跳转到主内容
加入维修社区 - 创建账户
iPad 4 CDMA Adhesive Strips Replacement (New Panel)
浏览量: 4127
浏览统计数据:
过去24小时
4
过去 7 天:
24
过去 30 天:
113
总计
4,127
评论: 2
2 comments on steps.
已完成: 6
6 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 10
10 人已收藏(并订阅)本指南。你会是下一个吗?
所需时间: 没有估计
难度: 中等
Use this guide to install adhesive strips on a replacement front panel.
Only for use with NEW front panel assemblies.
你所需要的
配件
工具
    1. iPad 4 CDMA Adhesive Strips Replacement (New Panel), Home Button Control Board: 步骤 1 中的图像 1,2 iPad 4 CDMA Adhesive Strips Replacement (New Panel), Home Button Control Board: 步骤 1 中的图像 2,2
      在这个步骤中使用的工具:
      • The two small notched trapezoidal strips will be used to attach the home button bracket to the front panel.
      • Carefully peel off the first trapezoidal adhesive strip with a pair of tweezers.
      • Using a pair of tweezers, place the first trapezoidal adhesive strip (minding its correct orientation) on the matching side of the home button mounting bracket.
      • Make sure to line up the profile of the strip with the edge of the mounting bracket.
      • Repeat the procedure for the second trapezoidal adhesive strip.
      询问修复机器人
      添加评论
    2. iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 2 中的图像 1,1
      • Use a pair of tweezers to grasp the corner of one of the adhesive strips placed on the mounting bracket.
      • Lift and peel the clear backing up off the adhesive strip, revealing the black adhesive strip.
      • Repeat the procedure for the secondary adhesive strip.
      询问修复机器人
      添加评论
    3. iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 3 中的图像 1,2 iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 3 中的图像 2,2
      • Gently place the home button mounting bracket on top of the home button.
      • Make sure the home button mounting bracket is lined up with the bottom of the digitizer.
      询问修复机器人
      添加评论
    1. iPad 4 CDMA Adhesive Strips Replacement (New Panel), Adhesive Strips (Existing Panel): 步骤 4 中的图像 1,3 iPad 4 CDMA Adhesive Strips Replacement (New Panel), Adhesive Strips (Existing Panel): 步骤 4 中的图像 2,3 iPad 4 CDMA Adhesive Strips Replacement (New Panel), Adhesive Strips (Existing Panel): 步骤 4 中的图像 3,3
      • In the following steps, you will be placing the remaining pieces of adhesive on the front panel.
      • Do not peel the clear backing off the strips just yet.
      • Place the bridge shaped adhesive strip between the top edge of the inner frame of the front panel and the camera mounting bracket.
      • Smooth the strip down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
      询问修复机器人
      添加评论
    2. iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 5 中的图像 1,2 iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 5 中的图像 2,2
      • Place the elongated C shaped adhesive strip on the right side of the front panel.
      询问修复机器人
      添加评论
    3. iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 6 中的图像 1,2 iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 6 中的图像 2,2
      • It is recommened to lift the home button ribbon cable aside while placing the next adhesive strip.
      • Place the straight, medium length adhesive strip on the bottom right side of the front panel, underneath the home button ribbon cable.
      询问修复机器人
      添加评论
    4. iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 7 中的图像 1,2 iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 7 中的图像 2,2
      • Place the tabbed rectangular adhesive strip on the bottom right side of the front panel.
      询问修复机器人
      添加评论
    5. iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 8 中的图像 1,2 iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 8 中的图像 2,2
      • Place the long L-shaped adhesive strip on the bottom left corner of the front panel.
      询问修复机器人
      添加评论
    6. iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 9 中的图像 1,2 iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 9 中的图像 2,2
      • Place the short rectangular shaped adhesive strip on the top left side of the front panel.
      询问修复机器人
      添加评论
    7. iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 10 中的图像 1,2 iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 10 中的图像 2,2
      • Place the last, short L-shaped adhesive strip on the top left corner of the front panel.
      询问修复机器人
      添加评论
    8. iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 11 中的图像 1,2 iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 11 中的图像 2,2
      在这个步骤中使用的工具:
      • Use a pair of tweezers to peel the clear backing up off the adhesive strip directly underneath the home button ribbon cable.
      • Lay the home button ribbon cable down on the adhesive strip and smooth the cable down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
      询问修复机器人
      添加评论
    9. iPad 4 CDMA Adhesive Strips Replacement (New Panel): 步骤 12 中的图像 1,1
      • Use a dry microfiber cloth to clean the LCD and inside of the front panel glass. You may want to use canned air or an air compressor to blow away and dust.
      • Use a pair of tweezers to peel the clear backing up off each adhesive strip.
      • Close the front panel down onto the iPad, careful to place it within the plastic bezel, and careful not to get any dirt or fingerprints between the glass and LCD.
      • To ensure a good seal, place the iPad face down on a padded envelope or cloth and pile a couple of books above it to weigh the screen down. Leave it like this for a few hours before using.
      添加评论
结论
取消:我没有完成这个指南。
6等其他人完成本指南。
作者
与
Walter Galan
711,938 声望
创作了1,203篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 24
过去 30 天: 113
总计 4,127
