跳转到主内容
iPhone 6 Plus Antenna Assembly Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iPhone 6 Plus Antenna Assembly Replacement, Antenna Assembly: 步骤 1 中的图像 1,1
    • Remove the following screws securing the antenna bracket to the rear case:
    • One 1.5 mm Phillips #00 screw
    • One 2.8 mm Phillips #00 screw
  2. iPhone 6 Plus Antenna Assembly Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Grasp the antenna bracket with a pair of tweezers and lift it off the iPhone.
  3. iPhone 6 Plus Antenna Assembly Replacement: 步骤 3 中的图像 1,1
    • Carefully pry the antenna connector up off the logic board with a plastic opening tool.
  4. iPhone 6 Plus Antenna Assembly Replacement: 步骤 4 中的图像 1,2 iPhone 6 Plus Antenna Assembly Replacement: 步骤 4 中的图像 2,2
    • Grasp the antenna connector with a pair of tweezers and gently lift it from its retaining clip on the logic board.
  5. iPhone 6 Plus Antenna Assembly Replacement: 步骤 5 中的图像 1,2 iPhone 6 Plus Antenna Assembly Replacement: 步骤 5 中的图像 2,2
    • The two connectors may be coupled by a single adhesive tab. If this is the case, then they may detach as a pair.
    • Disconnect the power button cable and audio control cable connectors from their respective sockets on the logic board.
  6. iPhone 6 Plus Antenna Assembly Replacement: 步骤 6 中的图像 1,1
    • Remove the following screws securing the top cellular antenna to the rear case:
    • Two 1.6 mm Phillips #00 screws
  7. iPhone 6 Plus Antenna Assembly Replacement: 步骤 7 中的图像 1,2 iPhone 6 Plus Antenna Assembly Replacement: 步骤 7 中的图像 2,2
    • Use a pair of tweezers to grasp and remove the top cellular antenna out of the iPhone.
    • During reassembly, make sure to place the small washer in the top left corner of the antenna assembly.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 675
