跳转到主内容
加入维修社区 - 创建账户
iPad Pro 11" 1st Gen Battery Replacement
浏览量: 5.1万
浏览统计数据:
过去24小时
41
过去 7 天:
316
过去 30 天:
1,471
总计
50,747
评论: 28
18 comments on steps, 10 guide comments.
Go to guide comments
已完成: 16
16 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 3
3 人已收藏(并订阅)本指南。你会是下一个吗?
所需时间: 2 - 4 小时
难度: 困难
特色指南
iFixit的工作人员认为该指南特别酷。
Follow this guide to replace the battery in your iPad Pro 11" 1st gen.
If your battery is swollen, take appropriate precautions.
This guide is written with an A2013 (Wi-Fi + Cellular) and an A2301 (Wi-Fi + Cellular + mmWave) iPad Pro. If you're fixing a Wi-Fi model, you can still use this guide—there will be some visual discrepancies, and you'll need to skip the steps related to the cellular antennas.
Some photos show the battery connector blocked with two card strips. While this is an optional method, it's more reliable to fully discharge the battery. Ignore this visual discrepancy as you work through the guide.
你所需要的
配件
工具
    1. iPad Pro 11" 1st Gen Battery Replacement, Prepare your iPad for disassembly: 步骤 1 中的图像 1,1
      • Allow your iPad's battery to fully drain before starting this repair. A charged battery may catch fire if damaged during the repair.
      • Unplug any cables and fully shut down your iPad.
      询问修复机器人
      添加评论
    1. iPad Pro 11" 1st Gen Battery Replacement, Screen removal information: 步骤 2 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Screen removal information: 步骤 2 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Screen removal information: 步骤 2 中的图像 3,3
      • While your iPad looks uniform from the outside, there are delicate components under portions of the screen. To avoid damage, follow instructions exactly as written and note the following areas as you open your iPad:
      • Camera module, ambient light sensors, proximity senor, and front microphone
      • Display cables
      • Screen magnets
      • LCD edges
      添加评论
    2. iPad Pro 11" 1st Gen Battery Replacement, Heat the right edge: 步骤 3 中的图像 1,1
      • Apply a heated iOpener to the right edge of the screen for two minutes.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the screen and/or internal battery, so proceed with care.
      添加评论
    3. iPad Pro 11" 1st Gen Battery Replacement, Anti-Clamp instructions: 步骤 4 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Anti-Clamp instructions: 步骤 4 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Anti-Clamp instructions: 步骤 4 中的图像 3,3
      在这个步骤中使用的工具:
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Place an object under your iPad so it rests level between the suction cups.
      • Position the suction cups near the middle of the right edge—one on the top, and one on the bottom.
      • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
      • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
      询问修复机器人
      添加评论
    4. iPad Pro 11" 1st Gen Battery Replacement: 步骤 5 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement: 步骤 5 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement: 步骤 5 中的图像 3,3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      询问修复机器人
      添加评论
    5. iPad Pro 11" 1st Gen Battery Replacement: 步骤 6 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement: 步骤 6 中的图像 2,2
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • If your screen isn't getting hot enough, you can use a hair dryer to heat along the right edge of the iPad.
      • For complete instructions on how to use a hair dryer, check out this guide.
      • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
      • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next step.
      询问修复机器人
      添加评论
    6. iPad Pro 11" 1st Gen Battery Replacement, Insert an opening pick: 步骤 7 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Insert an opening pick: 步骤 7 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Insert an opening pick: 步骤 7 中的图像 3,3
      • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Apply a suction handle to the right edge of the screen, about 5 cm from the bottom edge.
      • Pull up on the suction handle with firm, constant pressure to create a gap large enough to insert an opening pick.
      • Only create a gap small enough to insert an opening pick. Overbending the screen will damage it.
      • Insert the tip of an opening pick into the gap.
      • Don't insert the opening pick more than 5 mm or you'll damage the LCD.
      询问修复机器人
      添加评论
    7. iPad Pro 11" 1st Gen Battery Replacement, Separate the right edge adhesive: 步骤 8 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the right edge adhesive: 步骤 8 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the right edge adhesive: 步骤 8 中的图像 3,3
      • Insert a new opening pick in the gap you just created.
      • Slide the pick along the right edge to separate the adhesive.
      • When sliding near the volume buttons, don't insert the pick more than 2 mm or you'll damage the screen magnets.
      • Leave the pick in the top right corner to prevent the adhesive from re-sealing.
      询问修复机器人
      添加评论
    8. iPad Pro 11" 1st Gen Battery Replacement, Heat the top edge: 步骤 9 中的图像 1,1
      • Apply a heated iOpener to the top edge of the screen for two minutes.
      询问修复机器人
      添加评论
    9. iPad Pro 11" 1st Gen Battery Replacement, Top edge information: 步骤 10 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Top edge information: 步骤 10 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Top edge information: 步骤 10 中的图像 3,3
      • The top edge of the iPad contains the camera module, two ambient light sensors, the proximity sensor, and front microphone. These components are fragile and easily damaged if an opening pick is inserted too far. Only separate the adhesive in the marked locations to avoid damage.
      • The two ambient light sensors can be hard to see and can be located using a flashlight or by placing the iPad under a bright light.
      • Don't insert an opening pick more than 2 mm near the top left and right edges or you'll damage the ambient light sensors.
      • Don't insert an opening pick more than 1 mm near the middle of the top edge or you'll damage the camera module, proximity sensor, and front microphone.
      添加评论
    10. iPad Pro 11" 1st Gen Battery Replacement, Separate the top edge adhesive: 步骤 11 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Separate the top edge adhesive: 步骤 11 中的图像 2,2
      • Slide the pick along the top right edge, stopping when you reach the right ambient light sensor.
      • Don't insert the opening pick more than 5 mm.
      • Leave the pick to the right of the sensor to prevent the adhesive from re-sealing.
      询问修复机器人
      添加评论
    11. iPad Pro 11" 1st Gen Battery Replacement: 步骤 12 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement: 步骤 12 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement: 步骤 12 中的图像 3,3
      • Insert a new opening pick to the right of the ambient light sensor.
      • Slide the pick along the middle section of the top, stopping when you reach the left ambient light sensor.
      • Don't insert the pick more than 1 mm or you'll damage the proximity sensor and front microphone.
      • Leave the pick in to prevent the adhesive from re-sealing.
      询问修复机器人
      添加评论
    12. iPad Pro 11" 1st Gen Battery Replacement: 步骤 13 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement: 步骤 13 中的图像 2,2
      • Insert a new opening pick to the left of the ambient light sensor.
      • Slide the pick along the top left edge, stopping when you reach the left ambient light sensor.
      • Once the top edge adhesive has been separated, you can remove the two picks near the ambient light sensors.
      询问修复机器人
      添加评论
    13. iPad Pro 11" 1st Gen Battery Replacement, Heat the bottom edge: 步骤 14 中的图像 1,1
      • Apply a heated iOpener to the bottom edge of the screen for two minutes.
      询问修复机器人
      添加评论
    14. iPad Pro 11" 1st Gen Battery Replacement, Separate the bottom edge adhesive: 步骤 15 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Separate the bottom edge adhesive: 步骤 15 中的图像 2,2
      • Insert a new opening pick in the bottom right corner below the existing pick.
      • Don't insert the opening pick more than 2 mm when sliding on the right edge.
      • Slide the pick around the bottom right corner to separate the adhesive.
      询问修复机器人
      添加评论
    15. iPad Pro 11" 1st Gen Battery Replacement: 步骤 16 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement: 步骤 16 中的图像 2,2
      • Slide the opening pick along the bottom edge, stopping at the USB-C port.
      • Don't insert the opening pick more than 5 mm when separating the bottom edge adhesive.
      • Leave the pick in to prevent the bottom edge adhesive from re-sealing.
      询问修复机器人
      添加评论
    16. iPad Pro 11" 1st Gen Battery Replacement: 步骤 17 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement: 步骤 17 中的图像 2,2
      • Insert a new opening pick to the left of the USB-C port.
      • Separate the remaining bottom edge adhesive.
      • Leave the pick in the bottom left corner to prevent the bottom edge adhesive from re-sealing.
      询问修复机器人
      添加评论
    17. iPad Pro 11" 1st Gen Battery Replacement, Heat the left edge: 步骤 18 中的图像 1,1
      • Apply a heated iOpener to the left edge of the screen for two minutes.
      询问修复机器人
      添加评论
    18. iPad Pro 11" 1st Gen Battery Replacement, Left edge information: 步骤 19 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Left edge information: 步骤 19 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Left edge information: 步骤 19 中的图像 3,3
      • The left edge of the iPad contains several display cables. These cables are extremely fragile and easily damaged if an opening pick is inserted too far or at the wrong angle. Follow the instructions exactly as written to avoid damage.
      • The display cables are located within small indents of the frame and require an opening pick to be inserted at a 45° angle.
      • There are flat sections of the frame which require an opening pick to be inserted horizontally.
      询问修复机器人
      添加评论
    19. iPad Pro 11" 1st Gen Battery Replacement, Separate the left edge adhesive: 步骤 20 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Separate the left edge adhesive: 步骤 20 中的图像 2,2
      • Insert an opening pick at a 45˚ angle just above the bottom left corner.
      • Don't insert the pick more than 5 mm or you'll damage the display cables.
      • Carefully slide the pick along the left edge, stopping when you reach the flat section of the frame.
      询问修复机器人
      添加评论
    20. iPad Pro 11" 1st Gen Battery Replacement: 步骤 21 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement: 步骤 21 中的图像 2,2
      • Lower the opening pick so it is horizontal to the screen.
      • Don't insert the pick more than 5 mm.
      • Continue separating the left edge adhesive until you reach the next indented section of the frame.
      询问修复机器人
      添加评论
    21. iPad Pro 11" 1st Gen Battery Replacement, Separate the remaining adhesive: 步骤 22 中的图像 1,1
      • Separate the remaining adhesive, making sure to follow the instructions exactly as written.
      • Slide the pick at a 45˚ downward angle and don't insert the pick more than 5 mm.
      • Slide the pick horizontally and don't insert the pick more than 5 mm.
      询问修复机器人
      添加评论
    22. iPad Pro 11" 1st Gen Battery Replacement, Separate the screen from the frame: 步骤 23 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the screen from the frame: 步骤 23 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the screen from the frame: 步骤 23 中的图像 3,3
      • Grab two opposing corners of the screen and gently separate the rest of the adhesive.
      • Don't fully remove the screen as it's held in place by several ribbon cables underneath.
      • Shift the screen towards the bottom right corner of the frame until the ambient light sensor ribbon cable near the top edge is uncovered.
      询问修复机器人
      添加评论
    23. iPad Pro 11" 1st Gen Battery Replacement, Unfasten the ambient light sensor cable bracket: 步骤 24 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Unfasten the ambient light sensor cable bracket: 步骤 24 中的图像 2,2
      在这个步骤中使用的工具:
      FixMat
      $36.95
      • Use a Phillips screwdriver to remove the two screws securing the ambient light sensor cable bracket to the logic board:
      • One 1.3 mm screw
      • One 2.0 mm screw
      • During reassembly, this is a good point to power on your iPad and test all functions before sealing it up. Be sure to power your iPad back down before you continue working.
      询问修复机器人
      添加评论
    24. iPad Pro 11" 1st Gen Battery Replacement, Remove the ambient light sensor cable bracket: 步骤 25 中的图像 1,1
      在这个步骤中使用的工具:
      • Use tweezers or your fingers to remove the bracket.
      询问修复机器人
      添加评论
    25. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the ambient light sensor cable: 步骤 26 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the ambient light sensor cable: 步骤 26 中的图像 2,2
      • Use the flat end of a spudger to disconnect the ambient light sensor cable by lifting straight up on the press connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      询问修复机器人
      添加评论
    26. iPad Pro 11" 1st Gen Battery Replacement, Reposition the screen: 步骤 27 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Reposition the screen: 步骤 27 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Reposition the screen: 步骤 27 中的图像 3,3
      • Don't try to remove the screen yet, as it's still attached by delicate ribbon cables.
      • Grip the right edge of the screen and fold it open like a book.
      • Lay the screen down over the left edge of the iPad.
      询问修复机器人
      添加评论
    1. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the display cables: 步骤 28 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the display cables: 步骤 28 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the display cables: 步骤 28 中的图像 3,3
      • Use the pointed end of a spudger to pry up and disconnect the top two display cables.
      添加评论
    2. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the remaining display cables: 步骤 29 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the remaining display cables: 步骤 29 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the remaining display cables: 步骤 29 中的图像 3,3
      • Disconnect the two remaining display cables.
      询问修复机器人
      添加评论
    3. iPad Pro 11" 1st Gen Battery Replacement, Remove the screen: 步骤 30 中的图像 1,1
      • Grip the right edge of the screen and lift it away.
      • During reassembly, before installing a display, remove any remaining adhesive from the frame, and clean the glued areas with high-strength (>90%) isopropyl alcohol and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
      • If you plan to reinstall your existing screen, remove any remaining adhesive from the back and clean the adhered areas with isopropyl alcohol.
      • Follow this guide to install pre-cut adhesive strips on your iPad before sealing it up.
      添加评论
    1. iPad Pro 11" 1st Gen Battery Replacement, Unfasten the bottom cable shield: 步骤 31 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Unfasten the bottom cable shield: 步骤 31 中的图像 2,2
      • Use a Phillips screwdriver to remove the three 1.2 mm screws securing the bottom cable shield to the logic board.
      添加评论
    2. iPad Pro 11" 1st Gen Battery Replacement, Remove the bottom cable shield: 步骤 32 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Remove the bottom cable shield: 步骤 32 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Remove the bottom cable shield: 步骤 32 中的图像 3,3
      • Use tweezers or your fingers to remove the bottom cable shield.
      询问修复机器人
      添加评论
    3. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the battery: 步骤 33 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the battery: 步骤 33 中的图像 2,2
      • Use a Phillips screwdriver to remove the 1.8 mm screw securing the battery connector to the logic board.
      添加评论
    1. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the USB-C port cable: 步骤 34 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the USB-C port cable: 步骤 34 中的图像 2,2
      • Use the flat end of a spudger to disconnect the USB-C port cable.
      添加评论
    2. iPad Pro 11" 1st Gen Battery Replacement, Separate the USB-C cable adhesive: 步骤 35 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the USB-C cable adhesive: 步骤 35 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the USB-C cable adhesive: 步骤 35 中的图像 3,3
      • The USB-C port cable is secured to the logic board with weak adhesive.
      • Slide an opening pick between the cable and the logic board to separate the adhesive.
      询问修复机器人
      添加评论
    3. iPad Pro 11" 1st Gen Battery Replacement, Unfasten the USB-C port: 步骤 36 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Unfasten the USB-C port: 步骤 36 中的图像 2,2
      • Use a Phillips screwdriver to remove the two 1.9 mm screws securing the USB-C port to the frame.
      询问修复机器人
      添加评论
    4. iPad Pro 11" 1st Gen Battery Replacement, Remove the USB-C port grounding contacts: 步骤 37 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Remove the USB-C port grounding contacts: 步骤 37 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Remove the USB-C port grounding contacts: 步骤 37 中的图像 3,3
      在这个步骤中使用的工具:
      • Use tweezers to remove the two grounding contacts from each side of the USB-C port.
      询问修复机器人
      添加评论
    5. iPad Pro 11" 1st Gen Battery Replacement, Remove the USB-C port: 步骤 38 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Remove the USB-C port: 步骤 38 中的图像 2,2
      • Lift the USB-C port out of its slot in the frame.
      询问修复机器人
      添加评论
    1. iPad Pro 11" 1st Gen Battery Replacement, Unfasten the logic board shield: 步骤 39 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Unfasten the logic board shield: 步骤 39 中的图像 2,2
      • Use a Phillips PH00 screwdriver to remove the eight screws securing the shield to the logic board:
      • Five 2 mm screws
      • Three 1.2 mm screws
      询问修复机器人
      添加评论
    2. iPad Pro 11" 1st Gen Battery Replacement, Heat the logic board shield: 步骤 40 中的图像 1,1
      • Apply a heated iOpener to the top of the logic board for two minutes.
      询问修复机器人
      添加评论
    3. iPad Pro 11" 1st Gen Battery Replacement, Separate the bottom edge shield adhesive: 步骤 41 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the bottom edge shield adhesive: 步骤 41 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the bottom edge shield adhesive: 步骤 41 中的图像 3,3
      • Insert an opening pick between the shield and the shielding gasket on the bottom edge of the logic board.
      • Slide the pick along the bottom edge to separate the adhesive.
      询问修复机器人
      添加评论
    4. iPad Pro 11" 1st Gen Battery Replacement, Separate the right edge shield adhesive: 步骤 42 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the right edge shield adhesive: 步骤 42 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the right edge shield adhesive: 步骤 42 中的图像 3,3
      • Repeat the previous step for the right edge of the logic board shield.
      询问修复机器人
      添加评论
    5. iPad Pro 11" 1st Gen Battery Replacement, Separate the left edge shield adhesive: 步骤 43 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the left edge shield adhesive: 步骤 43 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the left edge shield adhesive: 步骤 43 中的图像 3,3
      • Repeat the previous step for the left edge of the logic board shield.
      询问修复机器人
      添加评论
    6. iPad Pro 11" 1st Gen Battery Replacement, Remove the logic board shield: 步骤 44 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Remove the logic board shield: 步骤 44 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Remove the logic board shield: 步骤 44 中的图像 3,3
      • Grip the logic board shield at the top and lift it up.
      • Stop lifting if the shield is stuck or begins to bend—a bent shield will reduce thermal transfer from the logic board. Use an opening pick to separate any remaining adhesive.
      询问修复机器人
      添加评论
    1. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the IR dot projector cables: 步骤 45 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the IR dot projector cables: 步骤 45 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the IR dot projector cables: 步骤 45 中的图像 3,3
      • Use the pointed end of a spudger to disconnect the IR dot projector cable.
      询问修复机器人
      添加评论
    2. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the camera cables: 步骤 46 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the camera cables: 步骤 46 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the camera cables: 步骤 46 中的图像 3,3
      • Use the pointed end of a spudger to disconnect the front-facing camera and Face ID camera.
      询问修复机器人
      添加评论
    3. iPad Pro 11" 1st Gen Battery Replacement, Separate the IR camera cable adhesive: 步骤 47 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the IR camera cable adhesive: 步骤 47 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the IR camera cable adhesive: 步骤 47 中的图像 3,3
      • The IR camera cable is secured to the logic board with weak adhesive.
      • Slide an opening pick between the IR camera cable and the logic board to separate it.
      询问修复机器人
      添加评论
    4. iPad Pro 11" 1st Gen Battery Replacement, Separate the camera cable adhesive: 步骤 48 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the camera cable adhesive: 步骤 48 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the camera cable adhesive: 步骤 48 中的图像 3,3
      • Repeat the previous step for the camera cable.
      询问修复机器人
      添加评论
    5. iPad Pro 11" 1st Gen Battery Replacement, Unfasten the front camera module: 步骤 49 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Unfasten the front camera module: 步骤 49 中的图像 2,2
      • Use a Torx T3 screwdriver to remove the two 2.1 mm screws securing the front camera assembly to the frame.
      询问修复机器人
      添加评论
    6. iPad Pro 11" 1st Gen Battery Replacement, Loosen the front camera assembly: 步骤 50 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Loosen the front camera assembly: 步骤 50 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Loosen the front camera assembly: 步骤 50 中的图像 3,3
      • Use the pointed end of a spudger to pry up and loosen the front camera assembly.
      询问修复机器人
      添加评论
    7. iPad Pro 11" 1st Gen Battery Replacement, Remove the front camera assembly: 步骤 51 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Remove the front camera assembly: 步骤 51 中的图像 2,2
      在这个步骤中使用的工具:
      • Use tweezers or your fingers to remove the front camera assembly.
      询问修复机器人
      添加评论
    1. iPad Pro 11" 1st Gen Battery Replacement, Logic board cable removal information: 步骤 52 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Logic board cable removal information: 步骤 52 中的图像 2,2
      • You're about to disconnect many connectors from the top and bottom of the logic board. During reassembly, use these photos as a reference to ensure all cables are connected in the correct locations.
      询问修复机器人
      添加评论
    2. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the rear camera interconnect cable: 步骤 53 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the rear camera interconnect cable: 步骤 53 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the rear camera interconnect cable: 步骤 53 中的图像 3,3
      • Use the flat end of a spudger to disconnect the rear camera interconnect cable.
      • Fold the interconnect cable over so the top right speaker cable is accessible.
      询问修复机器人
      添加评论
    3. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top microphone cable: 步骤 54 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top microphone cable: 步骤 54 中的图像 2,2
      • Use the flat end of a spudger to disconnect the top microphone cable.
      询问修复机器人
      添加评论
    4. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top right speaker: 步骤 55 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top right speaker: 步骤 55 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top right speaker: 步骤 55 中的图像 3,3
      • Use the pointed end of a spudger to disconnect the two cables for the top right speaker.
      • Avoid prying against the short sides of the connector. The socket on the logic board is delicate and may break off if pried against.
      询问修复机器人
      添加评论
    5. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top left speaker: 步骤 56 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top left speaker: 步骤 56 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top left speaker: 步骤 56 中的图像 3,3
      • Repeat the previous step for the two top left speaker cables.
      询问修复机器人
      添加评论
    6. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top interconnect board: 步骤 57 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top interconnect board: 步骤 57 中的图像 2,2
      • Use the pointed end of a spudger to disconnect the top interconnect board.
      • Don't bend or reposition the interconnect board, as it will break if stressed.
      询问修复机器人
      添加评论
    7. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top Wi-Fi antenna cable: 步骤 58 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the top Wi-Fi antenna cable: 步骤 58 中的图像 2,2
      在这个步骤中使用的工具:
      • To disconnect antenna cables like this, use tweezers to grip the connector near the cable and lift it up.
      • Use the pointed end of a spudger to disconnect the top Wi-Fi antenna cable.
      • To reinstall, hold the connectors in place and gently press them straight down. The connectors “snap” into their sockets much like the metal snaps on a jacket.
      询问修复机器人
      添加评论
    8. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the Smart Connector and SIM card reader: 步骤 59 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the Smart Connector and SIM card reader: 步骤 59 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the Smart Connector and SIM card reader: 步骤 59 中的图像 3,3
      • Use the flat end of a spudger to disconnect the Smart Connector and SIM card reader cables.
      • For the Wi-Fi only model there is no SIM card reader cable.
      询问修复机器人
      添加评论
    9. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom right speaker: 步骤 60 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom right speaker: 步骤 60 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom right speaker: 步骤 60 中的图像 3,3
      • Follow the procedure in step 57 to disconnect the bottom right speaker.
      询问修复机器人
      添加评论
    10. iPad Pro 11" 1st Gen Battery Replacement, Remove the bottom left speaker cable bracket: 步骤 61 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Remove the bottom left speaker cable bracket: 步骤 61 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Remove the bottom left speaker cable bracket: 步骤 61 中的图像 3,3
      • Use tweezers to peel back the tape securing the bottom left speaker cable bracket to the logic board.
      • Slide the bracket out horizontally.
      询问修复机器人
      添加评论
    11. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom left LTE wireless cable: 步骤 62 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom left LTE wireless cable: 步骤 62 中的图像 2,2
      • Use the pointed end of a spudger to disconnect the bottom left LTE wireless cable.
      询问修复机器人
      添加评论
    12. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom left speaker: 步骤 63 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom left speaker: 步骤 63 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom left speaker: 步骤 63 中的图像 3,3
      询问修复机器人
      添加评论
    13. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom interconnect board: 步骤 64 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom interconnect board: 步骤 64 中的图像 2,2
      • Follow the procedure in 59 to disconnect the bottom interconnect cable.
      询问修复机器人
      添加评论
    14. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom Wi-Fi antenna cable: 步骤 65 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom Wi-Fi antenna cable: 步骤 65 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the bottom Wi-Fi antenna cable: 步骤 65 中的图像 3,3
      • Use the pointed end of a spudger to disconnect the bottom Wi-Fi antenna cable.
      • Peel the cable away from the logic board and reposition it to the right.
      询问修复机器人
      添加评论
    15. iPad Pro 11" 1st Gen Battery Replacement, Disconnect the left microphone and Apple Pencil charger cables: 步骤 66 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the left microphone and Apple Pencil charger cables: 步骤 66 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Disconnect the left microphone and Apple Pencil charger cables: 步骤 66 中的图像 3,3
      • Use the pointed end of a spudger to disconnect the left microphone and Apple Pencil charger cables.
      询问修复机器人
      添加评论
    16. iPad Pro 11" 1st Gen Battery Replacement, Apply isopropyl alcohol to the logic board: 步骤 67 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Apply isopropyl alcohol to the logic board: 步骤 67 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Apply isopropyl alcohol to the logic board: 步骤 67 中的图像 3,3
      • The adhesive that secures the logic board to the frame is very strong. To remove the board, follow the next steps to weaken the adhesive using high-strength (>90%) isopropyl alcohol.
      • Prop the left side of the iPad up against an object so the isopropyl alcohol can flow under the logic board.
      • Apply a few drops of isopropyl alcohol along the left edge of the logic board.
      • Be careful if you're using a syringe with a needle or other sharp instrument to dispense isopropyl alcohol—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      • Let the alcohol soak for one minute to soften the adhesive under the logic board.
      询问修复机器人
      添加评论
    17. iPad Pro 11" 1st Gen Battery Replacement: 步骤 68 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement: 步骤 68 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement: 步骤 68 中的图像 3,3
      • Rotate your iPad 180˚ and lay it down with the right side elevated.
      • Repeat the previous step for the right edge of the logic board.
      询问修复机器人
      添加评论
    18. iPad Pro 11" 1st Gen Battery Replacement, Pry up the logic board: 步骤 69 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Pry up the logic board: 步骤 69 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Pry up the logic board: 步骤 69 中的图像 3,3
      • Insert the flat end of a spudger between the logic board and the bottom right speaker.
      • Slowly pry up the bottom of the logic board.
      • If it is difficult to pry up the logic board, apply additional isopropyl alcohol and wait one minute.
      • Replace the playing card strips with an opening pick to block the battery.
      询问修复机器人
      添加评论
    19. iPad Pro 11" 1st Gen Battery Replacement, Release the logic board: 步骤 70 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Release the logic board: 步骤 70 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Release the logic board: 步骤 70 中的图像 3,3
      • Slide an opening pick under the left edge of the logic board to loosen it.
      • Pry against the frame underneath the logic board to separate the adhesive.
      • Don't forcefully lever against the battery—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      • If the adhesive is still too strong to lift up the logic board, apply some additional isopropyl alcohol and wait one minute.
      询问修复机器人
      添加评论
    20. iPad Pro 11" 1st Gen Battery Replacement: 步骤 71 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement: 步骤 71 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement: 步骤 71 中的图像 3,3
      • Insert an opening pick under the right edge of the logic board above the left microphone and Apple Pencil charger cables.
      • Repeat the previous step for the right side of the logic board.
      询问修复机器人
      添加评论
    21. iPad Pro 11" 1st Gen Battery Replacement, Remove the logic board: 步骤 72 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Remove the logic board: 步骤 72 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Remove the logic board: 步骤 72 中的图像 3,3
      在这个步骤中使用的工具:
      Tesa 61395 Tape
      $8.95
      • Grip the top and bottom edges of the logic board.
      • Remove the logic board.
      • Remove the old adhesive from the rear case and bottom of the logic board using tweezers and high concentration isopropyl alcohol with a lint-free cloth where needed.
      • During reassembly, apply strips of Tesa tape to the bottom of the logic board.
      询问修复机器人
      添加评论
    1. iPad Pro 11" 1st Gen Battery Replacement, Battery adhesive information: 步骤 73 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Battery adhesive information: 步骤 73 中的图像 2,2
      在这个步骤中使用的工具:
      • There are 11 stretch-release adhesives that secure the battery to the frame. Each adhesive strip has a black pull tab:
      • Six on the inside edge of the left battery cell
      • Five on the inside edge of the right battery cell
      • The remainder of the adhesive is located under the battery boards.
      • Use your fingernails or tweezers to peel each pull tab away from the edge of the battery.
      • Be careful not to deform or puncture the battery—especially if you're using tweezers.
      添加评论
    2. iPad Pro 11" 1st Gen Battery Replacement, Remove the battery adhesive: 步骤 74 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Remove the battery adhesive: 步骤 74 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Remove the battery adhesive: 步骤 74 中的图像 3,3
      • Pull the strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the battery cells.
      • You can wrap the adhesive around a spudger to help keep the strip flat while pulling.
      • If the adhesive strip breaks off, try to retrieve it using your fingers or tweezers, and continue pulling.
      询问修复机器人
      添加评论
    3. iPad Pro 11" 1st Gen Battery Replacement, Apply isopropyl alcohol: 步骤 75 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Apply isopropyl alcohol: 步骤 75 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Apply isopropyl alcohol: 步骤 75 中的图像 3,3
      • If you removed all of the stretch-release adhesive, good job! You can skip the next four steps. If not, then follow the next four steps to apply isopropyl alcohol.
      • Prop the left side of the iPad up against an object so the isopropyl alcohol can flow under the right battery cell.
      • Apply high-strength (>90%) isopropyl alcohol along the inside edge of the right battery cell.
      • Let the alcohol soak for two minutes to soften the adhesive under the battery cell.
      询问修复机器人
      添加评论
    4. iPad Pro 11" 1st Gen Battery Replacement: 步骤 76 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement: 步骤 76 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement: 步骤 76 中的图像 3,3
      • Rotate the iPad 180 degrees so the inner edge of the left battery is facing up.
      • Repeat the previous step for the left battery cell.
      询问修复机器人
      添加评论
    5. iPad Pro 11" 1st Gen Battery Replacement, Separate the battery adhesive: 步骤 77 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the battery adhesive: 步骤 77 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the battery adhesive: 步骤 77 中的图像 3,3
      在这个步骤中使用的工具:
      Plastic Cards
      $2.99
      • Lay the iPad down flat on your work surface.
      • Starting at the top, insert a plastic card under the right battery cell.
      • Slide the plastic card toward the bottom of the iPad to separate the adhesive.
      • Stop sliding when you reach the Apple Pencil charger cable.
      • Don't force the card or bend the battery. If it's difficult to insert or slide the card, apply more isopropyl alcohol.
      询问修复机器人
      添加评论
    6. iPad Pro 11" 1st Gen Battery Replacement: 步骤 78 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement: 步骤 78 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement: 步骤 78 中的图像 3,3
      询问修复机器人
      添加评论
    7. iPad Pro 11" 1st Gen Battery Replacement, Separate the battery board adhesive: 步骤 79 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the battery board adhesive: 步骤 79 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement, Separate the battery board adhesive: 步骤 79 中的图像 3,3
      • Don't try to remove the battery yet – the battery boards are still held in place with adhesive.
      • Lift up the left battery cell.
      • Insert an opening pick under the left battery board and separate the remaining adhesive securing it to the frame.
      • If the adhesive does not separate easily, apply some high-strength (>90%) isopropyl alcohol and wait one minute.
      询问修复机器人
      添加评论
    8. iPad Pro 11" 1st Gen Battery Replacement: 步骤 80 中的图像 1,3 iPad Pro 11" 1st Gen Battery Replacement: 步骤 80 中的图像 2,3 iPad Pro 11" 1st Gen Battery Replacement: 步骤 80 中的图像 3,3
      • Repeat the previous step for the right battery cell.
      询问修复机器人
      添加评论
    9. iPad Pro 11" 1st Gen Battery Replacement, Remove the battery: 步骤 81 中的图像 1,2 iPad Pro 11" 1st Gen Battery Replacement, Remove the battery: 步骤 81 中的图像 2,2
      在这个步骤中使用的工具:
      Tesa 61395 Tape
      $25.95
      • Lift both battery cells out of the iPad at the same time.
      • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
      • Remove the old battery adhesive from the frame using tweezers and high-strength (>90%) isopropyl alcohol with a lint-free cloth where needed.
      • If your battery doesn't come with preinstalled adhesive, use Tesa tape to reattach the battery to the rear case.
      添加评论
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 11" 1st Gen answers community for help.
取消:我没有完成这个指南。
16等其他人完成本指南。
作者
与
Chayton Ritter
于08/21/20注册
28,211 声望
创作了105篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了62,190篇指南
10指南评论
My iPad will boot up but won't charge once it is on, would replacing the battery fix that?
I am Good - 回复 分享
Extremely upset with this guide! It didn’t have me disconnect the battery first. When taking off the first display cable, the logic board sparked and shorted out, frying the whole thing! Not even my iPad which makes it so much worse.
Andrew Manger - 回复 分享
Instructions for disconnecting the battery are ambiguous. It should be the first thing you do when the terminal is available?
Robb E - 回复 分享
I completed this and the screen powers on (goes dark blue) but isn’t showing anything. The iPad makes sounds. Anyone have any tips?
isa.stewart - 回复 分享
This is a great guide! Thank you.
filmcrash - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 41
过去 7 天: 316
过去 30 天: 1,471
总计 50,747
