跳转到主内容
修复你的物品
维修的权力
配件 & 工具
  1. Use the flat end of a spudger to disconnect the audio control cable connector from its socket on the logic board. Disconnect the rear facing camera cable connector from its socket on the logic board.
    • Use the flat end of a spudger to disconnect the audio control cable connector from its socket on the logic board.
    • Disconnect the rear facing camera cable connector from its socket on the logic board.
  2. A small piece of tape may obscure the logic board grounding clip. If so, use a pair of tweezers to remove the tape.
    • A small piece of tape may obscure the logic board grounding clip. If so, use a pair of tweezers to remove the tape.
  3. Remove the following screws securing the logic board grounding clip to the rear case: 1.2 mm Phillips #000 in the top side-wall
    • Remove the following screws securing the logic board grounding clip to the rear case:
    • 1.2 mm Phillips #000 in the top side-wall
    • 2.5 mm Phillips #000
  4. Manta 螺丝刀工具包
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  5. Use tweezers to remove the logic board grounding clip.
    • Use tweezers to remove the logic board grounding clip.
  6. Remove the following screws securing the logic board to the rear case:
    • Remove the following screws securing the logic board to the rear case:
    • Two 2.3 mm Phillips screws
    • Three 2.7 mm standoff screws
    • Standoff screws are best removed using an iPhone Standoff Screwdriver Bit and driver handle.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  7. Holding the phone level, lift the bottom end of the logic board up enough to grasp it with your fingers. Pull the logic board away from the rear-facing camera just enough to expose the gold contact cap under the top end of the board. Remove the gold-colored contact cap from the threaded post in the rear case, and set it aside.
    • Holding the phone level, lift the bottom end of the logic board up enough to grasp it with your fingers.
    • Pull the logic board away from the rear-facing camera just enough to expose the gold contact cap under the top end of the board.
    • Remove the gold-colored contact cap from the threaded post in the rear case, and set it aside.
  8. Flip the logic board up toward the volume control buttons to expose the antenna connector. Do not try to remove the logic board from the rear case yet, as it is still connected by an antenna cable on the back.
    • Flip the logic board up toward the volume control buttons to expose the antenna connector.
    • Do not try to remove the logic board from the rear case yet, as it is still connected by an antenna cable on the back.
  9. Disconnect the antenna connector from the back of the logic board.
    • Disconnect the antenna connector from the back of the logic board.
  10. Remove the logic board from the rear case.
    • Remove the logic board from the rear case.
结论
Andrew Optimus Goldheart
于2009年10月17日注册
444,993 信誉积分
创作了411篇指南
团队
iFixit iFixit 的会员
Community
115 名成员
创作了11,169篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 164
