跳转到主内容
iPhone 6 Plus 后盖更换
你所需要的
  1. iPhone 6 Plus 后盖更换, 五角螺丝: 步骤 1 中的图像 1,1
    • 在拆卸前,请确保您的iPhone 电池电量在25%以下。充满电的锂离子电池如果意外刺破,可能会引起火灾和/或爆炸。
    • 在开始拆卸之前请把iPhone关机。
    • 移除lightning接口两边的2颗3.6mm P2五角螺丝。
    I prefer to remove the SIM card as the very first step since it's safer to do so while the phone is fully assembled.
    estebanfallasf - 回复
    I stripped one of the two screws - at a dead stop.
    Margaret Patterson - 回复
    Before you even start: get the iOpener or hairdryer out. You’ll need it
    GPZ - 回复
    If a lightning connector won’t provide a charge or needs to be wiggled carefully to provide a charge, power off the device, then try using precision tweezers to scrape the innermost wall of the lightning jack in a pinching motion to check for lint buildup. Pocket lint or other debris can accumulate inside the jack, compacting each time a cable is inserted. This can prevent a lightning cable from seating fully. Clearing the lint may restore functionality without replacing the part.
    Andrew Dolan - 回复
    A few hints:
    * heating up the phone works great. I used a heating pad that you put in the microwave to heat sports injuries.
    * also, I made a sheet to help you keep track of the screws as you remove them. Print out the page, then place double sided tape below each color-coded listing of screws, and stick the screws to the tape as you disassemble. This helps prevent losing the screws and keeps track of what screws are what for easier reassembly. https://drive.google.com/file/d/1pLSvKvB...
    Paul Faulstich - 回复
    Additional hints, for anyone who needs them:
    * stick the screws to the tape in the same positions as they are shown in the guide. This will make it easier to identify them during reassembly.
    * if the screws get mixed together, the ‘mm’ (millimetre, millimeter) measurements given in the guide can be used to identify them. Compare the lengths of the threaded shafts to each other to determine which screw is which.
    Friendly Advice -
  2. iPhone 6 Plus 后盖更换, 反向钳使用指南: 步骤 2 中的图像 1,3 iPhone 6 Plus 后盖更换, 反向钳使用指南: 步骤 2 中的图像 2,3 iPhone 6 Plus 后盖更换, 反向钳使用指南: 步骤 2 中的图像 3,3
    • 接下来的两个步骤演示了如何使用反向钳,一个旨在简化打开过程的工具。 如果你不使用 反向钳,请跳过这两个步骤以使用替代方法。
    • 有关如何使用 反向钳的完整说明,请查看本指南
    • 将蓝色手柄拉向铰链以解锁反向钳的手臂。
    • 将反向钳手臂滑过 iPhone 的左边缘或右边缘。
    • 将吸盘放在靠近 iPhone 底部边缘的位置——一个在正面,一个在背面。
    • 向下推吸盘以将吸力施加到所需区域。
    • 如果发现设备表面太光滑而反向钳无法吸住,请使用包装胶带来创造一个更容易抓握的表面。
  3. iPhone 6 Plus 后盖更换: 步骤 3 中的图像 1,3 iPhone 6 Plus 后盖更换: 步骤 3 中的图像 2,3 iPhone 6 Plus 后盖更换: 步骤 3 中的图像 3,3
    • 将蓝色手柄向前拉,以锁定双臂。
    • 顺时针旋转手柄 360 度,直到吸盘开始拉伸。
    • 确保吸盘 保持相互对齐。如果它们开始滑出对齐位置,请稍微松开吸盘,然后重新对齐支臂。
    • 当反向钳创造出足够大的间隙时,将撬片插入屏幕下方。
    • 如果反向钳没有创造出足够的间隙,则对该区域施加更多的热量,并将手柄旋转四分之一圈。
    • 每次转动不要超过四分之一圈,每圈之间要等一分钟。让反向钳和时间为你工作。
    • 跳过下边两个步骤
    Use clear nontextured tape place that over the phone screen. Refer to any guide that addresses replacing a shattered screen
    Abigail Cherry - 回复
    I know it's tough with cracked glass. You just need enough to get in a plstic pry tool or guitar pick. Then you can pry it apart. Just be patient, I cannot stress that enough; the electronics are very, very small and fragile.
    Mike - 回复
  4. iPhone 6 Plus 后盖更换, 前面板组件: 步骤 4 中的图像 1,1
    • 如果你没有 iSclack,使用单个吸盘来打开前面板:
    • 把吸盘放到屏幕上,正好在 home 键上面一点。
    • 确保吸盘和屏幕吸得很紧。
    Avec la ventouse, l’ouverture est brutale, tout s’est déclipsé d’un seul coup. Faire attention.
    Paul Briffaut - 回复
    English Please!
    tom mozeleski -
    With the sucker, the opening is brutal, everything was cleared at once. Pay attention. (Paul’s comment translated by Google)
    Steve Schlotter - 回复
    May need to burp the sticker before it sticks. Need to let the air out. Once Idid that, no problem. Except it was still hard to get the cover to start up.
    Patricia Tucker - 回复
    Don’t waste your time with the suction cup - it doesn’t work! insert the blade of a box cutter just below the lower screen edge below the home button and gently pry just enough to start cracking the seal.
    Stephen Smith - 回复
  5. iPhone 6 Plus 后盖更换: 步骤 5 中的图像 1,1
    • 一只手把 iPhone 按下的同时,把吸盘轻轻地往上拉,使前面板组件和后机壳分离。
    • 慢慢来,使用恒定的力量。显示屏组件比大多数的设备都要紧。
    • 使用塑料撬棒,开始轻轻地把后机壳撬下来,在这个过程中继续拉吸盘。
    • 前面板组件和后机壳有几个夹扣连接,所以你需要使用吸盘和撬棒工具组合。
    Be extra careful here. If you don’t take your time, your front panel may jerk back on you, causing you to overextend and break the front camera/mic flex cable; happened to me. Slowly peel back the front panel, opening it no more than 90º.
    Thomas - 回复
    watch out for the left side of the phone the adhesive bunches up around the inner clips, i didn’t realize it and the upper left of my screen cracked pretty bad. But this guide is awesome follow every direction to the letter
    Aaron Fitzpatrick - 回复
    Note: this comment is written for the iPhone 6 Plus, but may also apply to other models of iPhone.
    Disassembly:
    The clips in the rear case attach to small slotted shapes under the edges of the display assembly, and these attachment points alternate from one side to the other. Moving from bottom to top, gently pulling the rear case away at these points will help to separate the two halves without using too much force.
    Reassembly:
    Ensure that the plastic clips along the top edge of the front panel (shown in step 8) are fitted properly inside the rear case, then gently press the display assembly into the rear case at these points, moving from top to bottom. There may be a small click sound as the clips in the rear case engage with the slots on the display assembly, and the rear case should fit flush with the edges of the display assembly.
    Friendly Advice - 回复
    This was challenging. For me, the suction cup could only create a tiny bit of motion and at first, no actual gap at all. You might have to pull the suction cup away from the base a few times just to loosen things up a tiny bit. Eventually, I got my fingernail in, and then after a few minutes got the plastic tool in.
    Also, use the plastic tool to gently pry along the sides of the phone once there’s light there. I was afraid of using too much leverage and breaking the screen as per the other comments, but starting at the bottom and then going around the sides slowly worked for me.
    FixingMyiPhone - 回复
  6. iPhone 6 Plus 后盖更换: 步骤 6 中的图像 1,2 iPhone 6 Plus 后盖更换: 步骤 6 中的图像 2,2
    • 拉住吸盘上的塑料凸起,破坏真空环境。
    • 把吸盘从显示屏组件上移除。
    There is an adhesive strip all along the edge between the top and bottom of the phone. Is that just adhesive or is it wire of some sort?
    Larry Ingerling - 回复
    @lingerling The adhesive strip was introduced on the iPhone 6s and 6s Plus (one model year later than what’s shown on this page). Guides specific to each model can be found here—be sure to use the correct one for your particular phone. And yes, just adhesive, no wires. ;)
    Jeff Suovanen - 回复
  7. iPhone 6 Plus 后盖更换: 步骤 7 中的图像 1,3 iPhone 6 Plus 后盖更换: 步骤 7 中的图像 2,3 iPhone 6 Plus 后盖更换: 步骤 7 中的图像 3,3
    • 拉起 home 键一端的前面板组件,以手机顶端为轴。
    • 把显示屏打开到角度为 90º ,把它如图所示靠在某物上。
    • 使用橡皮筋把显示屏固定在盒子上。这可以避免对显示屏电线不必要的拉扯。
    • 如果手边找不到合适的物品,你也可以用没打开的易拉罐来固定。
    Be careful If we leave the screen connected and set it to 90 degrees, the speaker / sensor flex may break. With an opening of 60 degrees it is convenient to completely disconnect the screen. The headset's flex is short, and if we put it at 90º, it can break. Guiding me from the images of iFixit, I have broken two cables.
    Español:
    Cuidado. Si dejamos la pantalla conectada y lo ponemos a 90 grados, el flex del altavoz/sensor puede romperse. Con una abertura de 60 grados es conveniente desconectar enteramente la pantalla. El flex del auricular es corto, y si lo ponemos en 90º , se puede romper. Guiándome de las imágenes de iFixit, se me han roto dos cables.
    txaukos - 回复
    At 60º the display will block access to all the screws and the phone would be practically unserviceable, so I’m having trouble making sense of this comment. The cables on a factory original display are pretty tough and designed with enough slack that a 90º angle is no problem. Same with any decent aftermarket display.
    Jeff Suovanen - 回复
    If you look at the enlarged image, you can see how the flex cable from the camera / speaker is in tension. This is my opinion. Sorry for my bad English
    Si usted se fija en la imagen ampliada, puede ver cómo el flex cable de la cámara/altavoz está en tensión. Esta es mi opinión.
    Perdón por mi mal inglés
    txaukos - 回复
    your English isn’t the issue, it’s the proposed 60 degree opening space that doesn’t allow for the removal of the screws of the mounting plate where the connectors connect to the main pcb…
    if can make a recommendation here; it helps if the can is full and not refrigerated, the weight helps in keeping the phone where it should stay without adding additional tension to the ‘flex’ ribbon cable. it’s called flex for a reason people, if your breaking these the phones already been overheated too much, the cables become brittle and should also be replaced. i replaced my battery without disconnecting the screen, at 90 degrees with a rubber band around an empty beer can. pierced the orig. battery and caused sparks. albeit, i wasn’t in a hurry and it took me a good 30+ minutes, removal of the battery and stickers is by far the most challenging, especially when NOT disconnecting the screen…
    it’s not a race, take your time. move slowly but precisely with forethought and persistent force…
    circuitbender 477 - 回复
    Werkt dit ook voor iPhone 7(plus)?
    Christina Pegtel - 回复
    Werkt dit hetzelfde voor iPhone 7 (plus)?
  8. iPhone 6 Plus 后盖更换: 步骤 8 中的图像 1,2 iPhone 6 Plus 后盖更换: 步骤 8 中的图像 2,2
    • 在手机顶端有几个夹扣,显示屏可以像书一样翻动。
    • 在组装过程中,把夹扣对齐后机壳顶部边缘。然后滑动前面板和后机壳扣上。
    I would recommend protecting the screen once the display is free and the suction cup has been removed. This will help avoid any possibility of accidental scratching of the display crystal while the remaining steps are being performed. I used an inexpensive screen protector then removed it after reassembling and testing are complete.
    anthonyspampinato - 回复
  9. iPhone 6 Plus 后盖更换: 步骤 9 中的图像 1,1
    • 将以下00号十字螺丝从电源接口盖移除
    • 一个2.3 mm长的00号十字螺丝
    • 一个3.1 mm长的00号十字螺丝
    for the iPhone 6 Plus, all screws were Phillips #000
    Michael Adams - 回复
    I had difficulty removing the 3.1mm (iPhone 6 Plus / Phillips #000); had to give it significant downward pressure to get it started.
    Allen Matheson - 回复
    stripped the 2.3mm screw attempting to remove, had to use excessive force to successfully remove
    Matthew Gao - 回复
    The Phillips bits provided in the kit would not engage the Phillips heads enough to loosen them. Luckily I had my own small screwdriver set that worked like a charm.
    David Davis - 回复
    Same issue. Could not remove the screw. Dead in the water.
    Tiffany - 回复
    Agree with above comments regarding the supplied Phillips bit. It is not the correct size.
    Use a Phillips #000.
    bobgottner - 回复
    Phillips #000 is what’s included in the kit. As others mentioned above, firm downward pressure is key. The phone is not that delicate; just press hard and crank it.
    Jeff Suovanen -
    Is this step necessary ?\
    Asianay - 回复
    @asianay0129 Yes, disconnecting the battery is necessary. You can sometimes get away with skipping it, at the risk of destroying something important and potentially bricking your phone. Not a wise gamble for the sake of skipping two screws.
    Jeff Suovanen - 回复
  10. iPhone 6 Plus 后盖更换: 步骤 10 中的图像 1,1
    • 将电源接口的金属盖从iPhone中移除
    Was not able to remove the battery connector bracket as one of the cable connectors was glued/stuck to the underside. Instead moved the bracket out of the way to disconnect the battery. Care should be taken not to over bend/stretch the ribbon cable.
    dwtan - 回复
    That may be just the foam connector adhering to the bracket. If you pull up gently and twist slightly it should separate.
    Evan Noronha -
    It was the foam connector, and it did twist free with a gentle pull
    Al Taylor - 回复
  11. iPhone 6 Plus 后盖更换: 步骤 11 中的图像 1,1
    • 用塑料撬棍从主板上撬下电池排线的接头。
    • 注意只在排线接口上用力,不要伤到主板上的接口插座。如果你撬到了接口插座,你可能会直接把接口弄坏。
    you may consider placing a thin non-conductive item between the connector and the socket like a bit of rubber band to prevent any power flowing during this procedure
    Michael Adams - 回复
    It was too close to other parts to pry up with either end of plastic tool. Finally used 1 tine of tweezer to lift edge. Came free easily
    Al Taylor - 回复
    J’ai pris une loupe pour bien observer l’endroit où placer l’outil.
    Paul Briffaut - 回复
    Magnification is key for many tasks and this is certainly one.
    Kenneth Gilbert - 回复
    I couldn’t use the iFixit blue opening tool to pry that battery connector. I used the top of the black spudger near the hole where the 3.1mm screw was in step 9-10 to easily pry it open!
    Alyssa Sayuki - 回复
    The blue plastic board breaker can easily cause damage here. Professionals would recommend using the human fingernail as the ideal tool for this job.
    Jessa Jones - 回复
  12. iPhone 6 Plus 后盖更换: 步骤 12 中的图像 1,1
    • 保持前面板张开立起约90度,卸下前面板排线固定板上的五颗Phillips螺丝。
    • 三颗1.2 mm螺丝
    • 一颗1.7 mm螺丝
    • 一颗3.1mm螺丝
    There's an other panel with one screw in the middle.........
    Herbert - 回复
    Sounds like you have an iPhone 6s Plus, rather than a 6 Plus. Be sure to use the correct guide! And make sure you’ve ordered the correct part, as they’re not cross-compatible.
    Jeff Suovanen -
    I _love_ the color coding of screws. I know this is a little OCD, but it would be incredibly useful if there were an 8.5 X 11 you could print with indicated homes for where to drop items from each step of disassembly. That is, in the box for step 9, little colored circles for where to place each screw type. As long as you don't jostle the paper, it would make it a lot easier to know exactly where you are in reassembly.
    cscarlson47shop - 回复
    I have done the exact same thing. Created a sheet where each screw goes.
    Chris Murphy -
    I used the 000 bit from the ifixit 54 piece kit.
    hhandh - 回复
    Actually you don’t need to do steps 12 to 18 if you attach the display panel to the iPhone box as shown in step 7 and handle your iPhone with care during the replacement. I didn’t disconnect the display panel mainly because the more you work on the interior of your phone the higher is the chance you break something.
    Dany Castillo - 回复
    Since this guide is for DISPLAY replacement, I don’t see how you can skip the steps for disconnecting and removing the DISPLAY.
    Jim Bateman -
    That's what I was thinking.
    The Wizard - 回复
    I skipped this series of steps too. I was very careful when removing the battery and never had an issue with the screen leaning back against the box that this battery shipped in. I even broke half of the third strip of adhesive but used a plastic card to slide under the battery and it slowly lifted out without applying heat.
    mark - 回复
    I'm having trouble with one screw not wanting to come out. Any suggestions to keep from stripping the head and getting it?
    Patric - 回复
    which screws are which sizes cause i ordered new ones and cant figure it out
    MONsterHEIT - 回复
    I also did not see the need to remove the display assembly for this repair. However I did place a can of corn against the vertically positioned display and then secured the display to the can with a rubber band.
    whiteshephard - 回复
    I recommend removing the display assembly, I didn’t and somehow damaged the home button cable. At least remove the cover to ease the tension on the cables.
    I played around with different screwdrivers to get certain screws out. I made sure I wasn’t applying heavy pressure so I wouldn’t strip the head. Apple is crazy for doing this to us lol.
    Anyways invest in a magnetized mat to organize your screws. It was really difficult to keep things organized and still, especially with these tiny screws…
    Jeffrey Robinos - 回复
    what happens if i forgot to put the ribbon cable shield back on? the phone is now working but i forgot to put the shield back on and i am missing 2 screws. can i leave the shield off?
    Fred ticoman. - 回复
    @ticoman12 It’ll work without the shield, but the connectors may pop out unexpectedly.
    Jeff Suovanen -
    Just be really careful remembering which screw is which. I drew a quick sketch of the bracket, then put the screws in the relevant places. There’s no way I would have been able to figure them out otherwise - my eyes can’t see the difference between a 1.2 and 1.5mm screw!
    Paul Johnson - 回复
    The most fiddly part of the job.
    Much easier if you put the screwdriver head on the screw and then insert it into the opening. The slight magnetism will hold it in place. Don’t fully tighten a screw until all the screws are in place. Much like installing lug nuts on a car.
    GPZ - 回复
    I also skipped steps 12-18 as Danny had suggested. It made this repair quite easy, so thank you and others for suggesting this. I was also very careful to allow the battery to discharge before starting the process.
    Bruce Platt - 回复
    I question whether Steps 12-18 (separating the display from the case) is actually necessary? The battery can be removed/replaced with the display connected (but standing upright, as displayed in Step 7.
    Leaving the display attached obviates the most difficult steps (re-connecting the various control ribbons — 3/4 of ‘em!
    I followed this manual completely and the repair was successful. But if I had this to do over, I’d leave the display connected.
    Dana Smith - 回复
    I skipped the steps 12-18 as well and thank goodness I did so I won’t have to worry about issues with any of the cables.
    my panel is different from what is pictured anyway ‘cause I have one screw in the middle like what Herbert said on the first comment.
    Maria Filamor-Robinson - 回复
    I realized too late just how handy the magnetic mat is that they have in their shop. So I organized the screws with a piece of clear packing tape. On the smooth side, use a sharpie to draw spacious circles with “R” “O” and “Y” inside each circle to represent the color coded screws and then use the sticky side to keep the screws in place. I found that using the tweezers to take them off the screwdriver helps you stick them head first to the tape better.
    Selena Castillo - 回复
  13. iPhone 6 Plus 后盖更换: 步骤 13 中的图像 1,1
    • 从主板上取下前面板排线固定板。
  14. iPhone 6 Plus 后盖更换: 步骤 14 中的图像 1,2 iPhone 6 Plus 后盖更换: 步骤 14 中的图像 2,2
    • 在接下来的四个步骤中,使用撬棒时注意只撬排线接口,而不是接口插座。
    • 使用撬棒的平头断开前摄像头和传感器排线接口。
    Why does the screen need to come off?
    Sterling Coffey (N0SSC) - 回复
    Because the cables are delicate, and following steps are easier if phone halves are not flopping around together, especially for amateurs.
    Matthew Goheen - 回复
    I don't know if anyone will see this but here it goes: for the life of me I can't get the front-facing camera and earpiece speaker connector to seat. Everything else went back together fine but this one connector will not go in. Sometimes it seems like it's in even though it doesn't really pop in and it'll kinda sit there for a sec and then it pops out.
    Any insight would be greatly appreciated, thank you
    Droopy Caledonia - 回复
    Try starting at one end instead of in the middle. It's to easy to bend a connector and this way, I can get a safe start and go from there.
    Rongwey - 回复
  15. iPhone 6 Plus 后盖更换: 步骤 15 中的图像 1,2 iPhone 6 Plus 后盖更换: 步骤 15 中的图像 2,2
    • 用撬棍的平头断开Home键排线接口。
  16. iPhone 6 Plus 后盖更换: 步骤 16 中的图像 1,2 iPhone 6 Plus 后盖更换: 步骤 16 中的图像 2,2
    • 用撬棒的平头断开显示排线接口。
    • 重新组装手机时,显示排线可能会从插座上松动,这回导致重开机时屏幕显示白线或者直接白屏。如果出现这种情况,只需再次装好排线并将手机电源重置一次。重置手机电源最好的方式就是将电池排线断开再装上
    The piece of advice about power cycling the phone by disconnecting and reconnecting the battery proved crucial to the success of my repair (camera and lens replacement). At first when charging the phone after closing it, I got a dark, blank screen with an intermittent buzzing noise. After re-opening the phone and making sure all cables had been properly reconnected, I ignored the advice to power cycle the phone. Still all I got was a dark, blank screen (and intermittent buzzing if charging t). Then I opened it a third time (leaving the screen connected and attached at a 90 degree angle) and I only disconnected and reconnected the battery. Voila! When I closed the phone and powered it up, I got the screen to light up!
    Gianni - 回复
    how did you disconnect and reconnect the battery?
    Teresa Trevino - 回复
    If you’ve been following the guide, you already disconnected it in this step. To reconnect it, just line up the connector and press it into place.
    Jeff Suovanen -
    After replacing the battery, the phone seems dead. I thought it just needed recharging so I left it charging all night. Still dead in the morning. Now I think it might be because the display data cable is off, and I should open the phone and check it. But the battery might be on full power in that case, and they don’t advice to open the phone when battery if full. What can I do?
    Ila Awasthi - 回复
    The advice aims at avoiding battery fire. Just be careful.
    Katherine Williams - 回复
  17. iPhone 6 Plus 后盖更换: 步骤 17 中的图像 1,2 iPhone 6 Plus 后盖更换: 步骤 17 中的图像 2,2
    • 用撬棒的平头断开触摸层排线接头。
    • 当你要组装触摸层排线时, 请不要按压接头的中间地方。按压接头的一端, 接着再按压另一端。因为若是按压接头中间时, 有可能造成触摸层变形损坏。
    some images and guidance regarding reassembly would be helpful. You don't need to use the spudger to get them back on: fingers are better because there's a really subtle click you feel when you get them seated properly.
    When you're reassembling, a note that this is the step where you should test for proper screen function would be really useful. First time I reassembled, I didn't seat something properly, got all the screws back together and then realized the screen wasn't functioning properly. Had to disassemble back down to step 14 and then re-reassemble.
    I am having this issues right now! I have unplugged and plugged in these cables at least 20 times and each time I get white lines. I finally have it to where there are only 4 white lines and I am almost willing to live with it. Any suggestions?
    mattmay002 -
    Clean the screen connectors incase they are not making a clean connection
    Karen Jones - 回复
    I'm having nightmares with the digitizer connector. Simply can't get it to work unless I'm applying some pressure on the connectors. Everything seems almost microscopically clean. Any suggestions friends?
    Henry A -
    could it be the replacement screen? test with your old screen and see if you have the same problem.
    Charles - 回复
    To ++mattmay002++  Did you power cycle the phone? Check out the comments on the previous step for a how to.
    Robert Liles - 回复
    I had issues with it too. When connecting this cable, make sure to rock finger side to side after connecting. It’s a wide connector so try to listen for 2 clicks on this one connector. That’s how I fixed mine
    Albert Einstein - 回复
    Re-attaching this cable is the only tricky part to replacing the battery on my 6+. It had a bow on the middle that I had to flatten out before pressing the connector on with finger first on one edge and then on the other. I had white tire tracks on the screen and no touch screen until I connected it correctly. The front has to rest in just the right place on the back while attaching this thing so the cables aren’t strained the front doesn’t fall down. Small fingers would be a plus at this step.
    richard - 回复
    Reseating these connectors on reassembly is definitely the most difficult part of this repair. It took me several attempts before the lowermost connector would seat properly and I did accidentally bend it slightly in the process. Fortunately I was able to get it straight again and get it to click in. The other three went in fine though and no lasting damage seems to have been done.
    Andy Gibbons - 回复
    Another thing - These cables can become overlapped in the wrong way and make you think they are in a different order than they should be. Eg. it’s easy to mix up the ones from step 15 and 17. You can actually unravel the cables and re-layer them on top of each other in any order, so remember this! They look like they’re one solid mass but they’re not.
    domarius - 回复
    I never removed the last digitizer connctor. I removed the first three connectors, left the screen propped at 90 deg tied to a box and removed the battery, there is minimal movement. In fact when I reattached the connectors, only the first and maybe second connector feels taut, so it’s necessary to only remove the first connector if you can be gentle with it. Less headache. And my guess why so many people had issues is that micro dust gets into the connectors and cause connection loss. You be surprised how little dust can cause havoc.
    darrcc - 回复
    And forgot one thing, keep a can of air duster woth you to remove as must dust as you can see. A camera air blower will also do nice.
    darrcc - 回复
    I haven’t removed my screen in past battery replacements, I found it easier. However, this time I followed the instructions because my old battery was very stuck, and I needed the screen gone to get the battery out…
    When I replaced the screen, at first it wouldn’t even boot/start up. (Yes, I inserted my own testing step, as someone here suggested, before final reassembly).
    The screen would just show a fuzzy image, and the board that all the cables attach to would heat up, then it would turn itself off. I tried reconnecting them carefully 3 times, and even made sure to get a little “click”, all to no avail.
    The final try, I used my fingernail to really press down on the back side of the digitizer cable. I heard more clicking, though I thought I might be tearing the cable too. With nothing left to lose, I continued across the back, and heard several more clicking/tearing sounds.
    This worked, and it booted after that. It still had white lines, but those faded away overnight.
    Morgan Giddings - 回复
    About the digitizer connector: its flat cable is so short that the when I attempted to seat the next connector, its flat cable pressed on the digitizer cable, which can pull on the connector and dislodge it. That happened several times for me before success.
    Robert Bernard 27 Nov 19
    Robert H Bernard - 回复
    Nous n’apercevons pas bien les nappes et l’ordre dans lesquelles elles doivent être replacer
    Patrick AZOULAY - 回复
  18. iPhone 6 Plus 后盖更换: 步骤 18 中的图像 1,1
    • 此时,前面板可以彻底与机身分离了。
    Never remove the screen without disconnecting the battery. It's possible the back light can be blown and that's a even more difficult repair. Always, ALWAYS, disconnect battery before repairing items. (Unless it's not possible.)
    Marvin Ballard - 回复
    How do you disconnect the battery from the screen?
    Shamil Bhatti -
    The Step 11 disconnects the battery :)
    jeffxtechs - 回复
    I think you mean Step 8 :)
    Jeff Suovanen -
    I tried it once and
    Brian - 回复
    And what? I tried it once and here’s a million dollars?
    Oh I get it… they got him! :(
    https://www.youtube.com/watch?v=UlznqpBg...
    domarius -
    When disassembling the iphone at this point note the cables, and there placement/orientation.
    GERARD SZAREK - 回复
    Be really careful with the step after this. Do not commence until you have read all the comments. You need to get a good hold of the plastic strips preferably before they double over on themselves. You have to avoid puncturing the battery at all costs. Slowness and caution here will save you a lot of long term pain.
    Laura Houghton - 回复
  19. iPhone 6 Plus 后盖更换, 电池: 步骤 19 中的图像 1,1
    • 从电池右下角剥离第一个电池胶带。
    • 用手指或摩钝的镊子。 在电池附近操作时要格外小心; 刺穿锂离子电池可能释放危险的化学物质并引起火灾。
    Ça été pour moi la partie la plus difficile du démontage de l’iPhone, j’ai cassé les 2 bandes parce que je ne me suis pas bien appliqué pour les décoller avec la pince. Pour m’en sortir,. j’ai tordu la batterie avec les outils de manière à faire apparaître les bandes adhésives pour les enlever sans problème.
    Paul Briffaut - 回复
    Translation from Google:
    It was for me the most difficult part of the disassembly of the iPhone, I broke the two bands because I did not apply well to take off with the clamp. To get out of it ,. I twisted the battery with the tools so that the adhesive strips appeared to remove them without any problem.
    Ken - 回复
    Slowly roll the pulled-out adhesive onto itself as you progress, this makes it easier to gauge how much stretch you need to exert on the remaining adhesive, as well as to gain enough grip to hold the adhesive properly. I also nearly tore off the middle one, it’s not due to my rough but because the battery’s black tape (at the area where these adhesive tabs are) caught onto the white adhesive, this must be the reason why most people’s tore off. Mine nearly tore off, so i slow rolled the pulled-out adhesive to catch back the adhesive, and then it’s roll and pull as per normal. With that I took equal precaution for the last one on the left, and it also was caught by the black tape, but since i know it this time, i slowly pulled it free of the black tape first before continuing the roll snd pull. 100% works. Trust me. My battery is slightly warm as i deliberately let it run for a while before i started the disassembly. I doubt it contributes much to the removal but no harm.
    darrcc - 回复
    It's easier if you grasp the full width of the adhesive strip, straight across it, before starting to pull. That way the force is applied gently and evenly to the whole strip. I used watchmaker's forceps because they precisely pull up the adhesive tab, and easily squeeze the whole width of the strip—since it's critical to apply the pulling force evenly across the strip. Tug gently and twist the forceps to take up the slack, pulling just a few millimeters at a time. I learned this the hard way. My center strip snapped pretty quick because I didn't have a good, even grasp of it.
    For heat, I put a cup of raw white rice in a clean sock, knotted the open end, and microwaved it for 2 minutes. When it was cool enough to handle, I flattened it on the table and lay the phone upon it. That gave off enough gentle steady heat that I could pry up the battery without much bending, locate the adhesive end, and successfully wind it up with the forceps. I think I would use the hot rice-bed from the start next time. —Kw
  20. iPhone 6 Plus 后盖更换: 步骤 20 中的图像 1,2 iPhone 6 Plus 后盖更换: 步骤 20 中的图像 2,2
    • 在进行此步骤时,请尽量保持胶带平整。不平整的胶带可能会粘在一起或者断裂而导致不能完整取出
    • 请缓慢地将胶带由电池向iPhone底部方向拉出
    • 在用力拉之前,请让胶带伸展开来。如果你在拉的时候感觉不到它在伸展,请放松一点,否则胶带会断裂。
    • 以尽可能低的角度拉出胶条,在拉出胶条过程中不要碰到手机上的任何配件。
    • 在拉出胶带的时候,请不要按压电池
    • 胶带可能会被拉伸至数倍于电池的长度。在它完全被从电池下方拉出来前请继续拉。
    • 如果胶条在拉出来的过程中断裂,请将剩余部分卷在手指或者钝镊子上继续拉
    • 如果任何胶条在电池下方断开,无法取出,请尝试取出剩余的胶带,然后按以下步骤处理
    I found this much easier than when I did it on a 5S. Not sure if the adhesive strips are different, but I also left the phone on a radiator for a few minutes to help warm the glue. All three then pulled straight out of the phone in one go.
    James - 回复
    I set my phone on a microfiber cloth on a plate that I had warmed (warm to the touch and that I could hold with my bare hands) in the microwave prior to this step. All 3 strips came off from the bottom and without any trouble.
    armitagd - 回复
    Excellent tip, thanks.
    vanshdx10 - 回复
    absolutely impossible unless you heat it. Thank You armitagd, that did the trick.
    chris - 回复
    All three of mine tore off immediately, I had warmed the phone up too. A bit of a struggle with the tweezers and card method, the battery bent and leaked. Came out okay.
    John Blanchard - 回复
    I recommend preheating the case before trying to remove each adhesive tape. Also, try wrapping the tape around a pencil as you pull and stretch the tape. I think that such gives a more even pull across the tape than by using one’s fingers.
    GPZ - 回复
    I even didn’t find an adhesive in my phone, I had to use hairdryer to heat the battery, then remove it gently using the blue plastic and couple of plastic cards
    Mohammed Jitarayah - 回复
    I can’t stress enough how important it is to preheat the case as others have mentioned. GPZ’s recommendation using a pencil is also pure gold - get enough initial purchase on the adhesive strip so that you can pull it taut and then place your pencil. From there, roll and tag alternately, keeping tension on it so that the adhesive doesn’t wrinkle in the process of removal.
    Jesse Espe - 回复
    Heating probably works but I slowly pulled out an inch or so and then started rolling it onto my screwdriver. Then I slowly rolled the screwdriver which gave me a good grip and I could go slowly. Took more than 5 min but it got easier and easier. Believe me, getting the battery out using the alternative is very hard, and dangerously easy to penetrate the battery and start a small flame thrower (voice of experience).
    Thomas Hayes - 回复
  21. iPhone 6 Plus 后盖更换: 步骤 21 中的图像 1,2 iPhone 6 Plus 后盖更换: 步骤 21 中的图像 2,2
    • 在电池的另一侧将易拉胶条头拉出
    • 再次,慢慢拉出易拉胶条头,将它从电池与后盖之间拉出。
    • 继续拉出易拉胶条头直到它完全剥离电池。如果中途断裂,请卷起剩余的部分继续拉,或者按照以下步骤处理
    This strip broke almost immediately with the first pull. I changed the battery on two iPhone 6 Plus’s. Impossible for me to retrieve broken ends. I moved on to the middle strip with no issue. I then used the blue opening tool to pry the battery up along the lower right edge of the battery (BE CAREFUL!). Once the battery is leveraged up enough to put the tip of the tweezers on the broken strip, grab a piece of the strip and pull it to a point where the removal process can continue as prescribed.
    whiteshephard - 回复
    Pulling the strip around the corner did not work for me - it broke. I then pulled the middle strip straight out with no issues and the remaining left strip also straight without no problem. I don’t recommend pulling the side strips around the corner of the battery
    Swenja - 回复
  22. iPhone 6 Plus 后盖更换: 步骤 22 中的图像 1,3 iPhone 6 Plus 后盖更换: 步骤 22 中的图像 2,3 iPhone 6 Plus 后盖更换: 步骤 22 中的图像 3,3
    • 从电池底部边缘拉出最后一条易拉胶。
    • 向上轻拉易拉胶使其从电池和后盖间慢慢分离出来。
    • 在拉出最后一条易拉胶的同时请将一只手按住电池,否则胶条可能会将电池带离iPhone
    • 继续轻拉易拉胶使其从机身中完全分离出来。
    • 如果你成功将三条易拉胶取出,请跳过以下两步
    • 如果任意一条易拉胶断裂在了电池底部,请继续以下步骤
    I don’t know why the instructions didn’t mention this, but I pulled it to the left and back, like the previous strip, rather than straight back, to avoid snapping.
    domarius - 回复
    Pull the adhesive strips at a 45° angle up away from the back or the strip will catch on the bottom board and will tear and break. If it starts to tear, , see if you can grab a spot after the ear and keep pulling. These things are super thin and fragile. Go sloooow when you pull the strips. You are going to pull them a long way, so be patient.
    Ok, so you broke one. Or two. Or all three. Forget the alcohol. Lay your phone face down on a towel and heat it with a hair dryer for two minutes. Flip it over carefully as it will be hot. Insert a plastic spudger under the bottom edge and carefully push/slide it under the battery toward to top of the phone along the strip(s) that are still stuck. DO NOT PRY. You may have to heat it again if it gets hard to push. BE CAREFUL. The battery will bend a bit, but don’t bend it excessively or poke it as it can catch fire when exposed to air. Eventually the battery will pop free. Remove the stuck adhesive and wipe it a bit with alcohol and let it dry.
    Sheldon Carpenter - 回复
  23. iPhone 6 Plus 后盖更换: 步骤 23 中的图像 1,1
    • 如果任何一条易拉胶拉断且电池仍然黏附在后盖上,准备一个 iOpener或者用电吹风机从后盖直接对电池进行加热。
  24. iPhone 6 Plus 后盖更换: 步骤 24 中的图像 1,1
    • 翻转iPhone,从左侧插入一张卡片到电池和后盖间隙间。
    • 不要对电池的顶端、音量上键、静音键部位撬拉 ,否则可能损坏隐藏在电池后面黏附在后盖上的音量控制排线。
    • 请勿撬到逻辑主板,否则可能对iPhone造成不可挽回的伤害。
    • 尽可能保持卡片与电池接触面水平避免电池弯折,否则可能损坏电池或者引起电池释放有害化学物质。
    • 轻压卡片使易拉胶从电池背部分离出来。
    • 或者一条牙线可以用来把电池和后机身分离。更好的选择是没有使用过的吉他弦,比如12弦套装中的0.009 E弦。
    • 把牙线或吉他弦放到电池的一端,使用锯东西的移动方式来分离黏胶。
    Hat leider alles nicht geklappt! Musste mit einer Karte und einer Seite sehr lange fummeln und da sich die Folie vom Akku zu sehr mit dem gehäuse verbunden hat. Dadurch hat sie sich gelöst und durch das erwärmen leider auch nicht wirklich besser.
    Jess Sass - 回复
    Unfortunately, everything did not work out! Had to fumble with a card and a page for a long time and because the film from the battery has too much connected to the housing. As a result, she has solved and by warming unfortunately not really better.
    Ken -
    This step was very difficult as the adhesive strips snapped on me and I had to use a card to make the strips come out by siding the plastic card on the strips as thought I was trying to cut a very thin slice of cheese. (NOTE: DO NOT USE ANYTHING METAL when attempting this method) I actually tried using a metal spudger while trying to remove the adhesive strips and punctured the old battery slightly enough to cause smoke.
    Bryan - 回复
    iBreak-it: caught the wifi antenna connector when using a guitar string to work the extremely stubborn battery adhesive strips off. Now I need a new wifi antenna. What next?
    Dale Williams - 回复
  25. iPhone 6 Plus 后盖更换: 步骤 25 中的图像 1,1
    • 将电池从机身中取出。
    • 如果你的更换电池上有塑料纸,请在安装之前把塑料纸去掉。
    • 当你安装电池时,可使用本指南对易拉胶进行更换。
    • 在安装好电池后请进行“硬件重置”(电源键+HOME键长按10s至iPhone重新启动),这样可以避免出现一些状况和使问题简单化。
    Once again, ifixit comes through! I bought the battery and the repair kit and the new battery installed and charging. My only hitch was that the three adhesive strips all broke when I pulled on them. I had to heat the bottom of the phone to separate the battery. It was a small moment of panic, but it just required a bit more patience. Thanks for all you do!
    jamesg - 回复
    Awesome procedure! Thanks. iPhone 6plus working great. Make sure you have quality tools. Thanks again.
    Leo Lambert - 回复
    Everything went well enough but, I replaced the battery last month and after a while the phone started going into an on-off cycle. It only happens intermittently. At first it would do it only once and stop. Now it does it, still intermittently, but when it happens it keeps cycling on and off. It even does it when it’s charging. If I let it sit, while charging, after several hours it stops doing it again.
    The battery kit didn’t come with adhesives. It seems that I’m not the only one to mention it .
    Nat Turner - 回复
    Hi there! The battery kit does come with replacement adhesive along with all the tools needed to complete the repair. The part-only battery does not include adhesive, it needs to be purchased separately!
    Sam Goldheart -
    Almost blew up the battery with alot of holes, im traumatized. In the end i did by force and trew it 10 meters away while i were outside.
    Milan - 回复
    i turned on my phone and the screen is all stripes :(
    Emily M. Curran - 回复
    Sounds like either the display cable isn't properly connected or it’s been damaged. If all else fails, send it to a professional.
    Rongwey -
    The Ifixit battery comes with new adhesive strips already attached to the battery. Suggest that it’s best to leave the protective acetate over the strips until AFTER the new battery is re-connected and the connector cover is reinstalled (2 screws). Then its easy to remove the acetate cover from the adhesive strips and locate the battery.
    If the battery is stuck in (with the adhesive strips BEFORE the connector is correctly installed it is impossible to adjust the position of the battery to align the connector.
    Dana Smith - 回复
    My screen doesn’t even show up anything when charging but it makes the sound thought.
    Osvaldo G - 回复
  26. iPhone 6 Plus 后盖更换, 后置摄像头: 步骤 26 中的图像 1,1
    • 松开把后置摄像头盖板固定在后盖上的螺丝:
    • 1颗1.7mm飞利浦#00螺丝
    • 1颗2.3mm飞利浦#00螺丝
    need to remove the screws third one that's underneath the 2.3
    sirgednosiam - 回复
  27. iPhone 6 Plus 后盖更换: 步骤 27 中的图像 1,1
    • 用镊子夹住后置摄像头盖板从机身中取出。
  28. iPhone 6 Plus 后盖更换: 步骤 28 中的图像 1,1
    • 用撬棒尖头挑开扣在主板上的后置摄像头排线。
  29. iPhone 6 Plus 后盖更换: 步骤 29 中的图像 1,1
    • 从机身中小心取出后置摄像头。
  30. iPhone 6 Plus 后盖更换, 天线组件: 步骤 30 中的图像 1,1
    • 松开把天线盖板固定在后盖上的螺丝:
    • 1颗1.5mm飞利浦#00螺丝
    • 1颗2.8mm飞利浦#00螺丝
  31. iPhone 6 Plus 后盖更换: 步骤 31 中的图像 1,1
    • 用镊子夹住天线盖板从机身中取出。
  32. iPhone 6 Plus 后盖更换: 步骤 32 中的图像 1,1
    • 用塑料开口工具小心挑开扣在主板上的天线排线。
  33. iPhone 6 Plus 后盖更换: 步骤 33 中的图像 1,2 iPhone 6 Plus 后盖更换: 步骤 33 中的图像 2,2
    • 用镊子夹住天线排线使其从主板的卡扣上分离出来。
  34. iPhone 6 Plus 后盖更换: 步骤 34 中的图像 1,2 iPhone 6 Plus 后盖更换: 步骤 34 中的图像 2,2
    • 两个连接头通过单个连接口连接。如果是这种情况,那么他们可以分离成一对。
    • 从逻辑板上的连接口上撬开电源按钮和音频控制的连接头。
  35. iPhone 6 Plus 后盖更换: 步骤 35 中的图像 1,1
    • 拆下固定顶部蜂窝天线到后盖的以下螺丝:
    • 一个2.8毫米菲利普#00螺丝
    • 两个1.6毫米的十字#00螺丝
  36. iPhone 6 Plus 后盖更换: 步骤 36 中的图像 1,2 iPhone 6 Plus 后盖更换: 步骤 36 中的图像 2,2
    • 用镊子移除顶部的蜂窝天线。
    • 重新组装时,请确保将小垫圈放置在天线组件的左上角。
  37. iPhone 6 Plus 后盖更换, 震动器: 步骤 37 中的图像 1,1
    • 用撬棍的平端从主板上的插槽里撬出震动器的接头。
  38. iPhone 6 Plus 后盖更换: 步骤 38 中的图像 1,2 iPhone 6 Plus 后盖更换: 步骤 38 中的图像 2,2
    • 用镊子的尖端来断开主板上的天线接头。
  39. iPhone 6 Plus 后盖更换: 步骤 39 中的图像 1,2 iPhone 6 Plus 后盖更换: 步骤 39 中的图像 2,2
    • 用镊子夹住天线内线并把它从扬声器上组件的线槽里提出来。
  40. iPhone 6 Plus 后盖更换: 步骤 40 中的图像 1,1
    • 拧下把震动器固定在后壳上的两个2.5mm Phillips #00 螺丝。
  41. iPhone 6 Plus 后盖更换: 步骤 41 中的图像 1,1
    • 从iPhone里取出震动器。
  42. iPhone 6 Plus 后盖更换, SIM 卡: 步骤 42 中的图像 1,2 iPhone 6 Plus 后盖更换, SIM 卡: 步骤 42 中的图像 2,2
    • 把卡针或者回形针插入卡槽的小孔中。
    • 按压推出卡槽。
    • 这可能需要一定的力量。
  43. iPhone 6 Plus 后盖更换: 步骤 43 中的图像 1,1
    • 从机身中取出卡托。
    • 重新插入SIM卡的时候,确保SIM卡安装在卡槽上的方向是正确的。
  44. iPhone 6 Plus 后盖更换, 逻辑主板组件: 步骤 44 中的图像 1,1
    • 拧下一个把塑料片固定在主板上的 2.8mm 飞利浦 #00 螺丝。
  45. iPhone 6 Plus 后盖更换: 步骤 45 中的图像 1,1
    • 拧下一个位于后壳顶部凹槽里的1.3mm 飞利浦 #00螺丝。
  46. iPhone 6 Plus 后盖更换: 步骤 46 中的图像 1,1
    • 用镊子夹住塑料片并把它从手机里移走。
  47. iPhone 6 Plus 后盖更换: 步骤 47 中的图像 1,1
    • 拧下一个用来固定夹在后壳上的天线的1.6mm 飞利浦 #00 螺丝。
  48. iPhone 6 Plus 后盖更换: 步骤 48 中的图像 1,1
    • 用镊子小心地夹住天线夹片并把它从手机里移走。
  49. iPhone 6 Plus 后盖更换, 逻辑主板: 步骤 49 中的图像 1,1
    • 拧下以下将主板固定在后壳上的螺丝:
    • 2个 2.4mm 的压铆螺柱螺钉
    • 你可以通过专用的压铆螺柱螺丝刀或螺丝刀组更轻松地卸下它们。
    • 如果手头没有上述工具,也可以用平头螺丝刀来拧,但是要十分小心以避免损伤周围的原件。
    • 一个2.1mm 飞利浦#00螺丝。
  50. iPhone 6 Plus 后盖更换: 步骤 50 中的图像 1,1
    • 小心地抬起(不是取下)主板,把它从靠近lightning 接口的边缘抬起。
  51. iPhone 6 Plus 后盖更换: 步骤 51 中的图像 1,1
    • 不要取下主板。此时它仍然被天线接头连接在后壳上。
    • 继续小心地抬主板底部直到它垂直。
  52. iPhone 6 Plus 后盖更换: 步骤 52 中的图像 1,2 iPhone 6 Plus 后盖更换: 步骤 52 中的图像 2,2
    • 轻轻地将仍然连接在后壳上的主板倒着放下。
    • 用撬棍平头从逻辑主板背部的插槽中挑出天线接头。
    An extra step needs to be added. the 1.3 millimeter Phillips head #00 screw retaining the antenna to the frame needs to be removed and then the antenna removed.
    Josh Ginsberg - 回复
  53. iPhone 6 Plus 后盖更换: 步骤 53 中的图像 1,1
    • 抬起并将主板从iPhone中移除。
  54. iPhone 6 Plus 后盖更换, 开机排线: 步骤 54 中的图像 1,2 iPhone 6 Plus 后盖更换, 开机排线: 步骤 54 中的图像 2,2
    • 用镊子撕开贴在开机排线和音量键以及静音键排线上的胶条。
  55. iPhone 6 Plus 后盖更换: 步骤 55 中的图像 1,1
    • 松开把开机排线盖板固定在后盖上的单颗1.3mm飞利浦#00螺丝。
  56. iPhone 6 Plus 后盖更换: 步骤 56 中的图像 1,1
    • 用镊子小心地夹住架子并且把它从iPhone中移走。
  57. iPhone 6 Plus 后盖更换: 步骤 57 中的图像 1,1
    • 松开把开机排线固定片固定在后盖内部边缘上的螺丝:
    • 1颗2.1mm飞利浦#00螺丝
    • 1颗1.7mm飞利浦#00螺丝
  58. iPhone 6 Plus 后盖更换: 步骤 58 中的图像 1,1
    • 用镊子夹住开机排线固定片从机身中取出。
  59. iPhone 6 Plus 后盖更换: 步骤 59 中的图像 1,1
    • 松开把电源键固定在后盖上的单颗2.1mm飞利浦#00螺丝。
  60. iPhone 6 Plus 后盖更换: 步骤 60 中的图像 1,1
    • 用镊子把电源键从后盖的凹槽上推出来,开始小心的从后盖上拉起开机排线。
  61. iPhone 6 Plus 后盖更换: 步骤 61 中的图像 1,3 iPhone 6 Plus 后盖更换: 步骤 61 中的图像 2,3 iPhone 6 Plus 后盖更换: 步骤 61 中的图像 3,3
    • 继续轻轻的从后盖上拉起开机排线直到从机身中分离出来。
  62. iPhone 6 Plus 后盖更换, 音量控制以及静音键排线: 步骤 62 中的图像 1,1
    • 松开把音量键以及静音键排线固定在后盖上的螺丝:
    • 2颗2mm飞利浦#00螺丝
    • 1颗2.5mm飞利浦#00螺丝
  63. iPhone 6 Plus 后盖更换: 步骤 63 中的图像 1,3 iPhone 6 Plus 后盖更换: 步骤 63 中的图像 2,3 iPhone 6 Plus 后盖更换: 步骤 63 中的图像 3,3
    • 用镊子夹住音量键以及静音键排线。
    • 慢慢的从后盖上拉起音量键以及静音键排线。
    • 小心的拉动。排线是用薄薄的胶条贴在后盖上的。
  64. iPhone 6 Plus 后盖更换, 音量键和静音键: 步骤 64 中的图像 1,2 iPhone 6 Plus 后盖更换, 音量键和静音键: 步骤 64 中的图像 2,2
    • 用尖头撬棒把音量键和静音键从后盖上的凹槽中推出来。
  65. iPhone 6 Plus 后盖更换: 步骤 65 中的图像 1,2 iPhone 6 Plus 后盖更换: 步骤 65 中的图像 2,2
    • 用镊子夹住顶部和底部音量键从机身中取出。
  66. iPhone 6 Plus 后盖更换, 扬声器: 步骤 66 中的图像 1,2 iPhone 6 Plus 后盖更换, 扬声器: 步骤 66 中的图像 2,2
    • 用一把鑷子抓住天線連接器,小心地從它在揚聲器上的通道中取走它。
  67. iPhone 6 Plus 后盖更换: 步骤 67 中的图像 1,1
    • 要完全避開天線連接器,可能需要輕輕拉回將其固定到揚聲器組合件的金屬夾。
  68. iPhone 6 Plus 后盖更换: 步骤 68 中的图像 1,1
    • 卸下將揚聲器固定在後殼上的以下螺釘:
    • 一棵2.3毫米十字鏍絲釘
    • 一棵2.8毫米十字鏍絲釘
  69. iPhone 6 Plus 后盖更换: 步骤 69 中的图像 1,1
    • 將揚聲器提起並從iPhone中取出。
  70. iPhone 6 Plus 后盖更换, lightning接口组件: 步骤 70 中的图像 1,1
    • 移除两个固定lightning接口金属框架的3.3mm 飞利浦 #00螺丝。
  71. iPhone 6 Plus 后盖更换: 步骤 71 中的图像 1,1
    • 用镊子从手机中夹走此金属框架。
  72. iPhone 6 Plus 后盖更换: 步骤 72 中的图像 1,1
    • 用撬棒的平端将天线连接头从其在lightning基带上的插槽里翘起。
  73. iPhone 6 Plus 后盖更换: 步骤 73 中的图像 1,1
    • 抬起并从手机中移走天线连接头。
  74. iPhone 6 Plus 后盖更换: 步骤 74 中的图像 1,1
    • 移除以下用来固定lightning接口基带的飞利浦 #00螺丝:
    • 2个3.2mm螺丝
    • 1个3.8mm螺丝
    • 2个1.7mm螺丝
    • 2个1.5mm螺丝
    • 2个1.4mm螺丝
  75. iPhone 6 Plus 后盖更换: 步骤 75 中的图像 1,1
    • 用镊子夹住位于耳机插孔右侧的塑料夹片并将其从手机中移走。
  76. iPhone 6 Plus 后盖更换, lightning接口和耳机插槽线缆: 步骤 76 中的图像 1,1
    • 下一步需要将lightning接口和耳机插槽的线缆从其所粘在的后壳上剥下来。我们十分推荐使用iOpener在手机后面加热软化粘性物质。
  77. iPhone 6 Plus 后盖更换: 步骤 77 中的图像 1,3 iPhone 6 Plus 后盖更换: 步骤 77 中的图像 2,3 iPhone 6 Plus 后盖更换: 步骤 77 中的图像 3,3
    • 用翘片慢慢的将lightning和耳机插槽线缆从后壳上剥下来。
    • 在线缆的右侧小心地使用翘片,确保一碰到底部就停止移动翘片。
  78. iPhone 6 Plus 后盖更换: 步骤 78 中的图像 1,1
    • 将翘片插入线缆的右下部。
  79. iPhone 6 Plus 后盖更换: 步骤 79 中的图像 1,2 iPhone 6 Plus 后盖更换: 步骤 79 中的图像 2,2
    • 在线缆上侧滑动翘片把将线缆粘在后壳上的粘性物质划开。
  80. iPhone 6 Plus 后盖更换: 步骤 80 中的图像 1,1
    • 抬起并从手机中移走lightning接口和耳机插槽组合线缆。
  81. iPhone 6 Plus 后盖更换, 后盖: 步骤 81 中的图像 1,1
    • 就只是后盖了。
结论
请倒序重组你的设备。
59等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Jeff Suovanen
于08/06/13注册
428,031 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,767篇指南
6条评论
what are the 5 metal "spacers" attached to the housing? they are simplistic metal spacing bars with a tiny rubber block. all held to the left side and right side walls with 2 screws per spacer. The instructions totally skipped this step about removing them. all housings i see being sold do not include them, so wouldnt you want to move them over too?
quysu714 - 回复
they probably don't add it because its pretty self explanatory.
Chris Gourlay -
step 84, When you have finished tearing it all down, there are a couple of things you missed, the rubber piece that is connected to the case near the speaker and the charging port housing when you remove the board at the bottom.
jamielee2k - 回复
In addition to the metal "spacers," the screen for the speaker and the charging port housing, don't forget to transfer a few other things that weren't mentioned in the guide to your new rear case: the power button, the little metal switch for the sim tray; there's a tiny black speaker screen near the headphone jack that must be transferred over (might want to clean it off if it has collected dust); in the top left corner there are two more screws to loosen: one is for a tiny metal spacer piece and the other for the antennae connector cable; there is also a little metal square that cushions the antenna connector's socket; a small strip where the earpiece speaker would be that looks like a black rolled piece of tape; and finally, the foam cushion for the rear camera and the little black screen next to it. But yea... pretty self explanatory.
ikennaugwuh - 回复
Hi all,
During the instructions, the screws flip from having #00 next to them and then nothing.
Does this mean that these screws are different? If so, how do you differentiate them? I have a replacement set of screws that are unsorted so hoping to sort them with my digital caliper.
All the best
Mike
dixonmichael1989 - 回复
Phillips #00 is the driver size, so unfortunately it’s not much help for sorting the screws. Check each screw length with a digital caliper and compare against the guide. When you find a good candidate, carefully thread it into place and don’t force it. If it doesn’t feel right, back off and try a different screw. Good luck!
Jeff Suovanen -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 40
过去 30 天: 102
总计 146,649
