跳转到主内容
加入维修社区 - 创建账户
iPhone 16 Pro Microphone Installation
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. iPhone 16 Pro Microphone Installation, Remove the old adhesive: 步骤 1 中的图像 1,3 iPhone 16 Pro Microphone Installation, Remove the old adhesive: 步骤 1 中的图像 2,3 iPhone 16 Pro Microphone Installation, Remove the old adhesive: 步骤 1 中的图像 3,3
    • Use tweezers to remove the old microphone adhesive from the bottom of the frame.
  2. iPhone 16 Pro Microphone Installation: 步骤 2 中的图像 1,2 iPhone 16 Pro Microphone Installation: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    Cotton Swabs
    • Use isopropyl alcohol and a cotton swab or lint-free cloth to clean any residual microphone adhesive from the frame.
  3. iPhone 16 Pro Microphone Installation, Apply new adhesive: 步骤 3 中的图像 1,3 iPhone 16 Pro Microphone Installation, Apply new adhesive: 步骤 3 中的图像 2,3 iPhone 16 Pro Microphone Installation, Apply new adhesive: 步骤 3 中的图像 3,3
    • If your replacement microphone comes with adhesive pre-installed, skip this step.
    • The adhesive can't be removed and reused once it sticks to the microphone. Ensure it's perfectly aligned before adhering.
    • Remove the solid white adhesive liner from the new microphone adhesive.
    • Align the holes in the adhesive with the three holes in the microphone, and stick it into place.
  4. iPhone 16 Pro Microphone Installation: 步骤 4 中的图像 1,2 iPhone 16 Pro Microphone Installation: 步骤 4 中的图像 2,2
    • Remove the plastic backing from the microphone adhesive.
  5. iPhone 16 Pro Microphone Installation, Install the microphone: 步骤 5 中的图像 1,3 iPhone 16 Pro Microphone Installation, Install the microphone: 步骤 5 中的图像 2,3 iPhone 16 Pro Microphone Installation, Install the microphone: 步骤 5 中的图像 3,3
    • Set the microphone in the frame, aligned with its screw holes.
    • Partially install the three screws securing the microphone:
    • One 3.6 mm‑long standoff screw
    • One 2.9 mm‑long standoff screw
    • One 1.3 mm‑long tri-point Y000 screw
    • Press the microphone against the bottom of the frame, and hold it for 15 seconds to seal the adhesive.
    • Fully tighten the microphone screws.
终点
Nick Schultz
于03/24/24注册
39,308 声望
创作了226篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,992篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 43
