跳转到主内容
加入维修社区 - 创建账户
iPhone 16 Microphone Installation
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
  1. iPhone 16 Microphone Installation, Remove the old adhesive: 步骤 1 中的图像 1,2 iPhone 16 Microphone Installation, Remove the old adhesive: 步骤 1 中的图像 2,2
    • Use tweezers or your fingers to remove the old adhesive from the bottom of the frame.
  2. iPhone 16 Microphone Installation, Clean the microphone opening: 步骤 2 中的图像 1,1
    • Use high concentration isopropyl alcohol (greater than 90%) and a microfiber or lint-free cloth to clean the adhesive residue off the microphone opening in the frame.
  3. iPhone 16 Microphone Installation, Remove the white liner: 步骤 3 中的图像 1,2 iPhone 16 Microphone Installation, Remove the white liner: 步骤 3 中的图像 2,2
    • If your microphone comes with adhesive installed, skip this step.
    • While holding the microphone adhesive with one hand, use your fingers or a pair of tweezers to remove the white liner from the adhesive.
  4. iPhone 16 Microphone Installation, Apply the adhesive to the microphone: 步骤 4 中的图像 1,3 iPhone 16 Microphone Installation, Apply the adhesive to the microphone: 步骤 4 中的图像 2,3 iPhone 16 Microphone Installation, Apply the adhesive to the microphone: 步骤 4 中的图像 3,3
    • Hold the microphone so the metal side is facing up.
    • Apply the adhesive to the microphone with the pull tab pointing up.
  5. iPhone 16 Microphone Installation: 步骤 5 中的图像 1,2 iPhone 16 Microphone Installation: 步骤 5 中的图像 2,2
    • Remove the blue liner from the microphone adhesive.
  6. iPhone 16 Microphone Installation, Install the microphone: 步骤 6 中的图像 1,3 iPhone 16 Microphone Installation, Install the microphone: 步骤 6 中的图像 2,3 iPhone 16 Microphone Installation, Install the microphone: 步骤 6 中的图像 3,3
    • Insert the microphone at a downward angle so the adhesive adheres firmly to the frame around the opening.
    • Press the microphone firmly into place.
  7. iPhone 16 Microphone Installation, Install the microphone screws: 步骤 7 中的图像 1,2 iPhone 16 Microphone Installation, Install the microphone screws: 步骤 7 中的图像 2,2
    • Install the four screws securing the microphone:
    • Two 3.3 mm‑long standoff screws
    • One 1.1 mm‑long tri‑point Y000 screw
    • One 1.5 mm‑long Phillips screw
  8. iPhone 16 Microphone Installation, Connect the microphone: 步骤 8 中的图像 1,2 iPhone 16 Microphone Installation, Connect the microphone: 步骤 8 中的图像 2,2
    • Use the flat end of a spudger to connect the microphone press connector.
  9. iPhone 16 Microphone Installation, Install the loudspeaker: 步骤 9 中的图像 1,2 iPhone 16 Microphone Installation, Install the loudspeaker: 步骤 9 中的图像 2,2
    • Place the loudspeaker into the frame.
  10. iPhone 16 Microphone Installation, Install the loudspeaker screws: 步骤 10 中的图像 1,2 iPhone 16 Microphone Installation, Install the loudspeaker screws: 步骤 10 中的图像 2,2
    • Install the five screws securing the loudspeaker:
    • Two 1.5 mm‑long Phillips screws
    • One 2.0 mm‑long Phillips screw
    • One 2.9 mm‑long Phillips screw
    • One 1.2 mm‑long tri‑point Y000 screw
终点
Spencer Pennington
于09/09/23注册
24,404 声望
创作了126篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了16,346篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 71
