简介
如果你的 iPhone 12 Pro Max 屏幕破裂,无法响应触摸或在手机开机时不显示图片,请使用本指南通过新屏幕(也称为显示屏部件)将 iPhone 恢复到正常工作状态。本指南仅介绍更换预装了屏蔽板的完整显示器组合件的步骤。
固定在显示器背面的组合式听筒扬声器+传感器组件已在工厂与你的单个iPhone配对,因此在更换任何显示器时,必须将其从旧显示器转移到新显示器上。它包含泛光照明器,这是生物特征 Face ID 安全功能的一部分。如果它已损坏或更换,则 Face ID 将停止工作,因此请格外小心,以免在此过程中损坏任何这些组件。如果损坏,则只有Apple或Apple授权的技术人员才能恢复Face ID功能。
“注意”:更换屏幕后,即使使用原装的 Apple 屏幕,True Tone 功能也被禁用。
你所需要的
如果您的iPhone屏幕破裂,在修理过程中通过胶带贴在玻璃上,防止进一步的破损,造成身体伤害。
将胶带条贴在iPhone的显示屏上,直到覆盖整个屏幕上。(如果不够宽可以重叠贴,如果要用吸盘重叠部分会漏气,所以最好使用7厘米宽的胶带,用吸盘时容易吸住)。做一步的目的是为了保持屏幕组件的受力结构,以方便拆卸。
在下面的步骤中如果吸盘吸不住已经破损的屏幕,可以用胶带把吸盘粘在屏幕上,然后在提起屏幕。
How to detect my Iphone what screen it is, OLED or LCD?
It’s OLED. You can find the specs here, https://support.apple.com/en-us/HT201296
When you find your phone, at the bottom of the description click on, See the tech specs…
mcr4u2 -
The included suction cups were stiff and worthless. They would not lift the screen. Also, I tried every type of tape on the screen to help the suction cups stick without success. Heavy duty suction cups were for my bathroom also failed. However, I had an old GoPro mount with some preapplied double sided 3M VSB tape and stuck that on the screen near the bottom. Magic! This method had the added bonus of being able to use a GoPro attachment as a handle to lift the screen, and propped up the screen like a kickstand in step 12.
Very cool! Thanks
Antonio -
My screen was pretty stuck… would not budge. Heated, super glued the suction cup, tried gorilla tape. Ended up doing the GoPro mount with 3M VSB tape method mentioned. Worked great. That 3M tape is the bomb.
If you have flat feeler gauges (for adjusting engine valve tappet clearance, ignition points … old school) the .003 thick goes right in. Work your way up until you can get the pick or supplied pry tool in.
where can I buy 3M VSB plis!!
3M VHB tape is at auto stores and other big box stores, or online.
nicO -
加热iPhone的下边缘有助于软化固定显示屏的胶粘剂,使其更易于打开。
wenn man die Frontkamera nicht tauscht sondern nur anhebt und reinigt, funktioniert Face ID dann noch?
Wenn du beim Aus- und Einbau alles richtig machst, dürfte dabei nichts passieren.
用恒定的拉力向上拉动吸盘,以在前面板和后壳体之间形成一个很小的间隙。
在间隙中插入一个三角撬片。
如果尚未卸下吸盘手柄或iSclack,请立即将其卸下。
像书的封面一样从右侧向上旋转显示屏,以打开iPhone。
当你在手机上工作时,将显示器靠在东西上,以保持其支撑。
使用撬棒或指甲断开前传感器组件电缆接口的连接。
when lifting up the front sensor assembly cable connector, you should use the flat end of the spudger. Using the pointed end as shown in the picture runs the risk of damaging components on the board and/or the cable connector itself.
将新的替换零件与原始零件进行比较——在安装之前,你可能需要转移剩余的组件或从新零件上取下粘性衬板。
要重新组装设备,请按逆序执行上述步骤。
将你的电子垃圾带到R2或e-Stewards认证回收商。
维修没有按计划进行吗?维修没有按计划进行吗?尝试一些[[修复后的问题|基本故障排除],或询问我们的iPhone 12 Pro Max 社区 寻求故障排除帮助。
要重新组装设备,请按逆序执行上述步骤。
45等其他人完成本指南。
由衷感谢以下译者:
75%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
6条评论
Thank you so much. how can I order fixit kit. Please I would like to replace my screen as soon as I could.
We don’t have a fix kit available for this yet, but at the top of this guide you’ll find lists of the necessary parts and tools. Good luck with the screen replacement!
that's an excellent explanation thank you!
Really nice explanation! Easy to follow for Newbies and Pro's!
replaced screen and also transferred the screen serial number to the new screen but still lost touch sensitivity and other functions. Is this a common problem?
