemas -
    I was nervous not following this guide step-by-step, but as others mentioned I did not have the correct ‘bit’ size to remove the 3 screws circled in ‘red’ in the above diagram. I skipped steps 17, 18, 19 BUT used the ‘tip’ in step 11 to prop the front screen without removing the front display completely and I was still able to replace battery.
    italianchick99 - 回复
    how to measure the screw? from the head or from under the head?
    Balieltello - 回复
    Measurements in the guide are for the entire length of the screw, including the head, as measured with an ordinary digital caliper.
    Jeff Suovanen -
    I was unable to remove the display cable bracket. Therefore I was unable to remove the display, which meant I couldn’t replace the screen seal. ☹️ The small Phillips bit seemed too pointed so it couldn’t get into the screw deep enough to grip. The second Phillips bit was too big. It makes me wonder if I got the correct tool kit with my battery replacement kit.
    Mark Morris - 回复
    The display does not have to be removed! If you secure it in place with a rubber band as advised (actually one at the top and one at the bottom works best - stops the bottom half of the phone sliding towards you) , it will quite happily sit there while the battery is replaced. It’s definitely better not to have to remove and reconnect those display connectors!
    J-P jpfromadelaide - 回复
    I’ve done this with an iPhone 5 and an iPhone 6S. I did not remove the display either time; I was afraid of damaging something unnecessarily. It’s definitely not necessary to remove it! I had an extra set of hands and eyes to help me be careful, but if you get the battery adhesive strips off cleanly, it’s easy to leave the display on.
    Matt Burleson - 回复
    I skipped 17 to 22 as I was not redoing the perimeter glue. Worked well for me, except the phone will not be water proof.
    Keith Paget - 回复
    no need to remove the display. I did not even secure it..just did the replacement carefully. All worked out well. Also unless you are planning on submerging the phone in the water replace the perimeter glue. Otherwise it works just fine with out it.
    Igor Kapitanker - 回复
    Perfect. I followed the instructions and it worked to a "T". For the critics who don't know, the screwdriver handle is magnetized and will hold the tiny screws in place while you remove or insert them. After the battery replacement the phone seems to be going through some type of setup. I'll wait and see what happens after its charged to 100%.
    Bob Harris - 回复
    The "Three 1.2 mm screws" seem to be particularly fragile either that or the PH00 and the PH000 are the incorrect drivers - this part of the guide should be clearer on what driver should be used as every time I touch these screws I seem to strip them 😩
    Hope this helps
    Regards
    Lewis Dexter Litanzios - 回复
    IMHO this is not neccessary.
    A Guy Called Guy - 回复
    I took A Guy Called Guy's advice and skipped this entire Front Assembly Step and went straight to Step 23.
    Kelly Archer - 回复
  19. iPhone 6s 显示屏总成更换: 步骤 19 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 19 中的图像 2,2
    • 从主板上取下前面板排线固定板。
    What can I do if one of the screws get stripped?
    Zoe Shadzad - 回复
    Mine has an additional 1.2 mm in the center of the cable bracket.
    Romke - 回复
  20. iPhone 6s 显示屏总成更换: 步骤 20 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 20 中的图像 2,2
    • 使用撬棒或清洁干净的指甲来断开前摄像头排线接口将其与主板分离。
    Note carefully the order that they are removed.  My new display had them in the WRONG order and I spent about 2 minutes trying to figure out what was wrong until I compared the new screen with the old screen and saw that they were in wrong sequence.  Fortunately they were relatively easy to fold out of the way and put them in the right order.  After that they popped right into place.  The new cables don’t have the “fold” yet so display had to be held at 90 degrees until all three were installed and the cover reattached.
    David Rogers - 回复
    I pop up these screen connectors using my fingernail. After doing a lot of repairs, this is the easiest and fastest way to get them loose.
    Kenneth Hilstan - 回复
    pad under earspeaker is lost, where to buy?
    Balieltello - 回复
    For me, both the camera flex cable and the digitizer cable from step 20 came out together. Made me wonder in step 20 where was the cable I needed to release :-)
    Jean-François Schmitz - 回复
    Are there any tips for plugging the connectors back in, besides don’t push on the center of the digitizer? It felt like I could really mess up the pins if they weren’t aligned correctly and I tried to push them in too firmly.
    Diana Riddle - 回复
  21. iPhone 6s 显示屏总成更换: 步骤 21 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 21 中的图像 2,2
    • 断开传感器排线使其与主板分离。
    • 重新组装传感器排线时, 请注意不要按压传感器中间的地方。正确应该是先按压一边, 之后再按压另一边, 因为若按压中间的地方, 可能会使零件变形, 造成传感器损坏。
    I can't seem to get the digitizer cable to snap back into place. Any suggestions?
    gbmazur - 回复
    Yes--if you, like me, could not get the digitizer connector to seat, you've probably got confused on the reassembly order. I had to remove the EMI shield (seven screws), and reinstall it ON TOP of the big flap tongue that comes with the new digitizer, rearranging the order of the connector tails. Note that one of the connectors is a bit shorter than the other, and one of the receptacles on the iPhone is shorter as well. Make sure you're laying down the tails and connectors in the right order when you reassemble! The display data cable--sideways to the others, toward the outer edge, goes first. Then the longer connector, and finally the shorter one. When they're seated, they're seated, and you'll be sure of it.
    David Shaddock - 回复
    Patience. I had trouble but after some time got it back in. Didn’t have to rearrange anything like above ^. Maybe the design was changed.
    Cbirdsey - 回复
    I have no audio through the earpiece after completing the process. I have removed and reseated all cables several times. What’s wrong?
    Tobin Antpusat - 回复
    Same problem…. any suggestions?
    Antonio Sacchet -
    My touch id does not work anymore after battery replacement. Can it be that its due to badly connected digitizer cable to connector? Everything else seems to work perfectly. Thanks
    cyp - 回复
    I can get one end of the thing to fit in to place, and then when I move over to push the other side down, the first side pops back out.
    Samuel Martin - 回复
    I've got the reassembly order backwards and installed the battery first, and the digitizet seccond. I think I fried something, because smoke came out of the socket. Can anyone tell me what needs to be replaced?
    Christiaan Erkelens - 回复
  22. iPhone 6s 显示屏总成更换: 步骤 22 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 22 中的图像 2,2
    • 在此步骤中断开或重新连接排线之前,请确保已断开电池的连接。
    • 断开显示排线将其与主板分离。
    I notice there are 3 flex cables, does this disassembly guide apply to the verizon version of iPhone 6s? I don't want to order the wrong digitizer screen for my new and improved iPhone that i somehow managed to crack the screen on.
    Bailey Duncan - 回复
    There are four cables to disconnect here to complete this process, at least on my phone. The replacement screen also had 4, so no problem.
    Scott Young - 回复
    My replacement screen had only two connectors while the old screen had 3. I sent it back for replacement. Not sure what went wrong here, because everything else fit perfectly. So what model could this replacement screen have been intended for?
    Martijn Vos -
    I am having a hard time reattaching the LCD cable. Is it possible I bent the connectors? Or possibly the gaskets around it are interfering? I’d like to just pull all of that waterproofing gasket off! >:(
    Amanda Cooper (Doula) - 回复
    Did you end up going this? My screen is black so I'm trying to figure out what i did
    Alex Tanner -
    I neglected to detach the battery before taking this step and upon reassembly I have no display. What might be my next step to repair.
    Dennis Gagomiros - 回复
    You can try reseating the cables, but the likely answer is that your logic board’s backlight circuit is blown. If you power on your phone and you can see an image on the display by shining a bright light on it, your backlight circuit is toast. This is a common repair and very fixable, but requires microsoldering equipment and expertise. It’s not a DIY.
    Jeff Suovanen -
    I made the same mistake and I'm wondering if you got a fix for it? Is the damage done on the screen assembly or phone itself?
    goesprotocall -
    My screen replacement only comes with two flex cables but all of the videos are showing three. It is not working to connect the flex cables to the connectors
    cellabella1 - 回复
    The third flex cable would be for the front-facing camera, sensors, etc. If you bought a display that doesn’t include those components, you’ll need to transfer them to your new display first, and then you’ll be able to install it and plug everything in. The instructions are over here. Good luck!
    Jeff Suovanen -
    The important warning about making sure that the battery is disconnected may be more beneficial at the BEGINNING of these instructions.
    ffissk - 回复
    I mean if you follow the guide it literally says to disconnect it first. Step 15
    Nick -
    There are four cables to disconnect here to complete this process. My replacement only got 3, what should i do?
    Vincent Ladida - 回复
    I work for Jabil building the rudder for the F-35 & THIS seems so aggravating ! I’m leaving this to someone experienced, doing it over & over again!! Gives someone a job too! Some things are just worth paying for!
    Kathleen Konecek - 回复
  23. iPhone 6s 显示屏总成更换: 步骤 23 中的图像 1,1
    If you're replacing the adhesive, be sure to check the two tabs on the display that receive the pentalobe screws before setting the display on the new adhesive. The tabs on my display were bent inward slightly—just out of reach of the pentalobe screws. I didn't bend these out before setting the display and was forced to re-open the display to adjust them, ruining my carefully placed adhesive.
    cdinger - 回复
    There is no need to remove camera or the logic board if all you want to do is replace the lightning assembly. Leaving things in place will save you a number of steps. Proceed directly to Step 35 and save yourself all this work.
    Ira Goldman - 回复
    Also read comments on step 37 as others have also pointed out that there is no need to pull logic board and you can skip those steps mentioned.
    Ira Goldman - 回复
    Unless you are replacing the speaker you can skip to step 34 as there is no need to remove the logic board.
    Bryan Solo - 回复
    My replacement display was not functional, but I didn’t test it until after my adhesive was already applied. Might be worth double-checking the replacement screen works before applying the adhesive at all. (though I’m glad I tried it before closing it up!)
    Ben - 回复
    When reconnecting to the logic board, reverse the order, so display first, then digitizer and finally camera. The front pannel slides into small edge of the backchannel. So start at the top when you put front and back together.
    Joep Willemsen - 回复
    be sure battery is disconnected before reassembling the display —in case you reconnected it to position battery
    Christa - 回复
    If reapplying adhesive, I would strongly recommend that you wait until you are reassembling the phone. Otherwise, trust me, it gets really sticky and limits your mobility around the phone. I had it all over my fingers by the time I finally got the old battery out and the new one in.
    Justin Tilghman - 回复
    Removing the battery was a challenge as the old adhesive snapped before it came out so I had to use a hair dryer to warm the adhesive before slowly peeling the battery off. I still manage to puncture the batter and nearly had a fire. When inserting the new battery I didn’t leave enough room for the connector to fit beside it so I had to pull it off, plug the connector into its port, then insert the battery. I think the instructions should warn you to leave enough room for the connector to tuck in beside it.
    The kit came with a new adhesive gasket but I could not find the instructions on how to install it. But after 45 minutes I had it done and my iPhone 6S is back in working order. Don’t forget to ‘hard’ reset the phone on start up, run the new battery all the way down. Otherwise this is a very good value time and money wise.
    Ramon Pabalan - 回复
    I preferred not to use the adhesive edges around the phone, as this makes replacing the battery in future more time consuming. My iPhone works fine without the adhesive.
    Mark Morris - 回复
  24. iPhone 6s 显示屏总成更换, Home键组件: 步骤 24 中的图像 1,1
    • 移除3颗固定home键托架的1.7 mm Phillips #00螺丝。
    • 不要把螺丝拧得过紧,这样有可能会损坏显示屏。
    When reinstalling, I had to experiment with how tightly to turn the screws, I first turned them all the way in but the home button wouldn't 'click' at all then, so I loosened the left most screw a touch and now it clicks and feel perfect. Not sure which screw is technically the best to adjust.
    amadscientist - 回复
    When reinstalling the screws be careful not to over tighten and strip the holes.
    John Livingston - 回复
    INCOMPLETA
    Manca tutta la parte che riguarda l’auricolare (altparlante o earpiece) che porta con se il rivelatore di prossimità e il microfono ambientale. Manca la descrizione delle plastiche da recuperare per essere riportate sul nuovo display. Manca la parte di separazione del touch controller dl backframe metallico (anch’esso da svitare e non menzionato in questo articolo…)
    Insomma un tutorial incompleto e anche inutile, a mio avviso.
    Mario Di Stefano - 回复
    When i assembled my new homebutton, I couldn’t mange to make it work properly. The screws, as described earlier, had to be adjusted but even this wasn’t enough. Once I put the iPhone case together and tightened up the screws it would push the metal cover all the way so the button wouldn’t click. After trying multiple screw settings I came to a somewhat unorthodox solution. I placed a piece of folded paper under the left corner of the metal cover. Now it wouldn`t press the button anymore and the paper keeps everything in place until fully reassembled.
    max - 回复
    Is this step necessary if you weren’t able to make the fingerprint recognition feature ever work in the first place?
    Neil Bass - 回复
    Hi Bub, you look marvelous. Guess what? your ifixit screen  didn’t come with a button so ha ha, it is necessary. But you my man are lookin so fine. Bye.
    Neil Bass -
    Totally necessary, as you found, but even if you had a new home button, it wouldn’t work, because the Secure Enclave information that encrypts the storage is stored within that assembly, so if you put in a new one, you’re not getting to the storage on the device anymore.
    johnjustinirvine -
    Yeah, super light on the screws here when you put them back in. I have a bit of stage lighting right over the screw area, so I’m thinking that’s coming from being put in just a tiny bit too tightly.
  25. iPhone 6s 显示屏总成更换: 步骤 25 中的图像 1,3 iPhone 6s 显示屏总成更换: 步骤 25 中的图像 2,3 iPhone 6s 显示屏总成更换: 步骤 25 中的图像 3,3
    • 将home键托架较低的那端轻轻扳起, 直到可以看到在右边的小钉。
    • 将托架从EMI电磁防护板底下移出。
    You have to lift it just a bit over the grey plastic knob on the left side.
    Martin Born - 回复
    My Home-Button was kind of “fixed” and didn’t “klick”, after I’ve reattached the Home-Button-Bracket and fixed the screws. Solution was, to slightly bend the bracket “away” from the Home-Buttons klick-dot.
    Robert Hoppe - 回复
    Thank you! Just a comment: when reassembling, I found it easier to slide the bracket from the bottom up (not from right to left) as the third image here may imply.
    jaderzelaya - 回复
  26. iPhone 6s 显示屏总成更换: 步骤 26 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 26 中的图像 2,2
    • 使用撬棒将home键排线连接器撬開,使之从home键脱落,以此来断开home键连接器的连接, 使之从前面板脱离。
    Make sure you're not heating it before you've popped the connector from its socket or else the socket might come loose.
    Sam Decrock - 回复
    You may need to use 2 picks/spudgers to do this as I have found that the socket and connector do not disconnect so easily. Place 1 on the socket and use the other to disconnect the connector.
    Bryan Solo - 回复
    Thanks, Bryan this helped a lot.
    Antonio Gomez -
    Yes, I was glad I was changing both screen and battery so had two repair kits and two picks. It helped to separate that connection carefully with two tools.
    Diana Riddle -
    When I did this step, the home button connecter tore right off at the bend in the thin ribbon. Not sure how - I got through other somewhat delicate steps in this project without damaging anything.
    Anyway, phone won’t even power up now (I put it back together hoping that I could navigate around the interface somehow without home button).
    New home button assembly on order from iFixit.
    John Matz - 回复
    I think it broke because there’s some adhesive right under where the thin neck joins to the casing. I did the same!
    Chris White - 回复
  27. iPhone 6s 显示屏总成更换: 步骤 27 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 27 中的图像 2,2
    在这个步骤中使用的工具:
    iOpener
    $19.99
    购买
    • Home键周围的橡胶垫圈非常薄且容易撕裂。
    • 使用温热(包括使用 iOpener 、热风枪、吹风机)来软化固定 Home 键垫圈的粘合剂。
    • 用你的指尖轻轻地从屏幕正面向上按 Home 键。用恒力将 Home 键的橡胶垫圈与前面板慢慢分开。
    What happens if the gasket ends up as toast? I had to re-assemble without and hope for the best.
    Todd Strack - 回复
    I think its main function is to keep moisture and dust out. Short-term probably nothing bad will happen; long-term, I’d guess you might have higher risk of contamination or corrosion on internal components.
    Jeff Suovanen -
    The video shows the the tech heating the bottom at this so it releases easier. I heated mine with a hair dryer. Came off fine.
    Patrick Egan - 回复
    Also remember to check the front and make sure any tape you applied is not covering the button. Doh!
    Steve Esson - 回复
    I also used the pointed spludger to gently pry up the rubber gasket after heating the backside with a hairdryer
    robert langley - 回复
    When reassembling, my button has become somewhat less responsive. The finger print works fine and the button clicks when pressed. But sometimes when clicking, it responds immediately, but other times I have to continuously press the button or press really hard. Any tips or ideas what I might have done wrong??
    zed0132 - 回复
    Slow and steady is the name of the game here. Heat it with a hair dryer, push the home button up through the bottom (as if you were pressing it, just a little harder), and keep heating it while you have it stretched. Eventually it will sort of snap out on one side, and then slowly work the pressure from underneath around the edge.
  28. iPhone 6s 显示屏总成更换: 步骤 28 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 28 中的图像 2,2
    • 使用撬棒尖头那端,将 Home 键曲型排线与屏幕面板小心地分开。
    When replacing the ribbon cable assembly, make sure to get the “blob” correctly centered over its two pin holes. One is ringed with metal, and one isn’t. When you have the blob over the pin holes, it helps to align the connector correctly. Once the blob is in place, push back the edge of the connector facing up toward the base of the screen until it snaps into place behind a little plastic ledge just above the blob. Once that’s done, reconnecting the top cap is much simpler.
  29. iPhone 6s 显示屏总成更换: 步骤 29 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 29 中的图像 2,2
    • 将home键取出。
    If you’re purchasing a replacement front panel part from ifixit, you can stop here. The remaining steps remove parts that are included with the replacement assembly.
    I have two i phone 6s both screen are broken,so can you please replace them with any type of i phone….
    Please..
    Thank you.
    Lokesh pandit - 回复
  30. iPhone 6s 显示屏总成更换, 内置听筒: 步骤 30 中的图像 1,1
    • 从听筒扬声器/前置摄像头支架卸下Phillips #00号螺丝
    • 二颗2.3mm螺丝
    • 一颗1.3mm螺丝
    are you sure it's long, short, long. From what it looks like, it's long, long, short.
    garegin - 回复
    Yup, you're right! We've updated the guide accordingly. Thanks for the heads up.
    Evan Noronha -
    its not 1,3mm ! its 1,9mm
    Boni Zei - 回复
    The "1.3mm" seems closer to 2.3mm to me so 1.9mm may be correct..?
    What part is the connection that connects this called ?
    Alfonso Estrada - 回复
    1.3mm is definitely too small. I had lost this screw and when I tried to put a 1.3mm screw in, the threads wouldn't catch. 1.4mm was the smallest that would fit. 1.9mm also worked so that's what I used. Seems like it would be more secure than 1.4mm.
    Benjamin Rose - 回复
  31. iPhone 6s 显示屏总成更换: 步骤 31 中的图像 1,3 iPhone 6s 显示屏总成更换: 步骤 31 中的图像 2,3 iPhone 6s 显示屏总成更换: 步骤 31 中的图像 3,3
    • 將听筒扬声器支架向上扳起, 并将支架上的垫圈剥离。
    • 由于垫圈非常的薄且容易撕坏, 因此. 在剥离垫圈的时, 要非常小心。
    I temoved the gasket while changing screen. What does the gasket actually do? Is it necessary?
    Atte Veijola - 回复
    Also removed gasket while replacing screen. The phone is now in a startup loop. It won't turn on while unplugged- when plugged to wall outlet, it starts to point of displaying Apple logo then restarts. Could this be a cause?
    foibuls - 回复
    Gasket thing literally does nothing. Couldn't get it back on properly so I peeled the flimsy thing off. No issues with my phone at all.
    Jaspal Goshal - 回复
    Gasket does not seem to have any connection or logic. I just let it be when I could not fit it. Worked fine.
    Niklas Magnusson - 回复
    Isn't the gasket some sort of water resistant seal?
    Nick Stine - 回复
    Gasket always breaks during reinstalling but so far no negative effects.
    Steve - 回复
    I couldn’t fit the gasket back around the metallic piece it surrounds. It run short and I couldn’t reach the bracket screw hole with the gasket screw hole so I left it loose. Everything seems to work fine. But I guess it is there for some reason so I am a bit uneasy….
    Homero - 回复
    I’ve never gotten this rubber piece on without it ripping . I’ve never had a problem with the operation of the phone upon reassembly. I wouldn’t worry about it.
    mcr4u2 - 回复
    A little bit of heat and gentle, patient tugging from both directions with my tweezers got the gasket out whole (although from the sounds of the other comments it is not important).
    Thomas Hayes - 回复
  32. iPhone 6s 显示屏总成更换: 步骤 32 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 32 中的图像 2,2
    • 使用撬棒平面那端, 将前置摄像头轻轻撬开。
    It took me a while to realize this while reassembling, but my replacement screen didn’t have a “housing” for the front-facing camera. I finally spotted a clear plastic piece in the broken screen, which provided a circular collar that was the camera housing. I was able to take it out and snap it into the equivalent spot on the replacement screen.
    Richard - 回复
  33. iPhone 6s 显示屏总成更换: 步骤 33 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 33 中的图像 2,2
    • 拿起前置摄像头,来取出内置听筒 。
    • 取出内置听筒 。
    Can I replace the iPhone 6s earpiece speaker with my phone iphone 6? The newer earpiece speaker seems more advanced.
    Yaser 777 - 回复
    I have the same question. They look like the same speaker. Are they compatible?
    The Wizard - 回复
    The problem might not be the earpiece speaker! I replaced mine and had no improvement in quality. After reviewing forums, I suspected the earpiece screen was dirty/plugged. I disassembled the phone again, removed the earpiece speaker, carefully scraped and poked at the earpiece screen until a flashlight revealed the holes were clear. After a quick reassembly, playback of a voicemail verified full volume has been restored. Since you’re in there anyway, whether the problem is the screen or the speaker, clean the screen and replace the speaker.
    toddniehaus - 回复
    Reassembly of this stage took me two goes to get right. Take care to ensure that the speaker connecter strip is properly aligned over the pegs.
    Keith Garbutt - 回复
  34. iPhone 6s 显示屏总成更换, 前置摄像头与光线传感器组件: 步骤 34 中的图像 1,2 iPhone 6s 显示屏总成更换, 前置摄像头与光线传感器组件: 步骤 34 中的图像 2,2
    • 拿起前置摄像头, 并使用尖头撬棒按压卡槽, 将光线传感器与前面板分离。
    Don’t forget the little white rectangular light diffusing (I assume) mat that goes between the ambient-light sensor and the screen if your replacement doesn’t have it!
    Brian Seavey - 回复
    Or if your replacement screen does have the clear plastic part (light diffuser?), then don’t forget to remove the one from the sensor assembly - not doing so makes it very difficult to replace the assembly…
    Kev Salmon - 回复
  35. iPhone 6s 显示屏总成更换: 步骤 35 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 35 中的图像 2,2
    • 将前置摄像头与感应排线握住, 方便接下来取下麦克风。
    The light sensor cable is unclear: the connection cable must be bent by 180 degrees, so that the flat side is looking outside (optical active side)? Or is the opposite sensor side with the hole the optical sensitive sensor ?
    Norbert Holzki - 回复
    When I reinstalled the assembly I had to bend the tiny cable the connects the microphone to the main cable so the gold side of the microphone faces up (to the inside of the phone). The next step in the reinstallation has you installing the ambient light sensor and ambient light sensor. You will need to bend the tiny cable that connects the ambient light sensor 180 degrees so it fits into the recess!
    wmetzgerusa - 回复
  36. iPhone 6s 显示屏总成更换: 步骤 36 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 36 中的图像 2,2
    • 使用撬棒平面那端, 轻轻将麦克风与前面板的黏胶分离。
  37. iPhone 6s 显示屏总成更换: 步骤 37 中的图像 1,1
    • 将前置摄像头与感应排线取下。
    iPhone 6s microphone has a small rubber speaker gasket attached to it. not shown in this picture
    Jeremy Hudson - 回复
    thankscfor letting me know
    Seizure Salad - 回复
    I think that rubber gasket is what you are trying to peel the microphone away from. In my phone, the gasket is part of the earpiece grill. My screen replacement included a new replacement earpiece grill with a new gasket on it, and new adhesive, so I did want to peel the old one off as shown here.
    dnkeys - 回复
  38. iPhone 6s 显示屏总成更换, 屏幕EMI电磁防护板: 步骤 38 中的图像 1,3 iPhone 6s 显示屏总成更换, 屏幕EMI电磁防护板: 步骤 38 中的图像 2,3 iPhone 6s 显示屏总成更换, 屏幕EMI电磁防护板: 步骤 38 中的图像 3,3
    • 移除图中7颗1.3mm的Phillips螺丝,
    • 在屏幕的左右两侧, 分别有3颗螺丝。
    • 另外1颗单独的螺丝在屏幕右侧约1.5cm的地方。
    What's the deal with these particular screws? I have found them much much harder to remove than the equivalent screws on any previous iPhone model. Am not sure if it's the head groove shape or if they are just secured very tightly. More than once I have ended up completely ruining the head grooves without getting them out. Any tips?
    Lars - 回复
    Lars, I have no idea why these are so stubborn, but I agree with you 100%. When removing these guys, I usually set the screen vertically on my work surface so the screws face straight up, then apply as much pressure as I possibly can to ensure the driver head doesn't slip even once. 90% of the time I bend the metal clips a little bit, but that usually doesn't matter to me since the new display has new clips.
    Evan Noronha -
    I had such a probem with one on each side closest to the home button.... Unfortunatley I used wire cutters to remove the screw completly. The assembly was not effected nor the functionality of the phone.
    Jaredrett - 回复
    When reassembling, I'd hold off on assembling the EMI shield until after the home button shield is reinstalled--just hold off on the one screw that installs both. This eliminates having to try to finesse the home button shield underneath the EMI shield, and also makes it easier to get the three connector tongues at the camera/earpiece/speaker end in the correct order for reassembly.
    David Shaddock - 回复
    As you apply pressure on the screw it bends the clips in slightly binding the screws, I found placing my thumb nail on the back of the screw to counter the pressure required to screw them in/out prevents the binding and they glide right out.
    Dan Scheive - 回复
    “1.5 cm” Needs to be changed to 1.5mm
    iHelpU.Tech - 回复
    Mr. Meinhart. 1.5 cm is right as it refers to the distance from the edge of the screen to where the screw is. It does not refer to the size of it.
    nelsongilm - 回复
    These screws are 100% impossible to remove. I have applied as much pressure as I can without completely destroying the component but nothing has worked. I know I have the correct size driver too. This is beyond frustrating. The 4 screws that are left in are now stripped. Any ideas would be very appreciated.
    Cody Fridley - 回复
    On two of these I have stripped the head out because Apple over-torqued them at the factory. Now I have to either cut the whole clip off or else take it to the garage and use a tiny drill bit to try and drill the head off the screw. Surely nothing will go wrong when a 10-amp drill touches the screen, right??
    maxarre - 回复
    Note the the screw that is 1.5cm from the right is smaller in diameter than the other 6 (it is the same length)
    Chris Hammerton - 回复
    I used WD40 on these damned screws and it helped. Putting the screen vertically on the edge of the table while removing them also helped.
    Supa tamraksa - 回复
    I hooked the display over the side of my table to support these 6 screw tabs from bellow and they were fairly easy to remove from my late in the run 6s (maybe the factory quit torquing them so hard?) Also, I had a small washer under the last screw 1.5 cm from the edge. Almost lost it since I wasn’t watching for it.
    dnkeys - 回复
    There were two screws which I couldn’t remove no matter what. I was forced to rip apart the metal with pliers until the screw was forced off. This took literally an hour to do. So annoyed.
    Joe Clinton - 回复
    Be carefull when you unscrew the orange one near the frontal camera slot, i did it verrrrrrry gently but the screw and part of the EMI’screen just fall apart! do it like if you were tring to pet an ant!
    Wissem Ben - 回复
    the screw at the side is not 1,5mm ! its 1,33mm - 1,34mm ! thx
    Boni Zei - 回复
    There's a 7th screw on the EMI shield right by the camera.
    michael - 回复
  39. iPhone 6s 显示屏总成更换: 步骤 39 中的图像 1,3 iPhone 6s 显示屏总成更换: 步骤 39 中的图像 2,3 iPhone 6s 显示屏总成更换: 步骤 39 中的图像 3,3
    • 你需要准备一个iOpener, 将iOpener置于手机顶端的边缘处, 让黏在EMI电磁防护板与前面板的黏胶软化。
    • 加热一分钟后, 在胶带与屏幕间插入塑胶片, 。
    • 将塑胶片往下推, 直到碰到EMI电磁防护板的上缘为止。
    The 6S I was working on didn't have any adhesive under it and the EMI shield came off easily.
    David Shaddock - 回复
    This explanation is terrible. The pictures are terrible. There seem to be two layers to the heat sheild. What needs to be removed? One or both??!!!
    mamashannon4u - 回复
    On my phone there was a second piece of tape like in step 38 below. Peel this up ,move onto step 38 and u r good to go..
    Steve - 回复
  40. iPhone 6s 显示屏总成更换: 步骤 40 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 40 中的图像 2,2
    • 使用镊子, 将前置摄像头附近的EMI电磁防护板上的胶带剥离。
    my iphone has a small connector immediately below this piece of tape. it seems to be attached with a little adhesive and I was able to carefully pry it up. peeling up the tape was unnecessary for me
    jjinatlanta - 回复
    My 6s had a second piece of tape on the opposite side as well. I had a really hard time getting both of these off intact, then realized that if you are replacing the glass/digitizer, these piece of tape are not reused. So you could just cut them to leave an overhanging tab from the EMI shield, then peel them off the EMI shield after it’s been removed.
    dnkeys - 回复
  41. iPhone 6s 显示屏总成更换: 步骤 41 中的图像 1,2 iPhone 6s 显示屏总成更换: 步骤 41 中的图像 2,2
    • 卸下EMI电磁防护板。
    • 在组裝EMI电磁防护板时, 将金属切口那边 (在底部中间的地方) 置于屏幕排线组件的上方, 直到胶带滑到后方的时候。
    I was confused by this instruction, and didn't realize until much later that the EMI shield has to keep the display cable assembly down against the digitizer, so you don't see the gold fingers/pcb traces at all when it's installed. I had to remove my EMI shield again and reassemble it, but that ended up being easier because the camera/speaker/ambient light sensor/etc. was already installed and I could get the three connector tails to stick out in the correct order for reassembly.
    David Shaddock - 回复
    Make sure when you put the EMI Shield back on, that the home button connector socket is not tucked beneath the shield. I got to the home button replacement step and I couldn’t find the socket to connect the connector with!
    Joe Clinton - 回复
  42. iPhone 6s 显示屏总成更换, 显示屏总成: 步骤 42 中的图像 1,1
    • 最后只剩屏幕和触摸。
    I had some difficulties putting a new screen gasket on. I found this video on youtube which is really helpful https://www.youtube.com/watch?v=g5ZqN1pf... . Other than everything works like a charm. Thank you very much iFixit team.
    Marc - 回复
    Félicitation
    Pus clair et plus précis était juste impossible
    Un “pros ??” avait déjà réparé ce téléphone il aurait été bien inspiré de lire votre tuto ça m’aurait évité que je retrouver le joint de caméra avant avait été cassé !! et une vis du blindage en vrac a l’intérieur !
    Un très grand MERCI
    Jean Luc BELLEVILLE - 回复
    Hey Marc! The youtube video which you say is really helpful is private. I can’t watch it! :(
    BeN Blazer - 回复
结论
如要组装的话, 请按逆序操作一下步骤。
466等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Evan Noronha
于02/05/15注册
223,418 声望
创作了168篇指南
50条评论
Swapping out the home button/main board flex cable on the iPhone 6 disabled TouchID. I assume it was also digitally signed like the home button. Is this also true of the 3D Touch panel now that it supplies that cable? In short, Is the original 3D Touch panel necessary for TouchID to work or will the replacement 3D Touch panel built into the replacement work?
Joe - 回复
I've had touchID work after replacing the flex cable... I cant imagine there would be a problem with it this year...
Andrew spoelstra -
Does the 6S need the home button flex cable to be moved for touch ID to work like the 6?
John Pampalone - 回复
Nope! The home button flex cable is integrated into the display and cannot be transferred to the new one.
Evan Noronha -
And then on the Iphone 6s the original flex cable hasn't to be moved. Only the button itself because it is paired with the CPU.
revher -
I've been prying for an hour with the pro tech tool kit. I CANNOT get the display up nearly enough to get a spludger under there. is there something i'm doing wrong? yes i've completely removed both screws. Its really hard to pull up with this crappy suction cup whil pushing back on the metal casing...
keyannorth - 回复
Try using a hair dryer or heat gun to soften the adhesive holding the screen in place. Once you do that, you can try pulling up on the screen and letting it down 10-20 times in quick succession to incrementally weaken the glue instead of pulling it all up in one shot (although I assume you've inadvertently done this if you've been working at it for an hour).
Evan Noronha -
To anyone else having this issue, try inserting a thin putty knife first, then separate with guitar picks. Just be careful so you don't scrape the housing!
rka -
I had also no success with the suction cup, so I used strong tape and formed a grip with it. That worked for me.
Connected Home -
In step 37, make sure that you keep the single screw separated from the others of the EMI shield, it is thinner!
Connected Home -
Work the fingerprint when i chang the lcd ?
Gilfor - 回复
The touch ID seems to be disable with replacement screens. As mentioned above the flex cable is built into the screens this time round so assume this is why.
Robert Hayman - 回复
You can safely swap out the screen without affecting TouchID as long as you are careful to follow instructions and transfer the original home button to your new screen. If your TouchID is disabled afterwards, it's likely because (1) you need to re-seat your cable connectors, (2) you accidentally damaged the home button hardware/cable, or (3) you have a defective replacement screen.
Jeff Suovanen -
This repair guide should be rated "EXTREMELY DIFFICULT"... Better yet, it should be deleted altogether because it's misleading . There's no possible way the authors can guarantee success by following this guide.
I challenge the authors to fix (3) iPhone 6s plus screens I will provide the phones and even pay you to do it. If you can do it, I shove my foot in my mouth. If any of them come back with the Touch ID not working, then you should delete this guide because it's misleading and I know several seasoned repair technicians who have followed this guide and failed.
applerepairshop -
@applerepairshop it is possible you are using low quality replacement parts. We've tested replacement screens in multiple scenarios, and myself and a number of my colleagues have done this repair for friends and family with a 100% success rate (and we've done far more than three). I suggest switching to a new supplier to see if your luck changes.
Evan Noronha -
I cant get the home button scanner to work on any screen but the original one. I've tried 2 screen replacements. All are unresponsive when I do anything requiring touch.
joltheadq - 回复
Hi, I would modify your instructions to emphasize in bold letters that disconnecting the battery is critical. It seems that if you don't you risk turning the phone into a paperweight by lowing the fuse on the mother board.
sbstooger - 回复
Is the EMI shield tape needed? I accidentally cut mine off without thinking I need it
SOBul - 回复
Is 3D-Touch working after replacing the Display?
Hugo Stiglitz - 回复
Keep the original home button
Nick Stine -
Always make sure that you disconnect the battery on the iphone 6s and 6s plus. I have seen many 6s with blown resisters on the either the backlight power rail or the display power. Both of which usually blow the pad off as well making the phone very difficult to repair. If you would like to avoid a data recovery situation make sure to unplug the battery right away. Don't be lazy guys!
Gadget Tech - PDX - 回复
Even using my original home button assembly, Touch ID fails after installing this new assembly. I believe that iFixit's display assembly is of poor quality. This is not my first time doing this sort of repair, and I have been successful in the past. The home button link cable (the one that runs from he home button out the top of the screen assembly) is built into this unit, so there is no way to use the original one for this design as iFixit suggests on other forums. Extremely disappointed - for $50 more I could have just taken my phone to Apple for a replacement, saved myself 5 hours of frustration, and had a working Touch ID!!!
mikerudolph22 - 回复
The quality of the Phillips #000 screwdriver that is supplied with the iFixit LCD Screen and Digitizer kit is not good enough - you are VERY likely to damage (strip) some screws. I am an electronic engineer that likes to tinker, yet I managed to damage 2 screws on the EMI shield. Only reason I damaged only 2 is that I stopped and bought better screwdriver, no more damaged screws after that...
Quality of screen - very good. Touch ID working 100%.
Albert van Urk - 回复
Have just replaced a screen on one of these and the touch ID has worked fine - it was a cheap screen too. thankyou
jason bullough - 回复
I just received a replacement screen. I've transferred the home button, the front camera, the earpiece and everything to the new screen, and now my phone is bricked. It won't even turn on or charge. What could be the issue?
wyuenho - 回复
Make sure your battery is properly connected. If so, see if iTunes recognizes your phone when plugged in to your computer.
Evan Noronha -
It was properly connected, iTunes says it can't access my phone because I had to type in the passcode, but I can't, the screen is dead, and I didn't even hear the startup chime.
wyuenho -
I followed these instructions very strict and was very carefully, but now my home button does not work at all (neither touch id or the button itself) what could be the reson?
Elias Feiner - 回复
My screen replacement came assembled wrong. I have model A1688 iPhone 6S and the box I got says compatible with A1633 AND A1688. However the home button ribbon cable is missing! And the plastic border that should have placements for screws are wrong! How am I supposed to screw it in properly and how am I supposed to use my home button!!
Andrew - 回复
Losing my mind here. I know my hookup is right, but the new replacement screen and digitizer just won't light up. I can see vague traces of the app buttons, and can manipulate them, but just can’t get the darn thing to light up! I have double checked all my micro connection, to no avail. Any suggestions would be appreciated
Will Carney - 回复
when i connect the new display the touch won’t work. And if i reconnect to old display the screen is completly black (but it works since it' reacts when i plug in the charger for example. Someone who knows what the problem might be?
ronja herrlin - 回复
Why can’t I find any Display EMI Shields for iphone 6s?? I can find it for the 6 and the 6 plus but no where is the one for 6s to be found. Please help
Pieter - 回复
@evan thank you for the instructions!
Eliane - 回复
Everithing ok except the 3D touch, it is extremly sensible ¿do you know why? i have had to deactivate it. thanks in advance
jmgonzalez - 回复
thanks! successfully replaced my screen with this guide ;)
Alexander Javier - 回复
A wire from the front panel has broken.
am i able to take it off from my old panel and replace it?
Hdh - 回复
I am so excited to say that this busy mom was able to complete a full tear down and reassemble of battery and display!!Difficult but doable as long as kids are sleeping! It took full concentration on this puppy!
Grace Albright - 回复
If the replace the screen and digitizer will it fix my problem with my screen have lines down it?
Evan Dupuis - 回复
Overall, a fairly easy replacement and decent parts. After having successfully replaced the screen, I noticed that the screen quality is quite different from the original Apple screen. Everything works perfectly fine but I noticed that the screen has a slight bluer hue than the original screen. It also is less bright that the original screen. I used to leave the screen at ~20% brightness throughout the day but now I have to push it to ~50% just to get the same amount of brightness. Another major thing I noticed was that if you are wearing polarized sunglasses, the screen looks like the back-light is not on even though it is. I thought this was very odd but I guess the cheaper parts don’t account for viewing with polarized sunglasses. Now I have to take my sunglasses off to see my screen while walking which is a little bit inconvenient.
Another thing to note is that the screen works fine but doesn’t have the same response time as the original Apple screen. Definitely a bit slower but it works.
ekk1288 - 回复
Thanks for a clear guide and it worked well for me. I found that I didn’t need to heat the adhesive around the EMI shield to separate it - came apart with a little patience. Secondly, be careful how you organise the three display connector cables. It’s easy to get two of them jumbled when reconstructing the camera/earpiece and it’s easy to miss in the pictures.
Dominic Casciani - 回复
What is the purpose of the tape connecting to the emi shield? Same with the tape gasket bracket on the ear piece shield? Do they just hold things in place?
matt.halliday08 - 回复
I think everyone needs to understand that this guide is FREE..!! and very useful. I think you guys are sometimes under appreciated. Thank you for what you do guys/girls. If it wasn’t for you, I probably wouldn’t have as much extra cash as I do right now. =-)
dabair30 - 回复
P.S.
It just so happens that I purchased the most inexpensive display replacement I could find. Moved all of the old parts over to the new display (Home button, ear speaker etc..) and everything works as it should. Including the fingerprint sensor.
dabair30 - 回复
Completed it in about 2 hours spread over 2 days. Probably could do it in an hour a second time. Found a $20 (shipped!) replacement screen / digitizer on eBay and transferred all the other parts. Working great so far.
dr_fixalot - 回复
I followed the guide correctly and connected the screen to the phone, re connected the battery and the screen won’t turn on. I’ve been charging it for a while and it still won’t work. Is there any reason for this and if so is there a fix?
Jacob Marshall - 回复
Great description, grateful. “ Follow these instructions in reverse order to reassemble your device”. This comment requires a sense of humor, reassembling it properly is a lot more difficult and risky
Jan Mastenbroek - 回复
Since I replaced my LCD Screen & Digitizer on my iPhone 6s, my iPhone won’t Turn on unless I had my charger Connected & even after my Apple Logo appears on the Screen, it seems to be stuck in a Bootloop & just repeatedly just returns to Apple Logo Screen i.e “Bootloop” but only when plugged in to a Power Source it just returns to Apple Logo Screen.
Josh Slaugther - 回复
Le plus difficile est l’ouverture quand l’écran est très cassé…
Autre difficulté, retirer le joint de collage de l’écran et nettoyer avant repose d’un autre…
Pour le reste, un peu de patience et d’ordre, être très délicat et hop, que du bonheur!Merci ifixit! mon 6S plus revit et le haut-parleur est top…si j’avais écouté ce génius, tout allait bien…
gauthier - 回复
Does iPhone 6s supports iPhone 6 screen
fakhir224 - 回复
mrc dcp je vais voire si j'arrive a le reparer
grine - 回复
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 167
过去 30 天: 709
总计 362,918
