简介
Use this guide to bring life back to your iPhone 6 Plus with a new battery. If your battery is swollen, take appropriate precautions.
This guide instructs you to remove the front panel assembly; this is intended to prevent damage to the display cables. If you feel comfortable supporting the display carefully while peeling the battery out of the iPhone, you can skip the display removal and go directly to the battery removal steps.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your iPhone until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
You can also use this guide to replace the battery connector bracket.
你所需要的
视频概述
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6 Plus.
Close the handle on the iSclack, opening the suction cup jaws.
Place the bottom of your iPhone in between the suction cups.
Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
If you don't have an iSclack, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Peel back the first battery adhesive tab from the bottom right edge of the battery.
Very slowly, pull and stretch one adhesive strip away from the battery, toward the bottom of the iPhone.
Pull at as low of an angle as you can without snagging the adhesive strip on any of the components along the lower edge of the phone.
Don't press down on the battery as you pull the strip.
Peel back the second battery adhesive tab from the other side of the battery.
Again, pull and slowly stretch the adhesive tab to slide it out from between the battery and the rear case.
Continue pulling the adhesive tab until it releases completely from the battery. If it breaks, try to retrieve the remaining length and continue pulling, or proceed as instructed below.
Peel back the final battery adhesive tab from the bottom edge of the battery. Gently pull the battery adhesive tab upward and away from the battery, allowing the adhesive strip to slowly slide out from between the battery and the rear case.
Continue pulling until the final strip comes free from the iPhone.
Wait about one minute for the alcohol solution to weaken the adhesive. Use the flat end of a spudger to gently lift the battery.
If the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
Then, use a plastic opening tool to gently lift the battery.
Thread the floss or string underneath one end of the battery and pull side to side in a sawing motion to separate the adhesive.
708等其他人完成本指南。
