跳转到主内容
iPhone 6 Plus Logic Board Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iPhone 6 Plus Logic Board Replacement, Logic Board: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Standoff Screwdriver for iPhones
    $5.49
    购买
    • Remove the following screws securing the logic board to the rear case:
    • Two 2.4 mm standoff screws
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    • One 2.1 mm Phillips #00 screw
  2. iPhone 6 Plus Logic Board Replacement: 步骤 2 中的图像 1,1
    • Carefully raise—but do not remove—the logic board, lifting it from the bottom edge nearest the Lightning connector.
  3. iPhone 6 Plus Logic Board Replacement: 步骤 3 中的图像 1,1
    • Do not remove the logic board. At this point it is still tethered to the rear case via an antenna connector.
    • Continue carefully lifting the bottom side of the logic board until it is vertical.
  4. iPhone 6 Plus Logic Board Replacement: 步骤 4 中的图像 1,2 iPhone 6 Plus Logic Board Replacement: 步骤 4 中的图像 2,2
    • Gently lay the logic board upside-down, with the top portion resting against the rear case of the iPhone.
    • Use the flat end of a spudger to disconnect the antenna connector from its socket on the back of the logic board.
  5. iPhone 6 Plus Logic Board Replacement: 步骤 5 中的图像 1,1
    • Lift and remove the logic board out of the iPhone.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 571
