简介
prereq only (full home button guide includes removing gasket)
你所需要的
在这个步骤中使用的工具:iOpener$19.99
Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button membrane.
Using your fingertip, apply firm, constant pressure on the home button from the front side of the display assembly, until the membrane starts to separate from the front panel.
9等其他人完成本指南。
一条评论
Home button robin cable malfunction after replaced.
Replaced broken Home button robin cable, now the phone will not turn on unless I unplug the home button cable from the mother board! I've thought of placing the phone in recovery mode and placing the phone in factory setting then trying to reconnect the cable, BUT to do that the home button has to be WORKINGand it's NOT working. Also the phone as the current iOS on it... Any ideas other than buying a new home button cable and trying the replacement again?
