跳转到主内容
iPad Mini CDMA Battery Connector Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iPad Mini CDMA Battery Connector Replacement, Battery Connector: 步骤 1 中的图像 1,1
    • Remove the three 1.3 mm Phillips #00 screws securing the connector shield to the logic board.
    • Be sure to not substitute these three screws with any other screws, specifically the screws securing the LCD shield plate to the rear case of the iPad. Any slightly longer screws may strip the screw holes and result in irreparable damage to the logic board.
  2. iPad Mini CDMA Battery Connector Replacement: 步骤 2 中的图像 1,1
    • Use a pair of tweezers to grasp and remove the connector shield from the iPad.
  3. iPad Mini CDMA Battery Connector Replacement: 步骤 3 中的图像 1,2 iPad Mini CDMA Battery Connector Replacement: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not on the socket itself. If you pry up on the logic board socket, you may break the connector entirely.
结论
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 500
