跳转到主内容
iPad Air 3 Screen Replacement
你所需要的
  1. iPad Air 3 Screen Replacement, Screen: 步骤 1 中的图像 1,2 iPad Air 3 Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Cracked near home button its important to not break home button flex cable
    • Apply heat to the screen! Do NOT SKIP THIS STEP
    • Make sure to turn it off if you can to prevent breaking the backlight filter
    • Pry with splicer around the edges
    • Display cables are on the bottom of screen opening up like an upside-down note pad
  2. iPad Air 3 Screen Replacement: 步骤 3 中的图像 1,1
    • Lift from the top like so
    • Display Cables
  3. iPad Air 3 Screen Replacement: 步骤 4 中的图像 1,3 iPad Air 3 Screen Replacement: 步骤 4 中的图像 2,3 iPad Air 3 Screen Replacement: 步骤 4 中的图像 3,3
    • Set screen up a little bit to get to power connection
    • Power connection has PH000 screw holding it together
    • Slide a card under connection
    • Its very important to disconnect battery try turning it on make sure it is off to avoid further damage to ipad
  4. iPad Air 3 Screen Replacement: 步骤 5 中的图像 1,2 iPad Air 3 Screen Replacement: 步骤 5 中的图像 2,2
    • Lift display back up to get to the display cables
    • Unscrew 2 PH000 Screws from display cable bracket
    • Use the flat end of plastic spudger to lift off connections
    • There is 4 flex cables that need disconnecting
  5. iPad Air 3 Screen Replacement: 步骤 6 中的图像 1,3 iPad Air 3 Screen Replacement: 步骤 6 中的图像 2,3 iPad Air 3 Screen Replacement: 步骤 6 中的图像 3,3
    • Whoohoo we got it off now clean the edges for any broken glass
    • Keep track of rubbers covering proximity light sensor on the top
    • Light covers place on top of proxmity sensors
  6. iPad Air 3 Screen Replacement: 步骤 7 中的图像 1,3 iPad Air 3 Screen Replacement: 步骤 7 中的图像 2,3 iPad Air 3 Screen Replacement: 步骤 7 中的图像 3,3
    • APPLY HEAT TO HOME BUTTON 15-20 Seconds should do the trick
    • If heat is not applied you might break the home button along with the touch ID. If you replace the home button touch ID will not work anymore
    • Take of home button flex cover
    • Use flat end of spudger to pry up home button flex connector
  7. iPad Air 3 Screen Replacement: 步骤 8 中的图像 1,3 iPad Air 3 Screen Replacement: 步骤 8 中的图像 2,3 iPad Air 3 Screen Replacement: 步骤 8 中的图像 3,3
    • Reapply heat if you spent to much time getting flex unhooked
    • Pry with splicer under the home button bracket car
    • Clean glass around gasket
  8. iPad Air 3 Screen Replacement: 步骤 9 中的图像 1,2 iPad Air 3 Screen Replacement: 步骤 9 中的图像 2,2
    • Install home button on new screen I recommend using liquid adhesive for this!
    • Push the home button a couple of times to make sure it stills on and make sure it is clicking!
  9. iPad Air 3 Screen Replacement: 步骤 10 中的图像 1,2 iPad Air 3 Screen Replacement: 步骤 10 中的图像 2,2
    • Connect all 4 Flex cables to the logic board!
    • Now at the bottom of the new screen screw in the battery connection to test the new screen!
  10. iPad Air 3 Screen Replacement: 步骤 11 中的图像 1,1
    • Test screen drawing on the notes make sure it works!
    • Adhere new screen with preinstalled adhesive and clap it!
终点
2等其他人完成本指南。
Mark D Schlossman
于09/25/19注册
5,603 声望
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 35
总计 337
