跳转到主内容
iPad Air LTE Battery Replacement
你所需要的
  1. iPad Air LTE Battery Replacement, iOpener Heating: 步骤 1 中的图像 1,2 iPad Air LTE Battery Replacement, iOpener Heating: 步骤 1 中的图像 2,2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. iPad Air LTE Battery Replacement: 步骤 2 中的图像 1,1
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. iPad Air LTE Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. iPad Air LTE Battery Replacement, Alternate iOpener heating method: 步骤 4 中的图像 1,2 iPad Air LTE Battery Replacement, Alternate iOpener heating method: 步骤 4 中的图像 2,2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. iPad Air LTE Battery Replacement, Front Panel: 步骤 5 中的图像 1,3 iPad Air LTE Battery Replacement, Front Panel: 步骤 5 中的图像 2,3 iPad Air LTE Battery Replacement, Front Panel: 步骤 5 中的图像 3,3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  6. iPad Air LTE Battery Replacement: 步骤 6 中的图像 1,2 iPad Air LTE Battery Replacement: 步骤 6 中的图像 2,2
    • Handling it by the tag, place the heated iOpener on the side of the iPad to the left of the home button assembly.
    • Let the iOpener sit for at least a minute to soften the adhesive beneath the glass.
  7. iPad Air LTE Battery Replacement: 步骤 7 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 7 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 7 中的图像 3,3
    • While the iPad looks uniform from the outside, there are delicate components under the front glass. To avoid damage, only heat and pry in the areas described in each step.
    • As you follow the directions, take special care to avoid prying in the following areas:
    • Front-facing camera
    • Antennas
    • Display cables
  8. iPad Air LTE Battery Replacement, Anti-Clamp instructions: 步骤 8 中的图像 1,3 iPad Air LTE Battery Replacement, Anti-Clamp instructions: 步骤 8 中的图像 2,3 iPad Air LTE Battery Replacement, Anti-Clamp instructions: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Clamp
    $24.95
    购买
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  9. iPad Air LTE Battery Replacement: 步骤 9 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 9 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 9 中的图像 3,3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  10. iPad Air LTE Battery Replacement: 步骤 10 中的图像 1,2 iPad Air LTE Battery Replacement: 步骤 10 中的图像 2,2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  11. iPad Air LTE Battery Replacement: 步骤 11 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 11 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 11 中的图像 3,3
    • Carefully place a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
    • If your iPad's screen is badly cracked, covering it with a smooth layer of clear packing tape may help the suction cup adhere. Alternatively, use a strong piece of tape (such as duct tape) and fold it into a handle.
  12. iPad Air LTE Battery Replacement: 步骤 12 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 12 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 12 中的图像 3,3
    • Place an opening pick in the gap opened by the suction cup.
    • Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD.
    • Pull the suction cup's plastic nub to release the vacuum seal and remove the suction cup from the display assembly.
  13. iPad Air LTE Battery Replacement: 步骤 13 中的图像 1,1
    • Reheat and replace the iOpener.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
  14. iPad Air LTE Battery Replacement: 步骤 14 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 14 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 14 中的图像 3,3
    • Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
  15. iPad Air LTE Battery Replacement: 步骤 15 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 15 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 15 中的图像 3,3
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  16. iPad Air LTE Battery Replacement: 步骤 16 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 16 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 16 中的图像 3,3
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
    • If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out just a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
  17. iPad Air LTE Battery Replacement: 步骤 17 中的图像 1,1
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  18. iPad Air LTE Battery Replacement: 步骤 18 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 18 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 18 中的图像 3,3
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  19. iPad Air LTE Battery Replacement: 步骤 19 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 19 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 19 中的图像 3,3
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • The third image shows where the front-facing camera and housing are in the iPad.
    • Avoid sliding the opening pick over the front facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front facing camera.
  20. iPad Air LTE Battery Replacement: 步骤 20 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 20 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 20 中的图像 3,3
    • Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge.
  21. iPad Air LTE Battery Replacement: 步骤 21 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 21 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 21 中的图像 3,3
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, and then slide it to the corner of the iPad to finish cutting the adhesive on that edge.
  22. iPad Air LTE Battery Replacement: 步骤 22 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 22 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 22 中的图像 3,3
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  23. iPad Air LTE Battery Replacement: 步骤 23 中的图像 1,1
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining side of the iPad—along the volume and lock buttons.
  24. iPad Air LTE Battery Replacement: 步骤 24 中的图像 1,2 iPad Air LTE Battery Replacement: 步骤 24 中的图像 2,2
    • Slide the opening pick around the top right corner of the iPad, releasing the adhesive there.
    • Leave this pick in place to keep the adhesive from re-sealing itself, and grab a new pick for the next step.
  25. iPad Air LTE Battery Replacement: 步骤 25 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 25 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 25 中的图像 3,3
    • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad.
  26. iPad Air LTE Battery Replacement: 步骤 26 中的图像 1,1
    • Leave the opening picks in place, and set the reheated iOpener on the home button end of the iPad.
  27. iPad Air LTE Battery Replacement: 步骤 27 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 27 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 27 中的图像 3,3
    • Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
    • Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
    • The third image shows the two antennas and the home button cavity in the lower case of the iPad.
    • The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
  28. iPad Air LTE Battery Replacement: 步骤 28 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 28 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 28 中的图像 3,3
    • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
    • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
    • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
    • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
    • Leave the pick in place before moving on.
  29. iPad Air LTE Battery Replacement: 步骤 29 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 29 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 29 中的图像 3,3
    • Take a new pick and slip it in to the right of the previous pick.
    • Slide across the home button and right-hand antenna using only the very tip to remove the adhesive.
  30. iPad Air LTE Battery Replacement: 步骤 30 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 30 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 30 中的图像 3,3
    • With the adhesive loosened, you can now insert the pick near the right-hand corner. Slide the pick to the left, and stop just short of the Home button.
    • Just like with the left antenna, only slide from the outer edge toward the center. Reversing this direction may damage the antenna.
  31. iPad Air LTE Battery Replacement: 步骤 31 中的图像 1,1
    • Reheat and reapply the iOpener to the volume control side of the iPad.
  32. iPad Air LTE Battery Replacement: 步骤 32 中的图像 1,2 iPad Air LTE Battery Replacement: 步骤 32 中的图像 2,2
    • Be very careful with this step. Take your time and ensure the adhesive is hot and soft, and that you've been through all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
    • On the side of the iPad opposite the volume controls, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along the display cable edge.
    • If you encounter a significant amount of resistance, leave the picks in place, reheat, and reapply the iOpener to the problem areas.
  33. iPad Air LTE Battery Replacement: 步骤 33 中的图像 1,2 iPad Air LTE Battery Replacement: 步骤 33 中的图像 2,2
    • Lift slowly and gently to further detach the adhesive along the display cable edge.
  34. iPad Air LTE Battery Replacement: 步骤 34 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 34 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 34 中的图像 3,3
    • While supporting the front panel glass, use an opening pick to cut the last of the adhesive.
    • Be very careful not to cut or damage any of the display cables.
  35. iPad Air LTE Battery Replacement: 步骤 35 中的图像 1,2 iPad Air LTE Battery Replacement: 步骤 35 中的图像 2,2
    • Once all of the adhesive has been separated, open the glass panel like a page in a book and rest it on your workspace.
    • During reassembly, clean the remains of the adhesive from the case (and the front glass if you are re-using it) with isopropyl alcohol, and replace the adhesive using our display adhesive application guide and pre-cut adhesive strips.
    • It's easy to pinch a flex cable between the front glass and the iPad's frame during reassembly. Be mindful of the flex cables and make sure they gently fold and tuck under the frame. If the folds in a flex cable are pressed completely flat, it may be damaged beyond repair.
  36. iPad Air LTE Battery Replacement, LCD: 步骤 36 中的图像 1,3 iPad Air LTE Battery Replacement, LCD: 步骤 36 中的图像 2,3 iPad Air LTE Battery Replacement, LCD: 步骤 36 中的图像 3,3
    • Remove any tape obscuring the LCD screws.
  37. iPad Air LTE Battery Replacement: 步骤 37 中的图像 1,1
    • Remove the four Phillips screws securing the LCD:
    • Three 4.0 mm screws
    • One 4.8 mm screw
  38. iPad Air LTE Battery Replacement: 步骤 38 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 38 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 38 中的图像 3,3
    • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Be gentle and keep an eye on the LCD cables as you flip the display over.
    • Lay the LCD on its face to allow access to the display cables.
    • Set the LCD down on a soft, clean, lint-free surface.
  39. iPad Air LTE Battery Replacement: 步骤 39 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 39 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 39 中的图像 3,3
    • Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board.
    • Make a battery blocker using a playing card and slide it underneath the logic board connector to disconnect the battery.
    • You can also use an iFixit battery blocker. Be very careful and don't push the battery blocker underneath the connector with excessive force.
    • Leave the blocker there to prevent the battery connector leads from making contact until you have completed your repairs.
  40. iPad Air LTE Battery Replacement: 步骤 40 中的图像 1,1
    • Remove the three 1.4 mm Phillips screws securing the display cable bracket.
  41. iPad Air LTE Battery Replacement: 步骤 41 中的图像 1,2 iPad Air LTE Battery Replacement: 步骤 41 中的图像 2,2
    • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
    • The display cable connector is adhered to the underside of the bracket, so don’t push the spudger too far under the bracket, or you may damage the connector.
  42. iPad Air LTE Battery Replacement: 步骤 42 中的图像 1,1
    • Remove the LCD.
  43. iPad Air LTE Battery Replacement, Front Panel Assembly: 步骤 43 中的图像 1,1
    • Remove any tape covering the home button ribbon cable connector.
  44. iPad Air LTE Battery Replacement: 步骤 44 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 44 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 44 中的图像 3,3
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable straight out of the ZIF connector.
  45. iPad Air LTE Battery Replacement: 步骤 45 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 45 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 45 中的图像 3,3
    • Use the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  46. iPad Air LTE Battery Replacement: 步骤 46 中的图像 1,2 iPad Air LTE Battery Replacement: 步骤 46 中的图像 2,2
    在这个步骤中使用的工具:
    Polyimide Tape
    $9.99
    购买
    • Remove the front panel assembly.
    • If the home button ribbon cable sticks to the iPad's rear case, don't try to force it. Gently peel it off the case using a pair of tweezers, and then you can fully remove the front panel assembly.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  47. iPad Air LTE Battery Replacement, Battery: 步骤 47 中的图像 1,2 iPad Air LTE Battery Replacement, Battery: 步骤 47 中的图像 2,2
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • In the following steps, you'll use plastic cards to separate the battery, which is glued to the rear case.
    • Some minor warping or deformation of the battery is unavoidable, but be very careful not to puncture or delaminate it. Lithium-ion batteries contain dangerous chemicals and may catch fire if mishandled.
    • Starting from the middle of the iPad, insert one corner of a plastic card beneath the upper battery cell.
  48. iPad Air LTE Battery Replacement: 步骤 48 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 48 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 48 中的图像 3,3
    • Remove the card and re-insert it nearby, opening up enough space to insert the entire short edge of the card.
    • Leave one corner of the card under the battery, near the center.
  49. iPad Air LTE Battery Replacement: 步骤 49 中的图像 1,2 iPad Air LTE Battery Replacement: 步骤 49 中的图像 2,2
    • Slide the short edge of a second plastic card underneath the upper battery cell, on top of the first plastic card.
  50. iPad Air LTE Battery Replacement: 步骤 50 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 50 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 50 中的图像 3,3
    • Insert multiple additional cards between the first and second card to create a wedge that will begin to lever the battery away from the rear case.
    • Don't insert your cards beneath or on top of the two starter cards, as the added pressure will increase the risk of puncturing the battery.
    • You can use additional plastic cards, old/expired credit cards, or even playing cards for this step.
  51. iPad Air LTE Battery Replacement: 步骤 51 中的图像 1,2 iPad Air LTE Battery Replacement: 步骤 51 中的图像 2,2
    • Remove the cards.
  52. iPad Air LTE Battery Replacement: 步骤 52 中的图像 1,2 iPad Air LTE Battery Replacement: 步骤 52 中的图像 2,2
    • Re-insert a corner of your plastic card under the upper battery cell, near the left edge of the iPad.
  53. iPad Air LTE Battery Replacement: 步骤 53 中的图像 1,2 iPad Air LTE Battery Replacement: 步骤 53 中的图像 2,2
    • Slide the short edge of a second plastic card underneath the battery cell and above the first plastic card.
  54. iPad Air LTE Battery Replacement: 步骤 54 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 54 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 54 中的图像 3,3
    • Insert multiple additional cards between the first and second card to create a wedge and lever this section of the battery away from the rear case.
  55. iPad Air LTE Battery Replacement: 步骤 55 中的图像 1,2 iPad Air LTE Battery Replacement: 步骤 55 中的图像 2,2
    • Remove the cards.
  56. iPad Air LTE Battery Replacement: 步骤 56 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 56 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 56 中的图像 3,3
    • Repeat the above steps to wedge up the lower left corner of the upper battery cell.
    • Remember not to puncture the battery. Keep deformation to a minimum. Do not crease or fold the battery.
  57. iPad Air LTE Battery Replacement: 步骤 57 中的图像 1,2 iPad Air LTE Battery Replacement: 步骤 57 中的图像 2,2
    • Finish wedging up the upper battery cell using the above procedure by inserting cards along the left edge of the upper battery cell (the edge opposite the logic board).
    • Don't use any cards to pry under the battery from the top edge of the iPad, or you may damage the upper case components.
  58. iPad Air LTE Battery Replacement: 步骤 58 中的图像 1,2 iPad Air LTE Battery Replacement: 步骤 58 中的图像 2,2
    • Remove the battery isolation pick.
  59. iPad Air LTE Battery Replacement: 步骤 59 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 59 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 59 中的图像 3,3
    • Gently lift the upper battery cell from the edge opposite the logic board, and swing it up to separate it from the rear case.
  60. iPad Air LTE Battery Replacement: 步骤 60 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 60 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 60 中的图像 3,3
    • Repeat the above procedure to separate the second, lower battery cell from the rear case.
    • Insert your cards only from the top edge of the battery cell and from the side opposite the logic board. Don't use any cards to pry under the battery from the bottom edge of the iPad, or you may damage ribbon cables for the speakers, antennas, and Lightning connector.
  61. iPad Air LTE Battery Replacement: 步骤 61 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 61 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 61 中的图像 3,3
    • Gently lift the lower battery cell from the edge opposite the logic board, and swing it up to separate it from the rear case.
    • Don't try to fully remove the battery yet.
  62. iPad Air LTE Battery Replacement: 步骤 62 中的图像 1,2 iPad Air LTE Battery Replacement: 步骤 62 中的图像 2,2
    • Use an opening pick to slice through the adhesive directly underneath the battery connector terminal.
    • There's a small standoff in the case that helps seat this connector. The pick may be obstructed by this. Simply work the pick around each side of the standoff to slice through the adhesive.
  63. iPad Air LTE Battery Replacement: 步骤 63 中的图像 1,3 iPad Air LTE Battery Replacement: 步骤 63 中的图像 2,3 iPad Air LTE Battery Replacement: 步骤 63 中的图像 3,3
    • Stand both battery cells up perpendicular to the iPad.
    • Clear the standoff by gently rocking the upper cell slightly away from the rear case, and then pulling it to the side (away from the logic board).
    • You don't need to lift very far (2 or 3 mm). Work carefully and don't put any unnecessary pressure on the logic board. Do not attempt to simply pull the battery straight up, or you may damage the logic board.
  64. iPad Air LTE Battery Replacement: 步骤 64 中的图像 1,1
    • Remove the battery.
结论
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Air Answers community for help.
80等其他人完成本指南。
Scott Havard
于06/27/16注册
49,624 声望
创作了31篇指南
21条评论
The guide says that it is Potentially Dangerous. What is potentially dangerous about this fix?
Anders Busk - 回复
Nothing other than what's mentioned in the intro and instructions: this is a soft-shell lithium ion battery, subject to leaking toxic fumes / catching fire / exploding if you accidentally puncture or deform it too aggressively. The same is true of all batteries of this type. Treat it with respect and take appropriate precautions.
Jeff Suovanen -
What about the adhesive? Do you need more to seal it up or do you reuse the existing?
scott - 回复
You should clean the old adhesive from the glass and chassis using isopropyl alcohol, and replace the adhesive using pre-cut adhesive strips.
Jeff Suovanen -
Very good guide, completed without any complications, thanks a bunch :)
Beninja - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 51
过去 30 天: 286
总计 42,776
