简介
本指南将教您如何更换 iPhone 5s 屏幕。此类屏幕已经附带前置摄像头、听筒和传感器排线,可以使更换更加简单。
您所要做的只有两件事:把屏幕换掉。然后把Home键移到新屏幕上,以使用Touch ID (指纹识别)的功能。
视频概述
握紧iSclack的把手,打开它的吸盘口。
把你iPhone的底部放置在两个吸盘之间,紧紧靠住塑料的深度计。
上面吸盘应该刚好在home键的上方位置。
使用iSclack把手把钳口合上。把吸盘放到手机中间,并且把吸盘牢牢地按到iPhone屏幕上和机身底部。
拿紧你的iPhone,然后合拢iSclack的把手,这样屏幕就和机身分离开来。
iSclack是专门设计用来打开你的iPhone的,它能够很好的保证在分离屏幕和机身时不扯断Home 键排线。
跳过下面三步,直接到第九步。
一只手固定好iPhone机身,另一只手轻轻地把机身从前面板底端的home键上分离。
当你左手使用吸盘拉动的时候,右手用塑料撬棒在后机壳边缘处,轻轻地撬动,使屏幕和机身分离。
稍微打开屏幕,可以看到盖住home键电线的挡板铁片就可以了。
只有手机原装的Home键组件才能使用Touch ID功能。如果你扯断这根电线,装上新的home键只能恢复home键功能,而将失去Touch ID功能。
使用手机撬棒推动松下铁片,再用镊子取下来。
一旦连接器被撬开了后,把home键底端从机身上拉起,把手机顶端当做一个转动支点。
把显示屏立起来,保持跟机身成90度角。在你维修手机的过程中一直保持这个状态。
用橡皮筋把显示屏如图三所示固定住。这会避免在维修过程中显示屏电缆的损坏。
要重新组装你的设备,请按相反顺序执行上述步骤。[...]将新的更换部件与原始部件进行比较。在安装之前,你可能需要转移剩余部件或从新部件上移除粘合剂背衬。将你的电子垃圾带到R2或e-Stewards认证的回收商。修理是否没有按计划进行?查看我们的问题解答社区以获取故障排除帮助。
1314等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
80条评论
Excellent guide, many thanks to the author and commenters. I replaced the rear facing camera at the same time and had no issues with parts or tools.
Agree with the comment from Nathan for Step 17 to be careful not to displace the captive spring, it would have slipped away from me if I had not read the comment. Tricky to manouvere that part.
Get the magnetic mat, makes things a lot easier. Thanks again.
Hi, i have problem with my earpiece speaker after i reassemble my screen, it doesn't work and i should talk with the speaker, why it happen and what should i do???
Tanks.
This same thing happened to me. I had to take the front camera/sensor assembly out of my old device and use it with the new display assembly. Thankfully that part wasn't damaged or I would have been screwed.
Jorden -
I think ifixit have miss-drawn the screws for the LCD Plate. I believe the two motherboard (lower/bottom) screws should be the short ones, and the "red screws" should go at the top. Only the bottom 2 go into the PCB, the others go into pillars. Please can someone check this. As putting the 1.7mm in the Bottom Left Corner is a bad idea. it should be the 1.3mmm
