跳转到主内容
在此拆机指南中使用的工具
简介
This is the teardown for a Clamcase for iPad 2.
这个拆解是不是维修指南。 要维修你的的iPad ClamCase,请使用我们的维修手册
  1. iPad ClamCase, iPad ClamCase: 步骤 1 中的图像 1,2 iPad ClamCase, iPad ClamCase: 步骤 1 中的图像 2,2
    • You can skip the first 2 steps if you don't want to detach the upper and keyboard covers from each other.
    • Open the case and unpeel the 2 black stickers in the top corners of the keyboard.
    • This will reveal the 6 screws that attach the upper cover to the keyboard cover.
  2. iPad ClamCase: 步骤 2 中的图像 1,2 iPad ClamCase: 步骤 2 中的图像 2,2
    • Use the T9 Torx screwdriver to unscrew the 2 bigger screws in the middle of each side.
    • Use the T6 Torx screwdriver to unscrew the remaining 4 screws.
  3. iPad ClamCase: 步骤 3 中的图像 1,2 iPad ClamCase: 步骤 3 中的图像 2,2
    • Turn the keyboard cover over so the bottom is facing up. Manually remove the thin black covering that is attached to the bottom.
    • Be patient, the thin black covering might be really stuck to the bottom.
  4. iPad ClamCase: 步骤 4 中的图像 1,1
    • Once the thin black covering is removed, you will see 15 screws.
    • Use the T6 Torx screwdriver to remove the screws.
  5. iPad ClamCase: 步骤 5 中的图像 1,1
    • Once the screws are removed, lift off the bottom panel to access the keyboard and battery.
  6. iPad ClamCase: 步骤 6 中的图像 1,1
    • You are done.
Izmet Barranco
于2012年12月12日注册
213 信誉积分
撰写一个指南
2条评论
Awesome! I used this guide to disassemble my clam case and repair some nonfunctional keys. Thanks!
justin duff - 回复
Thanks for the dis-assembly guide. Justin, what did you have to do to fix the keys that were not working. I have on with a few keys not working, not even intermittently.
dick haynes - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 60
总计 7,402
