简介
使用本指南来代替含有前置摄像头、麦克风、环境传感器排线和耳机扬声器接触垫,在您的iPhone 5s。
你也可以使用本指南来代替以下部分:
你所需要的
一只手固定好iPhone机身,另一只手轻轻地把机身从前面板底端的home键上分离。
当你左手使用吸盘拉动的时候,右手用塑料撬棒在后机壳边缘处,轻轻地撬动,使屏幕和机身分离。
稍微打开屏幕,可以看到盖住home键电线的挡板铁片就可以了。
只有手机原装的Home键组件才能使用Touch ID功能。如果你扯断这根电线,装上新的home键只能恢复home键功能,而将失去Touch ID功能。
使用手机撬棒推动松下铁片,再用镊子取下来。
一旦连接器被撬开了后,把home键底端从机身上拉起,把手机顶端当做一个转动支点。
把显示屏立起来,保持跟机身成90度角。在你维修手机的过程中一直保持这个状态。
用橡皮筋把显示屏如图三所示固定住。这会避免在维修过程中显示屏电缆的损坏。
这个步骤还没有翻译 帮忙翻译一下
Place the earpiece speaker bracket over the speaker so that it fits snugly in its housing.
Slide the left hook of the bracket into the notch above the top left corner of the front facing camera.
Rotate the bracket so it lays flat on the rear case, aligning the two screw holes. Press the bracket into place, ensuring the hook on the right side of the metal bracket latches onto the display.
将您的设备,遵循这些指示,逆序重组。
将您的设备,遵循这些指示,逆序重组。
152等其他人完成本指南。
由衷感谢以下译者:
87%
Leeroy_正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
21条评论
I'm confused as to what you attach the top part in the last picture, the part with yellow or orange on it? Does that connect to the grounding sticker portion? And how is that removed originally, just by pulling it off?
How do you attached the copper grounding shield to the new proximity flex ribbon?
I can't find a video showing that anywhere
jlh -
I have to second Machek Kozoil's question. What do you do with the yellow contacts? I can get the proximity sensor to work but not the camera. I assume it has to do with these yellow contacts. Any ideas? If anyone knows I will make a youtube video explaining this for others as I haven'y found one yet. In the link below I have included a picture of the factory part on top and replacement part on bottom.
lanekrarup - 回复
As someone has suggested, it is probably a part used in manufacturing process. The original part doesn't have it, and it seems to be cut off. And that is exactly what I did, and everything works. There is nowhere to attach it anyway so instead of folding it and trying to fit it in, you might as well just cut it off.
This is not a good guide. iFixit have been very lazy on the final, critical points regarding the EMI shielding. Without correct shielding the screen will wobble or the camera/proximity sensors will fail.
