当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
记住从旧的屏幕上取下Home键安装在新屏幕上(大多数情况,新屏幕是没有Home键)。Home键的橡胶垫圈是很薄的注意不要拉断。同时,观察替换的屏幕上是否有听筒网,如果没有,从旧屏幕上取下再装上去即可。
在安装新的屏幕前一定要撕下屏幕保护贴纸(通常是蓝色或者粉红色)。
如果你更换的新屏幕没有直径7mm的前置摄像头固定圈,从旧屏幕上取下安装在新屏幕上即可。
小心拉直屏幕排线和数字转换排线然后从中板打孔处穿过去。图片中图的做法是错误的,使橡皮圈和数字转换排线一起穿过开孔。中图展示的橡皮圈。
这个照片展示了屏幕组件被错误的安装的样子,在数字排线之间留有太多空隙,最终会导致排线弯曲/缠绕最终被卡在凹槽上。第三张照片展示了这个凹槽。
215等其他人完成本指南。
3条评论
I found the tear down somewhat easier than it's predecessor (IPhone 4) though for those attempting this kind of thing for the first time, extreme care should be taken to ensure the right tool is used for each job (ie. Phillips driver for Phillips screw etc.). I inherited this job from a friend that didn't know the difference between Phillips and pentalobe screws and hence destroyed the head of the first screw (and the pentalobe driver) once inside the unit.
Take care and you will enjoy a new found love for the device that YOU repaired.
I completed the teardown, but the metal fingers on the new display don't match the old one, hence the 6 screws that you loosen before removing the display no longer line up. VERY annoying... my phone is in pieces now until I can get a replacement display. Anyone else had this problem? BEWARE.. attempt to check yours before getting too far, line up the new display with the side screws and make sure it fits, it wasn't off by much so check they line up exactly. Did I get a iphone 4 display instead of a 4s? I dunno.. i've emailed ifixit to find out.
Did you put the screen + digitizer in upside down or backwards?
