跳转到主内容
加入维修社区 - 创建账户
本篇指南是分解流程而非维修指南。 如果您要维修您的iPad Mini 7th Generation,应参考我们的维修指南
  1. iPad Mini 7th Generation Chip ID, Main Board Side 1: 步骤 1 中的图像 1,2 iPad Mini 7th Generation Chip ID, Main Board Side 1: 步骤 1 中的图像 2,2
    • Apple APL1V02 / 339S01476 A17 Pro hexa-core applications processor w/ penta-core GPU and Neural Engine layered over a SK hynix H58G66AK6HX132 8 GB LPDDR5 SDRAM memory
    • Kioxia K5A3XF2641 128 GB NAND flash memory
    • Apple APL109A / 343S00700 power management
    • Apple APL1099 / 343S00513 power management
    • Apple 338S00693-B0 power management
    • Texas Instruments SN2012027P USB type-C controller
    • Macronix MX25V8035F 1 MB serial NOR flash memory
  2. iPad Mini 7th Generation Chip ID: 步骤 2 中的图像 1,1
    • Texas Instruments SN2610A0 battery charger
    • Analog Devices MAX98728B audio amplifier
    • Broadcom BCM15900B0 touch controller
    • Texas Instruments LM3567A1 LED flash driver
    • Likely Texas Instruments TPS61280H battery front-end DC-DC converter
    • Texas Instruments TPS259481A 8 A eFuse w/ bidirectional power delivery
  3. iPad Mini 7th Generation Chip ID, Main Board Side 1 - Sensors: 步骤 3 中的图像 1,1
    • Bosch Sensortec accelerometer & gyroscope
    • Bosch Sensortec pressure sensor
  4. iPad Mini 7th Generation Chip ID, Main Board Side 1 - Connectivity: 步骤 4 中的图像 1,1
    • USI 339S01438 WiFi 6E & Bluetooth 5.3 controller
  5. iPad Mini 7th Generation Chip ID, Display Board Side 1: 步骤 5 中的图像 1,2 iPad Mini 7th Generation Chip ID, Display Board Side 1: 步骤 5 中的图像 2,2
    • Parade Technologies DP815-A0 timing controller
    • Renesas ISL98667A display power supply
    • STMicroelectronics M24128-DF 16 kB serial EEPROM memory
4指南评论
Any idea of the cellular modem the iPad mini has?
Albus Brian - 回复
My question as well. What is the cellular modem chip in the iPad Mini 7 cellular model? Is it still the Qualcomm Snapdragon X60 used in the Mini 6 or is it the X75 used in the iPhone 16 Pro?
Michael Reynolds - 回复
The answer to my own question is, sources say, the Qualcomm X70 5G Modem
There is not modem chip in a ipad mini 7th gen if it's a wifi only version
Anas Jellouli -
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 55
过去 30 天: 191
总计 4,730
