跳转到主内容
简介
This guide shows how to remove the two bottom Pentalobe screws on the iPhone 4.
工具
没有特定工具。
  1. Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector. Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector.
    • Use the Pentalobe screwdriver to remove the two 3.6 mm Pentalobe screws near the dock connector.
    Extremely difficult.
    Lua Tech - 回复
结论
430等其他人完成本指南。
3条评论
What do you do when you strip a screw
Jesse Medrano - 回复
I also think I stripped one of the pentalobe screws,one came off the other was a problem from the start. How do you deal with a stripped pentalobe screw?
bftravers522 - 回复
添加评论
浏览统计数据:
过去的24小时: 7
过去的7天: 23
过去的30天: 83
总计 405,595
