The front-facing camera cable connector is secured with pieces of tape that wrap up around the sides of the cable and are fastened to two small metal plates.
In the next two steps, you will be prying the two metal plates up and out from the center of the cable.
While holding the front-facing camera cable up, use the tip of a spudger to separate the piece of tape adhered to the bottom side of the corner of the cable.
The tape is folded in half to attach to both the underside of the front-facing camera cable and the top side of the cable directly beneath it (headphone jack cable).
