简介
此指南会教导你如何更换iPhone 6s前面板及感应器组件, 里面的组件包含有:前置摄像头, 光线传感器及麦克风等。
请注意, 内置听筒在此指南已先拆卸, 请务必将内置听筒 及排线收好, 组装时, 也请记得将内置听筒及排线装回。
你所需要的
将蓝色的手柄朝铰链的方向拉,以解除反向钳的分离模式。
将支撑臂滑过 iPhone 的左边缘或右边缘。
将两个吸盘放到Home键上方的屏幕——一个在前,一个在后(屏幕朝向自己的地方为前)。
将上方吸盘向下压以施加吸力到目标位置。
在这个步骤中使用的工具:Magnetic Project Mat$19.95
卸下电池排线固定架上的2颗十字 #00 螺丝。
1颗2.9 mm螺丝
1颗2.2 mm螺丝
如要组装的话, 请按逆序操作。
如要组装的话, 请按逆序操作。
218等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
17条评论
I replaced this connector (+camera) and now the camera doesn't focus anymore. Any idea why is that?
There is a good chance that the camera is bad. Try to rub it with a Q tip and some alcohol if that does not fix it try to clean the glass of the screen from the inside.
The old speaker works fine?
Or should be replaced with the new flex, because I read in the other tutorial here in ifixit that mentions something about the speaker an oil that these have.
I questioned this because I broke the flex of my iPhone 6s Plus trying to clean after water immersion.
miguel.f07 - 回复
Just used this guide to replace the front camera in my iPhone 6s !!! Thank you guys at iFixit ! Now it works as well as a new one! yaaaaaaay
