跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
iPad mini 4 Wi-Fi Display Assembly Replacement
你所需要的
  1. iPad mini 4 Wi-Fi Display Assembly Replacement, iOpener Heating: 步骤 1 中的图像 1,2 iPad mini 4 Wi-Fi Display Assembly Replacement, iOpener Heating: 步骤 1 中的图像 2,2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 2 中的图像 1,1
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. iPad mini 4 Wi-Fi Display Assembly Replacement, Alternate iOpener heating method: 步骤 4 中的图像 1,2 iPad mini 4 Wi-Fi Display Assembly Replacement, Alternate iOpener heating method: 步骤 4 中的图像 2,2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. iPad mini 4 Wi-Fi Display Assembly Replacement, Opening Procedure: 步骤 5 中的图像 1,1
  6. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 6 中的图像 1,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 6 中的图像 2,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 6 中的图像 3,3
    • Apply a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
  7. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 7 中的图像 1,2 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 7 中的图像 2,2
    • While holding the glass up with the suction cup, insert the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
  8. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 8 中的图像 1,1
    • Reheat and reapply the iOpener to the left edge for a few minutes.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
  9. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 9 中的图像 1,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 9 中的图像 2,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 9 中的图像 3,3
    • Insert a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
  10. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 10 中的图像 1,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 10 中的图像 2,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 10 中的图像 3,3
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  11. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 11 中的图像 1,2 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 11 中的图像 2,2
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
  12. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 12 中的图像 1,1
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  13. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 13 中的图像 1,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 13 中的图像 2,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 13 中的图像 3,3
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  14. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 14 中的图像 1,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 14 中的图像 2,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 14 中的图像 3,3
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • As you reach the front-facing camera, pull the pick out slightly and continue sliding it across the top edge.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
  15. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 15 中的图像 1,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 15 中的图像 2,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 15 中的图像 3,3
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
    • Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
  16. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 16 中的图像 1,2 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 16 中的图像 2,2
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  17. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 17 中的图像 1,1
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
  18. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 18 中的图像 1,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 18 中的图像 2,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 18 中的图像 3,3
    • Insert a new opening pick and slide it down the right edge of the iPad, releasing the adhesive as you go.
  19. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 19 中的图像 1,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 19 中的图像 2,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 19 中的图像 3,3
    • Continue sliding the opening pick down the right edge of the iPad, reheating the edge using an iOpener if necessary.
    • Be careful not to slice too deep near the bottom right corner, or you risk damaging the display cable.
  20. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 20 中的图像 1,1
    • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpener—no more than once every ten minutes.
    • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
  21. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 21 中的图像 1,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 21 中的图像 2,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 21 中的图像 3,3
    • Insert a new opening pick at the bottom right corner of the display, below the last opening pick you used to slice down the right edge.
    • Rotate the new pick around the lower right corner of the device.
  22. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 22 中的图像 1,2 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 22 中的图像 2,2
    • Slide the pick from the bottom right corner along the lower edge of the device. Stop about half an inch shy of the home button.
  23. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 23 中的图像 1,2 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 23 中的图像 2,2
    • Insert a final opening pick at the lower left corner of the iPad, directly below the existing one.
  24. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 24 中的图像 1,2 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 24 中的图像 2,2
    • Slide the pick around the lower left edge of the iPad.
  25. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 25 中的图像 1,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 25 中的图像 2,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 25 中的图像 3,3
    • Continue sliding the pick at the lower left edge of the display toward the center of the iPad, until it is roughly half an inch from the home button.
  26. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 26 中的图像 1,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 26 中的图像 2,3 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 26 中的图像 3,3
    • Twist the two picks at the top edge of the iPad to break up the last of the adhesive holding the display assembly in place.
    • Lift the display from the top edge to open the device.
  27. iPad mini 4 Wi-Fi Display Assembly Replacement, Battery Connector: 步骤 27 中的图像 1,1
    • To avoid stressing any cables, hold the display assembly perpendicular to the body of the iPad until it is disconnected.
    • Remove the four 1.2 mm Phillips screws over the battery/display connector bracket.
  28. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 28 中的图像 1,1
    • Remove the battery/display cable bracket.
  29. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 29 中的图像 1,2 iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 29 中的图像 2,2
    • When disconnecting any press connectors from the logic board, be sure to lift the connector straight up to avoid ripping the socket off the board.
    • Use the flat tip of a spudger to disconnect the battery connector from its socket on the logic board.
    • Bend the battery connector ribbon cable up slightly to prevent it from making contact and powering on the iPad.
  30. iPad mini 4 Wi-Fi Display Assembly Replacement, Display Assembly: 步骤 30 中的图像 1,3 iPad mini 4 Wi-Fi Display Assembly Replacement, Display Assembly: 步骤 30 中的图像 2,3 iPad mini 4 Wi-Fi Display Assembly Replacement, Display Assembly: 步骤 30 中的图像 3,3
    • Use the flat tip of a spudger to disconnect the display data connector from its socket on the logic board.
    • Disconnect the digitizer cable connector from its socket on the logic board.
  31. iPad mini 4 Wi-Fi Display Assembly Replacement: 步骤 31 中的图像 1,1
    • Remove the display assembly.
结论
34等其他人完成本指南。
Evan Noronha
于02/05/15注册
223,594 声望
创作了168篇指南
2条评论
why after replacement power button doesn’t lock screen, where is those smart cover sensor are located?
nyestyerov - 回复
great guide but u dont discuss reapplying the adhesive strips .. which is very important.
ryandasilva23 - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 46
过去 30 天: 168
总计 25,231
