跳转到主内容
加入维修社区 - 创建账户
iPhone 16 Pro Front Camera Assembly Installation
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. iPhone 16 Pro Front Camera Assembly Installation, Install the front camera assembly: 步骤 1 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Installation, Install the front camera assembly: 步骤 1 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Installation, Install the front camera assembly: 步骤 1 中的图像 3,3
    • Lay the front camera assembly in its recess.
    • Gently tuck the camera flex cables into the gap between the rear camera assembly and the earpiece speaker assembly.
  2. iPhone 16 Pro Front Camera Assembly Installation: 步骤 2 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Installation: 步骤 2 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Installation: 步骤 2 中的图像 3,3
    • Use your fingers or a spudger to push the front camera flex cables up towards the earpiece speaker, then tuck them in the gap between the earpiece speaker and the logic board.
  3. iPhone 16 Pro Front Camera Assembly Installation, Connect the front camera assembly: 步骤 3 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Installation, Connect the front camera assembly: 步骤 3 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Installation, Connect the front camera assembly: 步骤 3 中的图像 3,3
    • Use your finger or a spudger to connect the two front camera assembly press connectors, located on the top edge of the logic board.
  4. iPhone 16 Pro Front Camera Assembly Installation, Connect the earpiece speaker: 步骤 4 中的图像 1,3 iPhone 16 Pro Front Camera Assembly Installation, Connect the earpiece speaker: 步骤 4 中的图像 2,3 iPhone 16 Pro Front Camera Assembly Installation, Connect the earpiece speaker: 步骤 4 中的图像 3,3
    • Use your finger or a spudger to connect the earpiece speaker and 5G mmWave antenna (US models only) press connectors, located on the top right corner of the logic board.
终点
Nick Schultz
于03/24/24注册
43,497 声望
创作了252篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了24,036篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 42
