跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
iPad Pro 12.9" 3rd Gen Screen Replacement
你所需要的
  1. iPad Pro 12.9" 3rd Gen Screen Replacement, Screen Replacement: 步骤 1 中的图像 1,1
    • iPad Pro 3rd Gen' A1895
    • Be Sure to turn off iPad by pressing and release the volume up button then volume down.
    • While Pressing and holding side button until screen turns off.
    • Just use the slider if you can.
    • Not powering it off can blow out your lcd back light just like iphones other ipads!
  2. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 2 中的图像 1,1
    • You can use a heat gun or another handy heating method! MUST DO!
    • Heating the entire screen will help make it easy to safely remove the screen.
  3. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 3 中的图像 1,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 3 中的图像 2,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 3 中的图像 3,3
    • After 15 Mins In Heater to loosen the strong adhesive!
    • Use a metal pry tool near the least broken shattered side.
    • Use a ifixit suction cup to pull up screen for a plastic guitar pick.
  4. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 4 中的图像 1,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 4 中的图像 2,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 4 中的图像 3,3
    • Apply tape or adhesive over broken glass!
    • Bust out the metal pry tool lifting broken causing glass to stick to tape working your way around broken side.
    • Wiggle Jiggle the screen off the adhesive using multiple plastic guitar picks.
    • Do Not Tear the Screen Off!!!
  5. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 5 中的图像 1,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 5 中的图像 2,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 5 中的图像 3,3
    • Do not rip the screen off!! Cables are very short will cause internal Damages!!!
    • On the Top of the screen the proximity sensor front camera has to be disconnected 1st.
  6. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 6 中的图像 1,2 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 6 中的图像 2,2
    • Lay screen flat pull it down just enough to use a PH000 Screw drive to remove the safety bracket
    • Use Flat Ended Spoudger remove the bracken and cable from the Logic board!
  7. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 7 中的图像 1,2 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 7 中的图像 2,2
    • Perfect! Now Lift the screen folding it up to the left like so!
    • Remove 5 PH000 Screws protecting Power Connection and Display Cables
  8. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 8 中的图像 1,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 8 中的图像 2,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 8 中的图像 3,3
    • PH000 to Battery Connection
    • After detaching battery connection
    • Move Small cable is taped around edges up so you can properly disconnect battery connection
    • Remove all 3 ribbon cables from logic board with flat headed spudger!
  9. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 9 中的图像 1,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 9 中的图像 2,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 9 中的图像 3,3
    • Just a touch of heat don't melt the thing off remove the face ID sensor from Old Screen.
    • Damaging Proximity sensor could effect True Tone with 3rd Party Parts
    • Gently use a tool to get under glued down connection on glass frame of screen!
  10. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 10 中的图像 1,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 10 中的图像 2,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 10 中的图像 3,3
    • Remove Bracket off old screen you and move it to new screen
    • Transfer Cables and Bracket to new screen
  11. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 11 中的图像 1,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 11 中的图像 2,3 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 11 中的图像 3,3
    • Place Screen without adhesive test your screen and face ID
    • After running test take
  12. iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 12 中的图像 1,2 iPad Pro 12.9" 3rd Gen Screen Replacement: 步骤 12 中的图像 2,2
    • Clean Edges with flat ended metal tool to remove broken glass
    • Clean desk of glass on table get ready to remove Proximity sensor from old screen!
    • Do not clamp recommend to use flat and heavy object
    • Broken glass on the frame will crack your new screen
结论
40等其他人完成本指南。
Mark D Schlossman
于09/25/19注册
5,525 声望
创作了8篇指南
33条评论
My Face ID no longer works?
Steve Pisano - 回复
Most likely you may have damaged the flex of proximity sensor.
Check connector
Check placement with flash light make sure everything is aligned correctly
Mark D Schlossman -
why not get a new flex cable from ebay or aliexpress
imab -
What adhesive do you use to reattach their screen?
puppitkey - 回复
添加评论
浏览统计数据:
过去 24 小时: 50
过去 7 天: 237
过去 30 天: 1,111
总计 58,533
