简介
使用本指南来更换前面板组件。
你所需要的
在锅或平底锅里装满足够的水来完全淹没iOpener。
把水加热到沸腾。关火。
将iOpener放入热水中2-3分钟。确保iOpener完全浸入水中。
用钳子从热水中提取加热的iOpener。
用毛巾彻底擦干iOpener。
你的iOpener已准备好使用!如果你需要重新加热iOpener,请将水加热到沸点,关火,并将iOpener放入水中2-3分钟。
移除下列将LCD屏蔽板与后壳固定的螺丝。
2颗2.6 mm Phillips #00 螺丝
13颗 1.7 mm Phillips #00 螺丝
在有些设备上,额外的一颗1.7 mm Phillips #00螺丝。
要重新组装您的设备,请按照本指南的相反顺序进行操作。
49等其他人完成本指南。
由衷感谢以下译者:
85%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
2条评论
I would recommend that in cases of replacing shattered screens, that you tape the front panel glass with clear packing tape using overlapping strips, before you begin. This helps to ensure that the panel stays intact, and reduces the chances of puncturing the digitizing layer, and damaging the LCD upon removal.
You want to use clear tape so that you are able to see how any of the glass remnants are shifting during removal.
In addition to the packing tape, I would recommend a blow dryer (or heat gun) to loosen the glue.
