简介
Use this guide to remove and replace the rear cameras in the iPhone 11 Pro. All three camera modules are replaced as a single unit.
你所需要的
Power off your iPhone before beginning disassembly.
Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
Pull the blue handle towards the hinge to disengage opening mode.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Push down on the cups to apply suction to the desired area.
Push the blue handle away from the hinge to engage opening mode.
Turn the handle clockwise until you see the cups start to stretch.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Insert an opening pick into the gap.
Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
Pull on the small nub on the suction cup to remove it from the front panel.
Open the iPhone by swinging the display up from the left side, like the back cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
Remove two 1.3 mm long Y000 screws securing the battery cover bracket.
Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Use a Y000 driver to remove six 1.3 mm screws securing the logic board cover bracket.
Use a spudger or a fingernail to disconnect the OLED panel cable connector.
Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
Use a spudger or a fingernail to disconnect the digitizer cable connector.
Use a Y000 driver to remove the two 1.5 mm screws on the left side of the rear camera cover.
Use a Y000 driver to remove the two 1.2 mm screws securing the rear camera cover.
Lift the camera cover from the edge closest to the battery, and remove it.
Use a spudger or a fingernail to disconnect the first two camera cable connectors by prying them straight up from their sockets.
Use a spudger to disconnect the third camera—its connector lies underneath the cable you disconnected in the previous step.
Slide the point of your spudger under the left edge of the camera assembly.
Gently lift up to lever the cameras out of the iPhone.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 11 Pro Answers community for help.
12等其他人完成本指南。
