跳转到主内容
加入维修社区 - 创建账户
iPhone 4S Battery Replacement
你所需要的
  1. iPhone 4S Battery Replacement, Pentalobe Screws: 步骤 1 中的图像 1,1
    • Remove the two bottom Pentalobe screws next to the 30-Pin connector.
    • It is recommended that you use a small 5-Point screwdriver for this process.
    • Remember to make sure your iPhone is fully turned off before commencing this process, to prevent serious injury to the phone.
  2. iPhone 4S Battery Replacement, Back Panel Removal: 步骤 2 中的图像 1,2 iPhone 4S Battery Replacement, Back Panel Removal: 步骤 2 中的图像 2,2
    • Push the back panel towards the top of the iPhone. Doing this should allow the back panel to slide off safely.
    • Do not apply too much pressure to the back. Especially if your phone has a cracked back panel.
    • Do not rush it! Time is key.
  3. iPhone 4S Battery Replacement, Battery Screws: 步骤 3 中的图像 1,1
    • Remove these two screws that are securing the battery connector to the Logic Board.
    • Beware of unscrewing the battery connector, as your screwdriver does have the possibility to slip and pierce the battery.
    • For the bottom screws, it is recommended that you use a 1.5 mm screw bit, and a 1.7 mm for the top screw.
  4. iPhone 4S Battery Replacement, Battery Strip: 步骤 4 中的图像 1,1
    • Locate and pull the plastic tab to pull out the battery. Make sure to pry up on the outside of the battery on all sides.
    • Do not pull on the plastic tab too hard, as it can easily rip, making the battery removal process harder.
  5. iPhone 4S Battery Replacement, Battery Removal: 步骤 5 中的图像 1,1
    • Carefully remove the battery.
    • Remember, if you are replacing your battery, remember to preform a hard reset on your iPhone by holding on both the home and power button for a few seconds once the repair is all finished.
结论
62等其他人完成本指南。
Cole Anello
于11/01/16注册
2,028 声望
撰写一个指南
1指南评论
la olum bunu benim 1 yaşında kızım da biliyo
ahmetceylanbm - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 41
过去 30 天: 224
总计 24,946
