简介
Use this guide to install adhesive strips on a replacement front panel.
Only for use with NEW front panel assemblies.
你所需要的
In the following steps, you will be placing the remaining pieces of adhesive on the front panel.
Do not peel the clear backing off the strips just yet.
Place the bridge shaped adhesive strip between the top edge of the inner frame of the front panel and the camera mounting bracket.
Smooth the strip down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
在这个步骤中使用的工具:Tweezers$4.99
Use a pair of tweezers to peel the clear backing up off the adhesive strip directly underneath the home button ribbon cable.
Lay the home button ribbon cable down on the adhesive strip and smooth the cable down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
You're finished.
You're finished.
33等其他人完成本指南。
一条评论
Conclusion:
“To reassemble your device, follow these instructions in reverse order. “
Something goes wrong here…
