将重叠的透明包装胶带条黏在 iPhone 的后玻璃上,直到覆盖整个手机后部。
如果在接下来的几个步骤中无法让吸盘粘在手机上,请将强力胶带(折叠到把手中,然后用它提起后玻璃。
将蓝色手柄拉向铰链以解除开启模式。
将反向钳手臂滑过 iPhone 的左边缘或右边缘。
将吸盘放在靠近 iPhone 底部边缘的位置——一个在正面,一个在背面。
向下推吸盘以将吸力施加到所需区域。
如果你仍然无法取出电池,请在电池边缘下胶条破损区域滴几滴高浓度(超过 90%)的异丙醇。
等待大约一分钟,让酒精溶液削弱粘合剂。
使用撬片或撬棒的平头轻轻提起电池。
将新更换零件与原始零件进行比较——您可能需要在安装前转移剩余的组件,或去除新零件的背胶。
要重新组装您的设备,请按逆序执行上述步骤。
请将维修过程中产生的点子垃圾送到 R2 或 e-Stewards 认证的回收商。
维修没有按计划进行?尝试一些 基本故障排除,或到我们的 iPhone 13 Pro [链接|https://www.ifixit.com/Answers/Device/iP...|论坛]咨询、求助。
14等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
4条评论
Most Complete In-depth iPhone Battery Replacement Guide On The Interwebs! Start to finish this repair took me an hour, given I've opened a few iPhone's in my day but still fairly simple for someone's first time.
Great Work Sam Omiotek & iFixit Team!
question - is step 25 - 30 necessary? Can I skip those
I wouldn’t if I were you. If I remember correctly you’ll need that space to leverage you’re pry tools to get under the battery and to get to those pull tabs to help in releasing it easier.
Tim R -
I have replaced my battery using this excellent guide and an iFixit battery and it went very well, however, now my phone will not verify iOS update. I have tried all steps to get it to verify the update and am left to conclude that the battery warning message also means that iOS update won't verify. Be warned. I am now scratching my head about what to do next.
