跳转到主内容
iPhone 5s Front Facing Camera and Sensor Cable Assembly Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iPhone 5s Front Facing Camera and Sensor Cable Assembly Replacement, Front Facing Camera and Sensor Cable Assembly: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    iOpener
    $19.99
    购买
    • This step requires removing the front facing camera and sensor cable from your front panel assembly.
    • The front facing camera and sensor cable is adhered to the display assembly with mild adhesive.
    • Using an iOpener to soften the adhesive will help safely remove it. Follow our iOpener instructions to use it.
  2. iPhone 5s Front Facing Camera and Sensor Cable Assembly Replacement: 步骤 2 中的图像 1,2 iPhone 5s Front Facing Camera and Sensor Cable Assembly Replacement: 步骤 2 中的图像 2,2
    • Using the edge of a set of tweezers or a metal spudger, gently pry the earpiece speaker contact cable up, to separate this portion of the camera and sensor cable from the adhesive below.
    • Only pry directly under the earpiece speaker contacts—there are sensors and microchips that can be damaged by prying elsewhere.
  3. iPhone 5s Front Facing Camera and Sensor Cable Assembly Replacement: 步骤 3 中的图像 1,2 iPhone 5s Front Facing Camera and Sensor Cable Assembly Replacement: 步骤 3 中的图像 2,2
    • Use the point of a spudger to lift the ambient light sensor and proximity sensor out of their recess in the display assembly.
    • There is a small, square plastic and metal holder for the proximity sensor. This holder is essential for the proximity sensor to function correctly.
    • If replacing the proximity sensor make sure that the holder remains adhered to the back of the display. If it comes off with the old proximity sensor, remove it from the old sensor and use a tiny bit of adhesive to re-attach it to the back of the display.
  4. iPhone 5s Front Facing Camera and Sensor Cable Assembly Replacement: 步骤 4 中的图像 1,2 iPhone 5s Front Facing Camera and Sensor Cable Assembly Replacement: 步骤 4 中的图像 2,2
    • Use the flat end of a spudger to gently peel the front-facing camera portion of the cable away from the display assembly.
  5. iPhone 5s Front Facing Camera and Sensor Cable Assembly Replacement: 步骤 5 中的图像 1,3 iPhone 5s Front Facing Camera and Sensor Cable Assembly Replacement: 步骤 5 中的图像 2,3 iPhone 5s Front Facing Camera and Sensor Cable Assembly Replacement: 步骤 5 中的图像 3,3
    • If you are reattaching the same shield plate to a new display, there is no need to peel the cable assembly off the LCD shield plate. Skip this step.
    • Carefully peel the cable assembly off of the LCD shield plate to remove it from the display.
    • Be careful not to grab the digitizer cable while peeling up the front facing camera and sensor assembly cable.
结论
9等其他人完成本指南。
Sam Goldheart
于10/18/12注册
465,647 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,732篇指南
2条评论
Be great if someone could put together some *reassembly* instructions for this. Particularly the section on the camera and sensors area.
Phil Thomas - 回复
It seems like a lot of steps have gone missing from this guide. The related guide (5SE) has much more explicit instructions for the same activity and should be used instead of this one. iPhone本身的前置摄像头和传感器电缆更换
Jeannie Crowley - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 6,308
