跳转到主内容
当前版本的文档还未经巡查,您可以查看最新的已查核版本
3G版iPad(初代)屏幕组件的金属垫片更换
你所需要的
  1. 这个步骤还没有翻译 帮忙翻译一下
    3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 1 中的图像 1,3 3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 1 中的图像 2,3 3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 1 中的图像 3,3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. 这个步骤还没有翻译 帮忙翻译一下
    3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 2 中的图像 1,2 3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 2 中的图像 2,2
    • The iPad shown in the photos may look slightly different from your iPad, but the procedure is the same.
    • Insert a metal spudger between the right edge of the display assembly and the rear panel assembly.
    • Rotate the spudger away from you to release the tabs along the top edge of the display.
  3. 这个步骤还没有翻译 帮忙翻译一下
    3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 3 中的图像 1,2 3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 3 中的图像 2,2
    • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
    • Pry the display assembly away from the rear panel.
  4. 这个步骤还没有翻译 帮忙翻译一下
    3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 4 中的图像 1,2 3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 4 中的图像 2,2
    • Continue prying the display assembly away from the rear panel along the bottom and left edges of the iPad.
    • Use extreme caution as you approach the top edge of the iPad. The digitizer ribbon cable is located near the edge of the rear panel and can easily be damaged.
  5. 这个步骤还没有翻译 帮忙翻译一下
    3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 5 中的图像 1,1
    • Lift the display assembly away from the rear panel assembly by its bottom edge.
    • Do not excessively lift the display assembly off the rest of the iPad, as a fragile antenna cable with very little slack still connects the two components.
  6. 这个步骤还没有翻译 帮忙翻译一下
    3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 6 中的图像 1,1
    • Use the flat end of a spudger to pry the antenna connector closest to the bottom of the iPad up off its socket on the communications board.
  7. 这个步骤还没有翻译 帮忙翻译一下
    3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 7 中的图像 1,1
    • In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
    • Digitizer
    • Ambient Light Sensor
    • Display Data Cable
  8. 这个步骤还没有翻译 帮忙翻译一下
    3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 8 中的图像 1,3 3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 8 中的图像 2,3 3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 8 中的图像 3,3
    • Use the edge of an iPod opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
    • Be sure you are flipping up the retaining flap, not the socket itself.
    • Pull the digitizer ribbon cables straight out of their sockets.
  9. 这个步骤还没有翻译 帮忙翻译一下
    3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 9 中的图像 1,1
    • Use an iPod opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
  10. 这个步骤还没有翻译 帮忙翻译一下
    3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 10 中的图像 1,2 3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 10 中的图像 2,2
    • Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
    • Pull the cable connector away from its socket.
    • Pull the connector parallel to the face of the logic board.
  11. 这个步骤还没有翻译 帮忙翻译一下
    3G版iPad(初代)屏幕组件的金属垫片更换: 步骤 11 中的图像 1,1
    • Remove the display assembly from the rear panel assembly.
  12. 3G版iPad(初代)屏幕组件的金属垫片更换, 屏幕组件的金属垫片: 步骤 12 中的图像 1,1
    • 在屏幕拆卸过程中,在屏幕周围的金属垫片极有可能会断裂。
    • 要更换坏掉的垫片,首先拧掉把坏的垫片固定屏幕支架上的Torx T5 螺丝。
    • 把新的垫片放置在屏幕支架内的定位销上,然后重新拧紧 Torx T5螺丝,将两个部件固定在一起。
    • 重复以上步骤更换屏幕组件周围损坏的金属垫片。
结论
请倒序重组你的设备。
9等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Warrior E正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 24
总计 14,045
