简介
使用本指南对iPhone 6 PLus 音量键和静音键进行更换。
这个指南需要对拆下电池,当重装电池时,你需要这个指南:this guide
对电池胶条进行更换。电池是很严格保护的设备,但重新正确安装也是可用的。
你所需要的
将蓝色手柄拉向铰链以解锁反向钳的手臂。
将反向钳手臂滑过 iPhone 的左边缘或右边缘。
将吸盘放在靠近 iPhone 底部边缘的位置——一个在正面,一个在背面。
向下推吸盘以将吸力施加到所需区域。
将蓝色手柄向前拉,以锁定双臂。
顺时针旋转手柄 360 度,直到吸盘开始拉伸。
当反向钳创造出足够大的间隙时,将撬片插入屏幕下方。
跳过下边两个步骤
Use clear nontextured tape place that over the phone screen. Refer to any guide that addresses replacing a shattered screen
如果你没有 iSclack,使用单个吸盘来打开前面板:
把吸盘放到屏幕上,正好在 home 键上面一点。
Avec la ventouse, l’ouverture est brutale, tout s’est déclipsé d’un seul coup. Faire attention.
English Please!
With the sucker, the opening is brutal, everything was cleared at once. Pay attention. (Paul’s comment translated by Google)
May need to burp the sticker before it sticks. Need to let the air out. Once Idid that, no problem. Except it was still hard to get the cover to start up.
Don’t waste your time with the suction cup - it doesn’t work! insert the blade of a box cutter just below the lower screen edge below the home button and gently pry just enough to start cracking the seal.
一只手把 iPhone 按下的同时,把吸盘轻轻地往上拉,使前面板组件和后机壳分离。
使用塑料撬棒,开始轻轻地把后机壳撬下来,在这个过程中继续拉吸盘。
watch out for the left side of the phone the adhesive bunches up around the inner clips, i didn’t realize it and the upper left of my screen cracked pretty bad. But this guide is awesome follow every direction to the letter
Note: this comment is written for the iPhone 6 Plus, but may also apply to other models of iPhone.
Disassembly:
The clips in the rear case attach to small slotted shapes under the edges of the display assembly, and these attachment points alternate from one side to the other. Moving from bottom to top, gently pulling the rear case away at these points will help to separate the two halves without using too much force.
Reassembly:
Ensure that the plastic clips along the top edge of the front panel (shown in step 8) are fitted properly inside the rear case, then gently press the display assembly into the rear case at these points, moving from top to bottom. There may be a small click sound as the clips in the rear case engage with the slots on the display assembly, and the rear case should fit flush with the edges of the display assembly.
This was challenging. For me, the suction cup could only create a tiny bit of motion and at first, no actual gap at all. You might have to pull the suction cup away from the base a few times just to loosen things up a tiny bit. Eventually, I got my fingernail in, and then after a few minutes got the plastic tool in.
Also, use the plastic tool to gently pry along the sides of the phone once there’s light there. I was afraid of using too much leverage and breaking the screen as per the other comments, but starting at the bottom and then going around the sides slowly worked for me.
拉住吸盘上的塑料凸起,破坏真空环境。
把吸盘从显示屏组件上移除。
There is an adhesive strip all along the edge between the top and bottom of the phone. Is that just adhesive or is it wire of some sort?
@lingerling The adhesive strip was introduced on the iPhone 6s and 6s Plus (one model year later than what’s shown on this page). Guides specific to each model can be found here—be sure to use the correct one for your particular phone. And yes, just adhesive, no wires. ;)
拉起 home 键一端的前面板组件,以手机顶端为轴。
把显示屏打开到角度为 90º ,把它如图所示靠在某物上。
使用橡皮筋把显示屏固定在盒子上。这可以避免对显示屏电线不必要的拉扯。
Be careful If we leave the screen connected and set it to 90 degrees, the speaker / sensor flex may break. With an opening of 60 degrees it is convenient to completely disconnect the screen. The headset's flex is short, and if we put it at 90º, it can break. Guiding me from the images of iFixit, I have broken two cables.
Español:
Cuidado. Si dejamos la pantalla conectada y lo ponemos a 90 grados, el flex del altavoz/sensor puede romperse. Con una abertura de 60 grados es conveniente desconectar enteramente la pantalla. El flex del auricular es corto, y si lo ponemos en 90º , se puede romper. Guiándome de las imágenes de iFixit, se me han roto dos cables.
At 60º the display will block access to all the screws and the phone would be practically unserviceable, so I’m having trouble making sense of this comment. The cables on a factory original display are pretty tough and designed with enough slack that a 90º angle is no problem. Same with any decent aftermarket display.
If you look at the enlarged image, you can see how the flex cable from the camera / speaker is in tension. This is my opinion. Sorry for my bad English
Si usted se fija en la imagen ampliada, puede ver cómo el flex cable de la cámara/altavoz está en tensión. Esta es mi opinión.
Perdón por mi mal inglés
your English isn’t the issue, it’s the proposed 60 degree opening space that doesn’t allow for the removal of the screws of the mounting plate where the connectors connect to the main pcb…
if can make a recommendation here; it helps if the can is full and not refrigerated, the weight helps in keeping the phone where it should stay without adding additional tension to the ‘flex’ ribbon cable. it’s called flex for a reason people, if your breaking these the phones already been overheated too much, the cables become brittle and should also be replaced. i replaced my battery without disconnecting the screen, at 90 degrees with a rubber band around an empty beer can. pierced the orig. battery and caused sparks. albeit, i wasn’t in a hurry and it took me a good 30+ minutes, removal of the battery and stickers is by far the most challenging, especially when NOT disconnecting the screen…
it’s not a race, take your time. move slowly but precisely with forethought and persistent force…
Werkt dit ook voor iPhone 7(plus)?
Werkt dit hetzelfde voor iPhone 7 (plus)?
I would recommend protecting the screen once the display is free and the suction cup has been removed. This will help avoid any possibility of accidental scratching of the display crystal while the remaining steps are being performed. I used an inexpensive screen protector then removed it after reassembling and testing are complete.
将以下00号十字螺丝从电源接口盖移除
一个2.3 mm长的00号十字螺丝
一个3.1 mm长的00号十字螺丝
for the iPhone 6 Plus, all screws were Phillips #000
I had difficulty removing the 3.1mm (iPhone 6 Plus / Phillips #000); had to give it significant downward pressure to get it started.
stripped the 2.3mm screw attempting to remove, had to use excessive force to successfully remove
The Phillips bits provided in the kit would not engage the Phillips heads enough to loosen them. Luckily I had my own small screwdriver set that worked like a charm.
Agree with above comments regarding the supplied Phillips bit. It is not the correct size.
Use a Phillips #000.
bobgottner - 回复
Phillips #000 is what’s included in the kit. As others mentioned above, firm downward pressure is key. The phone is not that delicate; just press hard and crank it.
@asianay0129 Yes, disconnecting the battery is necessary. You can sometimes get away with skipping it, at the risk of destroying something important and potentially bricking your phone. Not a wise gamble for the sake of skipping two screws.
将电源接口的金属盖从iPhone中移除
Was not able to remove the battery connector bracket as one of the cable connectors was glued/stuck to the underside. Instead moved the bracket out of the way to disconnect the battery. Care should be taken not to over bend/stretch the ribbon cable.
That may be just the foam connector adhering to the bracket. If you pull up gently and twist slightly it should separate.
用塑料撬棍从主板上撬下电池排线的接头。
you may consider placing a thin non-conductive item between the connector and the socket like a bit of rubber band to prevent any power flowing during this procedure
J’ai pris une loupe pour bien observer l’endroit où placer l’outil.
Magnification is key for many tasks and this is certainly one.
I couldn’t use the iFixit blue opening tool to pry that battery connector. I used the top of the black spudger near the hole where the 3.1mm screw was in step 9-10 to easily pry it open!
The blue plastic board breaker can easily cause damage here. Professionals would recommend using the human fingernail as the ideal tool for this job.
保持前面板张开立起约90度,卸下前面板排线固定板上的五颗Phillips螺丝。
三颗1.2 mm螺丝
一颗1.7 mm螺丝
一颗3.1mm螺丝
Sounds like you have an iPhone 6s Plus, rather than a 6 Plus. Be sure to use the correct guide! And make sure you’ve ordered the correct part, as they’re not cross-compatible.
I _love_ the color coding of screws. I know this is a little OCD, but it would be incredibly useful if there were an 8.5 X 11 you could print with indicated homes for where to drop items from each step of disassembly. That is, in the box for step 9, little colored circles for where to place each screw type. As long as you don't jostle the paper, it would make it a lot easier to know exactly where you are in reassembly.
I have done the exact same thing. Created a sheet where each screw goes.
Actually you don’t need to do steps 12 to 18 if you attach the display panel to the iPhone box as shown in step 7 and handle your iPhone with care during the replacement. I didn’t disconnect the display panel mainly because the more you work on the interior of your phone the higher is the chance you break something.
Since this guide is for DISPLAY replacement, I don’t see how you can skip the steps for disconnecting and removing the DISPLAY.
That's what I was thinking.
The Wizard - 回复
I skipped this series of steps too. I was very careful when removing the battery and never had an issue with the screen leaning back against the box that this battery shipped in. I even broke half of the third strip of adhesive but used a plastic card to slide under the battery and it slowly lifted out without applying heat.
which screws are which sizes cause i ordered new ones and cant figure it out
I also did not see the need to remove the display assembly for this repair. However I did place a can of corn against the vertically positioned display and then secured the display to the can with a rubber band.
I recommend removing the display assembly, I didn’t and somehow damaged the home button cable. At least remove the cover to ease the tension on the cables.
I played around with different screwdrivers to get certain screws out. I made sure I wasn’t applying heavy pressure so I wouldn’t strip the head. Apple is crazy for doing this to us lol.
Anyways invest in a magnetized mat to organize your screws. It was really difficult to keep things organized and still, especially with these tiny screws…
what happens if i forgot to put the ribbon cable shield back on? the phone is now working but i forgot to put the shield back on and i am missing 2 screws. can i leave the shield off?
@ticoman12 It’ll work without the shield, but the connectors may pop out unexpectedly.
Just be really careful remembering which screw is which. I drew a quick sketch of the bracket, then put the screws in the relevant places. There’s no way I would have been able to figure them out otherwise - my eyes can’t see the difference between a 1.2 and 1.5mm screw!
I also skipped steps 12-18 as Danny had suggested. It made this repair quite easy, so thank you and others for suggesting this. I was also very careful to allow the battery to discharge before starting the process.
I question whether Steps 12-18 (separating the display from the case) is actually necessary? The battery can be removed/replaced with the display connected (but standing upright, as displayed in Step 7.
Leaving the display attached obviates the most difficult steps (re-connecting the various control ribbons — 3/4 of ‘em!
I followed this manual completely and the repair was successful. But if I had this to do over, I’d leave the display connected.
Dana Smith - 回复
I skipped the steps 12-18 as well and thank goodness I did so I won’t have to worry about issues with any of the cables.
my panel is different from what is pictured anyway ‘cause I have one screw in the middle like what Herbert said on the first comment.
I realized too late just how handy the magnetic mat is that they have in their shop. So I organized the screws with a piece of clear packing tape. On the smooth side, use a sharpie to draw spacious circles with “R” “O” and “Y” inside each circle to represent the color coded screws and then use the sticky side to keep the screws in place. I found that using the tweezers to take them off the screwdriver helps you stick them head first to the tape better.
使用撬棒的平头断开前摄像头和传感器排线接口。
Why does the screen need to come off?
Because the cables are delicate, and following steps are easier if phone halves are not flopping around together, especially for amateurs.
I don't know if anyone will see this but here it goes: for the life of me I can't get the front-facing camera and earpiece speaker connector to seat. Everything else went back together fine but this one connector will not go in. Sometimes it seems like it's in even though it doesn't really pop in and it'll kinda sit there for a sec and then it pops out.
Any insight would be greatly appreciated, thank you
用撬棒的平头断开显示排线接口。
The piece of advice about power cycling the phone by disconnecting and reconnecting the battery proved crucial to the success of my repair (camera and lens replacement). At first when charging the phone after closing it, I got a dark, blank screen with an intermittent buzzing noise. After re-opening the phone and making sure all cables had been properly reconnected, I ignored the advice to power cycle the phone. Still all I got was a dark, blank screen (and intermittent buzzing if charging t). Then I opened it a third time (leaving the screen connected and attached at a 90 degree angle) and I only disconnected and reconnected the battery. Voila! When I closed the phone and powered it up, I got the screen to light up!
how did you disconnect and reconnect the battery?
If you’ve been following the guide, you already disconnected it in this step. To reconnect it, just line up the connector and press it into place.
After replacing the battery, the phone seems dead. I thought it just needed recharging so I left it charging all night. Still dead in the morning. Now I think it might be because the display data cable is off, and I should open the phone and check it. But the battery might be on full power in that case, and they don’t advice to open the phone when battery if full. What can I do?
The advice aims at avoiding battery fire. Just be careful.
用撬棒的平头断开触摸层排线接头。
some images and guidance regarding reassembly would be helpful. You don't need to use the spudger to get them back on: fingers are better because there's a really subtle click you feel when you get them seated properly.
When you're reassembling, a note that this is the step where you should test for proper screen function would be really useful. First time I reassembled, I didn't seat something properly, got all the screws back together and then realized the screen wasn't functioning properly. Had to disassemble back down to step 14 and then re-reassemble.
I am having this issues right now! I have unplugged and plugged in these cables at least 20 times and each time I get white lines. I finally have it to where there are only 4 white lines and I am almost willing to live with it. Any suggestions?
Clean the screen connectors incase they are not making a clean connection
I'm having nightmares with the digitizer connector. Simply can't get it to work unless I'm applying some pressure on the connectors. Everything seems almost microscopically clean. Any suggestions friends?
Henry A -
To ++mattmay002++ Did you power cycle the phone? Check out the comments on the previous step for a how to.
I had issues with it too. When connecting this cable, make sure to rock finger side to side after connecting. It’s a wide connector so try to listen for 2 clicks on this one connector. That’s how I fixed mine
Re-attaching this cable is the only tricky part to replacing the battery on my 6+. It had a bow on the middle that I had to flatten out before pressing the connector on with finger first on one edge and then on the other. I had white tire tracks on the screen and no touch screen until I connected it correctly. The front has to rest in just the right place on the back while attaching this thing so the cables aren’t strained the front doesn’t fall down. Small fingers would be a plus at this step.
Reseating these connectors on reassembly is definitely the most difficult part of this repair. It took me several attempts before the lowermost connector would seat properly and I did accidentally bend it slightly in the process. Fortunately I was able to get it straight again and get it to click in. The other three went in fine though and no lasting damage seems to have been done.
Another thing - These cables can become overlapped in the wrong way and make you think they are in a different order than they should be. Eg. it’s easy to mix up the ones from step 15 and 17. You can actually unravel the cables and re-layer them on top of each other in any order, so remember this! They look like they’re one solid mass but they’re not.
I never removed the last digitizer connctor. I removed the first three connectors, left the screen propped at 90 deg tied to a box and removed the battery, there is minimal movement. In fact when I reattached the connectors, only the first and maybe second connector feels taut, so it’s necessary to only remove the first connector if you can be gentle with it. Less headache. And my guess why so many people had issues is that micro dust gets into the connectors and cause connection loss. You be surprised how little dust can cause havoc.
I haven’t removed my screen in past battery replacements, I found it easier. However, this time I followed the instructions because my old battery was very stuck, and I needed the screen gone to get the battery out…
When I replaced the screen, at first it wouldn’t even boot/start up. (Yes, I inserted my own testing step, as someone here suggested, before final reassembly).
The screen would just show a fuzzy image, and the board that all the cables attach to would heat up, then it would turn itself off. I tried reconnecting them carefully 3 times, and even made sure to get a little “click”, all to no avail.
The final try, I used my fingernail to really press down on the back side of the digitizer cable. I heard more clicking, though I thought I might be tearing the cable too. With nothing left to lose, I continued across the back, and heard several more clicking/tearing sounds.
This worked, and it booted after that. It still had white lines, but those faded away overnight.
About the digitizer connector: its flat cable is so short that the when I attempted to seat the next connector, its flat cable pressed on the digitizer cable, which can pull on the connector and dislodge it. That happened several times for me before success.
Robert Bernard 27 Nov 19
Nous n’apercevons pas bien les nappes et l’ordre dans lesquelles elles doivent être replacer
此时,前面板可以彻底与机身分离了。
Never remove the screen without disconnecting the battery. It's possible the back light can be blown and that's a even more difficult repair. Always, ALWAYS, disconnect battery before repairing items. (Unless it's not possible.)
How do you disconnect the battery from the screen?
The Step 11 disconnects the battery :)
jeffxtechs - 回复
I think you mean Step 8 :)
And what? I tried it once and here’s a million dollars?
Oh I get it… they got him! :(
domarius -
When disassembling the iphone at this point note the cables, and there placement/orientation.
Be really careful with the step after this. Do not commence until you have read all the comments. You need to get a good hold of the plastic strips preferably before they double over on themselves. You have to avoid puncturing the battery at all costs. Slowness and caution here will save you a lot of long term pain.
从电池右下角剥离第一个电池胶带。
Ça été pour moi la partie la plus difficile du démontage de l’iPhone, j’ai cassé les 2 bandes parce que je ne me suis pas bien appliqué pour les décoller avec la pince. Pour m’en sortir,. j’ai tordu la batterie avec les outils de manière à faire apparaître les bandes adhésives pour les enlever sans problème.
Translation from Google:
It was for me the most difficult part of the disassembly of the iPhone, I broke the two bands because I did not apply well to take off with the clamp. To get out of it ,. I twisted the battery with the tools so that the adhesive strips appeared to remove them without any problem.
Slowly roll the pulled-out adhesive onto itself as you progress, this makes it easier to gauge how much stretch you need to exert on the remaining adhesive, as well as to gain enough grip to hold the adhesive properly. I also nearly tore off the middle one, it’s not due to my rough but because the battery’s black tape (at the area where these adhesive tabs are) caught onto the white adhesive, this must be the reason why most people’s tore off. Mine nearly tore off, so i slow rolled the pulled-out adhesive to catch back the adhesive, and then it’s roll and pull as per normal. With that I took equal precaution for the last one on the left, and it also was caught by the black tape, but since i know it this time, i slowly pulled it free of the black tape first before continuing the roll snd pull. 100% works. Trust me. My battery is slightly warm as i deliberately let it run for a while before i started the disassembly. I doubt it contributes much to the removal but no harm.
It's easier if you grasp the full width of the adhesive strip, straight across it, before starting to pull. That way the force is applied gently and evenly to the whole strip. I used watchmaker's forceps because they precisely pull up the adhesive tab, and easily squeeze the whole width of the strip—since it's critical to apply the pulling force evenly across the strip. Tug gently and twist the forceps to take up the slack, pulling just a few millimeters at a time. I learned this the hard way. My center strip snapped pretty quick because I didn't have a good, even grasp of it.
For heat, I put a cup of raw white rice in a clean sock, knotted the open end, and microwaved it for 2 minutes. When it was cool enough to handle, I flattened it on the table and lay the phone upon it. That gave off enough gentle steady heat that I could pry up the battery without much bending, locate the adhesive end, and successfully wind it up with the forceps. I think I would use the hot rice-bed from the start next time. —Kw -
请缓慢地将胶带由电池向iPhone底部方向拉出
以尽可能低的角度拉出胶条,在拉出胶条过程中不要碰到手机上的任何配件。
在拉出胶带的时候,请不要按压电池
All three of mine tore off immediately, I had warmed the phone up too. A bit of a struggle with the tweezers and card method, the battery bent and leaked. Came out okay.
I even didn’t find an adhesive in my phone, I had to use hairdryer to heat the battery, then remove it gently using the blue plastic and couple of plastic cards
I can’t stress enough how important it is to preheat the case as others have mentioned. GPZ’s recommendation using a pencil is also pure gold - get enough initial purchase on the adhesive strip so that you can pull it taut and then place your pencil. From there, roll and tag alternately, keeping tension on it so that the adhesive doesn’t wrinkle in the process of removal.
Jesse Espe - 回复
Heating probably works but I slowly pulled out an inch or so and then started rolling it onto my screwdriver. Then I slowly rolled the screwdriver which gave me a good grip and I could go slowly. Took more than 5 min but it got easier and easier. Believe me, getting the battery out using the alternative is very hard, and dangerously easy to penetrate the battery and start a small flame thrower (voice of experience).
在电池的另一侧将易拉胶条头拉出
再次,慢慢拉出易拉胶条头,将它从电池与后盖之间拉出。
继续拉出易拉胶条头直到它完全剥离电池。如果中途断裂,请卷起剩余的部分继续拉,或者按照以下步骤处理
This strip broke almost immediately with the first pull. I changed the battery on two iPhone 6 Plus’s. Impossible for me to retrieve broken ends. I moved on to the middle strip with no issue. I then used the blue opening tool to pry the battery up along the lower right edge of the battery (BE CAREFUL!). Once the battery is leveraged up enough to put the tip of the tweezers on the broken strip, grab a piece of the strip and pull it to a point where the removal process can continue as prescribed.
从电池底部边缘拉出最后一条易拉胶。
向上轻拉易拉胶使其从电池和后盖间慢慢分离出来。
继续轻拉易拉胶使其从机身中完全分离出来。
如果你成功将三条易拉胶取出,请跳过以下两步
Pull the adhesive strips at a 45° angle up away from the back or the strip will catch on the bottom board and will tear and break. If it starts to tear, , see if you can grab a spot after the ear and keep pulling. These things are super thin and fragile. Go sloooow when you pull the strips. You are going to pull them a long way, so be patient.
Ok, so you broke one. Or two. Or all three. Forget the alcohol. Lay your phone face down on a towel and heat it with a hair dryer for two minutes. Flip it over carefully as it will be hot. Insert a plastic spudger under the bottom edge and carefully push/slide it under the battery toward to top of the phone along the strip(s) that are still stuck. DO NOT PRY. You may have to heat it again if it gets hard to push. BE CAREFUL. The battery will bend a bit, but don’t bend it excessively or poke it as it can catch fire when exposed to air. Eventually the battery will pop free. Remove the stuck adhesive and wipe it a bit with alcohol and let it dry.
翻转iPhone,从左侧插入一张卡片到电池和后盖间隙间。
轻压卡片使易拉胶从电池背部分离出来。
把牙线或吉他弦放到电池的一端,使用锯东西的移动方式来分离黏胶。
Hat leider alles nicht geklappt! Musste mit einer Karte und einer Seite sehr lange fummeln und da sich die Folie vom Akku zu sehr mit dem gehäuse verbunden hat. Dadurch hat sie sich gelöst und durch das erwärmen leider auch nicht wirklich besser.
Unfortunately, everything did not work out! Had to fumble with a card and a page for a long time and because the film from the battery has too much connected to the housing. As a result, she has solved and by warming unfortunately not really better.
Ken -
This step was very difficult as the adhesive strips snapped on me and I had to use a card to make the strips come out by siding the plastic card on the strips as thought I was trying to cut a very thin slice of cheese. (NOTE: DO NOT USE ANYTHING METAL when attempting this method) I actually tried using a metal spudger while trying to remove the adhesive strips and punctured the old battery slightly enough to cause smoke.
iBreak-it: caught the wifi antenna connector when using a guitar string to work the extremely stubborn battery adhesive strips off. Now I need a new wifi antenna. What next?
将电池从机身中取出。
Once again, ifixit comes through! I bought the battery and the repair kit and the new battery installed and charging. My only hitch was that the three adhesive strips all broke when I pulled on them. I had to heat the bottom of the phone to separate the battery. It was a small moment of panic, but it just required a bit more patience. Thanks for all you do!
Awesome procedure! Thanks. iPhone 6plus working great. Make sure you have quality tools. Thanks again.
Everything went well enough but, I replaced the battery last month and after a while the phone started going into an on-off cycle. It only happens intermittently. At first it would do it only once and stop. Now it does it, still intermittently, but when it happens it keeps cycling on and off. It even does it when it’s charging. If I let it sit, while charging, after several hours it stops doing it again.
The battery kit didn’t come with adhesives. It seems that I’m not the only one to mention it .
Nat Turner - 回复
Hi there! The battery kit does come with replacement adhesive along with all the tools needed to complete the repair. The part-only battery does not include adhesive, it needs to be purchased separately!
i turned on my phone and the screen is all stripes :(
Sounds like either the display cable isn't properly connected or it’s been damaged. If all else fails, send it to a professional.
Rongwey -
The Ifixit battery comes with new adhesive strips already attached to the battery. Suggest that it’s best to leave the protective acetate over the strips until AFTER the new battery is re-connected and the connector cover is reinstalled (2 screws). Then its easy to remove the acetate cover from the adhesive strips and locate the battery.
If the battery is stuck in (with the adhesive strips BEFORE the connector is correctly installed it is impossible to adjust the position of the battery to align the connector.
Dana Smith - 回复
用镊子夹住音量键以及静音键排线。
慢慢的拉起音量键以及静音键排线从后盖上。
小心的拉起排线。排线是用薄薄的胶条贴在后盖上的。
请倒序重组你的设备。
请倒序重组你的设备。
36等其他人完成本指南。
由衷感谢以下译者:
100%
Warrior E正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Pentalobe P2
Enea Del Lama - 回复
I prefer to remove the SIM card as the very first step since it's safer to do so while the phone is fully assembled.
estebanfallasf - 回复
I stripped one of the two screws - at a dead stop.
Margaret Patterson - 回复
Before you even start: get the iOpener or hairdryer out. You’ll need it
GPZ - 回复
If a lightning connector won’t provide a charge or needs to be wiggled carefully to provide a charge, power off the device, then try using precision tweezers to scrape the innermost wall of the lightning jack in a pinching motion to check for lint buildup. Pocket lint or other debris can accumulate inside the jack, compacting each time a cable is inserted. This can prevent a lightning cable from seating fully. Clearing the lint may restore functionality without replacing the part.
Andrew Dolan - 回复
A few hints:
* heating up the phone works great. I used a heating pad that you put in the microwave to heat sports injuries.
* also, I made a sheet to help you keep track of the screws as you remove them. Print out the page, then place double sided tape below each color-coded listing of screws, and stick the screws to the tape as you disassemble. This helps prevent losing the screws and keeps track of what screws are what for easier reassembly. https://drive.google.com/file/d/1pLSvKvB...
Paul Faulstich - 回复
Additional hints, for anyone who needs them:
* stick the screws to the tape in the same positions as they are shown in the guide. This will make it easier to identify them during reassembly.
* if the screws get mixed together, the ‘mm’ (millimetre, millimeter) measurements given in the guide can be used to identify them. Compare the lengths of the threaded shafts to each other to determine which screw is which.
Friendly Advice -
