简介
更换内部Lighting接口和扬声器
你所需要的
逐步去除连接后壳并保护Lighting接口和扬声器的螺丝:
一颗 2.5 mm 的十字螺丝
两颗 3.3 mm 的十字螺丝
一颗 2.9 mm 的十字螺丝
两颗 1.5 mm 的十字螺丝
一颗 2.8 mm 的十字螺丝
使用平角撬棒轻轻的撬开Lighting接口和扬声器周围的电线,使其离开后壳。
this is NOT the right way to remove the speaker, anyone following this guide will do unnecessary damage to the phone.
Speaker is one of the "official" serviceable part of iPhone 5. Which means you don't have to remove the logic board and the battery. Skip straight to step 27, peel up the home button contact flex, remove the red, blue, yellow and the green screw, peel loose the grounding flex stuck around the headphone jack, then remove the flex and the speaker as one part. NEVER remove the lightning connector flex unless you really need to.
Heyi successfully took out this speaker and jack but i found 4 small rings and i dont know where they were placed
在后壳上拆下Lighting接口和扬声器组件。
Make sure to clean any bits of golden glue left on the phone case
The metal washers appear to have come from the bottom side of the lightning connector. Underneath the four screws. Two of mine were stuck on the old part that I had removed. I noticed this after installing the parts.
Any idea what is the strip which is stuck on the speaker, which helps connect the two screws? does it have any specific functionality or is it just to keep the speaker in place?
I see that it just connects two end points to the iphone body.
That part is the cellular antenna. iPhone 5 Cellular Antenna
slessard -
I am trying to find these washers that go under the lightning connector as to where I can find an extra one of these for a repair and also need some help figuring out after replacing power cable, LCD and screen, lightning connector and both flex cables on the motherboard, the back case and the battery why the iPhone 5 is not charging or powering on... If you can help me figure out this issue I would greatly appreciate it.
Could one missing washer cause this to be the issue.
跟随本教程步骤反向重新组装您的设备
跟随本教程步骤反向重新组装您的设备
由衷感谢以下译者:
100%
Leeroy_正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Every step after this one is vague and hard to understand. Seems to be a lot missing. Proceed with extreme caution!
Joe Wasser - 回复
