跳转到主内容
简介
Use this guide to replace the dual microphone assembly in your iPad 5 Wi-Fi.
Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage to the logic board. If you choose to complete the guide without isolating the battery, avoid using metal tools except when completely necessary (like when removing screws) to prevent shorting the battery and damaging sensitive circuit components.
  1. iPad 5 Wi-Fi Microphone Assembly Replacement, iOpener Heating: 步骤 1 中的图像 1,2 iPad 5 Wi-Fi Microphone Assembly Replacement, iOpener Heating: 步骤 1 中的图像 2,2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 2 中的图像 1,1
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. iPad 5 Wi-Fi Microphone Assembly Replacement, Alternate iOpener heating method: 步骤 4 中的图像 1,2 iPad 5 Wi-Fi Microphone Assembly Replacement, Alternate iOpener heating method: 步骤 4 中的图像 2,2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. iPad 5 Wi-Fi Microphone Assembly Replacement, Front Panel: 步骤 5 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement, Front Panel: 步骤 5 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement, Front Panel: 步骤 5 中的图像 3,3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  6. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 6 中的图像 1,2 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 6 中的图像 2,2
    • Handling it by the tag, place the heated iOpener on the side of the iPad to the left of the home button assembly.
    • Let the iOpener sit for at least a minute to soften the adhesive beneath the glass.
  7. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 7 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 7 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 7 中的图像 3,3
    • While the iPad looks uniform from the outside, there are delicate components under the front glass. To avoid damage, only heat and pry in the areas described in each step.
    • As you follow the directions, take special care to avoid prying in the following areas:
    • Front-facing camera
    • Antennas
    • Display cables
  8. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 8 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 8 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 8 中的图像 3,3
    • Carefully place a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
    • If your iPad's screen is badly cracked, covering it with a smooth layer of clear packing tape may help the suction cup adhere. Alternatively, use a strong piece of tape (such as duct tape) and fold it into a handle.
  9. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 9 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 9 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 9 中的图像 3,3
    • Place an opening pick in the gap opened by the suction cup.
    • Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD.
    • Pull the suction cup's plastic nub to release the vacuum seal and remove the suction cup from the display assembly.
  10. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 10 中的图像 1,1
    • Reheat and replace the iOpener.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
  11. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 11 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 11 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 11 中的图像 3,3
    • Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
  12. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 12 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 12 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 12 中的图像 3,3
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  13. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 13 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 13 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 13 中的图像 3,3
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
    • If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out just a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
  14. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 14 中的图像 1,1
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  15. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 15 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 15 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 15 中的图像 3,3
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  16. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 16 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 16 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 16 中的图像 3,3
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • The third image shows where the front-facing camera and housing are in the iPad.
    • Avoid sliding the opening pick over the front facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front facing camera.
  17. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 17 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 17 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 17 中的图像 3,3
    • Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge.
  18. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 18 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 18 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 18 中的图像 3,3
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, and then slide it to the corner of the iPad to finish cutting the adhesive on that edge.
  19. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 19 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 19 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 19 中的图像 3,3
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  20. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 20 中的图像 1,1
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining side of the iPad—along the volume and lock buttons.
  21. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 21 中的图像 1,2 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 21 中的图像 2,2
    • Slide the opening pick around the top right corner of the iPad, releasing the adhesive there.
    • Leave this pick in place to keep the adhesive from re-sealing itself, and grab a new pick for the next step.
  22. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 22 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 22 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 22 中的图像 3,3
    • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding the pick when you get ~4.5" from the bottom of the iPad.
  23. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 23 中的图像 1,1
    • Leave the opening picks in place, and set the reheated iOpener on the home button end of the iPad.
  24. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 24 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 24 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 24 中的图像 3,3
    • Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
    • Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
    • The third image shows the two antennas and the home button cavity in the lower case of the iPad.
    • The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
  25. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 25 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 25 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 25 中的图像 3,3
    • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
    • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
    • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
    • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
    • Leave the pick in place before moving on.
  26. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 26 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 26 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 26 中的图像 3,3
    • Take a new pick and slip it in to the right of the previous pick.
    • Slide across the home button and right-hand antenna using only the very tip to remove the adhesive.
  27. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 27 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 27 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 27 中的图像 3,3
    • With the adhesive loosened, you can now insert the pick near the right-hand corner. Slide the pick to the left, and stop just short of the Home button.
    • Just like with the left antenna, only slide from the outer edge toward the center. Reversing this direction may damage the antenna.
  28. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 28 中的图像 1,1
    • Reheat and reapply the iOpener to the volume control side of the iPad.
  29. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 29 中的图像 1,2 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 29 中的图像 2,2
    • Be very careful with this step. Take your time and ensure the adhesive is hot and soft, and that you've been through all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
    • On the side of the iPad opposite the volume controls, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along the display cable edge.
    • If you encounter a significant amount of resistance, leave the picks in place, reheat, and reapply the iOpener to the problem areas.
  30. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 30 中的图像 1,2 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 30 中的图像 2,2
    • Lift slowly and gently to further detach the adhesive along the display cable edge.
  31. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 31 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 31 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 31 中的图像 3,3
    • While supporting the front panel glass, use an opening pick to cut the last of the adhesive.
    • Be very careful not to cut or damage any of the display cables.
  32. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 32 中的图像 1,2 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 32 中的图像 2,2
    • Once all of the adhesive has been separated, open the glass panel like a page in a book and rest it on your workspace.
    • During reassembly, clean the remains of the adhesive from the case (and the front glass if you are re-using it) with isopropyl alcohol, and replace the adhesive using our display adhesive application guide and pre-cut adhesive strips.
    • It's easy to pinch a flex cable between the front glass and the iPad's frame during reassembly. Be mindful of the flex cables and make sure they gently fold and tuck under the frame. If the folds in a flex cable are pressed completely flat, it may be damaged beyond repair.
  33. iPad 5 Wi-Fi Microphone Assembly Replacement, LCD: 步骤 33 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement, LCD: 步骤 33 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement, LCD: 步骤 33 中的图像 3,3
    • Remove any tape obscuring the LCD screws.
  34. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 34 中的图像 1,1
    • Remove the following Phillips screws securing the LCD.
    • Three 4.0 mm screws
    • One 4.8 mm screw
  35. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 35 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 35 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 35 中的图像 3,3
    • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Be gentle and keep an eye on the LCD cables as you flip the display over.
    • Lay the LCD on its face to allow access to the display cables.
    • Set the LCD down on a soft, clean, lint-free surface.
    • Remove the single 2.3 mm Phillips screw securing the battery connector to the logic board.
    • To reduce the risk of a short, you can insert a battery blocker or a modified opening pick to disconnect the battery.
    • Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage.
    • Slide the battery blocker underneath the battery connector area of the logic board, and leave it in place while you work.
    • If you are having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery.
  36. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 37 中的图像 1,1
    • Remove the three 1.4 mm Phillips screws from the display cable bracket.
  37. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 38 中的图像 1,2 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 38 中的图像 2,2
    • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
    • The display cable connector is adhered to the underside of the bracket, so don’t push the spudger too far under the bracket, or you may damage the connector.
  38. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 39 中的图像 1,1
    • Remove the LCD.
  39. iPad 5 Wi-Fi Microphone Assembly Replacement, Front Panel Assembly: 步骤 40 中的图像 1,2 iPad 5 Wi-Fi Microphone Assembly Replacement, Front Panel Assembly: 步骤 40 中的图像 2,2
    • Remove any tape covering the home button ribbon cable connector.
  40. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 41 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 41 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 41 中的图像 3,3
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable horizontally out of the ZIF connector.
  41. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 42 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 42 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 42 中的图像 3,3
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  42. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 43 中的图像 1,2 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 43 中的图像 2,2
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
    • Remove the front panel assembly.
    • During reassembly, wipe any dust or fingerprints off of the inside of the front panel assembly to ensure a clean display.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  43. iPad 5 Wi-Fi Microphone Assembly Replacement, Upper Component Cable Bracket: 步骤 45 中的图像 1,1
    • Remove the three 1.4 mm Phillips #000 screws securing the upper component cable bracket.
  44. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 46 中的图像 1,1
    • Remove the upper component cable bracket.
    • If you have the Wi-Fi/Cellular model, your iPad will look slightly different and will require the removal of two additional screws to access components covered by this bracket.
  45. iPad 5 Wi-Fi Microphone Assembly Replacement, Front Facing Camera: 步骤 47 中的图像 1,2 iPad 5 Wi-Fi Microphone Assembly Replacement, Front Facing Camera: 步骤 47 中的图像 2,2
    • Use the flat end of a spudger to disconnect the front-facing camera connector from the logic board.
    • Only pry up on the connector—not on the socket itself.
  46. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 48 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 48 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 48 中的图像 3,3
    • Use a spudger to pry the front-facing camera housing up and lift it out of the case.
    • Depending on how you performed the digitizer removal, this component may be adhered to the inner side of the front panel.
  47. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 49 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 49 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 49 中的图像 3,3
    • Slide a spudger under the front-facing camera to separate it form the adhesive securing it to the rear case.
    • There is conductive tape between the front camera ribbon cable and the headphone jack cable underneath. When replacing your front camera, apply pressure on the gold contacts to readhere these cables.
    • Remove the front-facing camera from the iPad.
  48. iPad 5 Wi-Fi Microphone Assembly Replacement, Microphone: 步骤 50 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement, Microphone: 步骤 50 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement, Microphone: 步骤 50 中的图像 3,3
    • Use the flat end of a spudger to disconnect the headphone jack connector from the logic board.
    • Fold the headphone jack cable out of the way.
  49. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 51 中的图像 1,2 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 51 中的图像 2,2
    • Use the flat end of a spudger to disconnect the microphone cable connector from the logic board.
  50. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 52 中的图像 1,1
    • Place the top portion of the iPad on a reheated iOpener.
    • This will soften the adhesive holding the microphone assembly to the case.
  51. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 53 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 53 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 53 中的图像 3,3
    • Insert the flat end of a spudger between the case and the microphone cable.
    • Carefully scrape the lower portion of the microphone cable off of the case.
  52. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 54 中的图像 1,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 54 中的图像 2,3 iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 54 中的图像 3,3
    • Use the point of a spudger to pry the delicate upper portion of the microphone cable up off of the adhesive holding it to the rear case.
  53. iPad 5 Wi-Fi Microphone Assembly Replacement: 步骤 55 中的图像 1,1
    • Remove the dual microphone assembly from the iPad.
结论
2等其他人完成本指南。
Evan Noronha
于2015年02月05日注册
217,185 声望
创作了177篇指南
团队
The Home Depot The Home Depot 的会员
Community
10,557 名成员
创作了1,028篇指南
一条评论
I was already planning to change my screen when I saw the issue with the microphone was the same problem I had. Glad I only had to open the iPad once and did the microphone at the same time. The microphone replacement doesn’t have extra foam pieces for under the camera, so take your time removing the camera and try not to rip the foam too much. You can see a small C-shaped piece of foam attached to the microphone assembly on the step for removing the microphone. I warmed up my iOpener and placed the old microphone on it to soften the adhesive on it and transferred it to the new microphone.
Trevor Bugera - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 30
总计 1,018
