跳转到主内容
iPhone 11 Pro Rear Case Replacement
你所需要的
视频概述
  1. iPhone 11 Pro Rear Case Replacement, Remove the pentalobe screws: 步骤 1 中的图像 1,2 iPhone 11 Pro Rear Case Replacement, Remove the pentalobe screws: 步骤 1 中的图像 2,2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
结论
17等其他人完成本指南。
Arty
于10/27/19注册
30,969 声望
创作了108篇指南
3指南评论
how much for housing iphone 11 pro ? Thank you
daddy - 回复
If yo buy it from indonesia it only cost you arround $100-$200
izaz adityas -
I ordered a new charging port but it doesn’t seem to include a speaker element on the left side, and the charging connector module above the port. Can those be moved over from the old charging port?
lemonlev - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 55
过去 30 天: 267
总计 21,774
