简介
使用这个指南来移出并更换你的iPad Mini 2 Wi-Fi 中的电池。
你所需要的
在锅或平底锅里装满足够的水来完全淹没iOpener。
把水加热到沸腾。关火。
将iOpener放入热水中2-3分钟。确保iOpener完全浸入水中。
用钳子从热水中提取加热的iOpener。
用毛巾彻底擦干iOpener。
你的iOpener已准备好使用!如果你需要重新加热iOpener,请将水加热到沸点,关火,并将iOpener放入水中2-3分钟。
如果你的屏幕已经损坏,那么请效益以防止其进一步损坏或者因触摸而导致身体受伤。
在iPad显示屏上重叠贴上透明胶带直到iPad的整块显示屏都被覆盖。
最好尽你的最大努力来完成指南。但是,一旦玻璃已经损坏,它就会随着您的使用而继续损坏,所以你可能需要使用金属撬具来讲玻璃取出。
要重装你的设备,参照这些步骤倒序操作。
要重装你的设备,参照这些步骤倒序操作。
86等其他人完成本指南。
由衷感谢以下译者:
75%
Dorothy Boyd正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
15条评论
I was able to change the battery but I will say the hardest part was heating the screen to get it off. The guide was great.
I have just installed replacement battery in iPad mini 2. Changing for about 2-1/2 hours only shows logo, and slightly warm.
battery shows same markings as original, I have also recently done iPhone 5 and Nexus 7 , both went well,. I'm concerned something is wrong with this installation, can anyone advise? Many thanks
Ross
Just completed my first attempt to replace the battery. All went well following the instructions here, but the photos could use some loving when it comes to some red arrows pointing to specific points. Also a little better contrast of separation points like adhesive tape areas and the lcd shield. other than that this was not to hard for me to complete especially with all of the added comments by others throughout the steps.
Next is the reverse process once I do some cleaning and prepare the replacement adhesive strips.
I would have really found it useful to have some detailed guidance on how to reapply the adhesive. The adhesive strips are packaged in such a way that it actually makes applying them much more difficult… unless there’s some trick that I couldn’t figure out. Hence, the value of some instructions.
The sheet with the adhesives has a clear cover over the side of the strips that adheres to the glass, with a blue cover strip and tab for easy removal on the side that adheres to the body. This would lead you to believe that you should adhere it to the glass first, and then press the glass onto the body. But the adhesive has many notches and curves and if you don’t get them aligned on the glass correctly, they could cover the light sensor or camera, interfere with the button, etc. Thus it seems you have to first stick it to the body, meaning you have completely exposed double-sided adhesive that you’re wrestling with, sticking to itself, etc.
If this is NOT how it’s done, some instructions would seem necessary.
