跳转到主内容
iPad Mini CDMA LCD 更换
你所需要的
  1. iPad Mini CDMA LCD 更换, 加热iOpener: 步骤 1 中的图像 1,2 iPad Mini CDMA LCD 更换, 加热iOpener: 步骤 1 中的图像 2,2
    • 在操作前我们推荐你清空微波炉,在底部的任何讨厌的食物残渣最终都可能粘在iOpener上。
    • 将iOpener放在微波炉中央 。
    • 对于旋转式微波炉:确保盘子可以自由旋转。如果转盘卡住了,iOpener可能会过热并燃烧
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - 回复
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - 回复
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - 回复
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - 回复
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - 回复
    I used the wheat bag in a sensor microwave heating up to 65-70 deg C (155 def F).
    ian cheong - 回复
    Get yourself a cherry pit bean bag the size of your iPad. Heat it, put the iPad on it for 3 to 5 minutes or so, reheat the cherry pit bean bag, again put your iPad on it. Then heat the iOpener and start working. The cherry pit bean bag will have to be reheated several times, but it will soften the adhesive so you have less problems with the iOpener
    Tim Feyaerts - 回复
    The heating can be done very effectively (and quickly) with 3d printer heated bed. Make sure the bed is clean. Set the temperature to 60c, (130f ) and put the ipad face down for +/- 10 minutes. Repeat as needed throughout the “gentle prying” stages.
    polleyphony - 回复
    The iOpener did not work at all for me.
    I had to use a heat gun and bring the edges of the case up to ~200 degrees (used an infrared thermometer to measure) before the glue would weaken. This obviously superheated the metal frame, so I also had to wear gloves to handle the phone while prying the back off with the included picks.
    Mike Jeanette - 回复
    Repair instructions worked like a charm. Had to be patient with the iOpener and getting the screen off. I tried repeatedly without success until shifting the suction cup a bit to the left side where perhaps the glue had loosened up a bit more.
    Kyle - 回复
    The iOpener, in my opinion, is of no help. Many warnings to say “don’t warm it too much”, but the glue doesn’t melt if not warm enough. As a result, a complete waste of time and energy. In addition, too much liquid in it, so it doesn’t lay on the device on a sufficient surface. I took a hairdryer and it worked much much better.
    laurentvidu - 回复
    I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - 回复
    My experience. I was replacing the screen which had been cracked and a little shattered in some places. The iopener is pretty much useless, so was the suction cup. The suction cup would probably be more useful if I was doing something besides the screen. Also you probably want the clean the screen before using it so it can get good suction. I used a hair dryer on high for a couple of minutes at a time (someone on this tread suggested that). I used my exacto knife and a razor blade to get into the adhesive. First the exacto to get the initial cut, then the razor blade to go a little deeper. Could have probably just used the razor blade, but the exacto has a little more finesse. I got the razor blade in and a little under the glass then I used the picks to wedge in. I didn’t want to risk anything using the razor blade too much. Used tape to keep the shattered glass together.
    trebor65 - 回复
    My experience pt2
    Fortunately the shattering was mostly on the edges and most of it had adhesive on the back so it stuck together. Just take your time and work your way around following the guide to get the screen off. Have some goof off or goo be gone to clean the frame when putting the new glass on or putting the existing one back. (someone suggested that also, very good idea). Be careful of the LCD (you should know that). The cable on my LCD was pretty tight, so I propped it up while taking the cable cover off and when I put it back on I did the same thing. I just put a bottle on the battery and leaned the back of the LCD on that while attaching the cables and putting the screws back on the cover. Also be careful with the home button and the bracket on the back of it. I had enough old adhesive on left on the bracket that it stuck back to the new glass fine. So far only 12 hours in, so we will see how that holds up when the kids get at it.
    trebor65 - 回复
    Another alternative if you do not have the iopener is to use a bed time hotwater bottle. Do not over fill it though. Just put enough hot water in to support the phone while you work around the adhesive.
    I use both the hot water bottle and iopener together on Samsung's. It makes life easier
    gazza667 - 回复
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. This allowed me to separate the last bit of the back of my Samsung S8, which was already coming off due to a swollen battery (hence the reason for the repair).
    Dennis - 回复
    Hallo,habe den Akku erfolgreich getauscht.Doch seitdem gibt es bei Telefonaten eine Rückkopplung für den anrufenden.Bei mir ist alles normal.Woran liegt das?Mfg
    Manu R - 回复
    If you follow these instructions, you will crack your screen like I did. Heating the iOpener for 30 seconds, using it to melt glue, then waiting 10 minutes to reheat is useless. The iOpener can be used to maybe warm the glue on whatever side you aren’t working on. You need a hairdryer and/or a heat gun to melt the glue and separate the glass from the iPad.
    Anyone want to buy an old iPad with broken glass and a dead battery?
    mpulliam - 回复
    Not everybody has a microwave. You should provide a target temperature for the iOpener and instructions for a conventional oven, or pot of warm water, or whatever. Although I will probably use a heat gun …
    Esmond Pitt - 回复
    Three times heating opener and no luck. Tried pressing down gently on opener with a towel, and the opener broke. Wondering if I now replace table mats, fancy table cloth, etc. or will this stuff wash out.
    Not impressed so far. Maybe the hair dryer next.
    doug - 回复
    I support the comments about the iOpener. Everyone has a hair drier, FHS, so get a cheap IR thermometer (£18) and blow heat until the area is 60+ deg C. Still takes w while, and getting the screen off is v scary, but just add more heat if you feel resistance.
    The rest of the kit is good, esp the magnetic screwdrivers.
    Richard O'Brien - 回复
    No, everyone does not have a hairdryer. Some of us don’t even have hair. Thank goodness I already had an IR thermometer, though.
    nin10doh -
    #### WARNUNG WENN MINIMALSTER SPRUNG IM DISPLAY IST FUNKTIONERT DAS NICHT!!! ######
    Hatte einen winzigen, minimalen Sprung im Display. Ich dachte es könnte gehen, weil der Sprung “abgeschlossen” war. Er hat in einer Ecke ein winzige Glasteil rausgeschnitten. NEIN! Geht nicht. Habe alles mit viel Geduld dem iOpener und einem Föhn erhitzt. Es ist trotzdem sofort über das komplette Display zersprungen…
    T z - 回复
    I’ve started with iOpener but changed very quickly to a heatgun. That was more efficient.
    Mizzoo, s.r.o. - 回复
    I could not get the iOpener hot enough to melt the glue on my ipad 6. I heated for 45 seconds once and it was boiling and it still never worked. Thank goodness contributors mentioned using a hair dryer. Using an 1700w hair dryer on high did the trick to get the screen off. Still took some time and the case got pretty hot but be patient. It took twice as long and a lot more patience to get the battery out.
    Randal Haufler - 回复
    I have an Ipad with touch screen issue, if i replace this part it should be Ok?
    janderson martin - 回复
    WARNING - DO NOT MICROWAVE ON A METAL MICROWAVE RACK
    The metal microwave rack can heat up and melt through the iOpener cover letting the contents leak out.
    Not a big issue for me as I have a heat gun and used that instead.
    Run Up A Tree - 回复
    I opened my iPad with the iOpener. Be patient! It may take quite a bit longer to it the iOpener in the microwave than it says in the guide. My microwave can only do 800W and I had to put the iOpener in several times (maybe a total of 90-120 seconds). I recommend that you have the transparent side up an watch the bag carefully. As long a the bag doesn't bloat up and the liquid doesn't start bubbling you should be fine. But I recommend to take the iO out from time to time to check it. (More comments in Step 6.)
    marcelflueeler - 回复
    I gave upon the I opener and used a hairdryer. (Fixed an iPad 6)
    Tom Weber - 回复
    iPad mini gen5. I used the iOpener. My microwave is 1200w with carousel. 30 sec got the iOpener to 155ºF. For the 2nd heating, after 10 minutes sitting, the temp was still around 125º so I only cooked it for 15 sec. Not enough increase so +5 sec more which me to 165-170ºF. This should be considered ballpark info because who knows the real output of the various microwaves and the quality of the IR tool used to determine temp.
    To successfully open my iPad mini I applied the iOpener twice to the left edge and twice to bottom. & once to R edge. Using the suction cup was difficult for me (I'm in my 70's so my hands don't work too well anymore). I had trouble holding the guitar pick and slipping them in (at an downward angle). In the end, sliding my thumbnail along the edge opened it very slightly and allowed the pick to get into the gap. I marked the ends of all my picks with a sharpie pen for the recommended 2mm insertion to avoid going in too deep. To get the screen open it took me approx 1 hour.
    jharrison - 回复
    Can’t you just use a hair curler instead?
    Aspect22 - 回复
    A hairdryer or heat gun works, if heating is kept around 100 deg C (212 deg F - boiling point of water). But… heating this way is cumbersome. Using a hotplate, set to 100 deg C, measured carefully with a fairly inexpensive IR gun, is simpler and easier, if you can afford the hotplate (I used an old pancake griddle with a thermostat knob). It works great for phones, setting them face down for 2 minutes, then picking them up with insulated gloves - cheap, wool gloves work fine. This may require repeated reheating to continue the display removal, but its much simpler.
    Because its almost impossible to repeatedly lay an iPad/tablet on the hot plate, I propose an alternative.
    Initially lay the larger iPad/tablet, face down, for 2 min, to heat all of the adhesive surrounding the display. Lift and begin the picking process describe in your removal steps. Then lay an iOpener on the hotplate for 2 min (already set to the exact, desired temp) to bring it to working temp for the remaining operations.
    Dan Smith - 回复
    For iPads in particular, it makes sense to construct a simple, aluminum window frame, laid on a hotplate (see my comment above) that only touches the edges of the display, heating only the adhesive underneath. This prevents general heating of the entire device. Four strips of aluminum, placed together as a frame, would be the simplest and allow variations for all devices - envision it as a pinwheel of strips, radiating outward. Use it for any size device.
    Dan Smith - 回复
    BTW, always read all comments at each step. New, and possibly useful, suggestions appear on occasion that can be crucial.
    Dan Smith - 回复
  2. iPad Mini CDMA LCD 更换: 步骤 2 中的图像 1,1
    • 加热iOpener三十秒
    • 在整个维修过程中,如果iOpener 冷却了,在微波炉中每次重新加热额外的三十秒。
    • 注意在维修过程中不要过度加热iOpener,过热可能会导致iOpener爆炸。
    • 如果iOpener过热膨胀,千万不要触碰iOpener。
    • 如果iOpener中间部分依然烫的没法碰,请等待冷却后再使用,加热好的iOpener 应该可以保持热度十分钟
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - 回复
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - 回复
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - 回复
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - 回复
    All phones/devices differ it’s unrealistic and unsafe to put a exact time/temperature needed to soften the adhesive. It’s really quite simple you warm the device evenly and in a controlled manner just enough to enable pry tools and picks to begin separating. Best tool in my opinion but again this is because I have experience is a hot plate and heat gun both of which are used at nearly the lowest settings and I can handle flat palming the plate for almost 10 seconds I leave the device to conduct heat until approx it’s about 110 at most 120 ish this will be plenty to soften all the adhesive if any problem areas I use heat gun while prying. Again you need go slowly and learn with a throw away phone
    Greg Latta -
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - 回复
    Now that is a very good idea :) I was going to use a hairdryer
    Maz -
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - 回复
    I agree with this.
    Jarl Friis -
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - 回复
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - 回复
    I can’t recommend the microwave. If the the iOpener becomes too hot, it bursts. Better put the opener in cooking water. Dry it and use it. Instead of an iOpener you can use hot/cool packs as well.
    Bernhard Keim - 回复
    Great idea with using the heat packs. I will try that next time. Thank you
    Collins -
    Trust the directions! I forgot and left it in the Microwave too long and after 1 minute I had Mt Vesuvius - the iOpener burst and spewed the goodies out. The problem is, the Digitizer can be damaged by a hot air gun, so I had to tough out and remove the glue the hard way. I made it … with lots of patience! Tough lesson.
    Larry Bennett - 回复
    I also used a hairdryer. I used it on the low setting and I cut a piece of carboard to protect the rest of the screen. The iFixit tool and method is vert tedious and very time consuming in comparison. With the hairdryer method you can literally have the display apart in a few minutes. Using your other hand nearby the area you are heating it should be very hot but not enough to burn your hand. You only have to heat metal part of case near glass edge. If you have a cellular model then you need to be very careful because the black antenna area is plastic. So less heat and work your way up in adding heat just enough to separate around the area but not so much you melt the plastic!
    Fixrights - 回复
    iOpener was the worst part of the kit. Followed directions for :30 in microwave and took 4 trips to the microwave to loosen adhesive on left side of home button. I thought I was figuring it out and it was working well… even set a timer to wait 10 minutes between heating it up. Was on the right side and was on my 12th heat up when it exploded in the microwave. My only tip is that if you set it clear side up, as soon as you see any bubbles or boiling in the liquid, STOP! If you put a pot holder over the iOpener and press slightly to make good surface contact, that seemed to help. I finished heating with a “Corn Sack” that held heat better than the provided iOpener.
    digital_only - 回复
    Mon iopener n'a pas tenu une réparation. Je ne vous conseille pas ce produit
    Berard Romain - 回复
    Bonjour,
    Nous sommes désolés que votre réparation ne se soit pas déroulée comme prévu. Il se peut que le produit était défectueux. Veuillez contacter notre service client support@ifixit.com (boutique américaine) ou eustore@ifixit.com (boutique européenne) en décrivant ce qui s’est passé.
    Claire Miesch -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - 回复
    Thank you for posting some actual temperatures. I have a heat gun with a very fine self-temperature regulation setting capability.
    I will set it for 150-180 F, and use that to soften the adhesive.
    G Trieste -
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. A second heating about 15 minutes later in the micro and it came out at 190 degrees F. Plenty hot enough to soften the adhesive for removing the back on my S8. Based on the comments above I think people just need to use more patience.
    Dennis - 回复
    I used various time settings. It got very hot. It would soften the glue but not a whole lot. If my screen had been intact and I was replacing something that was not a digitizer, it may have worked. A broken screen makes the process significantly more difficult. I ended up breaking the home button cable. Good bye TouchID…
    cvela90 - 回复
    After reading previous comments I didn't even use the i-opener. Used the heatgun ( hairdryer ) which works great for me. Maybe I was lucky as this is my first attempt at replacing a cellphone battery. Motoz 3
    Collins - 回复
    It appeared 30 seconds were not enough, so I heated it more, by 5 seconds at a time until I got the right temperature about 70 degrees Celsius (measured with infrared pistol) to get the screen heated up to 60 C, the best for softening the glue. But the heat was quickly dissipating by the big aluminum back cover, so the best I got in 2 minutes of applying iOpener was around 45 C, which made the procedure difficult and having risk of breaking the screen. So I eventually abandoned iOpener and user a hot air gun with precise temperature setup. I set it to 90 C, which allowed me to open my iPad quickly and safely.
    Sergey Kofanov - 回复
    I, too, ended up using a hot air gun. I’ve done earlier versions of iPad before but the adhesive used on this IPad 5 A1822 was particularly difficult to remove.
    Also, while the suction cup worked great when the glass is in tact, any cracks in the glass make the suction cup useless.
    manningrl - 回复
    You need to remember here are different sizes of microwaves. I had the same issue.
    Heating on a smaller unit I used 45-60 seconds. That worked but was time comsuming
    William Draheim - 回复
    Yeah, the iOpener didn't work for me either.... ended up using a hair dryer and that worked. The iOpener was too warm to soften the glue in my case.
    Andrés Vettori - 回复
  3. iPad Mini CDMA LCD 更换: 步骤 3 中的图像 1,1
    • 把iOpener从微波炉中拿出来,捏着两边扁平边缘中的一个以避免碰到中心热的部分。
    • iOpener会非常烫,所以拿着它的时候千万要小心。必要的时候可以使用烤箱手套。
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - 回复
    I did too, you get far more control and no expense on fancy equipment.
    Billinski -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method. I don’t know how much microwaves vary in heating consistency with these pads, but knowing how inconsistent the temperature of a bowl of plain rice gets in my microwave, I wasn’t interested in even trying to use it for this.
    breadandbits - 回复
    I used an electric griddle set to the lowest setting. It seemed to work very well.
    John - 回复
    I vote for the hair dryer. The other methods work too but if you aren’t having any luck, switch to the hair dryer. While holding the iPad in my hand, I found that I am aiming the dryer at my finger at the same time and it gauges how hot it is. I stop when my finger can’t take it - maybe five seconds up close. Repeat as needed like I did.
    Robin - 回复
    This thing melts when placed up side down in the microwave…
    Mark - 回复
    If the maximum temperature for this iOpener is lower than the gadget glue minimum temperature, this device does not make sense.
    I think the maximum temperature for this iOpener is below 100⁰C and most gadget glue minimum temperature is higher than 100⁰C. So the iOpener is useless for many opening steps in repair guides. But who knows because temperature range is not specified for this iOpener.
    Jarl Friis - 回复
  4. iPad Mini CDMA LCD 更换, 加热iOpener的替代方案: 步骤 4 中的图像 1,2 iPad Mini CDMA LCD 更换, 加热iOpener的替代方案: 步骤 4 中的图像 2,2
    • 如果你没有微波炉,请按照此步骤在沸水中加热iOpener。
    • 在锅或平底锅里装满足够的水来完全淹没iOpener。
    • 把水加热到沸腾。关火。
    • 将iOpener放入热水中2-3分钟。确保iOpener完全浸入水中。
    • 用钳子从热水中提取加热的iOpener。
    • 用毛巾彻底擦干iOpener。
    • iOpener会很燙,所以拿取時請小心的從iOpener的邊邊拿
    • 你的iOpener已准备好使用!如果你需要重新加热iOpener,请将水加热到沸点,关火,并将iOpener放入水中2-3分钟。
    What do I do if I don’t have a iopener?
    alexdelarge103@gmail.com - 回复
    2 or 3 cups Rice in a sock, heat for about 2 minutes. But, I recommend the iopener.
    Robert Garcia - 回复
    When boiling in water you can put the iopener in a ziplock to keep it dry.
    Robert Garcia - 回复
    Even if you don't put in a ziplock bag, I found that the surface is mostly hydrophobic so drying it is very easy. I also didn't have tongs, but the bag is denser than water, so it sank and I attached clothes pins to the ends and was able to remove it with those.
    Jack Adrian Zappa - 回复
    2-3 minutes in near boiling water, then 2-3 minutes on my s10+ and it was super easy to cut the glue off.
    Kipras Bielinskas - 回复
    I have a question, if I have a pan, and I have water, and a mean to boil the water, won't it be easier and cheaper to just use that.
    Ollie Tan - 回复
    Have you tried it? Water limits your temperature to 100℃, whereas 'pan on the stove' can easily get up to twice that. If your pan is even slightly warped, you'll have a few hot spots of direct conduction with convection everywhere else, heating things unevenly. Assuming you get the device up to temperature, how will you get it out without scratching it or burning yourself? After you're finished, do you really want to prepare food in the pan you warmed up adhesives and trace manufacturing substances in?
    Boiling something form fitting to heat your device with is a lot more foolproof, and not being foolish is easier and cheaper. Direct pan heating can work, but you are leaving yourself open to a lot more problems than just taking the safe route.
    James Beegle -
  5. iPad Mini CDMA LCD 更换, 前面板: 步骤 5 中的图像 1,3 iPad Mini CDMA LCD 更换, 前面板: 步骤 5 中的图像 2,3 iPad Mini CDMA LCD 更换, 前面板: 步骤 5 中的图像 3,3
    • 如果您的显示屏玻璃已经碎裂,防止显示屏玻璃在您维修时进一步伤害到您,请使用胶带来固定已经碎裂的屏幕。
    • 给iPad 的正面整面贴上胶带。
    • 这一步将保证在您翘起和移除显示屏时能够保持完整。
    • 尽量根据下面的指南进行操作。但,一旦玻璃破碎,请停下拆解并使用金属撬刀撬出玻璃,避免更多的碎裂。
    • 戴上安全眼镜来保护你的眼睛。 小心操作不要损坏了LCD内屏。
    In case of broken glass, here are some hints:
    - I prefer 3M "3350" tape; a metalized polypropylene tape with an acrylic adhesive. It's a very thin, silvery HVAC tape, not your standard duct tape.
    - Test your tape to make sure it sticks really well to the glass.
    - Use isopropyl alcohol on a paper towel to remove fingerprints and other dirt to help the tape stick to the screen.
    - Use the widest tape you can find, and apply it evenly, without trapping bubbles, without crinkles: This greatly improves your chance of success with the suction cup later.
    - Cut tape pieces long enough and go over the (rounded) edge; afterwards carefully run a scalpel alongside the edge (between bezel and glass) to trim off any excess.
    - Don't overlap edges of the tape: butt-join them instead.
    - If needed: repeat in other direction.
    - If needed: Cut square piece of tape (size of suction cup) and place it where you want to lift the glass, so that the suction cup doesn't cover any butt-joins.
    Good luck, you brave person!
    volty - 回复
    This is the second broken screen I’ve fixed. Overlapped package tape carefully stuck to the glass and trimmed to the edges will contain most of the shards. I found that a hair dryer works for softening the glue. After getting under an edge with the suction cup I carefully followed the opening sequence using a combination of plastic picks and a single edge razor blade to get under the small pieces. It was slow going with lots of reheating with the dryer (about 45 minutes), but the taped glass came off without glass everywhere.
    Bill Roughen - 回复
  6. iPad Mini CDMA LCD 更换: 步骤 6 中的图像 1,1
    • 将iOpener放置在iPad左侧。也就是Home键左侧位置。
    • 将iOpener放置至少5分钟来软化玻璃下面的粘合剂。
    I worked at it for over 2 hours before deciding to microwave the opener for 45 seconds at a time. That seemed to do the trick.
    jaromhyde - 回复
  7. iPad Mini CDMA LCD 更换: 步骤 7 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 7 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 7 中的图像 3,3
    • 将吸盘小心的放在刚加热的一侧中间的位置。
    • 确保吸盘已经牢牢吸住前玻璃面板。
    • 使用一只手在固定住iPad,另一只手慢慢提起吸盘,将前玻璃面板与后壳分离。
    • 小心将玻璃面板提起能够将撬棒插入的高度。 抬的过高玻璃会有破损的风险。
    This step is totally pointless if you have a shattered screen. The suction cup is rendered useless. Any tips on what to do if you can't get any suction due to a shattered screen?
    robloomis - 回复
    just pick out the glass shards if it is cracked that bad you are better off scrapping the digitizer
    echow2001 -
    for shattered screens I cover the screen with tape. I find packing tape works best for me.
    George - 回复
  8. iPad Mini CDMA LCD 更换: 步骤 8 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 8 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 8 中的图像 3,3
    • 拉住吸盘,在玻璃和机壳之间的缝隙处放置一个撬片。
    • 切勿将撬片插入深度超过黑色边框,这样深入过度可能会使LCD屏幕受损。
    • 然后拉动吸盘塑料部分来将吸盘从显示模组上取下。
    you have to pull up on the suction cup harder than you might be comfortable with!
    jfaulks1 - 回复
    thanks jfaulks1 (I did not copy and paste lol)
    iliketrains kid - 回复
  9. iPad Mini CDMA LCD 更换: 步骤 9 中的图像 1,1
    • 重新加热iOpener
    • 小心,请勿在维修过程中过度加热iOpener。 在重新加热iOpener之前请至少等待10分钟。
    • 将其放在ipad左侧几分钟来重新加热。
  10. iPad Mini CDMA LCD 更换: 步骤 10 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 10 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 10 中的图像 3,3
    • 沿着第一个撬片的开的口处插入另外一个翘片同时向下滑动,让撬片分离粘合剂。
    • 在下来的步骤中,如果您遇到了巨大的阻力,请停下来,重新加热工作的部位。 暴力使用撬片会导致玻璃破裂。
  11. iPad Mini CDMA LCD 更换: 步骤 11 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 11 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 11 中的图像 3,3
    • 继续沿着下方继续滑动来将粘合剂分离。
    • 如果撬片卡住了,请沿着iPad的侧面滚动撬片,然后继续进行分离工作。
  12. iPad Mini CDMA LCD 更换: 步骤 12 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 12 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 12 中的图像 3,3
    • 将第一个插入iPad的撬片向上滑动到iPad的左上角
    • 撬片可能会出现图片上的情况,请不要慌张。 只需将撬片拉出一点点来继续进行维修工作。 但要避免这种情况,因为粘合剂可能会粘附在LCD显示屏上变得难以清理。
  13. iPad Mini CDMA LCD 更换: 步骤 13 中的图像 1,1
    • 重新加热iOpener 并将其放置在iPad顶部边缘位置且高于前置摄像头。
    • 如果您有可以弯折的iOpener,您可以弯折其使其同时加热左上角边缘位置。
    I left my iOpener on the bezel the entire time I slid picks in. worked great
    jfaulks1 - 回复
  14. iPad Mini CDMA LCD 更换: 步骤 14 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 14 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 14 中的图像 3,3
    • 在左顶部插入撬片来分离粘合剂。
    Gezz this is though! Cracked the glass while replacing it.
    Padraic Hoselton - 回复
    :( sad (rip glass lol)
  15. iPad Mini CDMA LCD 更换: 步骤 15 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 15 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 15 中的图像 3,3
    • 滑动撬片直到快接近前置摄像头位置时停下
    • 第三张图片展示了iPad前置摄像头的位置。
    • 避免使用撬片直接滑过前置摄像头,这样做可能会污损到摄像头。 接下来的步骤将会详细说明如何避免损伤前置摄像头。
  16. iPad Mini CDMA LCD 更换: 步骤 16 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 16 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 16 中的图像 3,3
    • 轻轻拉出些许撬片,并沿着前置摄像头顶部位置慢慢的滑动。
  17. iPad Mini CDMA LCD 更换: 步骤 17 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 17 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 17 中的图像 3,3
    • 将刚才那片撬片稍微滑过前置摄像头然后放在原位不动。
    • 拿另一片撬片插入到摄像头的左侧位置然后滑动到转角位置,完成对该边缘部分的粘合剂分离工作。
    • 将第二片撬片放在转角处,防止粘合剂冷却后重新粘连。
  18. iPad Mini CDMA LCD 更换: 步骤 18 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 18 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 18 中的图像 3,3
    • 将刚才那片撬片稍微深入iPad之中,从摄像头处滑动到右上角。
    Shattered my screen pretty bad here, making it so that whenever I continued to move the pick the glass separated and I couldn’t continue moving it. Be VERY gentle moving the pick; almost no force is required.
    Jasper Holden - 回复
  19. iPad Mini CDMA LCD 更换: 步骤 19 中的图像 1,1
    • 将三个撬片放置在转角处,防止粘合剂重新与粘连前面板。
    • 重新加热iOpener然后将其放置在iPad未撬开的右侧,音量和电源键一侧。
  20. iPad Mini CDMA LCD 更换: 步骤 20 中的图像 1,2 iPad Mini CDMA LCD 更换: 步骤 20 中的图像 2,2
    • 滑动右上角的撬片,分离那部分的粘合剂。
    • 将这个撬片就放在这,防止粘合剂重新粘连。 重新拿一个撬片来进行下一步。
  21. iPad Mini CDMA LCD 更换: 步骤 21 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 21 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 21 中的图像 3,3
    • 在右侧插入一个新的撬片来分离粘合剂,滑动到中部位置时停下。
  22. iPad Mini CDMA LCD 更换: 步骤 22 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 22 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 22 中的图像 3,3
    • 继续滑动到右下角处,来分离粘合剂。
  23. iPad Mini CDMA LCD 更换: 步骤 23 中的图像 1,1
    • 就把撬片放在停下的位置,然后重新加热iOpener。
    • 记住,切勿过度加热iOpener-加热间隔为10分钟。
    • 然后将iOpener放置在iPad的底部几分钟来软化玻璃面板下的粘合剂。
  24. iPad Mini CDMA LCD 更换: 步骤 24 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 24 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 24 中的图像 3,3
    • 滑动左下边的撬片来分离粘合剂。
    • 滑动到左下角时停止滑动。 然后放置在此
    • 这里有几个地方需要避免撬动到。 详见第三张图片。
    • 天线
    • Home键
    • 数字化线缆
    • 接下来的步骤将会指导您如何避免伤害这些部件。 只加热和撬动指南所指示的部位。
  25. iPad Mini CDMA LCD 更换: 步骤 25 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 25 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 25 中的图像 3,3
    • 将原撬片放置在原位,以防粘合剂重新粘合。
    • 拿一片新的撬片,轻轻的从左手边的天线处滑动到home键前
    • 只能从iPad外边缘向内滑动 请勿按照相反方向滑动 这样可能会损坏天线。
    • 如果您需要再次滑动来清理粘合剂,请取出撬片然后从外边缘重新插入再向内滑动。
    • 将撬片放置不动。
  26. iPad Mini CDMA LCD 更换: 步骤 26 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 26 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 26 中的图像 3,3
    • 拿一片新的撬片来从刚才那片撬片在右边Home键下继续滑动。
    • 在右手边大约1英尺的地方停下来,避免切割到数字化线缆。
    • 将撬片稍微深入,然后向Home键处滑动。
    • 再一次提醒,确保完全插入然后再滑动撬片。 不然的话这样会损坏玻璃面板下的天线。
  27. iPad Mini CDMA LCD 更换: 步骤 27 中的图像 1,1
    • 重新加热iOpener 将其放在iPad的顶端。
  28. iPad Mini CDMA LCD 更换: 步骤 28 中的图像 1,2 iPad Mini CDMA LCD 更换: 步骤 28 中的图像 2,2
    • 小心操作这一步,花点时间保证粘合剂是热和软的,同时确保您的撬片已经分离开了该分离的粘合剂。 不要怕返工和重新加热。
    • 在iPadHome键相对的顶部您应该在每个角落里插了撬片。 扭动撬片,轻轻地提起玻璃面板,分离最后残留的粘合剂。
    • 如果在打开过程中遇到很大的阻力,请立即停止扭动撬片。 将撬片放置原位,重新加热iOpener,将其放置在难以开启的位置,然后插入撬片来重新分离一遍粘合剂。
  29. iPad Mini CDMA LCD 更换: 步骤 29 中的图像 1,2 iPad Mini CDMA LCD 更换: 步骤 29 中的图像 2,2
    • 慢慢地轻轻地提起玻璃面板,以便沿着下边缘进一步分离粘合剂。
    Really, add a few more pics and a few more picks, see how long and difficult you can make this guide. 26 steps to get the top screen off is ridiculous.
    B. A. Computer Services - 回复
  30. iPad Mini CDMA LCD 更换: 步骤 30 中的图像 1,2 iPad Mini CDMA LCD 更换: 步骤 30 中的图像 2,2
    • 一旦所有的粘合剂被分离了,玻璃面板就可以像翻书一样将其放置在您的工作台上。
    I recommend wearing latex gloves or be sure not to put too many finger prints on the front or back of this front glass when lifting it or completing the remainder of the steps. I made this mistake and upon installing the new LCD and putting the iPad back together I realized that I left a few finger prints on the inside of the front glass. After re-securing the adhesive strips putting the iPad back together there are now unremovable fingerprints visible when the LCD is turned off. Just a recommendation on the gloves or be sure to wipe both sides of the front glass clean before putting all back together.
    Christian Screen - 回复
  31. iPad Mini CDMA LCD 更换: 步骤 31 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 31 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 31 中的图像 3,3
    • 前置摄像头的保护壳可能会粘在前面板上; 将保护壳从面板上取下,并放回相机上以保护相机模组。
    • 从保护壳一角晃动其,让其从前面板上的粘合剂上分离下来。
    • 将前置摄像机外壳放回后壳中的凹槽。
    this didn’t happen to me BUT the glue was still sticking to the top of the glass because one pick had gone OVER the glue and the other under, so I had to pull the glue off and cut it with scissors
    jfaulks1 - 回复
    OK this was glue, it was the tape from step 35!
    jfaulks1 - 回复
  32. iPad Mini CDMA LCD 更换, LCD 组件: 步骤 32 中的图像 1,3 iPad Mini CDMA LCD 更换, LCD 组件: 步骤 32 中的图像 2,3 iPad Mini CDMA LCD 更换, LCD 组件: 步骤 32 中的图像 3,3
    • 小的海绵胶带保护着顶部,底部右手边有螺丝将LCD与后壳相固定。
    • 使用镊子取下保护右上侧LCD螺丝的长方形海绵胶带。
    • 取下右下方LCD螺丝上的长方形胶带。
  33. iPad Mini CDMA LCD 更换: 步骤 33 中的图像 1,2 iPad Mini CDMA LCD 更换: 步骤 33 中的图像 2,2
    • 左上方的LCD螺丝有可能被胶带所覆盖。
    • 如果有的话,使用撬棒扁平的一端来撬起,露出下方的LCD螺丝。
  34. iPad Mini CDMA LCD 更换: 步骤 34 中的图像 1,1
    • 移除将LCD与后壳固定的四颗3.9 mm Phillips #000 螺丝。
    In my case the 4 screws are not the same. One is 4mm, and 3 of 3.5mm, or better 2 x 3.5mm and one 3.45mm. I put the longest one at the left edge at left of the LCD flat cable.
    mitja
    Mitja Jankovic - 回复
    Hi Mitja. I just checked the measurements with an electronic digital caliper. I got 3.9 mm for all four screws. Are you sure it was the same model? Thanks.
    Walter Galan -
    The top left screw is longer than the other 3 - iPad mini Retina Wi-Fi.
    sandro - 回复
    On mine the top right screw is longer
    oliver - 回复
    top right is longer on an ipad mini 2 retina wifi 32GB
    sagert - 回复
    ipad mini wifi no screws are longer
  35. iPad Mini CDMA LCD 更换: 步骤 35 中的图像 1,2 iPad Mini CDMA LCD 更换: 步骤 35 中的图像 2,2
    • 使用镊子来将LCD框架与右侧扬声器连接的胶带剥离。
    I wonder what does this sticker stands for…
    K8L - 回复
  36. iPad Mini CDMA LCD 更换: 步骤 36 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 36 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 36 中的图像 3,3
    • LCD框架上贴着一条薄薄的海绵胶带,将LCD面板下方的胶带相连接。 要继续,你需要将其破坏然后剥离一些,暴露下方的胶带。
    • 使用薄口镊子拉起LCD周围的泡沫胶带的顶部。
    • 不要用镊子触碰液晶显示器,否则可能会损坏显示屏。
    • 使用镊子将泡沫胶带剥去以暴露液晶显示屏的顶部。
  37. iPad Mini CDMA LCD 更换: 步骤 37 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 37 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 37 中的图像 3,3
    • 在LCD框与LCD顶部胶带之间插入撬棒的尖端。
    • 在LCD框与胶带之间滑动,将胶带与LCD框相分离。
    I finished a successful replacement of my screen following these instructions. Thanks.
    Step 36 (remove tape from LCD perimeter), however, seems unnecessary. I ended up spending a lot of time separating the tape from the LCD frame only to discover it was not necessary for steps 37-44 and actually made things really difficult for step 45-46 (removing the tape near the speakers). Finally, steps 45-46 can be skipped since it is much easier to remove this tape once you flip the LCD over (Step 55).
    Kenneth Snyder - 回复
  38. iPad Mini CDMA LCD 更换: 步骤 38 中的图像 1,2 iPad Mini CDMA LCD 更换: 步骤 38 中的图像 2,2
    • LCD金属屏蔽版与LCD使用胶水在其顶部左侧和右侧的边角相粘连。 为了安全分离这些粘合剂,你需要使用吉他拨片来移动几毫米。
    • 在LCD与后壳靠近左上角的位置插入吉他拨片
    • 小心向外弯曲拨片,不需要撬开过大的缝隙。
    I found a very simple method for removing the LCD from the metal shield. Slightly lift one of the top corners and insert a 1' piece of fishing line. Insert the line under the other top corner placing the length between the LCD and shield. Once in place, gently pull each end toward the bottom of the LCD breaking the adhesive as you go. This will make things much easier than using the picks and possibly breaking the LCD.
    bababooey - 回复
    The fishing line trick is amazing… although i had already broken the LCD when i saw that comment. Good Learn!
    Brandon Lukasik - 回复
    This step is what destroys my LCDs :(
    Dan Harris - 回复
    Just destroyed my LCD as well. A red warning remarking is missing here! The LCD assembly is very fragile an cannot be bent, even slightly!!
    brauliox - 回复
    I have broken about 10 of the 50 or so iPad minis that I have repaired. I always try to have a LCD on hand. I’ll have to try the fishing line trick!
    northstar - 回复
    I also recommend doing step 45 first (removing the two pieces of foam tape at the bottom).
    northstar - 回复
    I was able to do this the first time w/out damaging the LCD simply by following the instructions to the letter, slowly and carefully. The only thing I did differently was to follow Northstar’s instructions to remove the two pieces of tape at the bottom of the LCD before beginning.
    Jenny Lawson - 回复
    I found a good way to remove the LCD without breaking it. Once you finish to clean up around the LCD just lift a bit one of the white metal backing plate and insert in the gap a plastified playing card under le LCD and slowly make your way to the center of the LCD. Repeat on the other side and the LCD will lift up intact.
    lemerise - 回复
    nothing Brocken after
    (I did not read the comments before doing it lol)
  39. iPad Mini CDMA LCD 更换: 步骤 39 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 39 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 39 中的图像 3,3
    • 将吉他拨片器入液晶显示屏左侧的三个位置,并在每个位置弯曲,将液晶显示转到后壳的右侧。
  40. iPad Mini CDMA LCD 更换: 步骤 40 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 40 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 40 中的图像 3,3
    • 现在到了液晶显示屏的右侧,并沿着旁边的几个地方使用吉他拨片撬动,将液晶显示屏移回左边。
    • 重复此操作和上一步骤几次,直到LCD容易左右移动。
  41. iPad Mini CDMA LCD 更换: 步骤 41 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 41 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 41 中的图像 3,3
    • 在接下来几步中,你将使用撬棒在LCD与金属背板之间滑动来将LCD从下方的粘合剂中分离出来。
    • 将撬棒扁平的一端插入LCD框与金属背板之间。
    • 确保撬棒位于LCD框与背板之间,而不是在背板的下方。 撬起背板将会损坏部件,因为在LCD下方螺丝将背板与后壳固定。
  42. iPad Mini CDMA LCD 更换: 步骤 42 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 42 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 42 中的图像 3,3
    • 从设备的右上角开始,将撬棒滑入LCD框和金属背板之间,当您推动撬棒时也会分离两者之间的粘合剂。
    • 我们的目标是分离粘合剂,而不是撬起LCD。 所以尽量小角度撬动,防止损伤LCD。
    • 如果在LCD边角处深入撬棒会使得LCD弯曲,使用吉他拨片来重复上述动作来进一步分离粘合剂。
    These steps were hard. I was too scared that I was going to brake the LCD. Luckily I got it off! Don’t know how delicate these things are and how much force they can take.
  43. iPad Mini CDMA LCD 更换: 步骤 43 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 43 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 43 中的图像 3,3
    • 重复先前的步骤来分离LCD顶部。
    • 将撬棒扁平的一端插入LCD框与金属背板之间,小心地在顶部推动撬棒,分离粘合剂。
  44. iPad Mini CDMA LCD 更换: 步骤 44 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 44 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 44 中的图像 3,3
    • 在LCD左侧继续进行相同的操作,将撬棒扁平的一端尽可能深的插入LCD和背板之间。
    • 这时,LCD应该与固定的粘合剂分离了,如果没有的话,重新在右侧或者顶部插入撬棒来完全分离LCD。
  45. iPad Mini CDMA LCD 更换: 步骤 45 中的图像 1,1
    • 从后壳上抬起LCD几英寸,来确保它已完全与粘合剂相分离。
    When I did it I found that the adhesive sticking was mainly on the edges, so if you take a spudger and just break that adhesive carefully it will help. Be gentle lifting the lcd as it’s very breakable.
    Jasper Holden - 回复
  46. iPad Mini CDMA LCD 更换: 步骤 46 中的图像 1,2 iPad Mini CDMA LCD 更换: 步骤 46 中的图像 2,2
    • 两条宽胶带将LCD与扬声器相连。
    • 一只手拿着LCD, 另一只手将撬棒扁平一端插入左扬声器与胶带之间的空隙之间。
    • 将液晶显示器从扬声器中轻轻拉出,同时向外旋转撬棒将胶带与扬声器分离。
    I recommend removing these two pieces of foam tape prior to loosening and lifting the LCD.
    northstar - 回复
  47. iPad Mini CDMA LCD 更换: 步骤 47 中的图像 1,2 iPad Mini CDMA LCD 更换: 步骤 47 中的图像 2,2
    • 将撬棒扁平一端插入右扬声器与胶带之间的空隙之间。
  48. iPad Mini CDMA LCD 更换: 步骤 48 中的图像 1,2 iPad Mini CDMA LCD 更换: 步骤 48 中的图像 2,2
    • 将LCD翻转并放在前面板玻璃的顶部。
    • 不要尝试从iPad上取下LCD,因为它仍有排线线连接。
  49. iPad Mini CDMA LCD 更换, LCD 屏蔽板: 步骤 49 中的图像 1,1
    • 移除下列将LCD屏蔽板与后壳固定的螺丝。
    • 2颗2.6 mm Phillips #00 螺丝
    • 13颗 1.7 mm Phillips #00 螺丝
    • 在有些设备上,额外的一颗1.7 mm Phillips #00螺丝。
    At the iPad mini retina Wi-Fi there are only 7 screws.
    sandro - 回复
    On my iPad Mini (Gen 1 WiFi; A1432), these are not #00 screws, but #000 screws. They're much tinier than the first four screws that held the LCD tabs in place. The #00 driver sorta works, but requires a lot of force to get traction. The #000 driver works like a charm, though.
    volty - 回复
    On my 1432 there were mixed in 4 tiny #000 screws holding the shield plate aong the right side. Looks like these can be mixed in without consequence as they are shorter anyway
    gfriedman99 - 回复
    I have a missing plate and screws
    Keah Smith - 回复
  50. iPad Mini CDMA LCD 更换: 步骤 50 中的图像 1,2 iPad Mini CDMA LCD 更换: 步骤 50 中的图像 2,2
    • 在LCD屏蔽板Home键的正下方插入撬棒扁平的一端。
    • 撬起撬棒,来将屏蔽板与后壳分离。
  51. iPad Mini CDMA LCD 更换: 步骤 51 中的图像 1,1
    • 将屏蔽板从iPad中移除。
    theres a lip on the rear case that prevents you from lifting this straight out, be careful to not bend the plate.
    jfaulks1 - 回复
    Once the LCD is clear of the shield, wiggle a long plastic spudger up the center between the shield and the battery to gently bend the shield. That will help in getting it away from the sides and make it easier to come out.
    Bill Shannon - 回复
  52. iPad Mini CDMA LCD 更换, 电池连接头: 步骤 52 中的图像 1,1
    • 移除固定连接器支架的三颗 1.3 mm Phillips #00 螺丝
    • 确保这三颗螺丝没有与其他螺丝弄混, 任何稍长的螺丝可能会损坏螺丝孔,导致逻辑板的不可修复的损坏。
    Note: These three screws are smaller than the rest of the screws holding the larger LCD shield although they look similar. If you substitute the larger screws, you will pop a screw bracket which can damage the board on both the mini original and mini 2 retina. I just wrote a blog post about how this happens: http://mendonipadrehab.com/entries/gener...
    jessabethany - 回复
    Hi jessabethany. Thank you for the warning. I read your blog post and found it to be very informative. Thanks for adding the warning to the step. It will most definitely help others avoid any damage to the logic board. Thanks!
    Walter Galan -
    Be careful: At iPad mini retina Wi-Fi there are thw short and one longer screw! Don't mix them!
    sandro - 回复
  53. iPad Mini CDMA LCD 更换: 步骤 53 中的图像 1,1
    • 使用镊子将支架从iPad中移走。
  54. iPad Mini CDMA LCD 更换: 步骤 54 中的图像 1,2 iPad Mini CDMA LCD 更换: 步骤 54 中的图像 2,2
    • 使用塑料打开工具,轻轻地将电池连接器从逻辑板上的插座中撬起。
    • 千万小心地来撬起连接器,切勿直接撬动插座。 这样做将会完全损坏连接部分。
    Make sure you disconnect the battery. If not and ipad is still on you can have problems with the LCD backlight. To fix that problem you have to solder
    Mattis - 回复
    I may be experiencing the backlight problem you mentioned. What connection needs to be soldered?
    Grillwrecka -
    Have an issue - heard that if you don't disconnect the battery a fuse is blown. I need help to fix the blown fuse.
    Andrew Kivell -
    There is an extensive thread in Answers about iPad mini backlight problems.Th screen stays black after a digitizer replacement.
    jessabethany -
    After unplugging the battery place a guitar pick in-between the two connections.
    While continuing to work on the iPad you may inadvertently cause the two connections to touch.
    Michael Vovaris - 回复
    Yeah, you need to put the pick in between the connections so the battery doesn't touch the logic board connector and blow a fuse and make your backlight not turn on. You really don't want to have to solder the 2 connections together, especially if you don't know how, like me! I will use your comment's advice when working.
    WolfyHD - 回复
    I put a piece of cellotape on the contact side of the connector and could happily forget about it while getting on with the rest of the repair.
    Rory Filer - 回复
  55. iPad Mini CDMA LCD 更换, LCD: 步骤 55 中的图像 1,2 iPad Mini CDMA LCD 更换, LCD: 步骤 55 中的图像 2,2
    • 使用塑料打开工具来将LCD连接头从逻辑板上的插座中撬起。
    • 切勿靠着IC芯片来撬动,这样会损坏IC芯片。 如图小心在边缘处撬动。
    Putting the iPad back together: While plugging the LCD Connector back in, take your time finding the socket on the logic board. Do no use pressure until you are certain it is seated properly. Trust me, if you take your time you will know its seated correctly.
    Does it shares the same shape/size of the LCD connector between the ipad mini wifi only WHITE and the other one ipad mini 32gb BLACK?
    muhammadbukhari10 - 回复
  56. iPad Mini CDMA LCD 更换: 步骤 56 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 56 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 56 中的图像 3,3
    • LCD此时仍通过下方的两条宽胶带与后壳连接。
    • 一只手握住LCD,将撬棒插入左侧的胶带和LCD之间。
    • 向外滑动撬棒,分离胶带。 将LCD小心向外提起,使其远离胶带。
    • 在分离LCD与胶带的时候,扭动撬棒会更加高效的分离。
    Removing this tape and such to take the LCD off completely is unneccessary when replacing just the glass and digitizer, the digitizer cable is easily removed without further work to the LCD
    Dave Davidson - 回复
    When this tape damage, how we can take a new?
    Muhammed Kilic - 回复
    When this tape are damage, how we can order and take a new one?
    Muhammed Kilic - 回复
    Following from Nick H’s comment about LCD removal being unnecessary - I tried that first and got my broken glass OUT of the assembly by threading it thru a limited space beneath the LCD. Later when trying to reseat the digitizer connector I gave up and removed the LCD anyhow. Not that much extra work but a LOT easier to install the digitizer and reseat the connector without having to navigate around the LCD and its cable. Removal of the tape holding the LCD was easy - there are two short lengths of rubber or foam along the bottom edge of the LCD that faces the outside world. Remove those(save them) and then _carefully_ peel up the tape; I saw some metallic looking residue underneath. Later when re-assembling everything, I put the tape back and then those two short lengths of foam.
    Rory Filer - 回复
    on mine this tape was already loose.
    jfaulks1 - 回复
  57. iPad Mini CDMA LCD 更换: 步骤 57 中的图像 1,3 iPad Mini CDMA LCD 更换: 步骤 57 中的图像 2,3 iPad Mini CDMA LCD 更换: 步骤 57 中的图像 3,3
    • 仍用一只手握住LCD,按照先前操作方法来移除左侧的胶带。
    • 将撬棒扁平的一端插入LCD框与胶带之间,向外滑动撬棒,然后轻轻提起LCD。
  58. iPad Mini CDMA LCD 更换: 步骤 58 中的图像 1,2 iPad Mini CDMA LCD 更换: 步骤 58 中的图像 2,2
    • 将LCD从iPad mini 中分离出来。
结论
要重新组装您的设备,请按照本指南的相反顺序进行操作。
28等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,757篇指南
3条评论
you are the truth!
thisismrkia - 回复
Good guide. Will I need a new LCD shield plate, or can I use the old one?
slapstick4235 - 回复
nice job and thanks
luis torres - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 38
总计 31,245
