跳转到主内容
iPhone 4S Battery Replacement
你所需要的
  1. iPhone 4S Battery Replacement, Pentalobe Screws: 步骤 1 中的图像 1,1
    • Remove the Bottom Pentalobe Screws next to the charger connecter.
    • It is recommended that you use a small 5-Point screwdriver.
    • Remember to make sure your iPhone is fully turned off before tearing it down, to prevent serious injury.
  2. iPhone 4S Battery Replacement, Back Panel Removal: 步骤 2 中的图像 1,2 iPhone 4S Battery Replacement, Back Panel Removal: 步骤 2 中的图像 2,2
    • Push the back panel towards the top edges of the iPhone. Doing this should allow the back to slide off.
    • Do NOT apply so much pressure. Especially if your iPhone is cracked.
    • Do not rush it! Time is key.
  3. iPhone 4S Battery Replacement, Battery Screws: 步骤 3 中的图像 1,1
    • Remove these two screws that are securing the battery connecter to the Logic Board.
    • Remember to focus and pay attention. So you don't accidentally slip and pierce the Battery!
    • For the bottom screw, it is recommended that you use a 1.5 mm Screwdriver, and a 1.7 mm for the top screw.
  4. iPhone 4S Battery Replacement, Battery Strip: 步骤 4 中的图像 1,1
    • Locate and pull the Plastic tab to pull out battery. Make sure to pry up outsides of battery on other sides as well.
    • Do not pull the plastic tab to hard, as it can easily rip!
  5. iPhone 4S Battery Replacement, Battery Removal: 步骤 5 中的图像 1,1
    • Carefully remove the battery.
    • Remember, if you are replacing your battery, remember to preform a hard reset on your iPhone once its all finished.
结论
60等其他人完成本指南。
Cole Anello
于11/01/16注册
1,986 声望
撰写一个指南
一条评论
la olum bunu benim 1 yaşında kızım da biliyo
ahmetceylanbm - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 37
过去 30 天: 138
总计 20,622
