简介
Use this guide to replace the front panel assembly.
你所需要的
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Take the first pick you inserted and slide it up toward the top corner of the iPad.
If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
Antennas
Home button cavity
Digitizer cable
The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
The front-facing camera housing may stick to the front panel; peel up the housing and place it back over the camera to protect it.
Rock the camera housing up on one edge to free it from the adhesive and remove it from the front panel.
Return the front-facing camera housing to its recess in the rear case.
Use tweezers to peel up and remove the rectangular piece of foam tape covering the top right LCD screw.
Remove the triangular tape covering the lower right LCD screw.
Remove the following screws securing the LCD shield plate to the rear case of the iPad:
Two 2.6 mm Phillips #00
Thirteen 1.7 mm Phillips #00
One additional 1.7 mm Phillips #00 on some devices.
Remove the three 1.3 mm Phillips #00 screws securing the connector shield to the logic board.
To minimize stress on the socket, try prying under the short edge of the connector, rather than the long edge which is shown in these images.
Gently pry the digitizer connector up from its socket on the logic board.
32等其他人完成本指南。
3条评论
i say you have too many steps.
and youre missing some too.
i'd put that bad boy in the dehydro for 30 mins and the lcd and glass come out like butta.
spudger on the top and the lcd comes off like nothing!
60C
30mins
remember to also cover all the contacts on the new digi so you don't short it.
if you're wondering which, theyre on the bottom, look at the OEM glass and look at the replacment, see the gold that isn't covered?
cover it, as well as transfer the magnets over to the new glass.
presto!
you win!
Cheers guys hope i helped!
