跳转到主内容
iPhone 1代 天线盖更换
你所需要的
  1. iPhone 1代 天线盖更换, SIM卡: 步骤 1 中的图像 1,1
    • 在耳机孔旁的孔中插入SIM卡工具或扳直的回形针。
    • 向下压SIM卡工具或扳直的回形针,直到SIM卡托盘弹出。
    To remove the SIM, insert the end of a SIM eject tool or a small thin paper clip into the hole on the SIM tray. Press firmly and push the tool straight in until the tray pops out.
    http://support.apple.com/kb/ht1438
    neuronetix - 回复
    I put the SIM card back in, and the slide to unlock does not work.
    dean -
    The only carrier to accept this iPhone was AT&T, they have discontinued use of that baseband. Nobody else in the world except for early renegade reverse engineers such as Geohot can get the device to work as a really old iPod no use unlocking the device because the technology inside the most recently OEM sold/refurbed iPhone 1st gen fails universally. You should only buy a screen assembly and snap it onto the back and call it a dummy phone and put it in a museum.
    Alexander Weinhart - 回复
  2. iPhone 1代 天线盖更换: 步骤 2 中的图像 1,1
    • 抓住SIM卡托盘并将其拉出iPhone。
  3. iPhone 1代 天线盖更换, 天线盖: 步骤 3 中的图像 1,1
    • 此图显示了位于天线盖底侧的两个卡舌和两个卡扣。必须将图像顶部的两个选项卡推向黑色盖板以将其打开。
    YOU NEED TO PUT THE OPENER TOOL BETWEEN THE ANTENNA COVER AND THE DOCK CONNECTOR FIRST, THEN YOU WILL HAVE SPACE TO OPEN IT.. MY 2 CENTS
    riversde - 回复
    You better lay off the caps.
    lol SPLAAT -
    Very hard to remove and the plastic is very fragile
    Take care when removing
    miguelvillela - 回复
    When you get stuck follow this guy guide
    http://www.youtube.com/watch?v=sYHnr89HM...
    miguelb - 回复
    Great Guide.
    My dad banged his iPhone in a table after arguing with someone and got the aluminum cover next to the volume control bent in such a way as it got the volume control stuck in the max position. I used this guide to remove all parts out of the way so I can get the shape of that region and corrected it the "Han Solo" Way. It was an excellent opportunity to get the phone cleaned up as well
    The biggest problem I had was screwing some of the screws back. The screwdriver that I had was not magnetized, so I used a little bit of superglue to bind the screw and the screwdriver until I had it screwed tightly.
    The second biggest problem I had was that I lost a screw twice, but was lucky enough to find it quickly on the floor next to me.
    I am very happy as I waited more than a month to get the confidence to get this iPhone repaired.
    lantinian - 回复
    how do i know what part is in my phone? There are 2...
    Ivanfrost - 回复
    来自 Ivanfrost 的话:
    Once you have the phone apart and have gently unplugged the power ribbon, read the part number on the ribbon. If it's in the 821- family, you can safely use corresponding 821 headphone assembly. If it is the other part number, use the newer replacement. Many sites list both parts and let you order the appropriately numbered part. Otherwise (if you order the wrong part) it won't work or you'll have to [unnecessarily] hack the part to get it to work.
    Steve - 回复
    来自 Steve 的话:
    I bought the wrong one.... how do I hack it?
    Rune Smistad - 回复
    My iPhone is very first model. It doesn't have any of the four tabs shown.
    gameplayer2 - 回复
    The very first model does not have the four tabs. To open this version, use a plastic opener tool and push it into the middle of the tiny space between the rectangular dock connector and the antenna cover. Move the tool to the side and push it in a little deeper. A small gap should open up at the bottom of the antenna cover, where it meets the metal. Continue using the plastic opener tool in there, pushing it in and forcing it around the edge so that the antenna cover further separates. Then repeat this on the other side. To me it seems like a very brittle piece of plastic, so be careful. But now that it's loose at the bottom you can lift it with your fingers and work it off.
    Alexander Ljungberg - 回复
  4. iPhone 1代 天线盖更换: 步骤 4 中的图像 1,1
    • 确保将金属撬棒插入扩展坞连接器和天线盖之间,不要插入扩展坞连接器里面。
    • 将金属撬棒插入扩展坞连接器和天线盖之间的插槽中。在两个卡舌附近轻轻撬起,以在天线盖和银色前挡板之间形成一个小间隙。
    Take heed to the note about getting the spudger between the dock connector and the cover. The dock connector is black plastic, as is the antenna cover, so it's difficult to see any gap between them. Putting the spudger between the metal shielding of the connector and the plastic is incorrect.
    Michael Lance - 回复
    Rens' duct tape technique (see comment in step 6 section below) worked very well. No need to risk breaking the antenna with a spudger.
    jbshoe - 回复
  5. iPhone 1代 天线盖更换: 步骤 5 中的图像 1,1
    • 将塑料撬棒插入天线盖和前挡板之间的间隙。撬棒的楔子应指向天线盖。沿拐角处向上并向上滑动工具,直至到达金属底衬。
    • 在另一侧重复相同的步骤。
  6. iPhone 1代 天线盖更换: 步骤 6 中的图像 1,1
    • 抓住任一侧的天线盖,将其向上滑动并与iPhone分开。这需要一些力量。如果无法松开,请确保将天线盖提起至足以松开卡扣。
    It was released very hard on my iPhone 2G but the problem comes when i have to put it back.
    It remains a little more space between the dock and the Antena cover and maybe that's because the two tabs between the mic and the speaker are not entered under the gold board?
    If someone knows please tell me how to put it back.
    Thanks
    infomihai - 回复
    There is a very easy way to remove the cover by simply sticking duct tape on it and pulling the tape away of the phone.
    It will leave no marks and it didn't damage my antenna cover as much(my "chinese" repair tools were to weak).
    rens - 回复
    Thanks, using the tape was quick and easy, no damage at all.
    Roeland -
    Brilliant. Works perfectly. 20 seconds of work.
    koenatclaes -
结论
要重新组装设备,请按照相反的顺序进行操作。
108等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
HYONELIN正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
iRobot
于09/24/09注册
1 声望
创作了636篇指南
3条评论
parece muy bueno pero no entiendo es nada porque los pasos estan es en ingles
Ysmael - 回复
I need help I got my iPhone 2g 4gb pulled off the antenna cover and now it won’t go back on please help me!!!
Sergio Ayon - 回复
This is very helpful
kunle lawal - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 104
总计 164,373
