跳转到主内容
iPhone 4 Verizon Headphone Jack Cable Replacement
你所需要的
  1. iPhone 4 Verizon Headphone Jack Cable Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Your phone's rear cover may have two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws. Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
    • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
  2. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 2 中的图像 1,2 iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 2 中的图像 2,2
    • Push the rear panel toward the top edge of the iPhone.
    • The panel will move about 2 mm.
  3. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 3 中的图像 1,1
    • Pinch the rear panel with your fingers, and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
    • Be careful not to damage the plastic clips attached to the rear panel.
  4. iPhone 4 Verizon Headphone Jack Cable Replacement, Battery: 步骤 4 中的图像 1,1
    • Remove the single 1.5 mm Phillips screw securing the battery connector to the logic board (if present).
  5. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 5 中的图像 1,1
    • Use the edge of a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not the socket on the logic board. If you pry up on the logic board socket, you may break it entirely.
    • Remove the metal clip covering the antenna connector.
  6. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 6 中的图像 1,2 iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 6 中的图像 2,2
    • Pull up on the exposed clear plastic tab to peel the battery off the adhesive securing it to the iPhone.
    • If the tab breaks before the battery is freed, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery. Wait about one minute for the alcohol solution to weaken the adhesive. Carefully slide a spudger under the battery tab to release the adhesive.
    • Prying in other places may cause damage. Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • Remove the battery.
    • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
    • Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
  7. iPhone 4 Verizon Headphone Jack Cable Replacement, Dock Connector Cable: 步骤 7 中的图像 1,2 iPhone 4 Verizon Headphone Jack Cable Replacement, Dock Connector Cable: 步骤 7 中的图像 2,2
    • Remove the two 1.8 mm Phillips screws securing the dock connector cable to the logic board.
    • Remove the thin metal dock connector cable cover.
  8. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 8 中的图像 1,1
    • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
  9. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 9 中的图像 1,1
    • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
  10. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 10 中的图像 1,2 iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 10 中的图像 2,2
    • Remove the 1.6 mm Phillips screw securing the pressure contact to the logic board near the vibrator.
    • Remove the pressure contact.
  11. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 11 中的图像 1,2 iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 11 中的图像 2,2
    • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
    • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
    • When reconnecting the antenna wire be VERY certain that the round connector at the end of the wire is centered on its mating half on the motherboard before applying pressure. Failure to do so will likely destroy both halves of the connector.
  12. iPhone 4 Verizon Headphone Jack Cable Replacement, Rear Camera: 步骤 12 中的图像 1,1
    • Remove the following five screws:
    • Three 1.3 mm Phillips screws
    • One 1.5 mm Phillips screw
    • One 2.4 mm Phillips screw
  13. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 13 中的图像 1,2 iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 13 中的图像 2,2
    • Lift the cable cover from its edge nearest the top of the iPhone.
    • Pull the cable cover tabs out of their slots cut into the EMI shield on the logic board and remove it from the iPhone.
  14. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 14 中的图像 1,2 iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 14 中的图像 2,2
    • Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the logic board.
    • Be careful not to break any components off the surrounding area on the logic board as you pry upwards.
    • Remove the rear camera from the iPhone.
    • Be careful not to scratch the back of the display assembly after the removal of the rear facing camera.
  15. iPhone 4 Verizon Headphone Jack Cable Replacement, Logic Board: 步骤 15 中的图像 1,1
    • Disconnect the five cables near the top of the logic board in the following order:
    • Headphone jack/volume button cable
    • Power button cable
    • Front facing camera cable
    • Digitizer cable
    • Display data cable
    • To disconnect the cables, use the edge of a plastic opening tool to gently lift their connectors up and out of the sockets on the logic board.
    • Be careful not to break any of the small and delicate surface mount components as you disconnect the cables.
  16. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 16 中的图像 1,1
    • Remove the 1.5 mm Phillips #000 screw near the headphone jack.
  17. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 17 中的图像 1,1
    • Lift the small grounding clip up off the logic board and remove it from the iPhone.
  18. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 18 中的图像 1,1
    • Use the edge of a plastic opening tool to disconnect the Wi-Fi antenna cable connector from the logic board.
    • When reconnecting the wifi ribbon connector to the mother board be VERY certain that the round connector at the end of the ribbon cable is centered on its mating half on the motherboard before applying pressure. Failure to do so will likely destroy both halves of the connection.
  19. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 19 中的图像 1,2 iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 19 中的图像 2,2
    • If present, remove the piece of tape covering a Phillips screw near the power button.
  20. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 20 中的图像 1,1
    在这个步骤中使用的工具:
    Standoff Screwdriver for iPhones
    $5.49
    购买
    • Remove the 2.5 mm Phillips #000 screw securing the logic board near the power button.
    • Remove the 4.8 mm standoff screw near the headphone jack.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  21. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 21 中的图像 1,1
    • Remove the 3.4 mm Phillips screw near the vibrator motor.
    • Remove the two 3.6 mm standoff screws along the side of the logic board nearest the battery opening.
  22. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 22 中的图像 1,1
    • Carefully lift the logic board from the end closest to the speaker enclosure and slide it away from the top edge of the iPhone.
    • Remove the logic board.
    • Before reassembly, be sure to clean all metal-to-metal contact points on the logic board (not the mating halves of connectors) with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause grounding issues.
    • There's a small rectangular rubber pad at the top of the logic board that prevents the display cables from chafing against the edge of the board. If it comes loose during your repair, make sure to position it correctly when reinstalling your logic board.
  23. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 23 中的图像 1,1
    • Be sure not to lose the small grounding finger for the rear facing camera near the power button.
  24. iPhone 4 Verizon Headphone Jack Cable Replacement, Front Facing Camera: 步骤 24 中的图像 1,2 iPhone 4 Verizon Headphone Jack Cable Replacement, Front Facing Camera: 步骤 24 中的图像 2,2
    • Use the edge of a plastic opening tool to carefully pry the metal front facing camera retainer away from the case of your iPhone.
    • Remove the front facing camera retainer.
  25. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 25 中的图像 1,1
    • Remove the front facing camera.
  26. iPhone 4 Verizon Headphone Jack Cable Replacement, Upper Antenna: 步骤 26 中的图像 1,1
    • Use the edge of a plastic opening tool to peel the upper antenna off the headphone jack.
  27. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 27 中的图像 1,1
    • Remove the 2.4 mm Phillips screw next to the headphone jack.
  28. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 28 中的图像 1,1
    • Use the edge of a plastic opening tool to gently move the top antenna contact away from the headphone jack.
  29. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 29 中的图像 1,2 iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 29 中的图像 2,2
    • Use the edge of a plastic opening tool to peel the top microphone away from the outer case.
    • Pull the body of the headphone jack away from the top edge of the iPhone.
  30. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 30 中的图像 1,1
    • Remove the 2.5 mm Phillips screw securing the upper antenna to the outer case.
  31. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 31 中的图像 1,1
    • Remove the upper antenna from the iPhone.
    • Before reassembly, be sure to clean the metal-to-metal contact point on the upper antenna (not the mating halves of its connector) with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
  32. iPhone 4 Verizon Headphone Jack Cable Replacement, Headphone Jack Cable: 步骤 32 中的图像 1,1
    • Remove the four 1.6 mm Phillips screws securing the volume button and silent switch brackets to the outer case.
  33. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 33 中的图像 1,1
    • Carefully peel the headphone jack/volume button cables off the adhesive securing them to the rear case.
  34. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 34 中的图像 1,1
    • Gently pull the silent switch bracket away from the outer case and peel its small ribbon cable off the inside of the iPhone.
  35. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 35 中的图像 1,1
    • Remove the headphone jack cable from the iPhone.
  36. iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 36 中的图像 1,3 iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 36 中的图像 2,3 iPhone 4 Verizon Headphone Jack Cable Replacement: 步骤 36 中的图像 3,3
    • If you are replacing the headphone jack cable, use the edge of a plastic opening tool to remove the steel brackets for the volume buttons and the silent switch.
    • Transfer these steel brackets to the new headphone jack cable.
结论
28等其他人完成本指南。
2条评论
This is for step 28-29
Steve 1-27-2015
Steve Eng - 回复
I do not seem to have a contact tab that screws down with the screw on the right side of the headphone jack. Is it in all phones, or did I lose it?
This is for step 28-29.
Steve 1-27-2015
Steve Eng - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 27,896
