跳转到主内容
修复你的物品
维修的权力
商店
简介
Follow this guide to remove and replace the home button in an iPad Pro 9.7".
Note: Your original home button assembly is paired to the iPad's logic board. You will lose Touch ID if any part of the home button assembly (button or cable) is replaced.
  1. If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered. This will keep glass shards contained and provide structural integrity when prying and lifting the display.
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. The following steps involve using an iOpener to soften the adhesive holding the front panel assembly in place. When using the iOpener, be sure to heat it in the microwave for no more than 30 seconds.
    • The following steps involve using an iOpener to soften the adhesive holding the front panel assembly in place. When using the iOpener, be sure to heat it in the microwave for no more than 30 seconds.
    • Handling it by the tabs on either end, place a heated iOpener over the top edge of the iPad.
    • Let the iOpener sit on the iPad for two minutes to soften the adhesive securing the front panel to the rest of the iPad.
  3. While the iPad looks uniform from the outside, there are delicate components under certain portions of the front glass. To avoid damage, only heat and pry in the areas described in each step. As you follow the directions, take special care to avoid prying in the following areas: Home Button
    • While the iPad looks uniform from the outside, there are delicate components under certain portions of the front glass. To avoid damage, only heat and pry in the areas described in each step.
    • As you follow the directions, take special care to avoid prying in the following areas:
    • Home Button
    • Front Facing Camera
    • Main Camera
  4. Place a suction cup over the iPad's front-facing camera and press down to create a seal. To get the most leverage, place the suction cup as close to the edge as possible without going past the edge of the display.
    • Place a suction cup over the iPad's front-facing camera and press down to create a seal.
    • To get the most leverage, place the suction cup as close to the edge as possible without going past the edge of the display.
  5. Firmly pull up on the suction cup to create a small gap between the front panel and the rear case. Do not pull too hard or you may shatter the glass. Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
    • Firmly pull up on the suction cup to create a small gap between the front panel and the rear case.
    • Do not pull too hard or you may shatter the glass.
    • Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
  6. Slide the pick along the edge of the display, towards the headphone jack. If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat. Don't insert the pick past the bezel into the display area, or you will damage it.
    • Slide the pick along the edge of the display, towards the headphone jack.
    • If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat.
    • Don't insert the pick past the bezel into the display area, or you will damage it.
    • A good rule of thumb is to never insert the opening pick more than a quarter inch into the iPad.
  7. Insert a second opening pick by the front-facing camera. Insert a second opening pick by the front-facing camera.
    • Insert a second opening pick by the front-facing camera.
  8. Slide the second pick along the top edge of the iPad, towards the Sleep/Wake Button. Slide the second pick along the top edge of the iPad, towards the Sleep/Wake Button. Slide the second pick along the top edge of the iPad, towards the Sleep/Wake Button.
    • Slide the second pick along the top edge of the iPad, towards the Sleep/Wake Button.
  9. Insert a third pick by the front-facing camera. Insert a third pick by the front-facing camera.
    • Insert a third pick by the front-facing camera.
  10. Bring the right opening pick down and around the top right corner of the iPad. Bring the right opening pick down and around the top right corner of the iPad. Bring the right opening pick down and around the top right corner of the iPad.
    • Bring the right opening pick down and around the top right corner of the iPad.
  11. Bring the left opening pick around the top left corner of the tablet. Bring the left opening pick around the top left corner of the tablet. Bring the left opening pick around the top left corner of the tablet.
    • Bring the left opening pick around the top left corner of the tablet.
  12. Reheat the iOpener and lay it over the right edge of the display to loosen the adhesive underneath.
    • Reheat the iOpener and lay it over the right edge of the display to loosen the adhesive underneath.
  13. Slide the right opening pick roughly halfway down the display. Slide the right opening pick roughly halfway down the display. Slide the right opening pick roughly halfway down the display.
    • Slide the right opening pick roughly halfway down the display.
  14. Reheat the iOpener and apply heat to the left side of the iPad.
    • Reheat the iOpener and apply heat to the left side of the iPad.
  15. Slide the left-hand opening pick about halfway down the edge of the display. Slide the left-hand opening pick about halfway down the edge of the display. Slide the left-hand opening pick about halfway down the edge of the display.
    • Slide the left-hand opening pick about halfway down the edge of the display.
  16. Slide the opposite opening pick down to the bottom right corner of the iPad. If necessary, reheat the adhesive on the right edge to loosen the display assembly. If necessary, reheat the adhesive on the right edge to loosen the display assembly.
    • Slide the opposite opening pick down to the bottom right corner of the iPad.
    • If necessary, reheat the adhesive on the right edge to loosen the display assembly.
  17. Slide the left-hand opening pick down the edge of the display until you reach the corner. Slide the left-hand opening pick down the edge of the display until you reach the corner. Slide the left-hand opening pick down the edge of the display until you reach the corner.
    • Slide the left-hand opening pick down the edge of the display until you reach the corner.
  18. Use the iOpener to apply heat to the bottom edge of the iPad.
    • Use the iOpener to apply heat to the bottom edge of the iPad.
  19. Bring the right-hand opening pick around the bottom corner of the iPad. Bring the right-hand opening pick around the bottom corner of the iPad. Bring the right-hand opening pick around the bottom corner of the iPad.
    • Bring the right-hand opening pick around the bottom corner of the iPad.
  20. Repeat for the left-hand pick. Reheat and reapply the iOpener as needed. Reheat and reapply the iOpener as needed.
    • Repeat for the left-hand pick.
    • Reheat and reapply the iOpener as needed.
  21. Remove the right-hand opening pick at the bottom of the iPad. Remove the right-hand opening pick at the bottom of the iPad.
    • Remove the right-hand opening pick at the bottom of the iPad.
  22. Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad. Be very careful to not insert the pick more than a quarter inch into the display to avoid damaging the Home Button and display cables underneath. Be very careful to not insert the pick more than a quarter inch into the display to avoid damaging the Home Button and display cables underneath.
    • Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad.
    • Be very careful to not insert the pick more than a quarter inch into the display to avoid damaging the Home Button and display cables underneath.
  23. Use picks to ensure most of the adhesive has been cut through on the top, left, and bottom sides. Twist the top and bottom picks to separate the display assembly from the rear case. Do not attempt to remove the display—it is still attached to the rear case.
    • Use picks to ensure most of the adhesive has been cut through on the top, left, and bottom sides.
    • Twist the top and bottom picks to separate the display assembly from the rear case.
    • Do not attempt to remove the display—it is still attached to the rear case.
  24. Swing the display assembly towards the right of the case, using the right edge as a hinge. As you move the display assembly, make sure that the display ribbon cable is not being stressed. Continue swinging the display assembly until it lays flat next to the rear case.
    • Swing the display assembly towards the right of the case, using the right edge as a hinge.
    • As you move the display assembly, make sure that the display ribbon cable is not being stressed.
    • Continue swinging the display assembly until it lays flat next to the rear case.
  25. Remove the eleven 1.3 mm Phillips #00 screws securing the EMI shield.
    • Remove the eleven 1.3 mm Phillips #00 screws securing the EMI shield.
  26. Apply a heated iOpener to the EMI shield on the logic board for one minute.
    • Apply a heated iOpener to the EMI shield on the logic board for one minute.
  27. Lift the logic board EMI shield, starting at the edge nearest the top of the iPad. Slowly peel the EMI shield up from the logic board. This takes a bit of force due to the many tiny clips securing the shield, and the shield may deform slightly. That's okay—try to keep the deformation to a minimum, and it will lay flat when reinstalled and screwed down.
    • Lift the logic board EMI shield, starting at the edge nearest the top of the iPad.
    • Slowly peel the EMI shield up from the logic board.
    • This takes a bit of force due to the many tiny clips securing the shield, and the shield may deform slightly. That's okay—try to keep the deformation to a minimum, and it will lay flat when reinstalled and screwed down.
    • Remove the logic board EMI shield.
  28. Use a Phillips driver to remove the screw securing the battery connector.
    • Use a Phillips driver to remove the screw securing the battery connector.
  29. If the EMI shield has any sharp protrusions after removal, you should flatten them before reinstalling the shield. Squeeze the sharp protrusion with a pair of pliers to flatten it. Repeat the process for all sharp protrusions along the edges of the EMI shield.
    • If the EMI shield has any sharp protrusions after removal, you should flatten them before reinstalling the shield.
    • Squeeze the sharp protrusion with a pair of pliers to flatten it.
    • Repeat the process for all sharp protrusions along the edges of the EMI shield.
  30. Remove the three 1.3 mm Phillips #000 screws securing the display cable bracket.
    • Remove the three 1.3 mm Phillips #000 screws securing the display cable bracket.
  31. Remove the display cable bracket. Remove the display cable bracket.
    • Remove the display cable bracket.
  32. Use the flat end of the spudger to disconnect the display assembly connector from the motherboard socket. Use the flat end of the spudger to disconnect the display assembly connector from the motherboard socket.
    • Use the flat end of the spudger to disconnect the display assembly connector from the motherboard socket.
  33. Repeat the previous step for the two remaining connectors. Repeat the previous step for the two remaining connectors.
    • Repeat the previous step for the two remaining connectors.
  34. Remove the display assembly. If you are reusing the original display assembly, follow this display adhesive application guide to apply replacement display adhesive during reassembly.
  35. Remove the tape covering the ZIF connector above the home button. Remove the tape covering the ZIF connector above the home button.
    • Remove the tape covering the ZIF connector above the home button.
  36. Use the flat edge of a spudger to lift the flap on the connector that secures the cable. Use the flat edge of a spudger to lift the flap on the connector that secures the cable.
    • Use the flat edge of a spudger to lift the flap on the connector that secures the cable.
  37. Pull the cable out of the ZIF connector. Pull the cable out of the ZIF connector.
    • Pull the cable out of the ZIF connector.
  38. Use tweezers to remove the tape that covers the home button cable. Use tweezers to remove the tape that covers the home button cable.
    • Use tweezers to remove the tape that covers the home button cable.
  39. The home button's ribbon cable is very fragile. If it gets damaged, or if the home button has to be replaced, Touch ID will no longer function. Use an iOpener, heat gun, or hair dryer to soften the adhesive under the cable before you pry it up. Starting from the ZIF connector, use the blade on a halberd spudger or the edge of an opening pick to separate the home button cable from the adhesive holding it in place. Stop when you reach the home button.
    • The home button's ribbon cable is very fragile. If it gets damaged, or if the home button has to be replaced, Touch ID will no longer function.
    • Use an iOpener, heat gun, or hair dryer to soften the adhesive under the cable before you pry it up.
    • Starting from the ZIF connector, use the blade on a halberd spudger or the edge of an opening pick to separate the home button cable from the adhesive holding it in place. Stop when you reach the home button.
  40. Gently pry off the home button cover by inserting the hook of a halberd spudger  or the flat edge of a regular spudger between the cover and the LCD, and gently prying towards the bottom edge of the iPad. The hot-melt glue holding this bracket in place can be stubborn. Get it hot to make it easier to separate, and/or very carefully insert a razor blade under the bracket to separate it. The hot-melt glue holding this bracket in place can be stubborn. Get it hot to make it easier to separate, and/or very carefully insert a razor blade under the bracket to separate it.
    • Gently pry off the home button cover by inserting the hook of a halberd spudger or the flat edge of a regular spudger between the cover and the LCD, and gently prying towards the bottom edge of the iPad.
    • The hot-melt glue holding this bracket in place can be stubborn. Get it hot to make it easier to separate, and/or very carefully insert a razor blade under the bracket to separate it.
    • Remove the home button bracket.
    • During reassembly, after installing the home button, you'll need to glue this bracket into place to secure it.
    • Scrape off as much of the old adhesive residue as you can, then clean it with acetone or high-concentration (90% or greater) isopropyl alcohol.
    • Secure the bracket with hot-melt glue, superglue, or high-strength double-sided tape. Make sure the bracket is aligned correctly before allowing your adhesive to cure, or the home button will not click when pressed.
  41. Gently push the home button from the front of the display inward using the tip of a finger. Gently push the home button from the front of the display inward using the tip of a finger.
    • Gently push the home button from the front of the display inward using the tip of a finger.
  42. Remove the home button.
    • Remove the home button.
结论
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
To reassemble your device, follow the above steps in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
9等其他人完成本指南。
Arthur Shi
于2018年01月03日注册
152,752 信誉积分
创作了401篇指南
团队
iFixit iFixit 的会员
Community
135 名成员
创作了15,044篇指南
You swapped iPads half way thru. These pictures are all for the 10.5, not the 9.7. The home buttons and connectors are different. Please fix.
bryceschutte - 回复
Hello bryceschutte,
I took a look at the Home Button for the iPad Pro 9.7”. While it looks slightly different in terms of bracket shape, the steps described (which came from an iPad Pro 12.9” guide) should be almost identical.
Arthur Shi -
My iPad A1673 does not have the large rectangle silver piece near the home button connector.
Jollymon - 回复
I have swapped the home button but i have no function at all from the replacement, i have used 3 different replacements. Is this normal? Have i lost the return to home function? I expected to loose the touch id, but believed the return to home would still work.
Alan Crowley - 回复
Hi Alan,
The return to home should still work with a replacement button. I would suggest checking and re-seating all the connectors that are related to the Home button.
Arthur Shi -
添加评论
浏览统计数据:
过去的24小时: 13
过去的7天: 162
过去的30天: 736
总计 20,006
