跳转到主内容
iPhone 5c Logic Board Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iPhone 5c Logic Board Replacement, Logic Board: 步骤 1 中的图像 1,2 iPhone 5c Logic Board Replacement, Logic Board: 步骤 1 中的图像 2,2
    • Use the flat end of a spudger to disconnect the audio control cable connector from its socket on the logic board.
    • Disconnect the rear facing camera cable connector from its socket on the logic board.
  2. iPhone 5c Logic Board Replacement: 步骤 2 中的图像 1,1
    • A small piece of tape may obscure the logic board grounding clip. If so, use a pair of tweezers to remove the tape.
  3. iPhone 5c Logic Board Replacement: 步骤 3 中的图像 1,2 iPhone 5c Logic Board Replacement: 步骤 3 中的图像 2,2
    • Remove the following screws securing the logic board grounding clip to the rear case:
    • 1.2 mm Phillips #000 in the top side-wall
    • 2.5 mm Phillips #000
  4. iPhone 5c Logic Board Replacement: 步骤 4 中的图像 1,1
    • Use tweezers to remove the logic board grounding clip.
  5. iPhone 5c Logic Board Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    Standoff Screwdriver for iPhones
    $5.49
    购买
    • Remove the following screws securing the logic board to the rear case:
    • Two 2.3 mm Phillips screws
    • Three 2.7 mm standoff screws
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  6. iPhone 5c Logic Board Replacement: 步骤 6 中的图像 1,3 iPhone 5c Logic Board Replacement: 步骤 6 中的图像 2,3 iPhone 5c Logic Board Replacement: 步骤 6 中的图像 3,3
    • Holding the phone level, lift the bottom end of the logic board up enough to grasp it with your fingers.
    • Pull the logic board away from the rear-facing camera just enough to expose the gold contact cap under the top end of the board.
    • Remove the gold-colored contact cap from the threaded post in the rear case, and set it aside.
  7. iPhone 5c Logic Board Replacement: 步骤 7 中的图像 1,2 iPhone 5c Logic Board Replacement: 步骤 7 中的图像 2,2
    • Flip the logic board up toward the volume control buttons to expose the antenna connector.
    • Do not try to remove the logic board from the rear case yet, as it is still connected by an antenna cable on the back.
  8. iPhone 5c Logic Board Replacement: 步骤 8 中的图像 1,1
    • Disconnect the antenna connector from the back of the logic board.
  9. iPhone 5c Logic Board Replacement: 步骤 9 中的图像 1,1
    • Remove the logic board from the rear case.
结论
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,757篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 224
