跳转到主内容
加入维修社区 - 创建账户
你所需要的
视频概述
本篇指南是分解流程而非维修指南。 如果您要维修您的iPad Mini 5,应参考我们的维修指南
    1. iPad Mini 5 Teardown, iPad Mini 5 Teardown: 步骤 1 中的图像 1,3 iPad Mini 5 Teardown, iPad Mini 5 Teardown: 步骤 1 中的图像 2,3 iPad Mini 5 Teardown, iPad Mini 5 Teardown: 步骤 1 中的图像 3,3
      • This tablet may be mini, but it has some big specs:
      • 7.9-inch (diagonal), LED-backlit Retina True Tone display with 2048 × 1536 resolution (326 ppi)
      • A12 Bionic SoC with 64‑bit architecture and embedded M12 coprocessor
      • 8 MP rear camera + 7 MP FaceTime HD camera
      • Wi‑Fi (802.11a/b/g/n/ac) with dual channel (2.4 GHz and 5 GHz) and MIMO support + Bluetooth 5.0
      • 19.1 Wh rechargeable lithium-polymer battery
      • Three-axis gyro + accelerometer + barometer + ambient light sensor
      • Let's kick things off with an airport security view of the box, charger, and Lightning cable (hat tip to the gang at Creative Electron).
      询问修复机器人
      添加评论
    2. iPad Mini 5 Teardown: 步骤 2 中的图像 1,3 iPad Mini 5 Teardown: 步骤 2 中的图像 2,3 iPad Mini 5 Teardown: 步骤 2 中的图像 3,3
      • From the outside, this new Mini looks exactly like a downsized version of the equally-new iPad Air.
      • Spoiler alert: judging by the X-rays, it's not a downsized new iPad Air. It looks exactly like an upgraded iPad Mini 4.
      • The new Air, meanwhile, is based on the last-generation iPad Pro 10.5". (Stay tuned for our Air teardown, coming in about a day.)
      • Meanwhile, Apple also sells the iPad 6 (or just "iPad"), which itself is a reworked version of the original iPad Air.
      • Did you get all that? Because we haven't even mentioned the latest iPad Pros yet. In fact, let's go ahead and not mention those.
      • We pull a cellular-capable iPad Mini 4 from the lab to confirm our suspicions. Headphone jack: check. Big bezels: check. Home button: check.
      • About the only exterior clue that gives away the new model is its model number, A2133—oh, and the loss of those regulatory markings on the back, which all live in software now.
      添加评论
    3. iPad Mini 5 Teardown: 步骤 3 中的图像 1,3 iPad Mini 5 Teardown: 步骤 3 中的图像 2,3 iPad Mini 5 Teardown: 步骤 3 中的图像 3,3
      在这个步骤中使用的工具:
      iOpener
      $24.95
      • As much as we wish Apple would come up with a better approach to tablet construction (like they've done for phones, or like others have done for tablets), we're pretty sure we know how opening this one is going to go:
      • Heat.
      • Slash.
      • Repeat.
      • Once the Mini is shucked, we get our first peek at the tasty internals.
      询问修复机器人
      添加评论
    4. iPad Mini 5 Teardown: 步骤 4 中的图像 1,2 iPad Mini 5 Teardown: 步骤 4 中的图像 2,2
      • After all that glue, we're treated to some less frustrating fasteners.
      • Knowing Apple's penchant for goofy screw heads, we brought our whole set of drivers. Thankfully this part of the Mini hasn't changed—we're just dealing with standard Phillips heads here.
      • Our drivers make short work of those screws and we remove the bracket covering the display and battery connectors ...
      • ... and it brings along a friend! Turns out the battery flex connector is now adhered to that cover bracket, automatically disconnecting the battery when the bracket is removed. Nifty!
      • Hopefully this will help fixers to not accidentally kill the backlight on their displays.
      询问修复机器人
      添加评论
    5. iPad Mini 5 Teardown: 步骤 5 中的图像 1,3 iPad Mini 5 Teardown: 步骤 5 中的图像 2,3 iPad Mini 5 Teardown: 步骤 5 中的图像 3,3
      • Notice the clean lines and muted colors in Apple's foray into abstract art. The second image is extra abstract thanks to X-rays.
      • Let's channel our inner art critic and try to spot some differences between the newest Mini and its predecessor:
      • Different battery model, with updated (i.e. incompatible) connectors
      • Rated for 19.32 Wh, it matches the last Mini's, has less than the standard iPad's 32.9 Wh, and comes in a little over the Galaxy Note9's 15.4 Wh.
      • Upgraded front-facing camera module
      • Updated ambient light (True Tone) sensors
      • A migrated set of microphones
      • Here's a clean view with no markings, in case you want to spot the differences yourself.
      询问修复机器人
      添加评论
    6. iPad Mini 5 Teardown: 步骤 6 中的图像 1,2 iPad Mini 5 Teardown: 步骤 6 中的图像 2,2
      • Despite their similar hardware, iPads continue to lag way, way behind iPhones in their construction—this home button being a perfect example. On iPhones this is an easy, elegant swap, but here it's still a mess of glue, even after all this time.
      • Elsewhere on this display, we blast the shields off and smoke out the chips underneath:
      • Parade Technologies DP815 Display Port timing controller (likely)
      • Texas Instruments TPS65195 clock level shifter
      • Texas Instruments TPS65144 LCD Bias w/ integrated gamma reference
      • Intersil ISL24879 precision programmable LCD reference voltage generator
      • STMicroelectronics M24C64-F 64 Kb Serial EEPROM memory
      询问修复机器人
      添加评论
    7. iPad Mini 5 Teardown: 步骤 7 中的图像 1,3 iPad Mini 5 Teardown: 步骤 7 中的图像 2,3 iPad Mini 5 Teardown: 步骤 7 中的图像 3,3
      • This Mini inherits the 7 MP ƒ/2.2 front-facing camera setup we first saw in the 10.5-inch iPad Pro.
      • That's a pretty significant upgrade from the 1.2 MP sensor in the Mini 4, though the housing looks mostly the same.
      • With the cameras out of the way, we get a close look at the new upper microphone array, now centered near the selfie cam.
      • Next, the logic board comes free after a good struggle against the kragle underneath. (Why do iPads always feel like they're assembled by Lord Business?)
      询问修复机器人
      添加评论
    8. iPad Mini 5 Teardown: 步骤 8 中的图像 1,3 iPad Mini 5 Teardown: 步骤 8 中的图像 2,3 iPad Mini 5 Teardown: 步骤 8 中的图像 3,3
      • Let's see what kind of silicon Apple managed to squeeze in here:
      • Apple APL1W81 A12 Bionic SoC, layered over Samsung K3UH4H40AM-MGCL 3 GB LPDDR4X DRAM
      • Toshiba TSB3243VD1190CHNA1 64 GB flash memory
      • Apple/USI 339S00551 Bluetooth/WiFi module
      • Broadcom BCM15900 touchscreen controller
      • Apple 343S00286-A0 and 343S00282-A0 power management ICs (left to right)
      • NXP Semiconductor CBTL1612A1 display port multiplexer
      • NXP Semiconductor 100VB27 (SN100V) NFC controller
      添加评论
    9. iPad Mini 5 Teardown: 步骤 9 中的图像 1,3 iPad Mini 5 Teardown: 步骤 9 中的图像 2,3 iPad Mini 5 Teardown: 步骤 9 中的图像 3,3
      • IC identification, continued:
      • Cirrus Logic CS42L83A audio codec
      • Cirrus Logic audio amplifier
      • Cypress Semiconductor CYPD2104 USB-C port controller
      • Bosch Sensortec accelerometer/gyroscope
      • Bosch Sensortec pressure sensor
      • AKM Semiconductor AK0991xx digital compass
      询问修复机器人
      添加评论
    10. iPad Mini 5 Teardown: 步骤 10 中的图像 1,1
      • With this iPad Mini in pieces, we'll conclude our teardown! What did we learn?
      • The iPad Mini continues to be (mostly) its own entity—not quite a shrunken down iPad, nor a miniature iPad Air.
      • After a number of conflicting experiences ultimately leading up to this Mini's glued-in battery, we're officially not optimistic anymore about seeing adhesive pull tabs for iPad batteries.
      • That said, it's time to give this iPad a repairability score!
      询问修复机器人
      添加评论
    11. 最后的想法
      • A single Phillips driver takes care of all the screws.
      • Many components are modular and can be replaced independently, but the Lightning port is soldered to the logic board.
      • Battery replacement is possible, but still unnecessarily difficult.
      • Gobs of adhesive hold many parts and cables in place, complicating all repairs.
      • Removing the home button is tough, and will be required for display replacement if you want to keep Touch ID functionality.
      可修复性评分
      2
      可修复性10分中得2分
      (10是最容易修复)
16指南评论
This leaves me wondering what kind of chip is in the cellular model providing gigabit LTE.
Alex - 回复 分享
Like is it Intel? Probably Intel considering the current situations with Qualcomm.
jridder - 回复 分享
Touch ID gen 2 ?
JIGSAW Z - 回复 分享
I have one, and it’s def Touch ID 2 - it’s so fast.
djschillz - 回复 分享
So it’s extremely similar to iPad mini 4. Is it harder to repair than iPad mini 4?
Aaron - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 16
过去 7 天: 86
过去 30 天: 348
总计 118,794
