跳转到主内容
当前版本的文档还未经巡查,您可以查看最新的已查核版本
你所需要的
  1. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 1 中的图像 1,1
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
  2. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 2 中的图像 1,3 : 步骤 2 中的图像 2,3 : 步骤 2 中的图像 3,3
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
  3. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 3 中的图像 1,3 : 步骤 3 中的图像 2,3 : 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Clamp
    $24.95
    购买
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 4 中的图像 1,3 : 步骤 4 中的图像 2,3 : 步骤 4 中的图像 3,3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 5 中的图像 1,2 : 步骤 5 中的图像 2,2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 6 中的图像 1,3 : 步骤 6 中的图像 2,3 : 步骤 6 中的图像 3,3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  7. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 7 中的图像 1,3 : 步骤 7 中的图像 2,3 : 步骤 7 中的图像 3,3
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 8 中的图像 1,3 : 步骤 8 中的图像 2,3 : 步骤 8 中的图像 3,3
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 9 中的图像 1,3 : 步骤 9 中的图像 2,3 : 步骤 9 中的图像 3,3
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 10 中的图像 1,1
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
  11. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 11 中的图像 1,3 : 步骤 11 中的图像 2,3 : 步骤 11 中的图像 3,3
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
  12. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 12 中的图像 1,3 : 步骤 12 中的图像 2,3 : 步骤 12 中的图像 3,3
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 13 中的图像 1,3 : 步骤 13 中的图像 2,3 : 步骤 13 中的图像 3,3
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 14 中的图像 1,3 : 步骤 14 中的图像 2,3 : 步骤 14 中的图像 3,3
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 15 中的图像 1,1
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
  16. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 16 中的图像 1,3 : 步骤 16 中的图像 2,3 : 步骤 16 中的图像 3,3
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
  17. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 17 中的图像 1,3 : 步骤 17 中的图像 2,3 : 步骤 17 中的图像 3,3
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
  18. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 18 中的图像 1,1
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
  19. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 19 中的图像 1,3 : 步骤 19 中的图像 2,3 : 步骤 19 中的图像 3,3
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the bottom-left corner before moving to the next step.
  20. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 20 中的图像 1,3 : 步骤 20 中的图像 2,3 : 步骤 20 中的图像 3,3
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 21 中的图像 1,3 : 步骤 21 中的图像 2,3 : 步骤 21 中的图像 3,3
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
  22. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 22 中的图像 1,3 : 步骤 22 中的图像 2,3 : 步骤 22 中的图像 3,3
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 23 中的图像 1,1
  24. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 24 中的图像 1,2 : 步骤 24 中的图像 2,2
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 25 中的图像 1,2 : 步骤 25 中的图像 2,2
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  26. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 26 中的图像 1,3 : 步骤 26 中的图像 2,3 : 步骤 26 中的图像 3,3
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
  27. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 27 中的图像 1,2 : 步骤 27 中的图像 2,2
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
  28. , LCD: 步骤 28 中的图像 1,3 , LCD: 步骤 28 中的图像 2,3 , LCD: 步骤 28 中的图像 3,3
    • 剥离固定LCD屏幕螺丝上的胶带。
  29. : 步骤 29 中的图像 1,1
    • 拆下固定LCD屏幕的Phillips螺丝。
    • 3个4.0 mm螺丝
    • 1个4.8 mm螺丝
  30. : 步骤 30 中的图像 1,3 : 步骤 30 中的图像 2,3 : 步骤 30 中的图像 3,3
    • 因为LCD屏幕任然在Home键附近有许多排线与iPad Air主体相连,切勿尝试完全的将LCD屏移开。 仅可从前置摄像头尾端处抬起屏幕。
    • 使用撬棒扁平的一段来从前置摄像头一边撬起一道可以让你手指抓住LCD 屏幕的缝隙。
    • 从前置摄像头处提起iPad Air 的LCD屏幕,就像翻书一样将它翻转到Home键一侧。
    • 小心驶得万年船,切勿操之过急。在您进行翻转的时候请同时盯着LCD排线。
    • 放下LCD屏幕,以便来处理LCD的排线。
    • 请将LCD屏幕放置在柔软、干净、无绒的表面。
  31. : 步骤 31 中的图像 1,3 : 步骤 31 中的图像 2,3 : 步骤 31 中的图像 3,3
    在这个步骤中使用的工具:
    Battery Blocker
    $3.99
    购买
    • 卸下将电池连接器固定到主板的 2.3 毫米十字螺丝。
    • 为降低短路风险,你可以 插入电池隔离片或修改后的撬片来断开电池。
    • 使用电池隔离片隔离电池时要非常小心。 电池触点容易损坏,造成不可逆转的损坏。
    • 将电池阻挡器滑到主板的电池接口区域下方,并在工作时将其留在原位。
    • 如果你在主板下方安装电池隔离片时遇到问题,你可以尝试使用扑克牌断开电池连接。
  32. : 步骤 32 中的图像 1,1
    • 取下3个显示排线支架上的1.4 mm Phillips螺丝。
  33. : 步骤 33 中的图像 1,2 : 步骤 33 中的图像 2,2
    • 使用撬棒扁平一段来将支架从逻辑板上撬起。
    • 显示屏的排线就在支架下方,因此请勿将撬棒深入过深,这样可能会损坏排线。
  34. : 步骤 34 中的图像 1,1
    • 取下LCD显示屏。
  35. , 前面板: 步骤 35 中的图像 1,2 , 前面板: 步骤 35 中的图像 2,2
    • 拆下覆盖home键带状电缆连接器的任何胶带。
  36. : 步骤 36 中的图像 1,3 : 步骤 36 中的图像 2,3 : 步骤 36 中的图像 3,3
    • 使用撬棒的扁平端将home键带状电缆ZIF接口向上翻转。
    • 小心地将Home键带状电缆水平拉出 ZIF 接口。
  37. : 步骤 37 中的图像 1,3 : 步骤 37 中的图像 2,3 : 步骤 37 中的图像 3,3
    • 使用撬棒的扁平端或指甲将两个数字转换器电缆连接器从它们的插座中直接弹出。
    • 为了避免损坏iPad,只能在连接器上撬动,而不能翘逻辑板上的插座。
  38. : 步骤 38 中的图像 1,2 : 步骤 38 中的图像 2,2
    • 小心地将被粘合剂固定到后壳上的home键带状连接线缆剥下。
  39. : 步骤 39 中的图像 1,2 : 步骤 39 中的图像 2,2
    在这个步骤中使用的工具:
    Polyimide Tape
    $9.99
    购买
    • 移除前面板组件
    • 在组装过程中,擦拭前面板组件上任何的灰尘和指纹,确保显示屏干净。
    • 如果您的新屏幕遇到“幽灵”或“幻影”触摸输入问题,可以通过在面板背面的标注区域粘贴一层非常薄的绝缘胶带,例如Kapton (聚酰亚胺)胶带,来解决这个问题。 iFixit面板具有良好的绝缘性,不需要粘贴任何胶带。
    • 若无适当的绝缘措施,数字转换器的这些区域可能会与其他组件接地,导致触摸输入故障。
    • 这些绝缘材料是肉眼不可见的,这与许多iPad上的泡沫防尘条不同。
  40. , 右侧天线: 步骤 40 中的图像 1,2 , 右侧天线: 步骤 40 中的图像 2,2
    • 撬下接近 iPad 的天线电缆和用向上的力拔下天线电缆连接器的边缘。
  41. : 步骤 41 中的图像 1,3 : 步骤 41 中的图像 2,3 : 步骤 41 中的图像 3,3
    • 有两个大块的胶带缠右天线电缆,将它们固定到后方。
    • 这样来撕
    • 同时剥皮天线磁带,放在天线电缆的地方来协助重新组装上。
  42. : 步骤 42 中的图像 1,3 : 步骤 42 中的图像 2,3 : 步骤 42 中的图像 3,3
    • 天线线缆会被一个小金属支架与扬声器固定在一起。支架会永久的和天线卷在一起并且与扬声器粘在一起。
    • 小心的在扬声器与天线线缆支架之间插入一个拨片。
    • 向home键方向滑动来去除胶水的作用。
    • 清楚下面的胶水后,把支架从扬声器上拿开。
  43. : 步骤 43 中的图像 1,1
    • 移除以下固定右天线的 Phillips #000 螺丝。
    • 一个2.3 mm的螺丝
    • 两个1.4 mm 螺丝
  44. : 步骤 44 中的图像 1,3 : 步骤 44 中的图像 2,3 : 步骤 44 中的图像 3,3
    • 在天线和扬声器模组之间插入撬棒平的一端。
    • 把撬棒向home键反向滑动来去除固定天线的泡沫胶水。
  45. : 步骤 45 中的图像 1,1
    • 从iPad上移除右天线。
  46. , 右扬声器: 步骤 46 中的图像 1,2 , 右扬声器: 步骤 46 中的图像 2,2
    • 在左边天线下面插入一根撬棒,向上撬起来分离天线连接器。
  47. : 步骤 47 中的图像 1,3 : 步骤 47 中的图像 2,3 : 步骤 47 中的图像 3,3
    • 左边扬声器天线有五片胶布盖着接口。
    • 从后机壳把胶布揭起来。
    • 把天线拉出来。
  48. : 步骤 48 中的图像 1,2 : 步骤 48 中的图像 2,2
    • 扬声器电线弯折过来使得把天线拉出来很困难。
    • 另外,把胶布沿偏离机壳的方向拉出来。
    • 使用镊子要小心——仅仅抓住并分离胶布,而不是下面的电线。
  49. : 步骤 49 中的图像 1,3 : 步骤 49 中的图像 2,3 : 步骤 49 中的图像 3,3
    • 把胶布朝着 Home 键的防线分离来揭开扬声器接口。
  50. : 步骤 50 中的图像 1,3 : 步骤 50 中的图像 2,3 : 步骤 50 中的图像 3,3
    • 使用撬棒尖头一端把扬声器电线接口翻出来。
    • 滑动扬声器电线,滑出 ZIF 接口。
  51. : 步骤 51 中的图像 1,3 : 步骤 51 中的图像 2,3 : 步骤 51 中的图像 3,3
    • 移除固定扬声器到后机壳的胶带。
  52. : 步骤 52 中的图像 1,3 : 步骤 52 中的图像 2,3 : 步骤 52 中的图像 3,3
    • 仔细地从后机壳剥离 LCD 胶带。
  53. : 步骤 53 中的图像 1,1
    • 移除 2.2 mm 菲利普斯 #000 号固定扬声器到后机壳的螺丝。
  54. : 步骤 54 中的图像 1,3 : 步骤 54 中的图像 2,3 : 步骤 54 中的图像 3,3
    • 后后机壳角落,插入指甲或撬棒平头的一端。
    • 把扬声器拉离机壳角落。
  55. : 步骤 55 中的图像 1,3 : 步骤 55 中的图像 2,3 : 步骤 55 中的图像 3,3
    • 使用撬棒来帮助从后机壳边缘拉出扬声器。
    • 从 iPad 移除右边扬声器。
  56. , 上部电线支架: 步骤 56 中的图像 1,1
    • 移除3个 1.4 mm 菲利普斯 #000 号螺丝,这些螺丝是固定上部电线支架的。
  57. : 步骤 57 中的图像 1,1
    • 移除上部电线支架。
    • 如果你拥有 Wi-Fi 或 数据款,你的 iPad 会稍微长得不一样点。会有额外的两个螺丝在上面。
  58. , 主板: 步骤 58 中的图像 1,2 , 主板: 步骤 58 中的图像 2,2
    • 有2段胶贴把左边的天线固定在后盖上。
    • 用镊子把胶贴从后盖上撕下。
  59. : 步骤 59 中的图像 1,3 : 步骤 59 中的图像 2,3 : 步骤 59 中的图像 3,3
    • 小心的在扬声器外壳和天线电缆支架之间插入一个拨片。
    • 将拨片滑向 home 按钮以切割粘合剂。
    • 将支架推离扬声器,直至其下面的条带脱离。
  60. : 步骤 60 中的图像 1,1
    • 拧下这些十字 #000 螺丝:
    • 两个 1.4 毫米螺丝
    • 一个 2.3 毫米螺丝
  61. : 步骤 61 中的图像 1,3 : 步骤 61 中的图像 2,3 : 步骤 61 中的图像 3,3
    • 将撬棒的平端插入天线和扬声器组件之间。
    • 将撬棒向 home 键滑动以切割固定天线的泡沫粘合剂。
  62. : 步骤 62 中的图像 1,1
    • 将 iPad 上的左天线移除。
  63. : 步骤 63 中的图像 1,2 : 步骤 63 中的图像 2,2
    • 撕下左扬声器电缆连接器上的胶带。
  64. : 步骤 64 中的图像 1,2 : 步骤 64 中的图像 2,2
    • 使用撬棒的尖端来翻转左扬声器电缆连接器上的固定挡板。
  65. : 步骤 65 中的图像 1,2 : 步骤 65 中的图像 2,2
    • 将扬声器电缆从 ZIF 连接器上拉出。
  66. : 步骤 66 中的图像 1,2 : 步骤 66 中的图像 2,2
    • 取下在后壳上固定扬声器的胶带。
  67. : 步骤 67 中的图像 1,1
    • 拧下在后壳上固定扬声器的 2.2 毫米十字 #000 螺丝。
  68. : 步骤 68 中的图像 1,2 : 步骤 68 中的图像 2,2
    • 轻轻地将左侧扬声器带状电缆向上翻开,以便在将扬声器外壳拉出时将电池拿出。
  69. : 步骤 69 中的图像 1,3 : 步骤 69 中的图像 2,3 : 步骤 69 中的图像 3,3
    • 将指甲或撬棒平端插入扬声器外壳凹槽内,靠近后壳角部的位置。
    • 从角里向下把扬声器拉出来。
  70. : 步骤 70 中的图像 1,3 : 步骤 70 中的图像 2,3 : 步骤 70 中的图像 3,3
    • 用撬棒辅助把扬声器从后壳中拉出来。
    • 从 iPad 上取下左扬声器。
  71. : 步骤 71 中的图像 1,3 : 步骤 71 中的图像 2,3 : 步骤 71 中的图像 3,3
    • 使用撬棒平端将前置摄像头连接器从电路板上断开。
    • 只在连接器上撬,不在插座本身上。
    • 将前置摄像头电缆翻起。
    • 金色电缆触点之间有一点导电胶。 在重新组装期间,务必施加压力以再次黏接这些触点。
  72. : 步骤 72 中的图像 1,3 : 步骤 72 中的图像 2,3 : 步骤 72 中的图像 3,3
    • 用撬棒的平端把电路板上的后置摄像头连接器断开。
    • 只在连接器上撬,不在插座本身上。
    • 将后置摄像头电缆翻起。
  73. : 步骤 73 中的图像 1,3 : 步骤 73 中的图像 2,3 : 步骤 73 中的图像 3,3
    • 用撬棒的平端将耳机插孔连接器从电路板上断开。
    • 只撬开连接器,不在插座上。
    • 新版的 iPad 设备有一圈胶带连接电路板上的插座。必须断开该胶带才能断开耳机插孔。
    • 将耳机插孔电缆翻折起来。
  74. : 步骤 74 中的图像 1,2 : 步骤 74 中的图像 2,2
    • 用撬棒的扁平端将麦克风电缆连接器从电路板上断开。
    • 只撬开连接器,不在插座上。
  75. : 步骤 75 中的图像 1,2 : 步骤 75 中的图像 2,2
    • 撕下覆盖上部按钮组件电缆连接器上的所有胶带。
  76. : 步骤 76 中的图像 1,2 : 步骤 76 中的图像 2,2
    • 用撬棒的尖端去翻开上部按钮组件电缆连接器上的固定盖。
  77. : 步骤 77 中的图像 1,2 : 步骤 77 中的图像 2,2
    • 将上部按钮组件的电缆从 ZIF 连接器上滑出。
  78. : 步骤 78 中的图像 1,1
    • 卸下固定 Lightning 端口上的两个 3.3 毫米十字#000 螺丝。
    • 要找到这些螺丝,请垂直握住 iPad 并从Lightning 端口向下看。
  79. : 步骤 79 中的图像 1,3 : 步骤 79 中的图像 2,3 : 步骤 79 中的图像 3,3
    • 在接下来的几步,你将会使用到 iOpener 来加热 iPad 底部来软化主板的黏胶。
    • 当你重新加热,并把 iOpener 放到这些位置的时候,请保持至少一分钟,来软化黏胶。
    • 黏胶是六个泡沫形式的胶带 ——如果你需要知道它们的位置,请参考这个步骤。
  80. : 步骤 80 中的图像 1,1
    • 把加热过的 iOpener 放在后置摄像头那端,使之停留至少一分钟。
    • 时间越长越好,只是你可能需要重新加热 iOpener。
  81. : 步骤 81 中的图像 1,3 : 步骤 81 中的图像 2,3 : 步骤 81 中的图像 3,3
    • 当你完成之后几个步骤的时候,撬开固定的黏胶。如果不行,重新加热 iOpener 放到后盖后面。
    • 仔细地在主板下插入一个开机撬片,前置摄像头和电池之间。
    • 向前置摄像头接口那边滑动撬片,停在主板弯曲的地方。
  82. : 步骤 82 中的图像 1,3 : 步骤 82 中的图像 2,3 : 步骤 82 中的图像 3,3
    • 在主板下面滑动撬片,从前置摄像头到后置摄像头的方向。
  83. : 步骤 83 中的图像 1,1
    • 把加热的 iOpener 放在 iPad 底端。
    • 再一次,让 iOpener 放在后壳底部黏胶处至少一分钟。
  84. : 步骤 84 中的图像 1,3 : 步骤 84 中的图像 2,3 : 步骤 84 中的图像 3,3
    • Lightning 接口电线用粘合剂粘在外壳上。要分离粘合剂,你将滑动电线和外壳之间的开口。小心不要切断 Lightening 电线本身。
    • 在 Lightning 电线下面与逻辑板相连处插入一个撬片。
    • 将撬片向下滑动并绕过电线的弯曲处。
  85. : 步骤 85 中的图像 1,2 : 步骤 85 中的图像 2,2
    • 继续滑动撬片,到电线弯曲到 Lightening 接口之前停止。
    • 慢慢小心地移动。如果撬片不容易滑动,请加热,然后重试。如果用力过度,可能会滑过并切断 Lightning 接口电线。
  86. : 步骤 86 中的图像 1,2 : 步骤 86 中的图像 2,2
    • 最后,在电池和 Lightning 接口之间滑动撬片,以分离电线下面的最后一些粘合剂。
  87. : 步骤 87 中的图像 1,2 : 步骤 87 中的图像 2,2
    • 从后盖直接拉出 Lightning 接口。
  88. : 步骤 88 中的图像 1,1
    • 将加热的iOpener放在后壳的左侧,主板粘合处。
    • 让 iOpener 至少放置一分钟,以便通过后壳软化粘合剂。
  89. : 步骤 89 中的图像 1,3 : 步骤 89 中的图像 2,3 : 步骤 89 中的图像 3,3
    • 将塑料撬棒插入主板上部区域的矩形间隙中,然后从后壳上撬起主板。
    • 将塑料撬棒保持在主板下方时,将其沿着间隙的长边滑动,以将主板的上端从粘合剂中撬开。
  90. : 步骤 90 中的图像 1,3 : 步骤 90 中的图像 2,3 : 步骤 90 中的图像 3,3
    • 在矩形间隙的下边缘,在EMI屏蔽板附近撬起主板。
    • 缓慢提起主板的一端。如果遇到重大阻力,请停止撬动并重新使用 iOpener 融化粘合剂。
  91. : 步骤 91 中的图像 1,3 : 步骤 91 中的图像 2,3 : 步骤 91 中的图像 3,3
    • 在主板和电池之间滑动一个撬片。
    • 将撬片从基座滑动到主板的中心,以切割粘合剂。
    • 注意撬片不要切断电池;被刺破的电池会非常危险。如果遇到阻力,请重新加热并使用iOpener。
  92. : 步骤 92 中的图像 1,3 : 步骤 92 中的图像 2,3 : 步骤 92 中的图像 3,3
    • 滑动并提起主板长的一边。
    • 一旦粘合剂被切断了,撬动主板上电池的一边,脱离后壳。
  93. : 步骤 93 中的图像 1,2 : 步骤 93 中的图像 2,2
    • 继续沿着靠近电池的边缘提起主板,直到可以在主板的另外一边上得到开口。
    • 剪下将主板外缘固定在后壳上的粘合剂。
  94. : 步骤 94 中的图像 1,1
    • 移除 iPad 主板。
终点
5等其他人完成本指南。
Evan Noronha
于02/05/15注册
223,427 声望
创作了168篇指南
一条评论
Bonjour ou puis-je trouver une carte mere pour iPad merci
Fra - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 29
过去 30 天: 125
总计 12,172
